[Only registered and activated users can see links. Click Here To Register...] NTV SPORT
[Only registered and activated users can see links. Click Here To Register...] TRT1 buyucada
[Only registered and activated users can see links. Click Here To Register...] NOVA TV bucuresti
[Only registered and activated users can see links. Click Here To Register...] TVR2 costilanlar
[Only registered and activated users can see links. Click Here To Register...] TVR1 basinop + trt haber
[Only registered and activated users can see links. Click Here To Register...] cum arata baneasa pe antena speciala de baneasa unde o am continuuuuu color si cu teletext pe tropo
[Only registered and activated users can see links. Click Here To Register...] burgas tare in 26 si slab in 38
[Only registered and activated users can see links. Click Here To Register...] MASOCTA PROPAGARII .. sporadic in UIF ...
752mi - 1270km DX with multireflexion
1tv
[Only registered and activated users can see links. Click Here To Register...] NO COMENT ..
e a doua oara cand aud asa ceva in romania pe aceeasi frecventa .. insa nu ma pronunt daca este radio izaat al shaark de la LIBAN ala cu circularele lui si cu 200kw
Ieri s-au produs pe baza unei furtuni electromagnetice....cred!:cool2:
Uite:
Si doua linku-uri unde gasesti date relativ actualizate din 3 in 3 ore (timpul e UTC....sau GMT)
Ps: Eu m-am lasat de sportul asta ....dar mai urmaresc din cand in cand datele....si rapoartele tale.
BRAVO!
Latest Solar Wind Values
Created: 2010 May 03 1203 UTC
Magnetic Field
(Based on GSM coordinates) Plasma
Total Field, B : 3.9 nT Speed, V : 696.3 km s-1
Field in x-direction, Bx : 1.9 nT Temperature, T : 242681.7 k
Field in y-direction, By : -3.4 nT Density, n : 0.3 particles cm-3
Field in z-direction, Bz : -0.5 nT Pressure, P : 0.2 nPa
Latitude angle, beta : -7.3°
Angle, theta : 97.3°
---------- Post added at 12:35 ---------- Previous post was at 12:05 ----------
Created: 2010 May 03 1228 UTC
Magnetic Field
Total Field, B : 4.1 nT Speed, V : 719.7 km s-1
Field in x-direction, Bx : 0.2 nT Temperature, T : 215445.4 k
Field in y-direction, By : -3.8 nT Density, n : 0.3 particles cm-3
Field in z-direction, Bz : -1.6 nT Pressure, P : 0.3 nPa
Latitude angle, beta : -22.8°
Angle, theta : 112.8°
conditii momentan :
yky unde esti .. alerta
first black out from E2 channel
---------- Post added at 20:27 ---------- Previous post was at 18:54 ----------
[Only registered and activated users can see links. Click Here To Register...] dulovo
[Only registered and activated users can see links. Click Here To Register...] campina 1
[Only registered and activated users can see links. Click Here To Register...] shumen
[Only registered and activated users can see links. Click Here To Register...] topolog
[Only registered and activated users can see links. Click Here To Register...] focus buzau
[Only registered and activated users can see links. Click Here To Register...] galaxya kisssdoaiaaaanaaa
[Only registered and activated users can see links. Click Here To Register...] doibrici treibrici dobrich
[Only registered and activated users can see links. Click Here To Register...] variatii buzate
[Only registered and activated users can see links. Click Here To Register...] targoviste
[Only registered and activated users can see links. Click Here To Register...] valcea 1
[Only registered and activated users can see links. Click Here To Register...] valcea 1 II
[Only registered and activated users can see links. Click Here To Register...] baneasa
[Only registered and activated users can see links. Click Here To Register...] magic fm buzau
[Only registered and activated users can see links. Click Here To Register...] turnu
[Only registered and activated users can see links. Click Here To Register...] campina II
[Only registered and activated users can see links. Click Here To Register...] barlad
---------- Post added at 21:58 ---------- Previous post was at 20:27 ----------
nova tv varna
[Only registered and activated users can see links. Click Here To Register...] ca de fiecare data cand pleaca propagarea noaptea dupa cea care o exprimase tot asa tare
[Only registered and activated users can see links. Click Here To Register...] si aici faza totala de nova tv !
daca nu se remediaza problema care sa imi depasrta ideeile , de tropo cu alea de sporadic , MA DEZABONEZ !
