(PR) EK Launches Quantum X570 Monoblock for the ROG STRIX X570-E
EK, the European premium liquid cooling gear manufacturer, is releasing a new AMD AM4 socket based monoblock belonging to the Quantum Line of products, the EK-Quantum Momentum ROG Strix X570-E D-RGB. This monoblock is engineered specifically for the ROG Strix X570-E Gaming motherboard from ASUS. The addressable D-RGB LED in the monoblock is compatible with ASUS Aura Sync RGB control and offering a full lighting customization experience for every single diode at any given time.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/5GGDlOzj3pVRuabb.jpg" data-width="1161" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/5GGDlOzj3pVRuabb_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/I4BZh9hqZD0NnufH.jpg" data-width="1086" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/I4BZh9hqZD0NnufH_thm.jpg" width="147" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/j90FIGqYc4wQrsf6.jpg" data-width="1115" data-height="924" target="_blank"><img src="https://www.techpowerup.com/img/j90FIGqYc4wQrsf6_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AIvqN1kRBdHX8Pdb.jpg" data-width="1140" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/AIvqN1kRBdHX8Pdb_thm.jpg" width="154" height="130" alt="" /></a> </div><div class="readmore"><a href="/260971/ek-launches-quantum-x570-monoblock-for-the-rog-strix-x570-e">Read full story</a></div>
(PR) Thermaltake Releases TOUGHRAM RGB White Edition DDR4 Memory Kits
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear and Enthusiast Memory solutions, today announced the release of the Thermaltake TOUGHRAM RGB DDR4 Memory Series which now comes in a white edition along with new frequencies of 3,200 MHz and 3,600 MHz 2x 8 GB. TOUGHRAM is supported by Intel and AMD platforms and features 10-layer PCB construction, 2oz copper inner layers and 10μ gold fingers, the TOUGHRAM RGB white edition is not only visually appealing, but is also high in performance. The TOUGHRAM RGB White Edition is built with premium fine coating that reveals true elegance from inside out.<br />
<br />
The TOUGHRAM RGB DDR4 Memory Series 3,200 MHz and 3,600 MHz white edition is now available for pre-order at the TT Premium website. Please refer to the Thermaltake website or contact your local Thermaltake sales or PR representative for more information on pricing for the Thermaltake TOUGHRAM RGB DDR4 3,200 MHz and 3,600 MHz white edition memory kits.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OZZe1tQE21WzLa7w.jpg" data-width="1427" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/OZZe1tQE21WzLa7w_thm.jpg" width="193" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3N5Vl1gIOS0Wtb1z.jpg" data-width="1431" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/3N5Vl1gIOS0Wtb1z_thm.jpg" width="194" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4syua328avMnXpwD.jpg" data-width="1041" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/4syua328avMnXpwD_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CCzyoLrWROnSYgwI.jpg" data-width="1340" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/CCzyoLrWROnSYgwI_thm.jpg" width="181" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uWoYu7iSJBfhnLHU.jpg" data-width="1531" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/uWoYu7iSJBfhnLHU_thm.jpg" width="207" height="130" alt="" /></a> </div><div class="readmore"><a href="/260970/thermaltake-releases-toughram-rgb-white-edition-ddr4-memory-kits">Read full story</a></div>
(PR) ADATA Launches IM2P33E8 PCIe Gen3x4 M.2 2280 SSD
ADATA Technology, a leading manufacturer of high-performance DRAM modules, NAND Flash products, and mobile accessories is pleased to announce the launch of the ADATA IM2P33E8 PCIe Gen3 x4 M.2 2280 SSD. Designed with 5G networking, cloud computing, AI, and IoT in mind, the SSD sports excellent performance, large storage capacities, wide-temperature resistance (-40°C-85°C), and security features. These capabilities combine to offer an ideal solution for applications such as data centers, surveillance, and transportation. <br />
<br />
The IM2P33E8 PCIe Gen3 x4 M.2 2280 SSD is NVMe 1.3-compliant and delivers read/write speeds of up to 3500/3200 GB per second, making it up to six times faster than standard SATA III SSDs. It is equipped with 3D NAND Flash memory and comes with storage capacities ranging from 256 GB to 2 TB. It is available in normal-temperature (0°C to 70°C) and wide-temperature (-40°C to 85°C) variants. For enhanced security, integrity, and durability the IM2P33E8 features E2E (End-to-End) Data Protection and RAID Engine. What's more, the IM2P33E8 utilizes AES and TCG Opal encryption to keep confidential data away from prying eyes.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/RGOw3fEhjfhT0NT6.jpg" data-width="1985" data-height="1185" target="_blank"><img src="https://www.techpowerup.com/img/RGOw3fEhjfhT0NT6_thm.jpg" width="218" height="130" alt="" /></a> </div><div class="readmore"><a href="/260969/adata-launches-im2p33e8-pcie-gen3x4-m-2-2280-ssd">Read full story</a></div>
(PR) EK Announces New Line of Quantum Volume FLT D-RGB Reservoirs and Kinetic FLT D-RGB Pump-res
EK, the premium liquid cooling gear manufacturer based in Europe, is releasing a new Quantum Line of reservoirs and pump-reservoir combo units. They come in a completely new shape with straight edges and completely flat. This makes them even easier to fit in tight spaces, as they also utilize standard 120 mm fan mounting holes and take up as much space as a radiator in terms of width and length. The pump-reservoir combos come in both D5 and DDC variants, but either is compatible with both pumps. These EK-Quantum products come with sophisticated 5 V D-RGB addressable LEDs which can be controlled through your motherboard RGB control software.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/TUN1h3PEVoykmu4F.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://www.techpowerup.com/img/TUN1h3PEVoykmu4F_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xDdwVWrHyDDyl0xb.jpg" data-width="1200" data-height="1200" target="_blank"><img src="https://www.techpowerup.com/img/xDdwVWrHyDDyl0xb_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/260965/ek-announces-new-line-of-quantum-volume-flt-d-rgb-reservoirs-and-kinetic-flt-d-rgb-pump-res">Read full story</a></div>
(PR) Kolink Launches the Ethereal and Refine Chassis
Renowned for their innovative and high-performance cases, Kolink has now brought the new Ethereal & Refine to the market, representing a feature-rich gaming case that offers an abundance of space beneath its stylish exterior for all the powerful gaming hardware you could want. The tempered glass side door will allow users to enjoy an unobstructed view of their high-end gaming setup complete with compatibility for E-ATX motherboards.<br />
<br />
Given the use of tempered glass, aesthetics are important, and a PSU shroud cleverly conceals unsightly cables. The front of the case that consists of brushed aluminium underlines the chic appearance that is also accentuated by the addition of a digitally addressable RGB-LED strip. The lighting can be controlled via a switch on the I/O panel. Alternatively, the strip can also be connected directly to a motherboard and controlled by RGB software. A fine mesh with integrated dust filter on the top ensures proper ventilation. A pre-installed 120 mm fan at the rear provides adequate ventilation. The Kolink Ethereal and Refine chassis are now available from £62.99.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2g7cfuMuYFpThimn.jpg" data-width="953" data-height="527" target="_blank"><img src="https://www.techpowerup.com/img/2g7cfuMuYFpThimn_thm.jpg" width="235" height="130" alt="" /></a> </div><div class="readmore"><a href="/260964/kolink-launches-the-ethereal-and-refine-chassis">Read full story</a></div>
AMD Announces Ryzen 9 3950X, Details 3rd Gen Ryzen Threadripper, unlocked Athlon 3000G
AMD today announced four new desktop processors across three very diverse markets. To begin with, the company crowned its socket AM4 mainstream desktop platform with the mighty new Ryzen 9 3950X processor. Next up, it released its new baseline entry-level APU, the Athlon 3000G. Lastly, it detailed the 3rd generation Ryzen Threadripper HEDT processor family with two initial models, the Ryzen Threadripper 3960X and the flagship Ryzen Threadripper 3970X. The company also formally released its AGESA Combo PI 1.0.0.4B microcode, and with it, introduced a killer new feature for all "Zen 2" based Ryzen processors, called ECO Mode. <br />
<br />
The Ryzen 9 3950X is a 16-core/32-thread processor in the AM4 package, compatible with all socket AM4 motherboards, provided they have the latest BIOS update with AGESA Combo PI 1.0.0.4B microcode. The processor comes with clock-speeds of 3.50 GHz base, with 4.70 GHz maximum boost frequency, and the same 105 W TDP as the 12-core Ryzen 9 3900X. With 512 KB of dedicated L2 cache per core, and 64 MB of shared L3 cache, the chip has a mammoth 72 MB of "total cache."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/r93NOqQh2hmKm16J.jpg" data-width="1086" data-height="955" target="_blank"><img src="https://www.techpowerup.com/img/r93NOqQh2hmKm16J_thm.jpg" width="148" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a2WtGQZ94yp4OcEl.jpg" data-width="1228" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/a2WtGQZ94yp4OcEl_thm.jpg" width="166" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TrSGI0k8Cnetlt1C.jpg" data-width="1104" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/TrSGI0k8Cnetlt1C_thm.jpg" width="150" height="130" alt="" /></a> </div><div class="readmore"><a href="/260936/amd-announces-ryzen-9-3950x-details-3rd-gen-ryzen-threadripper-unlocked-athlon-3000g">Read full story</a></div>
(PR) GLOBALFOUNDRIES and SiFive to Deliver Next Level of High Bandwidth Memory on 12LP
GLOBALFOUNDRIES (GF ) and SiFive, Inc. announced today at GLOBALFOUNDRIES Technology Conference (GTC) in Taiwan that they are working to extend high DRAM performance levels with High Bandwidth Memory (HBM2E) on GF's recently announced 12LP+ FinFET solution, with 2.5D packaging design services to enable fast time-to-market for Artificial Intelligence (AI) applications.<br />
<br />
In order to achieve the capacity and bandwidth for data-intensive AI training applications, system designers are challenged with squeezing more bandwidth into a smaller area while maintaining a reasonable power profile. SiFive's customizable high bandwidth memory interface on GF's 12LP platform and 12LP+ solution will enable easy integration of high bandwidth memory into a single System-on-Chip (SoC) solutions to deliver fast, power-efficient data processing for AI applications in the computing and wired infrastructure markets.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JdowMwlcsLFvttUq.jpg" data-width="1211" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/JdowMwlcsLFvttUq_thm.jpg" width="164" height="130" alt="" /></a> </div><div class="readmore"><a href="/260951/globalfoundries-and-sifive-to-deliver-next-level-of-high-bandwidth-memory-on-12lp">Read full story</a></div>
(PR) Shuttle Redesigns Fanless 1.3-litre PCs Based on Whiskey Lake
The XPC slim model series has a new member. With the DS10 range, Shuttle now presents four slender, fanless barebones with a robust steel chassis and a variety of connection options. The available processors can handle different requirements from the energy-saving dual-core Intel Celeron through to the powerful i7 quad-core model.<br />
<br />
All DS10 models are completely fanless and operate without any noise. At the same time, they are very low-maintenance, because the passive cooling means that less dust gets inside them. This is why the DS10 range is also particularly suitable for constant 24/7 operation in adverse ambient conditions. The robust steel chassis measuring 20 × 16.5 × 3.95 cm (LWH) provides space for one 2.5-inch drive in the form of a hard disk or SSD as well as two SO-DIMM slots which can accommodate a total of up to 32 GB of DDR4 memory. An M.2-2280 slot is available for fast NVMe drives. The second M.2 slot is equipped with a WLAN/Bluetooth module which transmits and receives data using two external antennas.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/yUmfEPCkir0pZFU3.jpg" data-width="681" data-height="600" target="_blank"><img src="https://www.techpowerup.com/img/yUmfEPCkir0pZFU3_thm.jpg" width="148" height="130" alt="" /></a> </div><div class="readmore"><a href="/260943/shuttle-redesigns-fanless-1-3-litre-pcs-based-on-whiskey-lake">Read full story</a></div>
MSI TRX40 PRO Series Motherboards Pictured
Ahead of their launch, low-resolution pictures of two nearly identical MSI TRX40 PRO series motherboards surfaced on the web, the TRX40 PRO 10G, and the TRX40 PRO WiFi. The former is characterized by a 10 GbE wired Ethernet connection through an included add-on card, while the latter features 802.11ax Wi-Fi 6 WLAN. The two appear otherwise identical, with a couple of M.2 slots on the board, four additional M.2 slots on a cooled add-on card, four PCI-Express x16 slots, eight DDR4 DIMM slots, and other storage connectivity that includes four SATA 6 Gb/s ports, and U.2 port. From the looks of it, the new for the 3rd generation Ryzen Threadripper looks identical to TR4, which bodes well for people wanting to use their TR4-compatible CPU coolers or water-blocks on the new platform.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/VrT41cqtXTIAvRAs.jpg" data-width="334" data-height="319" target="_blank"><img src="https://www.techpowerup.com/img/VrT41cqtXTIAvRAs_thm.jpg" width="136" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3wxif0wBAEo8NeRI.jpg" data-width="348" data-height="308" target="_blank"><img src="https://www.techpowerup.com/img/3wxif0wBAEo8NeRI_thm.jpg" width="147" height="130" alt="" /></a></div>
