Si ce anume sa contina aceste setari ?Quote:
cine stie,poate abracadabra
@am scurtat un pic lucrurile trimise de Tine, valorile care erau default le-am sters. Asa a devenit mai "prietenos"
setarile au diferit doar ici colo, am pus ale tale, astept ce se antampla.
dimineata am avut ocazia sa asist problema, deodata imaginea se "pixeluie" ( banuiesc ca nu exista acest cuvant, dar voi intelegeti ) decodarea trece pe net, am putut urmari mai departe emisiunea. In webif local user avera last ecm time 18000 !!. Boxul raspundea anevoios la orice. Reset si din nou ok.
Alta chestie neplacuta, daca din emumanager dau restart atunci an 90% din cazuri boxul se blocheaza, reset ! O fi problema a PKT probabil.
posibil..incearca si 3c
card tivusat in dm800 ,imagine newnigma 2.
oscam.conf
[global]
logfile = stdout
failbantime = 5
failbancount = 0
cachedelay = 120
nice = -1
[monitor]
appendchaninfo = 1
[newcamd]
port = xxxxxx@183D:000000
keepalive = 1
[webif]
httpport = 88
httpuser = xxxxx
httppwd = xxxxx
httpcss = /var/tuxbox/config/DBR_Proflinux_DDCStyle_White_Text.css
httpallowed = 127.0.0.1,192.168.1.1-192.168.1.199
[anticasc]
enabled = 1
numusers = 1
sampletime = 25
penalty = 2
aclogfile = ./oscam_ac.log
oscam.server
[reader]
label = tivusat
description =
enable = 1
protocol = internal
device = /dev/sci0
device_out_endpoint = 0x 0
key =
password =
pincode = none
readnano =
services =
resetcycle = 0
smargopatch = 0
sc8in1_dtrrts_patch = 0
fallback = 0
cacheex = 0
cacheex_maxhop = 0
logport = 0
caid = 183D
boxid =
fix9993 = 0
rsakey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ins7e =
ins7e11 = 95
force_irdeto = 0
boxkey =
atr =
ecmwhitelist =
detect = cd
nagra_read = 2
mhz = 357
cardmhz = 357
ident = 183D:000000
chid =
class =
aeskeys =
group = 1
emmcache = 1,3,32
blockemm-unknown = 0
blockemm-u = 0
blockemm-s = 0
blockemm-g = 1
saveemm-unknown = 0
saveemm-u = 0
saveemm-s = 0
saveemm-g = 0
blockemm-bylen =
lb_weight = 100
savenano =
blocknano =
ccchop = 2
deprecated = 0
audisabled = 0
auprovid = 005411
ndsversion = 0
ratelimitecm = 0
ratelimitseconds = 0
cooldown = 0,0
oscam.user
[account]
user = test
pwd = test
group = 1
monlevel = 0
au = 1
services = tivusat
caid = 183D
ident = 183D:000000
keepalive = 1
uniq = 1
imi deschide de pe card insa la intervale scurte,1 ora ,maxim 2 imi apare ceva de genul:
17/12/2012 23:55:59 5D67E0 c dm500 (183D&000000/0000/0D52/8C:EBB6): found (128 ms) by tivusat - RaiSat Extra
17/12/2012 23:56:03 5D67E0 c dm500 (183D&000000/0000/0D52/8C:D747): found (127 ms) by tivusat - RaiSat Extra
18/12/2012 00:01:56 5D67E0 c dm500 (183D&000000/0000/0002/8C:4F8F): fake (1122 ms) (0/0/0/0) - Canale 5
18/12/2012 00:02:06 5D67E0 c dm500 (183D&000000/0000/0002/8C:C638): fake (1122 ms) (0/0/0/0) - Canale 5
daca dau restart la oscam merge pentru o perioada.
orice sfat ,parere e binevenit.si poate stie cineva si daca se poate face update la card si altcumva decat in receptorul sau.
Update la cardul de Tivusat se face foarte usor in scam 3.60, mai ales daca ratezi ziua si nu mai deschide din el.
Acele mesaje de fake cred ca au legatura cu optiunea [anticasc], pune-o pe enable = 0 si urmareste daca mai face asa.
am schimbat.acum urmaresc sa vedem ce se intampla.cand ai timp poate imi explici aici sau in privat cum se face update.simplu o fii dar pentru mine e dificil.multumesc mult
Instalezi scam3.60 in receptor, il pornesti si stai pe un canal din grila Tivusat, eu am facut data trecuta pe Rai Premium sau Rai HD.
In 5-10 minute apare imaginea. La scam nu trebuie sa umbli la configuri, merge la acest card cu cele default.
am instalat scam 3.60 dar nici mort nu vrea sa porneasca.
Esti sigur ca a pornit scam ? Eu am facut chiar in momentul asta update si a stat cardul in sertar de 3 luni nefolosit.
Am tinut pe Rai HD si s-a facut lumina in aproape 2 minute, m-am uitat la ceas.
