zgomotul solar ..
noise radio sun detected .. !
zgomotul solar ..
Cannakkale dx :
Istambul buiuk tepesi :
Fenomen during 1day .
Dx in last day 16.02.2010 at South romania .
Azimuth propagation : unsettled :
Start : at 16:52 tropo detect in zone Novaci at 220km of my house .
At 18:28 propagation add multiple taiectory and antena H and LOOP
at 20:56 propagation add extreme values at 220km : 55dB!
at 21:35 signal propagation moving in Se zone .. 172Km tropo detect .
At 22:07 signal move in NE zone and detection propagation ad 192Km range
Radios detected in tropo
88.6 radio valcea 1 cozia
89.8 radio white targoiste
90.6 radio zu topolog
91.5 radio 21 cozia
92.9 rractual novaci
93.0 trinitas harghita
93.3 pro fm sinaia
93.9 info pro baneasa
93.9 magic fm ploiesti
94.0 voces campi oltenita
94.3 info pro cozia
94.4 fm plus ruse
98.5 kiss fm kanlia
99.2 kiss fm cozia
99.9 guerilla cozia
101.6 cultural vacareni
103.2 wil fm campina
104.3 horizont\ dobrich
105.0 oltenia novaci
105.5 info pro simnic
106.4 rractual vacareni
Sites important in time tropo :
Vacareni , Cozia , Novaci , Simnic , Baneasa
Cities important :
Campina , Targoviste , Oltenita .
Captures :
[Only registered and activated users can see links. Click Here To Register...] valcea 1
[Only registered and activated users can see links. Click Here To Register...] novaci 50dB
[Only registered and activated users can see links. Click Here To Register...] 55dB novaci ( extra )
[Only registered and activated users can see links. Click Here To Register...] stil fm +11dB bonus ... 35db have continous
[Only registered and activated users can see links. Click Here To Register...] horizont shumen without localy 3.7km station 2w 101.9
[Only registered and activated users can see links. Click Here To Register...] wil fm campina
Antena : 3 element directive 90Mhz balun +feeder
loop antena 105Mhz + 103.0mhz feeder
Vertical jpoole simplified version 94.0mhz+94.0 feeder
radio - Blaupunkt version bp5501 with multiple modifications:L
2X150khz filtre + bridge 1X110khz+1X150khz
Agc : forced 50%
pentru inceput avem asa :
-Zona austriei de nord detine o depolarizare a undelor radio .
-In uncraina avem de a face cu doua tipuri de propagare , propagarea normala pentru aceasta perioada cat si propagare mai puterinica , peste perioada aceasta in zona NE a ucrainei .
-In romania aveam propagare normala , indicele de stabilitate al propagarii este exact pe culoarul montan de la drobeta pana la suceava - botosani , propagarea specifica ploii si anotimpului de primavara se regasete exact in sud la zona turnu magurele . Mai avem o propagare de schimbare de are , de la cel cald la cel rece pe zona montana a apusenilor , sau propagarea la fruntea muntiilor , dar aceasta nu va dura mai mult de jumatate de zi deoarece frigul va pune stapanire pe aceasta zona si fenomenul va scadea si muta .
-Bulgaria va avea o propagare supeba si stabila 2 ore si jumatate intre culoareul ruse - silsitra , o propagare dunareana mai bine zis , o propagare ce va avea exact sensul est - vest si vest - est .
propagarea de munte , este cea cuprinsa de la vrata , lovech , sofia , pazargik , plovdiv , arsenovgrad , smolien , karjali , hascovo . Aceasta propagare are stabilitate exact pe zona plovdiv - pazargik . Culoarul de mare stabilitate a propagarii normale de 4.5-6% din acest moment o detine , kavarna - edirne , un culoar tipic pentru stabilitate si propagare de pana la 80-100km fara conditii avansate .
- Turcia , are doua fronturi de propagare de instabilitate cuprinse intre antalya , manavgat , seydisehir , cumra , konya , karapinar . In zona alaya , in orele urmatoare propagarea se va ameliora si va urca in instenistate .
Cipru , propagarea cipriota detine loc superior in acest moment deoarece in jumatatea sudica a ciprului , Paphos si limmasol , larnaca , au propagarea de peste 18% , anormala pentru aceasta perioada , dar cu variatii catre zona famagusta catre orele urmatoare . Propagarea are stabilitate pe regiunea sudica a nicosiei si chiar in zona peristerona .
Libia - propagarea in stabilitate pe cheiul cuprins intre TRIPOLI , Misratah , Surt , bengazi ,sahdhat.
Spre orele urmatoare aceasta propagare va deveni instabila deoarece pe medirerana va apare un front de deploazirare ce va inteti scaderea aceseia.