(PR) NVIDIA Announces Jetson Xavier NX, Smallest Supercomputer for AI
NVIDIA today introduced Jetson Xavier NX, the world's smallest, most powerful AI supercomputer for robotic and embedded computing devices at the edge. With a compact form factor smaller than the size of a credit card, the energy-efficient Jetson Xavier NX module delivers server-class performance up to 21 TOPS for running modern AI workloads, and consumes as little as 10 watts of power.<br />
<br />
Jetson Xavier NX opens the door for embedded edge computing devices that demand increased performance but are constrained by size, weight, power budgets or cost. These include small commercial robots, drones, intelligent high-resolution sensors for factory logistics and production lines, optical inspection, network video recorders, portable medical devices and other industrial IoT systems.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/USh9B7flTg2ZIR2v.jpg" data-width="1158" data-height="878" target="_blank"><img src="https://www.techpowerup.com/img/USh9B7flTg2ZIR2v_thm.jpg" width="171" height="130" alt="" /></a> </div><div class="readmore"><a href="/260937/nvidia-announces-jetson-xavier-nx-smallest-supercomputer-for-ai-at-the-edge">Read full story</a></div>
Seagate's Roadmap Calls for 18 TB, 20 TB Drives in 2020, 50 TB by 2026
Seagate announced its roadmap for the coming years, and the company is naturally fighting tooth and nail for the relevance of HDD technology in the market. While the benefits of SSDs are already well understood by the entire industry, in some scenarios, it makes more sense to make use of high-density HDDs - particularly where deployment space is at a premium, and in scenarios where seek times for information stored on the media aren't all that important. This is why the company is aggressively pushing its new HAMR technology as a way to increase areal density on traditional platter-based media.<br />
<br />
Plans to achieve 18 TB and 20 TB density HDDs in the first semester of 2020 seem to be well within reason, considering the company has <a href="https://www.techpowerup.com/256244/seagate-announces-16tb-exos-and-ironwolf-hard-drives" target="_blank">recently shipped</a> 16 TB HDDs. These HDD solutions will still make use of older technologies such as CMR (Conventional Magnetic Recording), for the 18 TB drives) and SMR (Shingled Magnetic Recording) for their 20 TB 2020 products. The company will later make use of their proprietary <a href="https://www.techpowerup.com/250203/seagate-achieves-milestone-in-hamr-hdds-16-tb-units-internally-tested" target="_blank">HAMR (Heat Assisted Magnetic Recording)</a> technology in order to upgrade their 20 TB, and 20 TB+ HDDs with higher performance (and density) than can be achieved with the tried and true SMR. When it comes to performance improvements, a latent disadvantage in HDDs compared to solid state solutions, the company will eventually deploy HDDs which make use of two sets of read/write heads instead of a single one.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ukrO0wqRRPelm6ak.jpg" data-width="927" data-height="498" target="_blank"><img src="https://www.techpowerup.com/img/ukrO0wqRRPelm6ak_thm.jpg" width="242" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/GWDTqSdWSUfvNBIg.jpg" data-width="960" data-height="720" target="_blank"><img src="https://www.techpowerup.com/img/GWDTqSdWSUfvNBIg_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) EKWB Introduces D-RGB Version of Quantum Vector RTX RE Waterblocks
EK Water Blocks, the Slovenia-based premium computer liquid cooling gear manufacturer, today announces the product launch of EK-Quantum Vector RTX RE D-RGB water blocks, EK-Quantum Vector Upgrade Kits, and EK-D-RGB 6-Way Splitter Cable.<br />
<br />
The RE water blocks use the signature EK single slot slim look and cover the entire PCB length. The block also features a unique aesthetic cover over the block Terminal which is designed to showcase the graphics card model via LEDs, visible from the side. The water block comes in 2 different models tailor-made for either reference NVIDIA RTX 2080 or NVIDIA RTX 2080 Ti. The water blocks are equipped with 5V D-RGB (addressable) LEDs which are compatible with the motherboard 3-pin 5V D-RGB (addressable) LED header.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FGB7DIpySTbhBHYh.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://www.techpowerup.com/img/FGB7DIpySTbhBHYh_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UR7Y5A2ga9iKqZ6w.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://www.techpowerup.com/img/UR7Y5A2ga9iKqZ6w_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ayx61FLYkqUchisW.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://www.techpowerup.com/img/ayx61FLYkqUchisW_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/b0EJwD6D3AzKYvXG.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://www.techpowerup.com/img/b0EJwD6D3AzKYvXG_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="/260916/ekwb-introduces-d-rgb-version-of-quantum-vector-rtx-re-waterblocks">Read full story</a></div>
(PR) NZXT Reveals New Audio Suite for Gamers - AER, STND, and MXER Products
NZXT, a leader of gaming hardware, software, and PC building services, today announced its first lineup of audio products for gamers. The full suite includes the AER wired headset with Hi-Res certification, STND headset platform for sleek storage, and MXER audio control station. All are designed with the clean aesthetic NZXT fans love and expect. AER is a comfortable, lightweight gaming headset available in open and closed-back designs which pairs with STND and MXER for automatic audio switching between the headset and external speakers -- a simple solution that feels like magic.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Oua8AtEAM2ydoJ8z.jpg" data-width="512" data-height="512" target="_blank"><img src="https://www.techpowerup.com/img/Oua8AtEAM2ydoJ8z_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/260915/nzxt-reveals-new-audio-suite-for-gamers-aer-stnd-and-mxer-products">Read full story</a></div>
Intel Unveils World's Largest FPGA
Intel has today announced the Stratix 10 GX 10M - a Field Programmable Gate Array (FPGA) built on 14 nm technology that has an astonishing 43.3 Billion transistors, making it the largest FPGA in the world, dethroning the Xilinx with their previously largest Virtex VU19P FPGA which had a "mere" 35 Billion transistors. The Stratix 10 GX 10M is a home to over 10.2 million logic cells housed inside two large dies, connected by Intel's own Embedded Multi-die Interconnect Bridge (EMIB).<br />
<br />
The 10M model is packing four additional dies besides the two for logic, also connected by EMIB, that feature 48 transceivers in total which have a combined bandwidth of up to 4.5Tb/s. If you are wondering about the bandwidth between all dies, then judging by EMIB's 25,920 connections, there is 6.5 Tb/s of inner-die bandwidth, meaning that components will not be starving for additional speeds to transfer the data. Additionally there are 2,304 user I/O pins, allowing for some creative integration solutions that involve plenty of ports for development purposes.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/sfIuYGWJMMwfYHv5.jpg" data-width="650" data-height="636" target="_blank"><img src="https://www.techpowerup.com/img/sfIuYGWJMMwfYHv5_thm.jpg" width="133" height="130" alt="" /></a><a href="https://www.techpowerup.com/img/BaeOYsx0gq71ggar.jpg" data-width="650" data-height="332" target="_blank"><img src="https://www.techpowerup.com/img/BaeOYsx0gq71ggar_thm.jpg" width="255" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kRSg8lFG3wnTkHUk.jpg" data-width="650" data-height="335" target="_blank"><img src="https://www.techpowerup.com/img/kRSg8lFG3wnTkHUk_thm.jpg" width="252" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZMub2TTBmAuRdArY.jpg" data-width="650" data-height="334" target="_blank"><img src="https://www.techpowerup.com/img/ZMub2TTBmAuRdArY_thm.jpg" width="253" height="130" alt="" /></a><br />
</div><div class="readmore"><a href="/260906/intel-unveils-worlds-largest-fpga">Read full story</a></div>
Scythe Rolls Out SCY-920S Entry-level Tower-type CPU Cooler
Scythe unveiled the SCY-920S, an entry-level tower-type CPU cooler meant as a quieter substitute to your stock CPU cooler, with a thermal load capacity of 95 W. Its design involves an aluminium heatsink base through which two 6 mm thick copper heat pipes pass, making direct contact with the CPU, which then fan out through the fin-stack. A 92 mm fan ventilates the fin-stack. Spinning between 500 to 2,000 RPM, this fan pushes 7.1 to 48.2 CFM of air, with 8.3 to 28.3 dBA noise output. Measuring 87 mm x 62 mm x 127 mm (DxWxH), the SCY-920S weighs about 280 g. Among the CPU socket types supported are AM4 and LGA115x. The cooler goes on sale around mid-December.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YvNI0MrKpKOgQUTW.jpg" data-width="674" data-height="582" target="_blank"><img src="https://www.techpowerup.com/img/YvNI0MrKpKOgQUTW_thm.jpg" width="151" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NiA7mNgRT43pH9Gc.jpg" data-width="589" data-height="589" target="_blank"><img src="https://www.techpowerup.com/img/NiA7mNgRT43pH9Gc_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/REEFf6P0B2qmscXN.jpg" data-width="759" data-height="588" target="_blank"><img src="https://www.techpowerup.com/img/REEFf6P0B2qmscXN_thm.jpg" width="168" height="130" alt="" /></a></div>
HP Enterprise SSD Firmware Bug Causes them to Fail at 32,768 Hours of Use, Fix Released
HP issued a warning to its customers that some of its SAS SSDs come with a bug that causes them to fail at exactly 32,768 hours of use. For an always-on or high-uptime server, this translates to 3 years, 270 days and 8 hours of usage. The affected models of SSDs are shipped in many of HP's flagship server and storage products, spanning its HPE ProLiant, Synergy, Apollo, JBOD D3xxx, D6xxx, D8xxx, MSA, StoreVirtual 4335 and StoreVirtual 3200 product-lines. <br />
<br />
HP has released an SSD firmware update that fixes this bug and cannot stress the importance of deploying the update enough. This is because once a drive hits the 32,768-hour literal deadline and breaks down, both the drive and the data on it become unrecoverable. There is no other mitigation to this bug than the firmware update. HP released easy to use online firmware update tools that let admins update firmware of their drivers from within their OS. The online firmware update tools support Linux, Windows, and VMWare. Below is a list of affected drives. Get the appropriate firmware update from <a rel="nofollow" href="https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00092491en_us" target="_blank">this page</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cowP9FxkOGzVEnR2.jpg" data-width="732" data-height="917" target="_blank"><img src="https://www.techpowerup.com/img/cowP9FxkOGzVEnR2_thm.jpg" width="104" height="130" alt="" /></a></div>
ASUS Intros ROG Strix PCIe Riser Cable
Quite a few cases have a pair of vertical expansion slots that let you show off your graphics card through the glass side-panel, but don't include a PCIe riser cable. ASUS swooped in with a solution, the ROG Strix Riser Cable. Possibly the first ROG Strix product in years without any RGB LED illumination, the Riser features of a thick base plate that doubles up as PCB, with a metal reinforced PCI-Express x16 slot, dubbed Safe Slot. ASUS uses this slot in many of its premium ROG-branded motherboards. It offers up to 1.8x shearing force endurance compared to a traditional unshielded plastic slot. The baseplate is connected to a thick ribbon cable with rubber outer insulation, which connects to the PCIe x16 gold fingers. ASUS did not mention the length of the cable, but states the total dimensions of the accessory as 240 mm x 127 mm x 10 mm (LxWxH), so the cable should probably be 18-20 cm in length, if not more. The company didn't reveal pricing or availability information.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KTLQ1w1XQvAKwf2p.jpg" data-width="1004" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/KTLQ1w1XQvAKwf2p_thm.jpg" width="136" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cI6x7nGyIGyvJXpl.jpg" data-width="1040" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/cI6x7nGyIGyvJXpl_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/f1tt9dDLeGX4flxU.jpg" data-width="1455" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/f1tt9dDLeGX4flxU_thm.jpg" width="197" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eqAOwJ5sgBIvp5SF.jpg" data-width="1006" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/eqAOwJ5sgBIvp5SF_thm.jpg" width="136" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kBxEehVJJGiWMtCR.jpg" data-width="1336" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/kBxEehVJJGiWMtCR_thm.jpg" width="181" height="130" alt="" /></a></div>
Can I Interest You in Single Player Experiences? Respawn's Jedi: Fallen Order is EA's Fastest-Selling Star Wars Game Ever
There has always been something to be said about single-player experiences - most players just seem to prefer a strong single-player game to full-on multiplayer games. EA, LucasArts and Respawn Entertainment have now come out of the woodwork regarding the latest Star Wars release in the form of Star Wars Jedi: Fallen order, and it seems the game is shipping in no small amounts worldwide. The partners announced that this game has cemented itself as the fastest-selling digital launch for a Star Wars game in its first two weeks. And concurrently, EA has said this is the fastest selling PC-game for the company (in all distribution formats) in these same two weeks.<br />
<br />
