(PR) Icy Dock Unveils CP132 PCIe 5.0 NVMe Sneakernet Solution
Introducing the CP132 - a PCIe 5.0 NVMe Sneakernet Solution specifically designed for large digital file transport and offline data backup, fitting any standard 5.25" optical drive bay of a computer case or rackmount. The CP132 enables businesses and professionals to physically transfer data with up to 4x U.2/U.3 NVMe SSD capacity at a whopping 128 Gbps transfer rate from one system or workstation to another. The CP132 is ideal for large-scale data backup or transfer in enterprises or video production studios, data transport between remote areas lacking network connectivity, or data migration between large data centers and clients.
The CP132 features a heavy-duty, fully-enclosed removable drive caddy that allows users to remove/install 4x U.2/U.3 NVMe SSDs together for physically transporting large amounts of data between systems. To remove the drive caddy, simply rotate the center thumb screw to release the retractable mechanical handle and pull the handle to remove the drive caddy from the system. To reinstall the drive caddy quickly, just reverse the previous steps. The rugged, all-metal enclosed drive caddy securely protects the installed U.2/U.3 SSDs, preventing damage to the valuable SSDs and data during transportation.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Reddit Communities Go Private in Protest Over Policy Adjustments
Thousands of dicussion communities on Reddit have now shut doors to public access—warning signs started to appear online over past weeks, with community leaders drumming up support for a protest against the social news site's policy changes, including a strategy to monetize access to a vast pool of user data. For example the highly popular r/hardware subreddit is now "a private community"—unregistered users are greeted with a succinct message on the front page: "This subreddit is temporarily closed in protest of Reddit killing third party apps, see /r/ModCoord and /r/Save3rdPartyApps for more information." News sites are reporting that close to a total of 3500 subreddits have joined the "blackout" effort. According to the BBC this includes "five of the 10 most popular communities on the site - r/gaming, r/aww, r/Music, r/todayilearned and r/pics - which each have memberships of more than 30 million people."
A group message was shared by a moderation collective last week: "On June 12th, many subreddits will be going dark to protest this policy. Some will return after 48 hours: others will go away permanently unless the issue is adequately addressed, since many moderators aren't able to put in the work they do with the poor tools available through the official app. This isn't something any of us do lightly: we do what we do because we love Reddit, and we truly believe this change will make it impossible to keep doing what we love." A moderator (speaking to the BBC anonymously) said that the protest will be effective due to "strength in numbers," which will presumably grab the attention of Reddit's executive team.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Samsung Launches the $2,200 Odyssey OLED G9 with DQHD Resolution
Samsung Electronics today announced the global launch of the Odyssey OLED G9 gaming monitor (G95SC model), which has been enhanced with next-level AI upscaling technology. Building on the success of last year's Odyssey OLED G8 (G85SB), the new monitor joins the lineup to open a new era of OLED gaming. "Last year, Samsung addressed the demands and expectations of even the most experienced gamers with the launch of the Odyssey OLED G8," said Hoon Chung, Executive Vice President of the Visual Display Business at Samsung Electronics. "With the introduction of the Odyssey OLED G9, equipped with unrivaled picture quality, we are excited to offer our customers these powerful gaming monitors and raise the bar for OLED gaming."
Measuring 49 inches in size with a 1800R curvature, the Odyssey OLED G9 is the first OLED monitor to offer Dual Quad High Definition (DQHD; 5,120 x 1,440) resolution with a 32:9 ratio. The large and wide screen ratio enable users to lose themselves in super-ultrawide vistas—equivalent to two QHD screens side by side. At the same time, its rapid 0.03 ms gray-to-gray (GtG) response time and 240 Hz refresh rate offer players a competitive edge.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Abit Unveils AB-B760ITX Socket LGA1700 Motherboard
Abit unveiled the AB-B760ITX, a DIY retail segment Mini-ITX motherboard based on Intel Socket LGA1700, and B760 chipset. The board comes in two variants based on PCB color—black and white. It uses a conventional power input configuration of 24-pin ATX and 8-pin EPS, with a 10-phase VRM conditioning it for the processor. The LGA1700 processor is wired to two DDR4 memory slots for up to 64 GB of dual-channel DDR4-4000 memory; and an M.2 NVMe Gen 4 slot. The main PCIe interface is PCI_Express 5.0 x16. Connectivity includes 6-channel HD audio, Wi-Fi 6E + Bluetooth 5.2 WLAN, 2.5 GbE wired LAN, and four USB 3.2 ports. Display outputs include a pair of HDMI and one DisplayPort. Besides the M.2 slot, you get four SATA 6 Gbps ports. Abit is pricing these boards at RMB ¥599 (USD $84).
If it feels like you've seen a ghost, it's because Abit withdrew from the DIY PC component space around 2012, after fulfilling its support obligations for the last of its products shipped in 2008. Since then, the brand has been held by Universal Scientific Industrial, a mainland Chinese company that took it over from the original Taiwan-based Abit Computer.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Obsidian Entertainment Debuts Avowed Gameplay During Xbox Showcase
We at [Only registered and activated users can see links. Click Here To Register...] know players have been anticipating an updated look at [Only registered and activated users can see links. Click Here To Register...] and we're excited to show off what we've been working on with a first-ever gameplay trailer today at Xbox Games Showcase 2023. Expanding the universe that we created for the original Pillars of Eternity games, Avowed brings a new perspective, a new way to fight, and a new land to explore in the world of Eora. The Pillars games are near and dear to us and we can't wait to share Avowed with everyone next year.
In Avowed, you'll explore the Living Lands, a plagued, wild island set in the world of Eora. The Living Lands are full of mysteries and secrets, danger and adventure, and choice and consequences. Unique to the world of Eora, the Living Lands is home to bustling port towns and rolling hills adorned with weird and fantastical plant life. Every part of the Living Lands is home to its own ecosystem. Around every corner there are creatures, sentient mushrooms, or tribes of lizard-like Xaurips looking to make you their next meal…[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Sapphire Readies Third Variant of Radeon RX 6750 XT GPU
AMD's RDNA3 [Only registered and activated users can see links. Click Here To Register...] is [Only registered and activated users can see links. Click Here To Register...], but PC hardware enthusiasts are getting frustrated with the lack of announcements in regards to Team Red's supposed mid-to-high level "Radeon RX 7700 & 7800 series" card offerings. Current generation options are only available in the form of pricey flagship models - RX 7900 XT and XTX, as well as the recently released lower end [Only registered and activated users can see links. Click Here To Register...], with nothing classed as brand new appearing in the middle ground. Notable AMD board partner Sapphire Technology is also getting impatient with this situation and has decided to dip back into RDNA2—technology news site [Only registered and activated users can see links. Click Here To Register...] has discovered that the company is releasing another Radeon RX 6750 XT 12 GB GDDR6 card. This third variant follows previously issued [Only registered and activated users can see links. Click Here To Register...] and Pulse models.
Sources have indicated that this new model is called the "Overseas Edition," so it is possible that it will be getting international distribution. Sapphire's custom card has not hit the South East Asia market yet, and the company has not created (at the time of writing) an entry for it on their website or product catalog. ITHome reckons that the Radeon RX 6750 XT Overseas Edition will likely get a retail release to coincide with this week's [Only registered and activated users can see links. Click Here To Register...]. The card seems to offer a marginal performance advantage (0.9% factory set overclock) over AMD's reference specs—with a 2623 MHz boost clock. It shares the same features as its NITRO+ sibling—namely a Dual BIOS switch and two power connectors.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