SIRIA - lataqkya jableh va avea o propagare de stabilitate . adusa de mare , si aceasta nu va depasi zona Bergai jabhet . La pasrtea opusa de vest a siriei , aveam propagarea de la ABU KMAL spre ESHARA si eshara jisr shaddadah . Aceasta propagare este una stabila si normala pentru aceasta perioada , avand doar variatie spre scadere in orele urmatoare . Traiectoria acestei propaagari este spre Irak . Ar mai fi de zis ca propagarea din nordul siriei , granita cu turcia , are traiectorie exact pe langa suruc , akcakale , cu culoare spre ayn al arab-->alforat , sensul propagarii este de la est catre vest , propagarea va deveni turca in orele urmatoare .
Marea neagra - CUloarul zonguldak sevastopol se va redeschide in aceasta zi , este iar un prilej bun de dx si nunumai . Stabilitatea este medie , aceasta propagare avand tendinte spre simferopol fedosiia kerch ... Propagarea are posibilitatatea sa urce spredjankoy .
Felicitari pentru pasiunea ta.:cheers:
Today new athmoferic air mass appear in mediteranean sea :
In zone Tunis to south italy .. new propagation appear . Duration is maxim 4 hours but the athmospherical front closed by the new pressure .
libian propagation in NW appear at mid power level , in 2 zones : TRIPOLI - Ghadames . At the mirsatah zone to SURT appear at sea propagation high . this fenomen not receive in cityes but the distance sea to city is small <12km .
Sea mediteranean - to arabic zones long distance tropo , summer echivalent at peak mid level is in this moment . this fenomen appear in the most popular culoar - CRETE - AL JAWF .
The last summer the indicator of the tropo say - maxim peak level tropo to 1000Km W to E direction in zone al najaf , al anbar , kmal zone , latakya - larnaca ..
Turk propagation new verion in this day , a mountain culoar propagation . start in traiectory MUGLA , antalya - and - diagonal diretcion - antalya - isparta - afyon - usak - kutahya - ekisehir - bilecik - bolu - sakarya,kokaeli .
This propagation durmg maxim 8 hours and not stable troposferic reflexions .
Second propagation start in istambul zone - bursa - canakkale - gockeada - tekirdag - corlu ..
romanian propagation :
First propagation detected in center romania and reflexions are exact in traietcory covasna - targu mures . and second bistrita nasaud maramuresh zone .
Second propagation unstable is detected in zone tulcea - galati - buzau - focsani - tecuci
Small propagation appear in zone kanlia - baneasa to fetesti zone and in few hor propahgation up to festest - harsova - topolog zone
Small propagation at mountaisn appear in brasov to fagarasi - sibiu . Small propagation appear in zone barlad to vaslui zone .
at final propagation appear iasi - to suceava zone .
bulgarian propagation .. danube culoar swistrov - ruse - tutrakan - silsitra zones. This propgation appear in razgrad - kucrat zone - shumen - isperih - glavinitsa . Sthis propagation up to romania and brige to small propagation fetesti topolog .
This is a unstable proipagation E- to - W direction . rare appear fenomen SOUTH to NORTH direction proipagation in diretcion Razgrad - tutrakan .
South eats briged propaagtion dtect in culoar edirne - demirkoy - to malo tarnovo - boljavoro - elhovo - svilengrad - haskovo - kirkovo .
sa fie cu noroc pentru toata lumea ... :dance:
88.7Mhz - Troposcatter TRT 1 Karaburun - 643Km 11:45Z
93.00Mhz - TRT 1 Canakkale - Troposcatters multiple - 480km (*)
