madrid sud
135*120 cm fixa
offset antena oval
lnb inverto black ultra
--golden media uni-box2
-10964 H 22000 5/6 L=90% ,Q=71%
-10994 H 22000 5/6 L=90% ,Q=71%
-11023 H 23000 2/3 L=90% ,Q=21-49%
-11053 H 22000 5/6 L=90% ,Q=74%
-11126 V 22000 5/6 L=90% ,Q=75%
the signal audio-video is stable
--amiko alien 8900hd
-10964 H 22000 5/6 L=75% ,Q=95%
-10994 H 22000 5/6 L=75% ,Q=79%
-11023 H 23000 2/3 L=75% ,Q=78%
-11053 H 22000 5/6 L=74% ,Q=100%
-11126 V 22000 5/6 L=73% ,Q=100%
test efectuat in data de 14.12.2012 la ora 15:28 pm
Continued transfer of transponders at 28.2 east update 7th Dec 2012
Astra 2F is reported to not be able to cover 10700 to 10950 so we will probably have to wait for the launch of Astra 2E that covers 10.7 to 12.75GHz as does 2G,
I still find it hard to believe that Astra 2F cannot cover these frequencies unless this was a part built Eurostar E3000 satellite meant for another location ? so may have been used to get the African service up & running quickly that it has done & by 27th November as scheduled,
Next sequence of changes at 28 east transfer of transponders from Astra 1N to Astra 2F:
11.023 H, SR 23.000 FEC 2/3 DVB-S2 *PSK "8901" and "8911" (BBC 1 HD's) already there
10.964 H SR 22.000 FEC 5/6 (CH5/5USA/5*/Channel 5+1),
10.994 H SR 22.000 FEC 5/6 (ITV 1 Granada HD/ITV 1 Central South West SD/ITV 1 Anglia West SD/ITV 1 Meridian North SD/ITV 1 Yorkshire East SD/ITV 1+1 Yorkshire SD),
11.052 H SR 22.000 FEC 5/6 (ITV 1 Central South SD/ITV 1 Central East SD/ITV 1+1 Wales SD/ITV 1+1 Westcountry SD/ITV 1+1 Tyne Tees SD),
11.126 V SR 22.000 FEC 5/6 (Channel 4 HD/4Seven SD)
Completed.
The next part of the change over is dependent on the capability of Astra 2F to cover the Ku band below 10950 for the transfer of all transponders on Astra 1N if this is not possible then we will have to wait for Astra 2E launch in the 1st Qtr of 2013.
Phase 2 4th Qtr 2012 will be the transfer of Astra 2B transponders to Astra 2F
11739 V
11876 H
11895 V
11954 H no transmissions atm
11973 V
11992 H
12012 V
12032 H
12110 H
12246 V
12304 H
12344 H
12402 V no transmissions atm
12441 V no transmissions atm
12480 V
Astra 2B will then move to 19.2 east
Phase 3 1st Qtr 2013
Astra 2E will then after a successful launch will replace Astra 1N @28.2 east
Astra 1N will then move to 19.2 east
Phase 4 1st Qtr of 2014
Astra 2G will replace Astra 2A & if allowed to the 3 satellites 2E,2F & 2G will cover the whole of the Ku band 10.7GHz to 12.75GHz @ 28.2 east.
Am schimbat lnb, am pus inverto black.Parca e putin peste inverto red.BBC HD tot nu vrea sa intre cu toate ca in jur de ora 7 seara am semnal si rupe imaginea, dar intra foarte greu imagine, pe alte frecvente cu acelasi semnal am imagine si este stabila.
Cu inverto black am semnal stabil PE 11758 si fara ber unde sunt ITV HD 2,3,4.
Receptia este stabila pe tot parcursul zilei.
Craiova, 1,8M, Ghid de unde Invacom ( a fost singurul care ofera ceva in plus ) lnb black inverto receptor sunray4.
[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
@marsel90 da ai dreptate precum ai scris ,dar sa nu uitam un lucru important ca acel plus cat este el de mic ne confera receptia acelor frecvente care cu alte feedhornuri nu reusim sa atingem acel varf sau nici macar nu visam
-incearca sa gasesti acel SKEW optim prin mai multe reglaje si poate vei reusi receptia si altor frecvente mult dorite
- despre lnb inverto red uni pasionati afirma ca este mai bun decat black ultra ,acum in targ umbla vorba ca lnb octagon (simplu,twin,quatro) ar fi mai bune decat inverto ramane de vazut,testat
