Astazi am incercat sa readuc la viata un optibox. Simptomele era asemanatoare cu cele descrise de esteticu; comunica cu pc-ul prin dream-up, pot instala imagini, dar nu afiseaza nimic pe tv si ramane ledul verde aprins fara sa comunice cu telecomanda. Sursa a fost schimbata, telecomanda verificata....la fel si cablurile video.
Am incercat cu jtag. Acesta e logul:
c:\jtag>JtagDm500 -m dm500 -e 00:09:34:20:E4:63
Dreambox Dm500 board initialize
Flash info. : INTEL JS28F640J3D75
[dm500] reading CA:ca 00 01 06 33 55 33 00 09 34 20 a3 12 06 04 ff
[CA] 4th mac addr byte is not redunderant, fixing it
[CA] 5th mac addr byte is not redunderant, fixing it
[CA] 6th mac addr byte is not redunderant, fixing it
Readed Config Area
Configuration Area
Mac Address: 00:09:34:33:55:33
Redunderant Mac Address: 33:55:33
Tuner Type alps
Mac Address Change Requested
Commit Config Area
Configuration Area
Mac Address: 00:09:34:20:e4:63
Redunderant Mac Address: 20:e4:63
Tuner Type alps
Erase Flash. done
Download..................................... done
Bienvenidos Amigos!!!!
Complete !
c:\jtag>
15:15:39 box type: DM500
15:15:48 Ping result: OK, box is alive and speaking to us ;-)
15:15:54 erasing complete flash (without bmon stage of course)...
15:16:31 OK, flash erased
15:18:12 Ping result: OK, box is alive and speaking to us ;-)
15:18:13 Ping result: OK, box is alive and speaking to us ;-)
15:18:16 Found no valid jffs2 in image, flash-erase not supported
15:18:16 Uploading file to box...
15:30:46 calculating CRC32 on STB...
15:30:47 erasing flash...
15:31:23 box is flashing from its memory...
15:31:59 calculating CRC32 on STB's flash...
15:32:08 OK, flash-copy succeeded
15:32:16 Ping result: OK, box is alive and speaking to us ;-)
15:32:21 Uploading file to box...
15:40:26 calculating CRC32 on STB...
15:40:26 erasing flash...
15:40:50 box is flashing from its memory...
15:41:08 calculating CRC32 on STB's flash...
15:41:14 "flash erase"...
15:41:27 OK, flash-copy succeeded
15:41:31 Ping result: OK, box is alive and speaking to us ;-)
Se pare ca e o problema pe partea de video. Daca as putea sa vad un log la bootare poate mi-as putea da seama unde e problema. O sa incerc cu hyperterminal cu ajutorul unui cablu serial. Poate reusesc ceva.
Pentru conectare la dream cu ajutorul hyperterminal e nevoie de cablu null modem.
Trebuie puse urmatoarele setari:
COM port 1 (sau 2)
- Bits per second = 115200
- Data bits = 8
- Parity = None
- Stop bits = 1
- Flow control = Xon / Xoff
La mine apare asa:
Dreambox DM500
loaded at: 00500000 0060116C
relocated to: 00400000 0050116C
board data at: 004FF124 004FF16C
relocated to: 00405194 004051DC
zimage at: 004058D1 004FE1BE
avail ram: 00502000 02000000
Linux/PPC load: console=null root=/dev/mtdblock5 rootfstype=squashfs ro
Uncompressing Linux...done.
Now booting the kernel
Si sta si nu mai face nimic.
---------- Post added at 12:18 ---------- Previous post was at 11:47 ----------
Am reusit sa dau comanda ( console=null root=/dev/mtdblock5 rootfstype=squashfs ro console=ttyS0,115200 ) sa imi apara pe terminal ce se inampla cand booteaza:
Dreambox DM500
Linux/PPC load: console=null root=/dev/mtdblock5 rootfstype=squashfs ro console=
ttyS0,115200
Linux version 2.6.9 (obe@vmlinux.obesoft.com) (gcc version 3.4.4) #26 Mon Dec 22
17:16:45 CET 2008
Built 1 zonelists
Kernel command line: console=null root=/dev/mtdblock5 rootfstype=squashfs ro con
sole=ttyS
PID hash table entries: 256 (order: 8, 4096 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 30080k available (1692k kernel code, 584k data, 80k init, 0k highmem)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lougher
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_o
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Serial: 8250/16550 driver $Revision: 1.90 $ 7 ports, IRQ sharing disabled
ttyS0 at MMIO 0x0 (irq = 20) is a 16550A
ttyS1 at MMIO 0x0 (irq = 21) is a 16550A
ttyS2 at MMIO 0x0 (irq = 22) is a 16550A
loop: loaded (max 8 devices)
ne.c:v1.10 9/23/94 Donald Becker (becker@scyld.com)
Last modified Nov 1, 2000 by Paul Gortmaker
NE*000 ethercard probe at 0xc3060600:<4>eth0: interrupt from stopped card
eth0: interrupt from stopped card interrupt from stopped cardT DEV
et
eth0: interrupt f
eth0: interrupt from stopped card1 Enabled Applicnterrup
eth0: interrupt from stopped cardtLe IP: interrup
eth0: interrupt from stopped card stopped carde for S1 Booted ca
relocated
eth0: in
Si asta se repeta la nesfarsit. Unde-i buba?