Of course, one needs to remember that fastest, highest-selling doesn't automatically make the game the most grossing Star Wars release. It's likely that Star Wars games with a more multiplayer-focused DNA (such as Battlefront I and Battlefront II from DICE) will gross more in their lifetime than Star Wars Jedi: Fallen Order ever will. That said, it goes to show what an original storytelling experience set in a beloved franchise can achieve. Read on after the break for the comments from all developing parties.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/sIRf9Sh9TmL123aC.jpg" data-width="900" data-height="1275" target="_blank"><img src="https://www.techpowerup.com/img/sIRf9Sh9TmL123aC_thm.jpg" width="92" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gS2lZjmfSPkZ7DAU.jpg" data-width="1214" data-height="933" target="_blank"><img src="https://www.techpowerup.com/img/gS2lZjmfSPkZ7DAU_thm.jpg" width="169" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vth7WbuRX3iVRDy0.jpg" data-width="1200" data-height="676" target="_blank"><img src="https://www.techpowerup.com/img/vth7WbuRX3iVRDy0_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/261549/can-i-interest-you-in-single-player-experiences-respawns-jedi-fallen-order-is-eas-fastest-selling-star-wars-game-ever">Read full story</a></div>
CD Projekt Red Says Cyberpunk 2077 to Have Shorter Main Story Than The Witcher 3, More Complex Sidequest System
A Reddit user reported on a recent CD Projekt Red community event held in Warsaw, where the developer of the highly expected Cyberpunk 2077 (and highly acclaimed The Witcher 3) expanded on their latest cyberpunk game's story. According to CD Projekt Red, Cyberpunk 2077 will have a shorter main storyline than that of The Witcher 3, albeit its sidequests will be much more complex and impactful regarding the entire experience. With the Witcher 3 and its numerous sidequests taking north of 120 hours to fully complete (at least at this editor's pace), this might still place the game's playtime above that of The Witcher 3, depending on the number and complexity of said sidequests.<br />
<br />
According to the user, CD Projekt Red in the community event said that The Witcher 3 sidequests were designed as branching events from the main storyline, which would then, sometimes, make it back onto the main storyline with some repercussions. However, Cyberpunk 2077 sidequests are being developed so as to then enable more of them to be generated upon completion, depending on choices made during that slight deviation from the main story, with most of them having some kind of impact on one another.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JCJScuuQKifjMbiw.jpg" data-width="750" data-height="445" target="_blank"><img src="https://www.techpowerup.com/img/JCJScuuQKifjMbiw_thm.jpg" width="219" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4NoA1cPQIHBjajLx.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/4NoA1cPQIHBjajLx_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/261543/cd-projekt-red-says-cyberpunk-2077-to-have-shorter-main-story-than-the-witcher-3-more-complex-sidequest-system">Read full story</a></div>
TechPowerUp NVCleanstall v1.2.0 Released
TechPowerUp today released the latest version of NVCleanstall, our free lightweight utility that gives you greater control over your NVIDIA GeForce driver installation, by letting you select from a more detailed list of components to install than the NVIDIA installer. You can prevent installation of components you don't need, such as telemetry. With version 1.2.0, we've improved in three key areas. To begin with, the driver version selection page loads faster, and consumes 95 percent less bandwidth. <br />
<br />
NVCleanstall v1.2.0 also introduces two new features. The first one is the ability to periodically check for driver updates. By default, this feature is turned off — you opt to enable it. When enabled, you can tell the app just how frequently you want it to check for updates. It's optimized to generate as little Internet traffic as possible (800 bytes per check), it does not permanently run in the background, and thus has no additional CPU or memory footprint. No information is transmitted when checking for driver updates. The app merely looks up what's the latest driver version on our server, and if it's newer than what you have, a notification pops up. This notification gives you the option to download and install it, seek more details (change-log), or choose to skip the version altogether. Lastly, we've added a feature that looks for updates to NVCleanstall itself, to ensure you're always up-to-date. Grab NVCleanstall from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/techpowerup-nvcleanstall/" target="_blank">TechPowerUp NVCleanstall 1.2.0</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/5JXQRIYOQq8Vh5PD.jpg" data-width="572" data-height="677" target="_blank"><img src="https://www.techpowerup.com/img/5JXQRIYOQq8Vh5PD_thm.jpg" width="110" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/h64Hm3Qw6QkesjyU.jpg" data-width="555" data-height="457" target="_blank"><img src="https://www.techpowerup.com/img/h64Hm3Qw6QkesjyU_thm.jpg" width="158" height="130" alt="" /></a> </div>The change-log follows.<div class="readmore"><a href="/261542/techpowerup-nvcleanstall-v1-2-0-released">Read full story</a></div>
Quake II RTX Updated with More Sharper Textures and Better Lighting Effects
NVIDIA today released a major update to Quake II RTX that add even more eye-candy to the game, leveraging RTX. Quake II RTX, promoted by NVIDIA, is a playable tech-demo for its RTX real-time ray-tracing technology that's based on a classic 3D game so it runs on nearly all DXR-compatible graphics cards (GeForce GTX 10-series, 16-series, and RTX 20-series). It comes with id Software's shareware 1st episode content, although you can add your own licensed game data for the full game. <br />
<br />
With version 1.2, NVIDIA added support for a boatload of modern technology, beginning with support for dynamic resolution scaling. Much like watching online videos with resolution toggle set to "auto" (which adjusts resolution based on your Internet bandwidth), dynamic resolution scaling adjusts the rendering resolution of your game on the fly in pursuit of a frames-per-second target. NVIDIA also remastered several textures of the game, increasing texture detail. Over 400 textures have been redone by NVIDIA, adding detail. Support is added for multiple reflection/refraction bounces, which makes it possible to create a "hall of mirrors" effect. NVIDIA implemented light shafts or god rays throughout the game, including underwater light shafts. Light shafts also get reflected off certain metal or glass surfaces. NVIDIA also improved the AI denoiser for the game. Metal and glass surfaces are made to appear more photo-real thanks to denoiser improvements. Find many other technical changes in the official change-log below.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NGvc8UDZeKtuDPzD.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/NGvc8UDZeKtuDPzD_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XGipVWGD6OmNjo4I.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/XGipVWGD6OmNjo4I_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OFBJ1RlHQGnzXrCg.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/OFBJ1RlHQGnzXrCg_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dmsRr8fL2GKLkdR7.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/dmsRr8fL2GKLkdR7_thm.jpg" width="231" height="130" alt="" /></a> </div><b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/quake-ii-for-nvidia-rtx/" target="_blank">Quake II RTX v1.2</a><div class="readmore"><a href="/261541/quake-ii-rtx-updated-with-more-sharper-textures-and-better-lighting-effects">Read full story</a></div>
NVIDIA Releases GeForce 441.41 Game Ready Drivers
NVIDIA today released the latest version of GeForce software. Version 441.41 WHQL comes game-ready for "Halo: Reach," which includes performance optimization and bug fixes specific to the game. The drivers also include optimization for "Quake II RTX v1.2" update, which includes higher-resolution textures and more lighting content. With GeForce 441.41, NVIDIA has also added OpenGL and Vulkan API support for Image Sharpening. With this, NVIDIA's implementation of Image Sharpening beats AMD's by supporting two APIs AMD doesn't yet: DirectX 11 and OpenGL. Both AMD and NVIDIA support DirectX 9, DirectX 12, and Vulkan. <br />
<br />
GeForce 441.41 also address a handful bugs, beginning with "Red Dead Redemption 2." A bug has been fixed, which was causing RDR2 benchmark to crash on systems with SLI playing the game with its Vulkan renderer. Another bug that caused stalling on machines with certain 4-core and 6-core CPUs has been fixed. A "Shadow of the Tomb Raider" game crash at startup in DirectX 12 mode has been fixed. Also fixed is a "low streaming bandwidth" error in "Forza Horizon 4" after extended periods of gameplay. Grab the driver from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/" target="_blank">NVIDIA GeForce 441.41 WHQL</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/1umgh83jLGUjlvCZ.jpg" data-width="1200" data-height="800" target="_blank"><img src="https://www.techpowerup.com/img/1umgh83jLGUjlvCZ_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="/261539/nvidia-releases-geforce-441-41-game-ready-drivers">Read full story</a></div>
(PR) MediaTek Announces Dimensity & Dimensity 1000 5G SoC
MediaTek today unveiled Dimensity, MediaTek's family of powerful 5G system-on-chips (SoCs) offering an unrivaled combination of connectivity, multimedia, AI and imaging innovations for premium and flagship smartphones.<br />
<br />
The MediaTek Dimensity 5G chipset family brings smart and fast together to power the world's most capable 5G devices. Dimensity represents a step toward a new era of mobility - the fifth dimension - to spur industry innovation and let consumers unlock the possibilities of 5G connectivity.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Yrjplq8Yc991SMer.jpg" data-width="678" data-height="509" target="_blank"><img src="https://www.techpowerup.com/img/Yrjplq8Yc991SMer_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="/261538/mediatek-announces-dimensity-dimensity-1000-5g-soc">Read full story</a></div>
(PR) SilentiumPC Announces Fortis 3 RGB HE1425 CPU Cooler
The European cooling and PC Case brand SilentiumPC presents the improved version of its Fortis 3 CPU cooler. For the Fortis 3 RGB HE1425, SilentiumPC has applied nickel-plating of the whole heat sink, which on the one hand visually enhances the tower cooler and on the other hand protects the material from corrosion. The tower cooler is also equipped with the brand-new Stella HP RGB 140 mm SE PWM fan, which not only enables modern RGB lighting, but is also more powerful at the same time. SilentiumPC is able to enrich the market with an improved and powerful tower cooler, which is particularly suitable for PC upgrades as well as new PC systems with modern RGB lighting.<br />
<br />
In the course of the modernization of the Fortis 3, SilentiumPC gives the Fortis 3 RGB a finishing touch. The difference to the predecessor model can be seen right away, due to the fact that the Fortis 3 RGB has all copper elements as well as the aluminium fins carefully nickel-plated. This gives the tower cooler a uniform, high-quality look and protects the material from corrosion. The black coated top plate features covers for the heatpipe end pieces and the embossed SilentiumPC logo. Thanks to the five 6 mm copper heat pipes that form the base plate contact surface on the Fortis 3 RGB and the large cooling surface, the tower cooler is capable of effectively cooling modern high-end processors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/WRrH1mIbDAiL2unY.jpg" data-width="824" data-height="806" target="_blank"><img src="https://www.techpowerup.com/img/WRrH1mIbDAiL2unY_thm.jpg" width="133" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xOXWhNRZWKZJzwWt.jpg" data-width="1000" data-height="898" target="_blank"><img src="https://www.techpowerup.com/img/xOXWhNRZWKZJzwWt_thm.jpg" width="145" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/M4zee44XwkRyZaW1.jpg" data-width="828" data-height="732" target="_blank"><img src="https://www.techpowerup.com/img/M4zee44XwkRyZaW1_thm.jpg" width="147" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/oHFCBXPrbQjg3l07.jpg" data-width="774" data-height="754" target="_blank"><img src="https://www.techpowerup.com/img/oHFCBXPrbQjg3l07_thm.jpg" width="133" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IhhprU5ZxVA7CwId.jpg" data-width="860" data-height="858" target="_blank"><img src="https://www.techpowerup.com/img/IhhprU5ZxVA7CwId_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/261531/silentiumpc-announces-fortis-3-rgb-he1425-cpu-cooler">Read full story</a></div>
(PR) ASUS Announces ZenWiFi Mesh Kit
ASUS today announced ZenWiFi, a new series of mesh WiFi systems that deliver extremely fast and reliable whole-home WiFi and offer easy, flexible and powerful configurability. ASUS Zen series products are known for their balance of premium design and ultimate performance, and ZenWiFi continues this tradition with a beautiful, low-profile design that blends perfectly with any décor and ultrafast, seamless and WiFi coverage for the entire home. The ZenWiFi series offers two models: ZenWiFi AX with the latest WiFi 6 (802.11ax) and ZenWiFi AC with WiFi 5 (802.11ac).<br />
<br />
The ZenWiFi system offers an intuitive setup process with upgraded AiMesh technology that makes getting a whole-home mesh network up and running fast and easy. For users who prefer more hands-on control, ZenWiFi offers advanced configuration options that lets them fine-tune every aspect of their network. To ensure a safe and enjoyable home-networking experience, ZenWiFi also comes with AiProtection Pro, built-in network security with free lifetime signature updates from Trend Micro for ongoing protection. AiProtection also includes advanced parental controls to keep kids safe online.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/WunT5bysjVQavuvR.jpg" data-width="640" data-height="431" target="_blank"><img src="https://www.techpowerup.com/img/WunT5bysjVQavuvR_thm.jpg" width="193" height="130" alt="" /></a> </div><div class="readmore"><a href="/261527/asus-announces-zenwifi-mesh-kit">Read full story</a></div>
NVIDIA Unveils Tesla V100s Compute Accelerator
NVIDIA updated its compute accelerator product stack with the new Tesla V100s. Available only in the PCIe add-in card (AIC) form-factor for now, the V100s is positioned above the V100 PCIe, and is equipped with faster memory, besides a few silicon-level changes (possibly higher clock-speeds), to facilitate significant increases in throughput. To begin with, the V100s is equipped with 32 GB of HBM2 memory across a 4096-bit memory interface, with higher 553 MHz (1106 MHz effective) memory clock, compared to the 876 MHz memory clock of the V100. This yields a memory bandwidth of roughly 1,134 GB/s compared to 900 GB/s of the V100 PCIe. <br />
<br />
NVIDIA did not detail changes to the GPU's core clock-speed, but mentioned the performance throughput numbers on offer: 8.2 TFLOP/s double-precision floating-point performance versus 7 TFLOP/s on the original V100 PCIe; 16.4 TFLOP/s single-precision compared to 14 TFLOP/s on the V100 PCIe; and 130 TFLOP/s deep-learning ops versus 112 TFLOP/s on the V100 PCIe. Company-rated power figures remain unchanged at 250 W typical board power. The company didn't reveal pricing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/USl0XH2KEszlEMD9.jpg" data-width="980" data-height="654" target="_blank"><img src="https://www.techpowerup.com/img/USl0XH2KEszlEMD9_thm.jpg" width="195" height="130" alt="" /></a></div>
Intel Launches SSD 665p "Neptune Harbor Refresh" Line of M.2 NVMe SSDs
Intel late Monday released its SSD 665p "Neptune Harbor Refresh" line of client-segment M.2 NVMe SSDs. The series was announced in September at the company's Storage Day event in South Korea. Built in the M.2-2280 form-factor, the drives feature PCI-Express 3.0 x4 host interface. They combine a Silicon Motion SMI2263 series controller with Intel's new 96-layer 3D QLC NAND flash memory. The previous-generation SSD 660p series use 64-layer chips. The SMI2263 controller is cushioned by an LPDDR3 DRAM cache.<br />
<br />
Intel is debuting the SSD 665p series with just two models, 1 TB and 2 TB, skipping sub-terabyte capacities such as 500 GB. The 2 TB variant offers sequential transfer speeds of up to 2000 MB/s reads and up to 2000 MB/s writes; and random access speeds of up to 250,000 IOPS on both reads and writes. The 1 TB variant offers up to 2000 MB/s sequential reads, up to 1925 MB/s sequential writes, up to 160,000 IOPS random reads, and up to 200,000 IOPS random writes. The company didn't reveal endurance ratings for the drives. The 1 TB variant is priced at USD $125, while the 2 TB variant hasn't yet been priced. Both drives are backed by 5-year warranties.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XW7A0q3WeqFUyCTZ.jpg" data-width="1623" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/XW7A0q3WeqFUyCTZ_thm.jpg" width="220" height="130" alt="" /></a></div>
(PR) FinalWire Announces AIDA64 v6.20 with AMD Renoir and RX 5500 Support
FinalWire Ltd. today announced the immediate availability of AIDA64 Extreme 6.20 software, a streamlined diagnostic and benchmarking tool for home users; the immediate availability of AIDA64 Engineer 6.20 software, a professional diagnostic and benchmarking solution for corporate IT technicians and engineers; the immediate availability of AIDA64 Business 6.20 software, an essential network management solution for small and medium scale enterprises; and the immediate availability of AIDA64 Network Audit 6.20 software, a dedicated network audit toolset to collect and manage corporate network inventories.<br />
<br />
The latest AIDA64 update introduces optimized benchmarks for AMD Renoir and Intel Ice Lake processors, monitoring of sensor values on EVGA Z10 RGB displays, and supports the latest AMD and Intel CPU platforms as well as the new graphics and GPGPU computing technologies by both AMD and NVIDIA.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kB6Rx1SzUZnMLY83.jpg" data-width="955" data-height="696" target="_blank"><img src="https://www.techpowerup.com/img/kB6Rx1SzUZnMLY83_thm.jpg" width="178" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7i9ctylXfenHcpmp.jpg" data-width="847" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/7i9ctylXfenHcpmp_thm.jpg" width="115" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NpVzNcTRZ6X5SN8k.jpg" data-width="847" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/NpVzNcTRZ6X5SN8k_thm.jpg" width="115" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VYqs27SZVvq4Zfxs.jpg" data-width="847" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/VYqs27SZVvq4Zfxs_thm.jpg" width="115" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XCaFGWeLwdAVsdZP.jpg" data-width="847" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/XCaFGWeLwdAVsdZP_thm.jpg" width="115" height="130" alt="" /></a> </div><b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/aida64-extreme/" target="_blank">FinalWire AIDA64 Extreme v6.20</a><div class="readmore"><a href="/261508/finalwire-announces-aida64-v6-20-with-amd-renoir-and-rx-5500-support">Read full story</a></div>
NVIDIA to Open G-Sync Monitors to VRR Support, Enabling AMD Graphics Cards Support
In the wars of variable refresh rates, much ink has already been spilled regarding the open, AMD FreeSync approach and NVIDIA's proprietary G-Sync modules. The war started to give its first signs of abatement once NVIDIA seemed to throw in the towel by officially supporting VESA's VRR (Variable Refresh Rate) technology on its graphics cards, basically opening the way for NVIDIA graphics cards to correctly operate with previously AMD FreeSync-branded monitors. Now, it seems one more step will be taken on that road which should be G-Sync's proprietary approach final whiff, since according to a report from TFT Central, confirmed by NVIDIA, the company will enable VRR support for next releases of monitors equipped with the company's G-Sync module. This will essentially enable AMD graphics cards to work with NVIDIA-branded G-Sync monitors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/G2sMmnD5qUHlwyNG.jpg" data-width="640" data-height="360" target="_blank"><img src="https://www.techpowerup.com/img/G2sMmnD5qUHlwyNG_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/261494/nvidia-to-open-g-sync-monitors-to-vrr-support-enabling-amd-graphics-cards-support">Read full story</a></div>
(PR) G.SKILL Announces New High-Performance, Ultra-Capacity DDR4 Memory Kits for HEDT Platforms
G.SKILL, the world's leading manufacturer of extreme performance memory and gaming peripherals, is pleased to announce the release of new high-performance and high-capacity quad-channel memory kits for the latest Intel X299 and AMD TRX40 high-end desktop (HEDT) platforms, including the high-capacity DDR4-3600 CL16-19-19-39 256 GB (32 GB x8), DDR4-4000 CL18-22-22-42 256 GB (32 GB x8), and the high-speed, low-latency DDR4-4000 CL15-16-16-36 64 GB (8 GB x8) specifications. By bringing ultra-high 32 GB memory module capacity into the realm of HEDT computing, powerful workstations are now truly able to achieve a complete combination of high core count processor with high-speed, high-capacity memory for heavy workloads or for running more virtual machines than ever.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JXqMCCTsX09Au2su.jpg" data-width="1000" data-height="750" target="_blank"><img src="https://www.techpowerup.com/img/JXqMCCTsX09Au2su_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="/261489/g-skill-announces-new-high-performance-ultra-capacity-ddr4-memory-kits-for-hedt-platforms">Read full story</a></div>
(PR) Club 3D Announces Next Generation Multi Stream Transport (MST) Hubs
Club 3D is proud to announce its next generation Multi Stream Transport (MST) Hub models CSV-7300 (DisplayPort 1.4 Triple Monitor 4K60Hz) and CSV-1550 (USB Type C 3.2 Gen 1 DisplayPort 1.4 Triple Monitor 4K60Hz) which will be available in the market from beginning of December.<br />
<br />
Since Multi-Monitor-Solutions are part of Club 3D's DNA for many years, we have taken the time to develop the best available solutions with those two new MST Hubs. They both can provide 2x 4K60Hz when the source device is not supporting DSC 1.2 (Display Stream Compression). In case the source device supports DSC 1.2 all three outputs can deliver 4K60Hz. Detailed Display/Resolution charts can be found in the respective specification sheet.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/aQbZ6KUCTBZ0cisU.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/aQbZ6KUCTBZ0cisU_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/261488/club-3d-announces-next-generation-multi-stream-transport-mst-hubs">Read full story</a></div>
(PR) CORSAIR Offers a Range of High-Performance Components for 3rd Gen AMD Ryzen Threadripper Builds
CORSAIR, a world leader in PC gaming peripherals and enthusiast components, today announced a range of products including liquid CPU coolers, high-frequency DRAM, and efficient power supplies fully tested and validated for compatibility with the new 3rd Generation AMD Ryzen Threadripper high-end desktop processors. With the highest core and thread count on the HEDT market, combined with the lightning-fast PCI-Express 4.0 platform, AMD's most powerful desktop processor can create, composite, render, encode, and deliver with unprecedented multitasking power - and CORSAIR is ready with the widest range of guaranteed-compatible products to help get the best performance out of a new Ryzen Threadripper-based PC.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Y5Plzu1hdXoLNban.jpg" data-width="624" data-height="481" target="_blank"><img src="https://www.techpowerup.com/img/Y5Plzu1hdXoLNban_thm.jpg" width="169" height="130" alt="" /></a> </div><div class="readmore"><a href="/261485/corsair-offers-a-range-of-high-performance-components-for-3rd-gen-amd-ryzen-threadripper-builds">Read full story</a></div>
(PR) EK Waterblocks Partners With InWin, Announce EK-Classic InWin 303
EK Water Blocks, the Europe-based water cooling gear manufacturer, is proud to announce the launch of a product which is a result of a successful collaboration between EK and InWin, the renowned case manufacturer. The product belongs to the EK Classic Line of products, hence the full name of the product is EK-Classic InWin 303EK - Black.<br />
<br />
<b>EK-Classic InWin 303EK</b><br />
The EK-Classic InWin 303EK case is a unique version of the popular In Win 303 case. It features an integrated distribution plate and this makes it really special as there is no similar product on the market. This is the only mass-produced case that is specifically re-designed and modified to seamlessly integrate the coolant distribution plate equipped with a powerful DDC pump. The 303 is one of InWin's most popular cases which has been on the market for quite a while now. It is a tested, market-proven case with interesting fan and radiator layout options. The 303EK version brings this a new level, wherewith the purchase of the case, the customer will get a fully integrated coolant reservoir and a pump in the form of a distribution plate.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dfOfraHLyIFL2fXp.jpg" data-width="1500" data-height="626" target="_blank"><img src="https://www.techpowerup.com/img/dfOfraHLyIFL2fXp_thm.jpg" width="312" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dyTJLlwFALk6RGVe.jpg" data-width="1500" data-height="686" target="_blank"><img src="https://www.techpowerup.com/img/dyTJLlwFALk6RGVe_thm.jpg" width="284" height="130" alt="" /></a> </div><div class="readmore"><a href="/261484/ek-waterblocks-partners-with-inwin-announce-ek-classic-inwin-303ek-chassis">Read full story</a></div>
(PR) HyperX Now Shipping Alloy Origins Core Tenkeyless RGB Mechanical Gaming Keyboard
HyperX, the gaming division of Kingston Technology Company, Inc., today introduced a new addition to its award-winning lineup of gaming keyboards - HyperX Alloy Origins Core. Featuring HyperX Red mechanical switches, the new keyboard is built for performance and longevity with a shorter actuation point and 80 million click rating.<br />
<br />
Alloy Origins Core maximizes desktop real estate with a space-saving tenkeyless layout for ultimate mouse movement. The keyboard features RGB exposed backlit keys for brighter illumination with radiant lighting effects and five adjustable brightness levels to enhance gaming, day or night. For added durability, stability and flexibility, Alloy Origins Core is built with a full aircraft-grade aluminium body and the USB Type-C to USB Type-A keyboard cable is detachable.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UI0GOsu7rBW2wLjU.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/UI0GOsu7rBW2wLjU_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3SZykSTcstPZ82vW.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/3SZykSTcstPZ82vW_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lU1ZukyFsMA34730.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/lU1ZukyFsMA34730_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/261482/hyperx-now-shipping-alloy-origins-core-tenkeyless-rgb-mechanical-gaming-keyboard">Read full story</a></div>
Steam Reveals Its Top Sellers for 2019
Steam has revealed the games that sold the most on the platform for this year of 2019. While Steam's own numbers don't represent the entirety of the PC market - considering other digital storefronts such as GOG, EPIC Games Store and publisher-exclusive stores like Origin also have a relevant market share - this does let us take a considered peek at the PC gaming landscape. Steam's top sellers also includes top grossing, where games that have store-bound skins or extras are also taken into account).<br />