Astazi din lipsa de ocupatie m-am legat de sarma de rufe a nevesti si am tras o scanare, printre altele a intrat un canal PRO-BG si juri ca e PRO-TV.
S-au bagat PROTV-isiti si pe Bulgaria?
Stie cineva ceva?
Are imagine 16;9
Se pare ca da
Ei acum trebuie sa iti dau niste lamuriri in privinta PRO BG si RING.BG, cele doua televiziuni fac parte din grupul CME(Central Media Europe) care detine controlul asupra urmatoarelor posturi din diferite tari :
Romania: grupul PRO
Bulgaria: PRO BG, RING BG, BTV
Cehia: Nova tv
Slovacia: Markiza...si asa mai departe
Mai multe informati despre grupul CME ai aici: [Only registered and activated users can see links. Click Here To Register...]
Pai eu in locul lor le adunam pe toate pe 2 tp pac pac subtitrare in 6 limbi tac tac le faceam hd si gata un nou dth.
usor nu?
Poate nu lea trecut ideea prin cap...ia trimitele un email...:)
Pana le vine lor idea cu ce le strang eu la un loc si ro so bg
mai exact:
am facut un dipol (fara masuratori) cu bucla si tot ce trebuie dar...
intra cele romanesti
tvr1,2
antena1
protv
prima
si bulgaresti
bnt
btv
pro.bg
nova.bg
si mai este unu cu sigla 7 cred sau cam asa ceva(se vede rau)
cand reglez pt ro bg f rau si invers
Ce antena cumpar pt toate?
O antena tip gratar si te ai scos.....sau daca vrei ceva mai profi o antena de la antech...[Only registered and activated users can see links. Click Here To Register...]
Oameni buni si care gandim si care luam la purecat tot ce scrie pe oriunde d-l zvartoshu , haideti sa tragem si o linie , eu am tupeu ca pot combate in draci pe oricine asta dupa ani buni de radio electronica si radio receptie .
1 Zona unde ii vin semnalele este cu dubla reflexie , pozele postate si panoramele , isi zic cuvantul , 2 cladiri are exact pe traciectoriile antenei lui de 3 elemente ex TVR1 canal 4 , 91.75mhz .. etc
2 Casa lui este acoperita cu tabla , antena este exact dupa primul divizor , adica 3.32M , face in draci calibrarea fixa pe fm sa rezoneze maxim .
3 Receptiile lui sunt teribile , deoarece sta langa radiouri ce au peste 500w , iar antena ce emite de la radiouri este cu fata exact spre antena lui .
4 radioul ce il tot lauda este un radio cu amplificator gen <MT28> cu 2 fet-uri + 1 care este al circuitului original . Amplfiicarea ii functioneaza enorm , si o mai poate regla , intermodularea este mica cand da sus instablatia . teribilism .. depaseste normalul . ( pe testate)
5 Cand apar receptii turcesti , verificate de altfel , semnalele slabe de la mine , la aparatul lui sunt redate cu blank , deci trisarea functioneaza .
-Calculand , si explicand d-lui Burcea Cosmin care lucra la radio progresul acest caz mot a mot , acesta s-a crucit cum un radio comercial nu se inceaca si mai are si receptii slabe in zona cu radiouri de putere .
- Calculele mele imi arata un castig prin reflexie si plus ce ii mai vine din atmosfera , dubland totodata semnalul receptionat , adica TRISEAZA , asta o zic aratand si demonstrand . Receptia lui fiind de 3 ori mai puternica din orice punct de vedere .
-Vara cand incep receptiile sporadice , el este fruntas , sunt om ce ascult , am ascultat si o voi mai face cat mai am puterea si pot arata argumente si contra argumente , dovezi , ca sa inteleaga omul de rand . Acum va descriu cuiele infipte in toc de nervi .
