(PR) FSP Introduces the VITA GM Line of PSUs
FSP Group, the world's leading high-performance ODM, modified STD power supply and PC component manufacturer today, is excited to unveil the all-new VITA GM PSU lineup designed to power the future generation of personal computing. The VITA GM (Gold efficiency & modular cable) PSU series embodies the pinnacle of advanced power delivery technology and durability, specifically designed for the demands of future-proof computing. Available in a range of power options from 650 W to 1000 W, each unit in the series guarantees exceptional efficiency and flexibility. With an 80 Plus Gold certification. This sleek new PSU lineup boasts fresh, clean design elements and high-quality materials. It is available in two classic color options - elegant black and pristine white for user preference.
Adhering to the latest technical standards, VITA GM PSU series from FSP Group is engineered to meet and exceed modern computing requirements. VITA GM series power supplies deliver the Intel recommended 17 ms @ 80% load hold-up time compared to the standard 12 ms @ 100%, ensuring stable flow of power and safety against sudden power outages, inrush current, and critical power surges. The series boasts an impressive efficiency rate of over 90% at typical loads, a testament to its superior design and engineering. FSP's commitment to reliability and longevity is evident in the use of 105°C Japanese bulk capacitors, renowned for their quality and durability. The VITA GM series also features a 120 mm hydraulic bearing (HYB) fan, providing optimal cooling while maintaining low noise levels. These PSU units stand out with their notably compact dimensions of 140 x 150 x 86 mm, making them an ideal choice for space-limited setups. Yet, it does not compromise on delivering robust performance.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