<br />
Steam's Platinum lineup includes all the hallmarks of PC gaming: online experiences such as Warframe, DOTA 2, PUBG, and the Elder Scrolls Online, through strategy experiences such as Civilization VI and Total War: Three Kingdoms. Considering that Destiny 2 also made it in the platform, many gamers actually enjoy that experience - it is unclear if Steam considers every redeem from the Blizzard store into the Steam Store a sale, but if not, it's mighty impressive that a game that released on October 1st.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Xm1NQEd1YV1VgBJl.jpg" data-width="1040" data-height="814" target="_blank"><img src="https://www.techpowerup.com/img/Xm1NQEd1YV1VgBJl_thm.jpg" width="166" height="130" alt="" /></a> </div><div class="readmore"><a href="/262416/steam-reveals-its-top-sellers-for-2019">Read full story</a></div>
Intel DG1 Discrete GPU Shows Up with 96 Execution Units
As we are approaching the year 2020, when Intel is rumored to launch its discrete graphics cards to the hand of consumers around the world, we are gearing up on the number of leaks about the upcoming products. Thanks to Twitter user @KOMACHI_ENSAKA, who found the latest EEC listing, we have new information regarding Intel's upcoming DG1 discrete graphics solution. <br />
<br />
In the leaked EEC listing, the DG1 GPU is being presented as a GPU with 96 execution units, meaning that Intel is planning to take on entry-level graphics cards with this GPU. If the graphics unit is following the same design principle of the previous-generation GPUs, then there should be around 8 shading units per one execution unit, totaling 768 shading units for the whole DG1 GPU. If the 12th Gen Xe design inside the DG1 follows a different approach, then we can expect to see a double amount of shading units, meaning 1536 in total.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3rot4qii7XXBdUo7.jpg" data-width="1545" data-height="682" target="_blank"><img src="https://www.techpowerup.com/img/3rot4qii7XXBdUo7_thm.jpg" width="295" height="130" alt="" /></a><br />
</div><div class="readmore"><a href="/262404/intel-dg1-discrete-gpu-shows-up-with-96-execution-units">Read full story</a></div>
MSI Teases Evoke Line of Notebooks for Creators
MSI debuted the Evoke brand of hardware targeted at creators, with its Radeon RX 5700-series Evoke graphics cards. The company is now planning to extend the brand to a range of other products, beginning with notebooks. The company teased the design of what's allegedly the first Evoke branded notebook, which ships with a minimalist and durable design, and hardware tailored for content-creation applications. The company didn't tease its specs, but you can expect anything from Intel's 10th gen "Comet Lake-H" to AMD's Ryzen 4000 "Renoir" processors, and discrete graphics options that include RX 5500M "Navi" or even Max-Q RTX 20-series. Some of the higher trims could even leverage fast NVMe storage. MSI is expected to launch its Evolve notebooks on 7th January, 2020.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/B1pVbGkLJk5m2Jbw.jpg" data-width="1200" data-height="675" target="_blank"><img src="https://www.techpowerup.com/img/B1pVbGkLJk5m2Jbw_thm.jpg" width="231" height="130" alt="" /></a></div>
Intel LGA1200 Socket Sketched, Appears Cooler-compatible with LGA115x
Intel's upcoming LGA1200 mainstream desktop socket (aka socket H5), appears to be cooler-compatible with older LGA115x sockets. This would mean any CPU cooler compatible with sockets LGA1156, LGA1155, LGA1150, and LGA1151, should be mechanically compatible with LGA1200. You'd still need to ensure the cooler has enough thermal capacity to cool some of the higher TDP SKUs such as the range-topping Core i9-10900K. <br />
<br />
Comparative mechanical drawings of LGA1200 and LGA1151 were posted by momomo_us and eUUUK50, which show the LGA1200 package to have the same dimensions as the older socket. A picture of the land-grid of an LGA1200 package also leaked to the web, showing how Intel utilized empty bits of the fiberglass substrate to cram in the additional 49 pins, without changing the size of the contacts. The LGA1200 socket debuts with Intel's 10th generation Core "Comet Lake" desktop processors and motherboards based on the company's 400-series chipsets. Intel is expected to launch these processors by Q2-2020.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/bjf1hHifrO0m24R9.jpg" data-width="1155" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/bjf1hHifrO0m24R9_thm.jpg" width="156" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lkuQtpVMfRCkyfib.jpg" data-width="528" data-height="524" target="_blank"><img src="https://www.techpowerup.com/img/lkuQtpVMfRCkyfib_thm.jpg" width="131" height="130" alt="" /></a></div>
(PR) MONTECH Releases New Fighter 400 and Fighter 600 Budget Gaming Cases
Montech, a new enthusiast PC Case, Power and Cooling solutions brand based in Taiwan introduces their new Fighter 400 and Fighter 600 line of competitively priced gaming cases. Both mid-tower ATX cases come with tempered glass side panels. The Fighter 400 comes with a pre-installed 120 mm Blue LED rear fan, while the Fighter 600 comes 3 front 1 rear 120 mm Rainbow LED fans. <br />
<br />
Aimed at the highly competitive budget gaming case range, both the Fighter 400 and Fighter 600 comes with all the bells and whistles of higher end alternatives. Both cases comes with full Tempered Glass side panels to show off your RGB peripherals, not to mention both cases comes with pre-installed 120 mm LED fans! For the Fighter 400 you get a 120 mm blue LED rear fan and with the Fighter 400 you get a total of 4 120 mm Rainbow LED fans. Designed for maximum airflow and performance, both cases include top and bottom dust filters to keep cooling and also dust in check. Industry standard front USB 3.0/2.0 I/O ports are also present, as well as a shielded PSU compartment, cable management ports, support for 120/240 mm radiators on the Fighter 600 and 120/240/280/360 mm radiators on the Fighter 400.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/W01x0O1Jb5TyXD31.jpg" data-width="629" data-height="640" target="_blank"><img src="https://www.techpowerup.com/img/W01x0O1Jb5TyXD31_thm.jpg" width="128" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ttg6iZROPTO14kQ4.jpg" data-width="715" data-height="629" target="_blank"><img src="https://www.techpowerup.com/img/ttg6iZROPTO14kQ4_thm.jpg" width="148" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wrV5vbsoSWll4ILj.jpg" data-width="722" data-height="629" target="_blank"><img src="https://www.techpowerup.com/img/wrV5vbsoSWll4ILj_thm.jpg" width="149" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KGd5Cim1rAmz0OkZ.jpg" data-width="686" data-height="683" target="_blank"><img src="https://www.techpowerup.com/img/KGd5Cim1rAmz0OkZ_thm.jpg" width="131" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PWxc8uXlurW9r4Es.jpg" data-width="744" data-height="683" target="_blank"><img src="https://www.techpowerup.com/img/PWxc8uXlurW9r4Es_thm.jpg" width="142" height="130" alt="" /></a> </div><div class="readmore"><a href="/262401/montech-releases-new-fighter-400-and-fighter-600-budget-gaming-cases">Read full story</a></div>
TechPowerUp Wishes You a Merry Christmas and a Happy New Year!
We at TechPowerUp wish you and your family a Merry Christmas! We thank you from the bottom of our hearts to help us make 2019 a phenomenal year in the tech world, with the introduction of new computing platforms that set the direction in which the industry will grow in the next decade. Our content teams have kept you on the forefront with lightning fast news and in-depth product reviews. As we begin to turn the page in our calendars, we wish you an equally fruitful New Year, and the beginning of a prosperous new decade. Don't forget to tell us what you found under your tree!
ADATA to Expand its Product Offerings to Monitors, Laptops and Gaming PCs
ADATA is a company currently selling only memory solutions like SSDs and DRAM, however, the company now wants to try something different in 2020. For starters, ADATA wants to launch more products that will be a part of its Xtreme Performance Gear lineup called XPG shortly. XPG will start offering new products like monitors, laptops, gaming PCs and PC cases with a goal of capturing new market share and try to establish itself as a strong brand of PC gaming products. The new lineup will get revealed with more details at CES 2020, however, we have information of what the new lineup contains.<br />
<br />
For starters, XPG will begin with a laptop called Xenia 15, a 15.6-inch gaming laptop with 1080p IPS display and 9th gen Intel core i9 CPU. Next up the chain is a gaming PC called XPG Gaia - 5 liters mini PC with one PCIe slot for a graphics card that's up to 8-inches long. In addition, XPG will showcase a new monitor called Photon equipped with a 27-inch panel that features PixelDisplay's Vivid Color Eye-Safe Display technology which is essentially a technique for blocking out blue light. There is also going to be a new case called XPG Volta, a cylindrical case made out of premium materials such as tempered glass and metal. It is supposed to fit up to E-ATX motherboard and have plenty of room for water-cooling setups. Last but not least, XPG will have two concepts of RGB DDR4 memory modules, with both of them having speeds of up to 4800 MHz and having capacity of up to 32 GB per DIMM.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/drzWl7C98JRpI34Q.jpg" data-width="911" data-height="554" target="_blank"><img src="https://www.techpowerup.com/img/drzWl7C98JRpI34Q_thm.jpg" width="214" height="130" alt="" /></a></div>
GoodOffer24 Warms Up Your Christmas with Bright Deals on Genuine Software
It's not too late to stock up on gifts, especially if they're delivered lighting-fast, electronically. GoodOffer24 brightens up your Christmas with deep discounts on genuine, globally-valid Windows 10 and Office software, letting you and your friends upgrade your Windows 7 PCs to the latest operating system, or replace Office 365 subscriptions with lifetime licenses to full-featured Office 2019. Bag unbelievable deals such as Office 2019 Professional Plus for USD $42.56, and Windows 10 Pro for $10.62, upon applying TechPowerUp-exclusive discount codes. Save even more when you bundle your favorite Windows 10 edition with Office 2016 or 2019 editions. Check out other deals below that are sure to sweeten up your Holiday!<br />
<br />
Apply the discount code <b>JCM30</b> at checkout on the following products to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-professional-cd-key-32-64-bit.html?acc=651" target="_blank">Buy Windows 10 Pro for $10.62</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-enterprise-2019-ltsc.html?acc=651" target="_blank">Buy Windows 10 Enterprise LTSC for $12.40</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-professional-cd-key-32-64-bit-2-pc.html?acc=651" target="_blank">Buy Windows 10 Pro twin-pack for $18.20</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-home-32-64-bit.html?acc=651" target="_blank">Buy Windows 10 Home for $11.08</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/microsoft-office-2016-pro-plus-cd-key.html?acc=651" target="_blank">Buy Office 2016 Professional Plus for $26.31</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/microsoft-office-2016-home-and-student.html?acc=651" target="_blank">Buy Office 2016 Home and Student for $22.34</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-office-2016-pro-bundle-key.html?acc=651" target="_blank">Buy Windows 10 Pro + Office 2016 Professional Bundle for $31.44</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-home-office-2016-pro-bundle.html?acc=651" target="_blank">Buy Windows 10 Home + Office 2016 Profesional Bundle for $29.79</a><br />
<br />
Apply the code <b>JCM40</b> on the following products to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.goodoffer24.com/software/microsoft-office-2019-professional-plus-cd-key-1pc.html?acc=651" target="_blank">Buy Office 2019 Professional Plus for $42.56</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-office-2019-pro-bundle.html?acc=651" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Bundle for $46.11</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-home-office-2019-pro-bundle.html?acc=651" target="_blank">Buy Windows 10 Home + Office 2019 Professional Bundle for $44.69</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/c2isQJshbg8JzbS5.jpg" data-width="728" data-height="360" target="_blank"><img src="https://www.techpowerup.com/img/c2isQJshbg8JzbS5_thm.jpg" width="263" height="130" alt="" /></a> </div><div class="readmore"><a href="/262362/goodoffer24-warms-up-your-christmas-with-bright-deals-on-genuine-software">Read full story</a></div>
(PR) Greenliant Announces EnduroSLC 2.5 Industrial Enterprise SSDs with 30DWPD for 5 Years
Greenliant is now sampling its SATA 2.5" EnduroSLC Industrial Enterprise EX Series solid state drives (SSDs) for primary storage applications that require ultra high endurance under extreme temperature conditions. Designed with Greenliant's EnduroSLC Technology, SATA 2.5" Industrial Enterprise EX Series SSDs provide ultra robust data retention and ultra high system-level lifetime endurance of 30 drive writes per day (DWPD) for 5 years.<br />
<br />