-Fratii mei , prindeam si eu radio MASR , dar dao dracu de treaba , in filmele lui , acelasi timp ce prindeam acelasi radio , el avea receptie fluenta si rar incoerenta , pe cand la mine era o instabilitate si zgomot mult , avand antena de 5 elemente si radio laudat KENWOOD .
Pe final , recunosc , dar ce a aratat el in un film de prin Oltenita , receptia radio constanta , turcii , scosi fara propagare m-a lasat ca la dentist .
Va spun un adevar , multi nu cred , si nu or sa creada ce inseamna recepie de putere , si radio ce sa detecteze peste 300Km in mod normal . Va garantez ca omul ce va pune mana pe un radio de acest gen va spune ca este stricat din cauza receptiilor instabile (scatter) sau va ramane prost si il va inchide de rusine cum in camp el va auzi maxim kiss fm sau radio zu .
Asteptam acum dreptul la replica a lui gaspadin zvartosu. Gaspadin, ai legatura.
Bai parca se retrasese de aici , asta ca nu mai scrie, deci mai vine abia dupa ce maninca borcanul de castraveti sau dupa ce il vedem la bulgaria 1 . Da , si il si vad ca vine si ma domina , sa vezi ce il iau la puricit cu ce dx trisat face , il fac de nu se vede . Sa ne lase cu manevre dastea forjate , sa intre in realitatea receptiei naturale .:wellcome:
Rugaminte: fara rafuieli personale pe acest forum; limitati-va la posturi strict tehnice.
Dau cu buna ziua cum as da cu paru'
Ia sa vedem de ce ma deranjeaza lumea ca scrie x si y de mine gogoloaie .
Pai cum vrei mai revista casei ca sa ai dx in zona muci cand tu tre sa faci sa rezoneze atat sus la antena cat jos la capatul firului la ce ai nevoie ?
Pai daca nu te-ar lauda favoritii ca ma iei la ciocan ca la nicovala , eu nu as rade ca esti "bou" , sincer nu mie jena sa o zic mai acesta , acesta mic , nu cunosti LIVE-UL de dx printre zgomote prafuieli de la snr- goruile gorilute .
Daca sunt in zona de reflexie , eu fiiind in punctul C , am rezultatele pe tava ale B-ului din spate si A din fatza , si semnalul in aer e scazut de la "cataroaiele" de la big berceni . Deci cum ramane cu protv novaci scos cu antena spre sud si sud est ?
Tu te iei de toti , ii combati., insa tu nimuric dala mai mic , nu vi cu poza gen
TV7 de la tutrakan scos cu 50w ai lui , na sa iti dau o bucata de apa la moara sa te simti bine ....
linge monitoru pana turbezi , am antena veche de canal 32 , aia de rusia 1 , hai sa te vad cu poza daca mai ai vre una pe vre un bloc de pe langa tine , macar ruginita , macar asa , sa o postezi . Nu veni cu antene dalea de banda larga de la zonele marginase ale satelor unde sunt aia plecati in spanie sau italie , cu casoaiele si vilele ca nu ma da la intors imaginea asta , ma da la intos cat de tampiti sunt unii cand isi lauda draciile prin poze de la tara , acelasi joc , unde lucreaza , are casa palat unde sta .
Inca o data , inchideti dracu geamurile sa nu mai vina bondaru' ala cu nume de revista casei ca ma ia rasu de ma tavalesc prin cartier de ras .. !
Mai lume si cu asta am pus punct , nu ma intereseaza ce iese , dar garantez ca i-am dat sah mat , la fileu sau cum se mai zice fix inrte o-o .:agresiv: .
Eu sunt dx-er iar tu mahala ! corect ? parca da ! bafta .
Scurt, concis si la subiect. L-ai facut praf, gaspadin zvartosu.
Argumente am , am traite , am pe erdelyi care zice el in nas , paote vrea sa ii dau un .. Benouazeci.. si cum dracu ii zice , televiziunea aia de la sarbi .. b_9X sau cum benouajdoiu ei ii zice .:dance:
