Cine poate sa puna pe upload w3camd compilat ptr router?
Am gasit doar versiunea necompilata si nu am cum sa o compilez.
Multumesc.
Multumesc.
ia de mai jos, atasat
Se pare ca am ajuns in acelasi punct ca si tine. Ai rezolvat? Posibil sa lipseasca niste librarii.Quote:
Originally Posted by goldsat [Only registered and activated users can see links. Click Here To Register...]
@prodigy - multumesc.
In primul rand, la -d ai scris gresit , device-u de camera de obicei se incarca in /dev/v4l/video0 din cite imi aduc eu aminte...deci comanda ar fii:
Code:root@DD-WRT:/dev# /opt/var/bin/./w3camd -v -p 8999 -s 640x480 -h 192.168.10.1 -d
/dev/v4l/video0
Scuze....am dat replay si n-am verificat comanda. Device-ul de camera se incarca in /dev/v4l/video0 sau in /dev/video0 in cazul in care s-a facut un link catre el ( ln -s /dev/v4l/video0 /dev/video0 ). Cand accesez [Only registered and activated users can see links. Click Here To Register...] vad ca se aprinde ledul de la webcam....imi apare eroarea in putty si apoi se stinge (ledul) fara sa vad nimic in pagina de web.
Eu am asa :
mai departe nu ma descurc am cititCode:root@OpenWrt:~# lsusb
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
Bus 001 Device 002: ID 0781:5151 SanDisk Corp. Cruzer Micro 256/512MB Flash Driv e
Bus 001 Device 003: ID 03eb:0902 Atmel Corp.
Bus 001 Device 004: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 007: ID 0ac8:0323 Z-Star Microelectronics Corp. Luxya WC-1200 USB 2.0 Webcam
Code:opkg update
opkg install kmod-videodev (root@OpenWrt:~# opkg install kmod-videodev
Collected errors:
* Cannot find package kmod-videodev.)
apoi se face insmod la videodev.o
se verifica sa fie incarcata prin comanda lsmod
apoi se face insmod la spca5xx.o si la lsmod arata asa
Code:root@OpenWrt:~# /opt/var/bin/./w3camd -v -p 8999 -s 640x480 -h 192.168.10.1 -d
/opt/var/bin/./w3camd: option requires an argument -- d
Usage: /opt/var/bin/./w3camd [-v] [-p #] [-h host] [-s #x#] [-m #] [-i #] [-d device]
root@OpenWrt:~# dmesg | grep usb
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb.c: new USB bus registered, assigned bus number 1
usb.c: new USB bus registered, assigned bus number 2
usb.c: USB device 2 (vend/prod 0x781/0x5151) is not claimed by any active driver.
usb.c: registered new driver usb-storage
usb.c: USB device 4 (vend/prod 0x67b/0x2303) is not claimed by any active driver.
usb.c: USB device 5 (vend/prod 0x67b/0x2303) is not claimed by any active driver.
usb.c: USB device not accepting new address=6 (error=-145)
usb.c: USB device not accepting new address=7 (error=-145)
usb.c: registered new driver serial
usbserial.c: USB Serial support registered for Generic
usbserial.c: USB Serial Driver core v1.4
usbserial.c: USB Serial support registered for PL-2303
usbserial.c: PL-2303 converter detected
usbserial.c: PL-2303 converter now attached to ttyUSB0 (or usb/tts/0 for devfs)
Pai nu ai instalat "kmod-videodev". Probabil nu se numeste asa pachetul. Incearca sa il instalezi cu ajutorul interfetei web. Nu ai specificat ce firmware ai ca sa iti spun exact unde sa cauti.
OpenWrt Firmware
Kamikaze (r16206)
Load: 0.77 0.35 0.13
Hostname: OpenWrt
Am instalat kmod-video-core
La comada asta cred ca nu am driverul instalat ce pot sa fac?
Code:usb.c: USB device not accepting new address=5 (error=-145)
usb.c: USB device not responding, giving up (error=-145)
usb.c: USB device 7 (vend/prod 0xac8/0x323) is not claimed by any active driver.
Exista driver ptr acest vendor?
Code:root@OpenWrt:~# dmesg | tail -n3
usb.c: registered new driver quickcam
hub.c: new USB device 01:02.0-1.1, assigned address 3
usb.c: USB device 3 (vend/prod 0x93a/0x2628) is not claimed by any active driver.