"Greenliant has brought its SLC NAND expertise to the enterprise with its new line of EnduroSLC Industrial Enterprise EX Series SSDs," said Xuanhui Li, Vice President of Business Development, Datacenter Products, Greenliant. "With high reliability and outstanding quality of service, Greenliant's industrial enterprise storage products are ideal for mission critical, I/O intensive applications in aerospace, defense, transportation, energy and power, communications and industrial control."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ZjqbdwqahqIGXt0U.jpg" data-width="662" data-height="541" target="_blank"><img src="https://www.techpowerup.com/img/ZjqbdwqahqIGXt0U_thm.jpg" width="159" height="130" alt="" /></a> </div><div class="readmore"><a href="/262360/greenliant-announces-enduroslc-2-5-industrial-enterprise-ssds-with-30dwpd-for-5-years">Read full story</a></div>
Deepcool Rolls Out GAMMAXX GTE V2 White CPU Cooler
To help with your snow-themed builds on a budget, Deepcool rolled out a [mostly] white variant of its GAMMAXX GTE V2 tower-type CPU cooler. The GTE V2 White features a silvery-white top-plate that caps the aluminium fin-stack heatsink; white caps for the heat-pipes, while fan-frame and impeller, and a white LED illumination for the fan. The aluminium fins retain their typical chrome finish. <br />
<br />
The GAMMAXX GTE V2 features a tower-type aluminium fin-stack heatsink to which heat is conveyed by four 6 mm-thick copper heat pipes that make direct contact with the CPU at the base. The included 120 mm fan takes in 4-pin PWM input, spins between 500 to 1,650 RPM, pushing up to 64.5 CFM of air, with a maximum noise output of 27.8 dBA. The fan features a hydro bearing. Measuring 129 mm x 77 mm x 157.5 mm (WxDxH), including fan, the cooler weighs 650 g. Among the CPU socket types supported are AM4 and LGA115x. Expect the cooler to be priced at a tiny premium over the USD $30 price of the standard model.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YjCJixCTwzVMt449.jpg" data-width="992" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/YjCJixCTwzVMt449_thm.jpg" width="134" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hnO007zDHhkRgpjM.jpg" data-width="1280" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/hnO007zDHhkRgpjM_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JzXUEaH4dwSq8qAX.jpg" data-width="1056" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/JzXUEaH4dwSq8qAX_thm.jpg" width="143" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/V92SkvfbG2iwyT7V.jpg" data-width="1362" data-height="989" target="_blank"><img src="https://www.techpowerup.com/img/V92SkvfbG2iwyT7V_thm.jpg" width="179" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cE0lK8BWAlL9MKlJ.jpg" data-width="1011" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/cE0lK8BWAlL9MKlJ_thm.jpg" width="137" height="130" alt="" /></a></div>
(PR) Western Digital Samples World's First 20TB SMR and 18TB CMR Hard Drives
Western Digital announced that it has started shipping the industry's highest-capacity HDD samples to enterprise OEMs and hyperscale customers worldwide. The 20 TB Ultrastar DC HC650 SMR HDDs and 18 TB Ultrastar DC HC550 CMR HDDs, first previewed in June 2019, and announced in September 2019, feature its first-ever commercial implementation of energy-assisted magnetic recording technology on a nine-disk platform, enabling customers to more efficiently provision and scale their data center environments with unmatched total cost of ownership.<br />
<br />
With zettabyte-scale data growth, the need for higher-capacity data storage across a broad spectrum of applications and workloads can be reliably met only with high Capacity Enterprise HDDs. The industry-leading capacities of Western Digital's Ultrastar 20 TB SMR and 18 TB CMR HelioSeal HDDs enable customers to deploy up to 22 percent fewer racks and reduce their TCO by up to 11 percent, along with the corresponding reductions in power consumption, cooling costs, and data center infrastructure needs when compared with today's 14 TB CMR HDDs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/VmRcRtMDjNMWooKH.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/VmRcRtMDjNMWooKH_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qzK7nivBTP7OOO3Z.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/qzK7nivBTP7OOO3Z_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/262357/western-digital-samples-worlds-first-20tb-smr-and-18tb-cmr-hard-drives">Read full story</a></div>
China Cuts Import Tariffs on Some U.S. Tech, Could Impact Electronic G
China announced that it will reduce import tariffs on several U.S. commodities, including certain kinds of technology. This is a sign of easing tensions between the United States and China on its devastating trade-war waged between 2017-19 that wiped billions of Dollars of value from the capital markets and saw increases in prices of goods around the world. The exhaustive list of 859 commodities covers raw materials for a variety of polymers and plastics found in consumer durables, raw materials for energy storage devices, certain kinds of semiconductor manufacturing equipment, photo and video imaging equipment (camera components), LCD and OLED display components. There are hundreds of other commodities from other industries, covering food, industrial automation, and agriculture. <br />
<br />
The items on China's updated import tariffs list amounts to some USD $389 billion in annual trade, or about 18 percent of China's annual imports. The cuts in import tariffs are expected to not just benefit U.S. exporters to China, but also stimulate similar import tariff cuts from the U.S. in response. China has an insatiable appetite for camera equipment, and has eased imports of OLED and certain semiconductor manufacturing equipment, which could have a trickle-down effect on the tech industry. Find the complete schedule of goods with updated import tariffs <a rel="nofollow" href="http://gss.mof.gov.cn/gzdt/zhengcefabu/201912/P020191220564315355326.pdf" target="_blank">here</a>. We've machine translated relevant pages in the screenshots below.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/nMzaxK72GXLWygpQ.jpg" data-width="786" data-height="1090" target="_blank"><img src="https://www.techpowerup.com/img/nMzaxK72GXLWygpQ_thm.jpg" width="94" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ImmINtM9TLwYWjWl.jpg" data-width="759" data-height="1093" target="_blank"><img src="https://www.techpowerup.com/img/ImmINtM9TLwYWjWl_thm.jpg" width="90" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uVVPWJK5JjlinrRf.jpg" data-width="761" data-height="1107" target="_blank"><img src="https://www.techpowerup.com/img/uVVPWJK5JjlinrRf_thm.jpg" width="89" height="130" alt="" /></a></div>
AMD RX 5600 XT Poised to Offer Vega 56-like Performance, Possible Specs Rumored
AMD's upcoming RX 5600 XT will bring about a much needed power increase over the current baseline RX 5500 series, slotting smoothly between it and the mainstream, high-performance RX 5700 and RX 5700 XT. New benchmarks spotted by Videocardz place AMD's upcoming graphics card (which could feature a 6 GB VRAM with higher capacities likely to be offered as well) some 35% ahead of the RX 5500, as well as on the overall performance level of AMD's RX Vega 56. That AMD card debuted at $399 and now has performance 8% to 15% higher than NVIDIA's current GTX 1660 SUPER, exactly where AMD would want the RX 5600 XT's performance to land.<br />
<br />
Other details come courtesy of another publication, where Igor Wallosseck over at Igor's Lab says that AMD could be looking at harvesting the Navi 10 dies that power the company's RX 5700 XT and RX 5700 by disabling one of four Asynchronous Compute Engines (ACEs). These four ACEs are found two each on one of Navi's Shader Engines (SEs), and disabling one ACE and subordinate hardware from the full Navi 10's 40 RDNA Units, 2,560 Stream Processors (SPs), 160 texture mapping units (TMUs) and 64 render output units (ROPs) would make up for an RX 5600 XT with 30 RDNA CUs, 1,920 SPs, 120 TMUs, 48 ROPs and expected 3 MB of L2 cache. AMD could be looking to position the AMD RX 5600 XT in the $249 price range, since top tier RX 5500 XT tend to go for $200.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kfUKk2oOeycHXTRg.jpg" data-width="681" data-height="268" target="_blank"><img src="https://www.techpowerup.com/img/kfUKk2oOeycHXTRg_thm.jpg" width="330" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ByhCF6R63TzMu16g.jpg" data-width="675" data-height="269" target="_blank"><img src="https://www.techpowerup.com/img/ByhCF6R63TzMu16g_thm.jpg" width="326" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/saR8fkliUMUkI9QL.jpg" data-width="645" data-height="1200" target="_blank"><img src="https://www.techpowerup.com/img/saR8fkliUMUkI9QL_thm.jpg" width="70" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KfOMyizOO4M8gwPM.jpg" data-width="645" data-height="1200" target="_blank"><img src="https://www.techpowerup.com/img/KfOMyizOO4M8gwPM_thm.jpg" width="70" height="130" alt="" /></a></div>
(PR) G.SKILL Announces New Ultra Low-Latency DDR4 32GB-Module Kits
G.SKILL International Enterprise Co., Ltd., the world's leading manufacturer of extreme performance memory and gaming peripherals, is excited to announce an all-new high-capacity, low-latency DDR4-3200 CL14-18-18-38 memory kit specification based on 32 GB modules across the Trident Z RGB, Trident Z Royal, and Trident Z Neo series. Available in 256 GB (32GBx8), 128 GB (32GBx4), and 64 GB (32GBx2) kit capacities for quad-channel and dual-channel platforms, these new DDR4 memory specifications are built with the latest high-density 16Gb components and provide the perfect mix of extreme performance and high memory capacity.<br />
<br />
DDR4-3200 CL14 has always been the ultimate sweet spot for performance since the early days of DDR4 memory, and G.SKILL is now bringing the legendary high-performance efficiency to the latest 32 GB high-capacity DDR4 modules. Designed for the latest HEDT platforms with quad-channel support, the DDR4-3200 CL14-18-18-38 specification with 256 GB (32GBx8) memory kit capacity can be seen validated in the screenshots below with the new Intel Core i9-10900X processor on the ASUS ROG RAMPAGE VI EXTREME ENCORE motherboard and the Intel Core i9-10940X processor on the MSI Creator X299 motherboard.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JKHZjLzw6ZkzzvHB.jpg" data-width="1920" data-height="1040" target="_blank"><img src="https://www.techpowerup.com/img/JKHZjLzw6ZkzzvHB_thm.jpg" width="240" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IqT429rGFQjdeC9U.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/IqT429rGFQjdeC9U_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iHwoEKXHnzO9wIrz.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/iHwoEKXHnzO9wIrz_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xRAzOXSLsvRISZ1L.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/xRAzOXSLsvRISZ1L_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/262342/g-skill-announces-new-ultra-low-latency-ddr4-32gb-module-kits">Read full story</a></div>
AeroCool Intros Cylon 4F CPU Cooler
AeroCool late last week rolled out the Cylon 4F its mainstream tower-type CPU cooler. The Cylon 4F features a black anodized aluminium fin-stack to which heat is conveyed by four 6 mm-thick copper heat pipes that make direct contact with the CPU at the base. A plastic shroud covers the top of the fin-stack, and has an ARGB LED diffuser. This shroud extends into the 120 mm fan, featuring an ARGB element along the bore of the frame. The fan spins between 800 to 1,800 RPM, pushing 26.1 to 52.5 CFM of air, with noise output ranging between 14 to 26 dBA. AeroCool claims the Cylon 4F can handle thermal loads of up to 145 Watts. It measures 126.5 mm x 76 mm x 155 mm (WxDxH). Among the CPU socket types supported are AM4, LGA115x, and LGA2066. The company didn't reveal pricing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/T06IDuVTiOat39Gj.jpg" data-width="654" data-height="589" target="_blank"><img src="https://www.techpowerup.com/img/T06IDuVTiOat39Gj_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uwGHTKwkDPlEhuAz.jpg" data-width="638" data-height="589" target="_blank"><img src="https://www.techpowerup.com/img/uwGHTKwkDPlEhuAz_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WLEonAQ233OOFCU0.jpg" data-width="652" data-height="589" target="_blank"><img src="https://www.techpowerup.com/img/WLEonAQ233OOFCU0_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TNvEnioP0yXg7XUM.jpg" data-width="1065" data-height="1042" target="_blank"><img src="https://www.techpowerup.com/img/TNvEnioP0yXg7XUM_thm.jpg" width="133" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iuTLQlErjXSpKhYW.jpg" data-width="700" data-height="620" target="_blank"><img src="https://www.techpowerup.com/img/iuTLQlErjXSpKhYW_thm.jpg" width="147" height="130" alt="" /></a></div>
AMD Renoir APU Models Spotted in ASUS Notebooks
Following the previous report about AMD's upcoming "Renoir" APU lineup of processors for notebook and desktop, we have new information about the new processor models and their configurations. Supposed to launch in early 2020, the Renoir lineup is supposed to feature up to 8 cores and 16 threads in high-end models. Dubbed Ryzen 4000 series, the new APU lineup will be available in four configurations determined by its TDP: 15 W and 45 W chips for notebooks, and 35 W and 65 W variants meant for desktop.<br />
<br />