93.00Mhz - Trinitas romania Harghita Bai - small tropo - 262Km
93.10Mhz - TGRT Istanbul - Troposcatter 15:41Z - 448KM
93.20Mhz - Darik Karjali Bulgaria- Troposcatters 314Km -11:54Z - 12:37Z
97.20Mhz - TRT-FM Zongguldak - troposcatter 582KM - 13:15Z
105.0Mhz - Oltenia Craiova Ro - 220Km tropo fluent 2Hours
Radio : Acr3250 modified
with 60% agc ajustable mode
Dual brige 150khz filter + 1X110khz
Filtered input LC to mos-fets in PCB
Antena : 3 element directive antena Horizontal , S azimuth +
1 Rejetcor for 94.8Mhz , 1 LC cut noise for 90.2Mhz .
73
Band 2 logs in S romania city Buchrest - center - 11.03.2010
11:32 - 88.7Mhz - RRACTUAL SIMNICU DE SUS - troposcatter - 197KM
11:44 - 93.0Mhz - TRT CANAKKALE - 2 troposcatters - 480KM
14:27 - 88.7Mhz - RRA SIMNICUL DE SUS - 197KM troposcatter
14:51 - 93.2Mhz - darik karjali - troposcatters - 2 minutes 318km
16:58 - 93.0mhz - trt canakkale - troposcatter - 480km
19:06 - 107.7mhz - micul rvic del cahul - 233km troposcatter
21:44 - 93.0mhz - trt canakkale - troposcatter 480km
22:17 - 105.0mhz - rractual topolog - 192km coerent 4 minute tropo
22:18 - 90.6mhz - radio zu topolog - 192km - coerent 5 minute tropo
23:01 - 107.7mhz - micul rvic de peste prut - 233km 2 minute tropo
23:47 - 88.7mhz - trt karaburun - 642km unsettled scatters
23:51 - 90.5mhz - radio light beirut - METEOR SCATTER - indetified by TP and arab language
23:56 - 93.0mhz - trt canakkale - stroposcatter - 480km
radio balupunkt with modifications
j-pole simplified antena
3 eelment directive H antena
73
HB9SIX 13:51 50058.2 Switzerland (EU) DK2EA jn47qf(tr>jo50uf 449 QSB
VK4AFN 13:51 50170.0 Australia (OC) UB5IKZ qsy to 50180.0
KG6DX 13:47 50110.0 Guam (OC) VK8MS-@ Joel 5x9 here into Darwin
VK8VF/B 13:28 50310.0 Australia (OC) KG6DX QK23(TEP>PH57
SP6BVR 13:08 50285.0 Poland (EU) SP6HED JO80IL(TR>JO80HK 599 CQ CQ
VK8MS 12:46 50122.0 Australia (OC) PA0HIP 59 PH57(>PK10 DU7/PA0HIP
VK8MS 12:25 50122.0 Australia (OC) JR6EXN SSB..RS 59++
VK8MS 12:20 50122.0 Australia (OC) JO3UGX 52 in PM75
VR2SIX/B 12:19 50075.0 Hong Kong (AS) KG6DX QK23(TEP>OL72
BV2YA/B 12:19 50001.0 Taiwan (AS) KG6DX QK23(TEP>PL05
VK8MS 12:11 50110.0 Australia (OC) JE6AZU cq qsy 50.120
VK8MS 12:07 50120.0 Australia (OC) JE6AZU 55
KZ4RR 11:32 50125.0 United States (NA) KB3RHR 5/5-7 MS s1 resid EM90(>EN9
WA4VUT 11:09 50125.0 United States (NA) KB3RHR CQCQ 5/7 bursts EM50>EN90 M
[Only registered and activated users can see links. Click Here To Register...] 46.25 first reception after 10 years .
hai sa radem ca e propagare
[Only registered and activated users can see links. Click Here To Register...] doribiceasca
si
nu te ploiesteana
reteta zilei :
1Xbfr96+4Xbfp67 = 77dB
Iata ce se intampla la un tv cand dai cu asa ceva :
first stage amplifier with 1Xbfr96A
second stage amplifier with 1Xbfr96+1Xbfp67
three stage amplifier with 1Xbfr96+2Xbfp67
[Only registered and activated users can see links. Click Here To Register...][/URL]
for stage amplifier with 1Xbfr96+3Xbfp67 - 62dB maxim
---------- Post added at 11:09 ---------- Previous post was at 09:13 ----------
configuratia antenelor
bucla si balon rejectii pentru gorilutzele di langa mini
j-pol simplificat cu adaptare in baza de prindere
Folositi careva pe FM antene tip " J " ? Ce parere aveti de ele ?
am fosloit antena circulara Jhcp .. ma dadea pe spate cum sa zic ! un semnal de pe diretcia nord , il luam si pe sud si pe sud est si pe est si pe vest si sud vest.
Multumesc de raspuns dar eu ma refeream la o antena J-pole ( pe scurt antena J ) si nu la antena Jampro pe care ai folosit-o .
O antena J-pole este o antena verticala , omnidirectionala , usor de construit si cica si buna ( vezi Google ). Asta ma intereseaza .
Salutare,
Scuzati interventia mea,va rog dar DX-ul ma pasionat dintodeauna.
Dintre multele antene pe care le-am construit una sa evidentiat in mod deosebit,datorita cistigului si directivitatii.
Este vorba despre antena SWAN dimensionata intre frecventele de 88MHz si 634MHz,cuprinzind 10 dimensiuni in FIF+FM+145 MHz radioamatori ,si 13 dimensiuni in UIF intre canalele 22 si 41 OIRT/CCIR.
Ar fi pacat sa se piarda aceast tip de antena,are intradevar ceva de oferit celor care au nevoie de servicile ei.
Depaseste in cistig si directivitate multe antene FM+Tv existente astazi pe piata chiar si faimoasele antene cu elementi in X,bag mina in foc pentru antena asta cum se spune,iar daca elementii sint facuti in totalitate din teava de cupru nu are egal.
Am testato in cele mai dificile situatii,inpreuna cu alte tipuri de antene si intotdeauna a iesit pe primul loc.
mouse.
Corect mouse ! swan e swan .. nu se compara !
Cat despre J-pol .. am pe casa , cu ea am dat lectie anc care spunea ca nu se poate face receptie de distanta langa 3 posturi de radio ce au maxim 6/5kw putere totala radiata pe 6 antene verticale gamma !:gathering:
Exemple langa gurillaa .. >?
FM+ 94.4 si 94.0 voces campi .. zona unde pe aparatele de radio apare brum .
La mine apare VOCES si FM+ , chiar si vara am sporadic pe 94.500Mhz si 95.100!