---------- Post added at 13:50 ---------- Previous post was at 12:18 ----------
Acum alta problema (offf); incerc sa rescriu bootloaderul si se opreste (o data la 3%, apoi 10%, iar acum la 18%)
C:\jtag>JtagDm500 -m dm500 -e 00:09:34:26:D4:34
[dm500] reading CA:ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
Readed Config Area
Configuration Area
Mac Address: 00:09:34:aa:0b:cc
Redunderant Mac Address: aa:0b:cc
Tuner Type alps
Commit Config Area
Configuration Area
Mac Address: 00:09:34:26:d4:34
Redunderant Mac Address: 26:d4:34
Tuner Type alps
Erase Flash. done
Download....... 18%
Ai verificat tnsiunile 5v. 3,3v. 1,8v. 2,5v?
Cele de pe placa de baza sunt OK.
Am rescris bootloaderul (OK), am reinstalat imagine (OK), dar totusi nu merge. Inclin sa cred ca e o problema la placa de retea.
Dreambox DM500
loaded at: 00500000 0060016C
relocated to: 00400000 0050016C
board data at: 004FE124 004FE16C
zimage at: 004058D1 004FD8F9
avail ram: 00501000 02000000
Linux/PPC load: console=null root=/dev/mtdblock5 rootfstype=squashfs rw console=
ttyS0,115200done.
Linux version 2.6.9 (root@localhost.localdomain) (gcc version 3.4.4) #3 Sun Apr
1 11:24:06 CEST 2007
Built 1 zonelists
Kernel command line: console=null root=/dev/mtdblock5 rootfstype=squashfs rw con
sole=ttyS0,115200
Memory: 30080k available (1688k kernel code, 576k data, 80k init, 0k highmem)
devfs: boot_options: 0x1
Incearca sa masori alimentarile de AX dupa bobinute ,L1,L2, si schimba condensatori electrolitici C63,C17,C23,iar apoi scote ax si porneste aparatu sa vezi ce mai vorbeste cu tine
Inainte de a scrie bootloaderul verificati f bine tensiunile de pe sursele interne ,sant simtome de ,,Adios amigo daca o tensiune nu este in parametrii ,asa ca ,atentie mare.
---------- Post added at 14:57 ---------- Previous post was at 14:55 ----------
Ptr @radutiu ,AX-ul afecteaza numai daca este scurt pe el sau gaura ,posibil la descarcari atmosferice sa crape si flash-ul
Flashul il vede daca nu-l vedea nu apuca sa-l identifice si sa-l scrie
Nu am schema ca sa vad ce anume se verific. Pana una alta am luat unul nou si am verificat in consola ce scrie la bootare. Problema la cel vechi e placa de retea. Priviti logul la un optibox bun:
Dreambox DM500
zimage at: 004058D1 004FD8FD
ttyS0,115200
Linux version 2.6.9 (root@localhost.localdomain) (gcc version 3.4.4) #1 Fri Aug
29 16:55:38 CEST 2008
Built 1 zonelists
sole=ttyS0,115200
00 09 34 27 A5 D2
eth0: NE2000 found at 0xc3060600, using IRQ 25.
Universal TUN/TAP device driver 1.5 (C)1999-2002 Maxim Krasnyansky
Using deadline io scheduler
dreambox: flash mapping: 800000 at 7f800000
DreamBOX rev3+: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
disable flash VPP
Creating 7 MTD partitions on "DreamBOX rev3+":
0x00000000-0x00600000 : "DreamBOX cramfs+squashfs"
0x00600000-0x007c0000 : "DreamBOX jffs2"
0x007c0000-0x00800000 : "DreamBOX OpenBIOS"
0x00000000-0x007c0000 : "DreamBOX (w/o bootloader)"
0x00000000-0x00800000 : "DreamBOX (w/ bootloader)"
0x00120000-0x00600000 : "DreamBOX SquashedFS"
0x00000000-0x00120000 : "DreamBOX Cramfs"
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
IBM IIC driver v2.1
ibm-iic0: using standard (100 kHz) mode
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET: Registered protocol family 17
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 80k init
etc
Totul s-a intamplat in urma unei descarcari electrice sau probleme cu tensiunea.