According to WCCFTech, AMD will launch high-performance Ryzen 9 4900H and Ryzen 7 4800H APUs soon in the first notebooks. Supposed to be part of the "H" series of mobile APUs, these models will feature high core count, that can reach up to 8 cores, SMT support as well, all within TPD of 45 Watts. A power-optimized Ryzen 7 4800HS has also appeared in the listings as a lower clocked alternative to Ryzen 7 4800H, which is supposed to feature lower TDP as well. All of the former processors appear listed as the base of ASUSes upcoming GA401 and GA502 laptops, featuring 16 GB of RAM, Windows 10, and a 14-inch display. While configurations of the laptop will affect its price, Ryzen 7 4800HS powered model is currently listed at 1904 EUR, featuring 16 GB of RAM and 1 TB of storage, so we now have a ballpark price estimate to speculate upon.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/tLqO6vlU6ZyxXqgs.jpg" data-width="1382" data-height="650" target="_blank"><img src="https://www.techpowerup.com/img/tLqO6vlU6ZyxXqgs_thm.jpg" width="276" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xbN7VQCI7w2q7vsu.jpg" data-width="1437" data-height="891" target="_blank"><img src="https://www.techpowerup.com/img/xbN7VQCI7w2q7vsu_thm.jpg" width="210" height="130" alt="" /></a> </div><div class="readmore"><a href="/262336/amd-renoir-apu-models-spotted-in-asus-notebooks">Read full story</a></div>
(PR) OWC Announces Accelsior 4M2 NVMe Storage Solution with up to 6 GB
OWC today announced the all-new Accelsior 4M2 ultra high-performance PCIe M.2 NVMe internal SSD that delivers over 6,000 MB/s real-world speeds in capacities up to 8 TB. The Accelsior 4M2 is the fastest SSD ever built by OWC and is the perfect storage solution for large format video editing, VR/AR/MR environments, extreme gaming, compute-intensive applications and other high bandwidth needs.<br />
<br />
Whether you have the Mac Pro 2019, a Mac Pro 2012 or 2010, or PC tower, the Accelsior 4M2 delivers the blazing performance, unstoppable reliability and stunning versatility that are the hallmarks of OWC's brand reputation. As a half-length x8/x16 compatible card, this game-changer offers true versatility, so users can install it in full-length PCIe 3.0 or 2.0 slots as well. Even Thunderbolt 3-equipped laptops can experience the performance boosting benefits of Accelsior 4M2 with Plug-and-Play ease using the OWC Mercury Helios 3S PCIe expansion chassis (sold separately). In other words, it's incredibly versatile.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/gcK6muDxydBVADSZ.jpg" data-width="1000" data-height="1000" target="_blank"><img src="https://www.techpowerup.com/img/gcK6muDxydBVADSZ_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AWEAQYwOU2NK4nvf.jpg" data-width="1000" data-height="1000" target="_blank"><img src="https://www.techpowerup.com/img/AWEAQYwOU2NK4nvf_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/g2DTtnZiJVs0IrRx.jpg" data-width="1000" data-height="1000" target="_blank"><img src="https://www.techpowerup.com/img/g2DTtnZiJVs0IrRx_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DukuslUp45LJxWwU.jpg" data-width="1000" data-height="1000" target="_blank"><img src="https://www.techpowerup.com/img/DukuslUp45LJxWwU_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/262335/owc-announces-accelsior-4m2-nvme-storage-solution-with-up-to-6-gb-s-transfer-rates">Read full story</a></div>
AMD "Renoir" 4700U Beats i7-1065G7 "Ice Lake" at PCMark 10, 18% Faster than 3700U
AMD's upcoming Ryzen 7 4700U "Renoir" mobile processor posts an 18 percent performance gain in PCMark 10 over its predecessor, the 3700U, according to benchmark results data compiled by Reddit enthusiast _rogame. The 4700U combines a 4-core/8-thread CPU ticking at 2.00 GHz (base) with up to 4.20 GHz boost, according to the SystemInfo module. It also ends up about 2.8 percent faster than a Core i7-1065G7 "Ice Lake" processor. <br />
<br />
The 4700U is rumored to feature AMD's new "Zen 2" CPU cores, an iGPU with <a href="https://www.techpowerup.com/262201/amd-renoir-apu-igpu-configuration-and-platform-spread-detailed" target="_blank">up to 13 "Vega" NGCUs</a> (832 stream processors), and leverage the 7 nm silicon fabrication process to boost CPU clock-speeds without affecting the ultraportable platform's typical TDP. <a href="https://www.techpowerup.com/260631/amd-renoir-apu-3dmark-11-performance-figures-allegedly-surface" target="_blank">3DMark 11 figures</a> of the iGPU surfaced earlier suggesting competitiveness to Intel's Gen11 graphics. "Renoir" <a href="https://www.techpowerup.com/258859/amd-renoir-apu-to-support-lpddr4x-memory-and-new-display-engine" target="_blank">also supports</a> the cutting-edge LPDDR4X memory standard, which could further lower platform power draw, while boosting memory clocks as high as 4266 MHz DDR. Below are comparative "best result" screenshots.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wgjgFQfjnmxkhE8y.jpg" data-width="2954" data-height="9904" target="_blank"><img src="https://www.techpowerup.com/img/wgjgFQfjnmxkhE8y_thm.jpg" width="39" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CHaO43hPwf7Y8bMs.jpg" data-width="2954" data-height="9746" target="_blank"><img src="https://www.techpowerup.com/img/CHaO43hPwf7Y8bMs_thm.jpg" width="39" height="130" alt="" /></a></div>
Intel Enthusiast-Grade K Processors in the Comet Lake-S Family Rumored
This piece of news shouldn't surprise anyone, except for the fact that Intel is apparently signing on a TDP of 125 W for even its K-series unlocked processors for their next-generation Comet Lake-S family. Intel's current Comet Lake 9900K CPU features a TDP of "only" 95 W - when compared to the rumored 125 W of the 10900K), whilst their current top offering, the i9-9900KS, features a 127 W TDP. Remember that Intel's 10900K should feature 10 cores and 20 threads, two extra cores than their current 9900K - this should explain the increased TDP, a mathematical necessity given that Intel can only count on marginal improvements to its 14 nm fabrication process to frequencies and power consumption of its CPUs.<br />
<br />
A leaked slide from momomo on Twitter shows, if real, that Intel's future enthusiast-grade CPUs (likely i5-10600K, i7-10700K and i9-10900K) will feature this 125 W TDP, while other launches in that family will make do with the more traditional 65 W TDP (interesting to see that Intel has some 10-core CPUs with 65 W TDP, the same as their current 9900, despite two more cores). A footnote on the leaked slide shows that these K processors can be configured for a 95 W TDP, but this would likely come at a significant cost to operating frequency. Intel seems to be bringing a knife to a gunfight (in terms of core counts and TDP) with AMD's Ryzen 3000 and perhaps Ryzen 4000 CPUs, should those and Intel's future offerings actually coexist in the market.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/89jMDuVkvJBNAOsW.jpg" data-width="1536" data-height="829" target="_blank"><img src="https://www.techpowerup.com/img/89jMDuVkvJBNAOsW_thm.jpg" width="241" height="130" alt="" /></a></div>
AMD Ryzen 4000 Rumored to Offer Around 17% Increased Performance
AMD's upcoming Ryzen 4000 series processors will be based on the company's Zen 3 design, which will feature a deeply revised architecture aiming to offer increased performance (surprising no-one). AMD themselves have already said that Zen 3 will offer performance increases in line with the reelase of new architectures - and we all remember the around 15% increase achieved with the release of Zen 2 Ryzen 3000 series, which surprised even AMD on its performance capabilities. Several sources around the web are quoting an around 17% increase in performance, taking into account increased operating frequencies of Zen 3 (100 to 200 MHz at least for the enterprise solutions, which could pave the way for even higher increases in consumer-geared products) and increased IPC of its core design. The utilization of EUV in the 7 nm process shouldn't have much to do with the increased frequencies of the CPUs, and will mostly be used to reduce the number of masks that are required for production of AMD's Zen 3 CPUs (which in turn will lead to increased yields).<br />
<br />
Sources are claiming an increase of up to 50% in Zen 3's Floating Point Units (FPU) compared to Zen 2, while integer operations should make do with a 10-12% increase. Cores should remain stable across the board - and with that increase in performance, I'd say an upper limit of 16 physical and 32 logic cores in a consumer-geared CPU is more than enough. Increased IPCs and frequencies will definitely make AMD an even better proposition for all markets - gaming in particular, where Intel still has a (slightly virtual) hold in consumer's minds.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/pUSYDTQj46gOqyUl.jpg" data-width="725" data-height="408" target="_blank"><img src="https://www.techpowerup.com/img/pUSYDTQj46gOqyUl_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) SK hynix to Introduce Consumer PCIe NVMe SSDs at CES 2020
SK hynix Inc., a global semiconductor maker based in Korea, is set to introduce its newest offering of "Gold P31" and "Platinum P31" PCIe NVMe Solid State Drives (SSDs) at the Consumer Electronics Show (CES) 2020, which will be held on January 7-10 in Las Vegas, Nevada. The drives are built with SK hynix's 128-layer 4D NAND flash, only six months after the Company announced the mass production of the world's first and highest vertical stack for NAND flash, demonstrating the chipmaker's technological edge.<br />
<br />
As a leading manufacturer of memory chips, SK hynix builds and supplies its own DRAM and NAND flash devices, as well as SSD controllers designed and developed in-house. The company has a proven track record as a major supplier to global OEMs including top-tier PC makers, who have trusted and purchased SK hynix's SSDs for nearly a decade now. As a next step, SK hynix is now expanding into the consumer market with its newest drives.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ZMMDQPDwyLdD1geI.jpg" data-width="1200" data-height="628" target="_blank"><img src="https://www.techpowerup.com/img/ZMMDQPDwyLdD1geI_thm.jpg" width="248" height="130" alt="" /></a> </div><div class="readmore"><a href="/262422/sk-hynix-to-introduce-consumer-pcie-nvme-ssds-at-ces-2020">Read full story</a></div>
GTA V was in Top US Game Sales Charts for 74 Months
GTA V, made by Rockstar and Take-Two, is possibly the biggest game ever designed, with the massive player base and massive profits fulfilled. Perhaps the most interesting report today is that the game has stayed in the top game sales chart in the United States for the past 74 months. Month after month, gamers have been buying digital copies of the game to a point where it maintained some of the top spots on the charts. Since the game launched in 2013, it got support for two generations of consoles and PC platforms, making it accessible to a huge base of gamers. With constant updates and new content, the game managed to keep players interested and busy with new quests to conquer. <br />
<br />
"Recurrent consumer spending on GTA Online grew 23% YoY to a new record, driven by the July release of the Diamond Casino Resort update. This update was GTA Online's biggest content launch ever, delivering record daily, weekly, and monthly active users in July and again in August," CEO of Take-Two Interactive Strauss Zelnick said in November.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JaaMxOl26hAHNVfD.jpg" data-width="1280" data-height="720" target="_blank"><img src="https://www.techpowerup.com/img/JaaMxOl26hAHNVfD_thm.jpg" width="231" height="130" alt="" /></a></div>
Welcome 2020 with the Latest Genuine Software from GoodOffer24
With the warmth of Christmas upon us, we turn to the turn of the year - and of the decade. Why not give your computers the latest genuine software they deserve? With GoodOffer24, you can save big on genuine, globally-valid Windows 10 and Office digital licenses, helping you spend more of your X'mas moneis on better hardware; or upgrading your computers from Windows 7 to the latest and greatest editions of Windows 10. Save even more, when you pick up bundles of the various editions of Windows 10 and Office, giving your PCs the best software they need. Shop confidently on GoodOffer24 with PayPal securing not just your payment instruments, but also you purchase. Don't forget to apply TechPowerUp-exclusive coupon codes to avail the prices you see here. <br />
<br />
Apply the coupon code <b>JGohw25</b> at checkout on the following items to shave <b>25% off</b> on the list prices and avail the prices you see here.<br />
<a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-professional-cd-key-32-64-bit.html?acc=651" target="_blank">Buy Windows 10 Pro at $11.38</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-professional-cd-key-32-64-bit-2-pc.html?acc=651" target="_blank">Buy Windows 10 Pro Twin Pack at $19.50</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/microsoft-office-2016-pro-plus-cd-key.html?acc=651" target="_blank">Buy Office 2016 Professional Plus at $28.19</a> | Buy <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-enterprise-2019-ltsc.html?acc=651" target="_blank">Windows 10 Enterprise LTSC at $13.29</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-office-2016-pro-bundle-key.html?acc=651" target="_blank">Buy Windows 10 Pro + Office 2016 Professional Plus at $33.69</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-home-office-2016-pro-bundle.html?acc=651" target="_blank">Buy Windows 10 Home + Office 2016 Professional Plus at $31.92</a><br />
<br />
Don't forget to apply the coupon code <b>JGohw40</b> at checkout on the following items to shave <b>40% off</b> and avail the prices you see here. <br />
<a rel="nofollow" href="https://www.goodoffer24.com/software/microsoft-office-2019-professional-plus-cd-key-1pc.html?acc=651" target="_blank">Buy Office 2019 Professional Plus at $42.56</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-pro-office-2019-pro-bundle.html?acc=651" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $46.11</a> | <a rel="nofollow" href="https://www.goodoffer24.com/software/windows-10-home-office-2019-pro-bundle.html?acc=651" target="_blank">Buy Windows 10 Home + Office 2019 Professional Plus at $44.69</a><div class="readmore"><a href="/262433/welcome-2020-with-the-latest-genuine-software-from-goodoffer24">Read full story</a></div>
TechPowerUp Cooler Master TUF Gaming Alliance Full System Giveaway: The Winner!
TechPowerUp and Cooler Master, in partnership with ASUS TUF Gaming Alliance, brought you a cracker of an year-end Giveaway, with a full gaming desktop on offer, equipped with stable and reliable components from the ASUS TUF Gaming Alliance of co-branded hardware. Our TUF Gaming Alliance system includes an ASUS TUF X470-Plus Gaming motherboard, AMD Ryzen 5 2600 processor, ASUS GeForce RTX 2060 TUF Gaming graphics card, 16 GB Apacer Panther Rage RGB TUF Gaming Edition memory, Cooler Master MasterBox MB500 TUF Gaming Edition case, Team Group T-Force Delta S TUF RGB 250 GB SSD, Cooler Master MasterWatt 750 W TUF Gaming Edition power-supply, and a Cooler Master MasterAir MA410M TUF Gaming Edition CPU cooler. The Winner takes all in our Giveaway, and without further ado here they are:<ul><li>TechPowerUp Forums user "diatribe" from the United States</li></ul>Huge Congratulations @diatribe, a winner is you! TechPowerUp and Cooler Master will return with more such interesting giveaways!<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4ClbWtXDJDACSox4.jpg" data-width="800" data-height="800" target="_blank"><img src="https://www.techpowerup.com/img/4ClbWtXDJDACSox4_thm.jpg" width="130" height="130" alt="" /></a></div>
MSI Unveils the Optix MAG272QR 27-inch Fast 1440p Monitor
MSI today unveiled the Optix MAG272QR, a 27-inch fast gaming monitor. Slotted in the company's Arsenal Gaming family, the MAG272QR features a VA panel with WQHD (2560 x 1440 pixels) resolution, 165 Hz refresh-rate, 1 ms (GTG) response-time, AMD FreeSync support, and 95.6% DCI-P3 coverage. Other key panel specs include 10 bpc color (1.07 billion colors), 178°/178° viewing-angles, 300 cd/m² maximum brightness, and dynamic mega-contrast ratio, besides 3000:1 static contrast. <br />
<br />
The Optix MAG272QR features a stand that lets you adjust height, 90° rotation to portrait mode, ±75° swivel, and 5-20° tilt. Behind the monitor are RGB LED embellishments that you control with MSI Mystic Light RGB app, and can also configure as mood-light. Display inputs include USB-C (DisplayPort TMDS passthrough), standard DisplayPort 1.2a, and two HDMI 2.0b inputs; all of which support the monitor's full 1440p resolution. Using HDMI 2.0b caps the refresh-rate to 144 Hz. Available now, the Optix MAG272QR is priced at USD $350.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/mRjPf3xSiscKMIxS.jpg" data-width="1024" data-height="820" target="_blank"><img src="https://www.techpowerup.com/img/mRjPf3xSiscKMIxS_thm.jpg" width="162" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QnfprCoMmQeiRcVG.jpg" data-width="1024" data-height="820" target="_blank"><img src="https://www.techpowerup.com/img/QnfprCoMmQeiRcVG_thm.jpg" width="162" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eUoJf6w5yl5NdkOK.jpg" data-width="1024" data-height="820" target="_blank"><img src="https://www.techpowerup.com/img/eUoJf6w5yl5NdkOK_thm.jpg" width="162" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QmstaXDpxN6pzjTt.jpg" data-width="1024" data-height="820" target="_blank"><img src="https://www.techpowerup.com/img/QmstaXDpxN6pzjTt_thm.jpg" width="162" height="130" alt="" /></a></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Windows 7 ESU Customers to Continue Getting Security Updates
Today Microsoft confirmed that customers from Windows 7 Extended Security Updates (ESU) program will still get security updates, even when the operating system reaches End-of-Life. On an FAQ page, Microsoft answers that "Windows 7 ESU includes security updates for critical and important issues as defined by Microsoft Security Response Center (MSRC) for a maximum of three years after January 14, 2020. After January 14, 2020, if your PC is running Windows 7 and you have not purchased Extended Security Updates, the computer will no longer receive security updates."<br />
<br />
This confirms Microsoft's intentions to support some customers who are unable to switch to more modern OS versions like Windows 10, presumably customers who can afford to pay for extended security on their machines. More info can be found on Microsoft's website for <a rel="nofollow" href="https://support.microsoft.com/en-us/help/17150/windows-7-what-is-microsoft-security-essentials" target="_blank">Security Essentials</a> and FAQ about <a rel="nofollow" href="https://support.microsoft.com/en-us/help/4527878/faq-about-extended-security-updates-for-windows-7" target="_blank">ESU for Windows 7</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/EiuxnwMN8DJnOfok.jpg" data-width="800" data-height="450" target="_blank"><img src="https://www.techpowerup.com/img/EiuxnwMN8DJnOfok_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) Greenliant Releases EnduroSLC SSDs in U.2 NVMe Form-factor
Greenliant is now sampling its NVMe U.2 EnduroSLC Industrial Enterprise EX Series solid state drives (SSDs) to customers that require ultra high endurance primary storage with sustainable low latency and high performance in extreme environments. Designed with Greenliant's EnduroSLC Technology, NVMe U.2 Industrial Enterprise EX Series SSDs provide ultra robust data retention and ultra high system-level lifetime endurance of 30 drive writes per day (DWPD) for 5 years.<br />
<br />
"For the highest levels of data integrity, Greenliant's NVMe U.2 Industrial Enterprise SSDs implement on-chip adaptive RAID," said Xuanhui Li, Vice President of Business Development, Datacenter Products, Greenliant. "With Greenliant's NVMe U.2 Industrial Enterprise SSDs, customers can achieve the efficiency and scalability required to meet the demands of write intensive applications in harsh environments."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oQiCskHDkvPYUiGb.jpg" data-width="662" data-height="603" target="_blank"><img src="https://www.techpowerup.com/img/oQiCskHDkvPYUiGb_thm.jpg" width="143" height="130" alt="" /></a> </div><div class="readmore"><a href="/262531/greenliant-releases-enduroslc-ssds-in-u-2-nvme-form-factor">Read full story</a></div>
AMD Ryzen Threadripper 3980X is a 48-core Monster for When 64 Cores Are Too Many, 32 Too Few
In the press-deck of its 3rd Generation Ryzen Threadripper 3970X/3960X launch, AMD teased its flagship HEDT part for the TRX40 platform, the Ryzen Threadripper 3990X, with a 2020 launch date. It should come as little surprise then, that the core-count gap between the 3970X and the 3990X has an SKU in the middle - the 3980X. This SKU reportedly surfaced in CPU-Z 1.91 code. The 3980X is a 48-core/96-thread monstrosity for when 64 cores are too many, and 32 too few. <br />
<br />
Like the 3990X, the 3980X will likely be built with eight "Zen 2" CCDs (chiplets) for optimal IFOP bandwidth utilization and heat-spread. Each CCD will likely be configured with 6 cores (3 per CCX), adding up to 48 cores on the package. Much like the 3990X, clock-speeds of the 3980X remain under the wraps. AMD is expected to launch the two some time in 2020, featuring compatibility with existing AMD TRX40 chipset motherboards. The company could target a sub-$3,000 price-point to make the Xeon W-3175X obsolete both in performance and value.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6n4kA5IK7Hdf9qMw.jpg" data-width="1600" data-height="1062" target="_blank"><img src="https://www.techpowerup.com/img/6n4kA5IK7Hdf9qMw_thm.jpg" width="196" height="130" alt="" /></a></div>
Intel 10th Gen Core "Comet Lake" Lineup and Specs Revealed
Ahead of a possible reveal in the sidelines of CES, followed by an early-Q2 2020 product-launch, company slides detailing Intel's 10th generation Core desktop processors in the LGA1200 package, codenamed "Comet Lake-S," leaked to the web courtesy Informatica Cero. They confirm that HyperThreading will play a key role, with Intel enabling it across the lineup. The range-topping Core i9 series will be 10-core/20-thread along with 20 MB of L3 cache. The Core i7 series will be 8-core/16-thread, along with 16 MB L3 cache. The all-important Core i5 series will be 6-core/12-thread, equipped with 12 MB of L3 cache. The Core i3 series will have two sub-tiers: i3-103xx series with 4-core/8-thread and 8 MB L3 cache; and i3-101xx series 4-core/8-thread with 6 MB L3 cache. <br />
<br />
The Core i7 and Core i9 "Comet Lake" chips will feature native support for dual-channel DDR4-2933, while the Core i5 and Core i3 will make do with native DDR4-2667 support (memory overclocking possible). Besides core/thread counts, and cache size increases, Intel will dial up clock speeds across the board by as much as 300 MHz per SKU (vs. their 9th gen predecessor), and introduce Turbo Boost Max 3.0, which has been exclusive to its HEDT processors. The introduction of Turbo Boost Max 3.0 could also bring about modern favored-core capability (benefiting Windows 10 1909 and later). The classic Turbo Boost is also available. There's also a mysterious new feature called "Thermal Velocity Boost," with its own set of clock-speeds depending on core/thread load. The chips could also feature Modern Standby C10 power-state support (first to the desktop platform). Intel is said to have also added several new core and memory overclocking features on the K-SKUs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/7NihLzb0LewMDljG.jpg" data-width="2853" data-height="1252" target="_blank"><img src="https://www.techpowerup.com/img/7NihLzb0LewMDljG_thm.jpg" width="296" height="130" alt="" /></a> </div><div class="readmore"><a href="/262506/intel-10th-gen-core-comet-lake-lineup-and-specs-revealed">Read full story</a></div>
Intel to Announce Advanced Cooling Solutions for Project Athena Laptops
According to sources at DigiTimes, Intel will announce its advanced cooling solutions for project Athena thin and light laptops, at 2020's CES. Pushing project Athena to be the finest of all laptop options, Intel wants to give users the ability to have their laptops run even cooler than ever with a new thermal solution that will supposedly enable an additional 25-30% of cooling headroom. The new cooling module will combine two ingredients to make up for a powerful cooling solution - vapor chambers and graphite sheets.<br />
<br />
Usually, the cooling modules inside laptops are placed between the keyboard and laptop's bottom shell, where they could utilize only a small space, so thermal management became hard. In contrast, Intel's design is combining the vapor chamber with graphite sheets to create a bigger surface for heat dissipation. The vapor chamber will replace all the current modules and connect to graphite sheets placed behind the laptop screen, where a lot of area is available. Connecting the vapor chamber to the graphite sheet is a laptop hinge, where a graphite cooling solution would pass through. This hints at a complete redesign of laptop hinges, so we can expect to see some creative solutions there as well. Additionally, this design will allow manufacturers to make fanless laptops that use lower-power CPU models, and we can expect to see even slimmer laptop designs than ever before.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LO6qvp5BbCquNIN7.jpg" data-width="1200" data-height="742" target="_blank"><img src="https://www.techpowerup.com/img/LO6qvp5BbCquNIN7_thm.jpg" width="210" height="130" alt="" /></a></div>
AMD Radeon RX 5600 XT Features 2,304 Stream Processors
AMD's upcoming Radeon RX 5600 XT graphics card features the same exact stream processor count as the $350 RX 5700, according to a leaked specs sheet of a an AIB partner's custom-design graphics card. With a stream processor count of 2,304, it's safe to assume that the RX 5600 XT is based on the same 7 nm "Navi 10" silicon as the RX 5700 series. What set the RX 5600 XT apart from the RX 5700, besides lower clock-speeds, is the memory subsystem, which is severely stripped down. The Radeon RX 5600 XT will be equipped with 6 GB of GDDR6 memory across a 192-bit wide memory interface. What's more, the memory ticks at 12 Gbps, compared to 14 Gbps on the RX 5700 series. <br />
<br />
With these specs, the RX 5600 XT has 288 GB/s of memory bandwidth at its disposal, same as NVIDIA's GeForce GTX 1660 Ti. In contrast, with 8 GB of 256-bit GDDR6 running at 14 Gbps, the RX 5700 enjoys 448 GB/s. The specs sheet suggests that AMD has also dialed down the engine clock-speeds (GPU clocks) a bit, with up to 1620 MHz boost, up to 1460 MHz gaming, and 1235 MHz base. With these specs, it's highly likely that the RX 5600 XT outperforms the GTX 1660 Ti and gets close to the RTX 2060. It all boils down to pricing. The RX 5500 XT is a decent GTX 1650-series alternative with a lukewarm price thanks to NVIDIA's aggressive product-stack management by getting its partners to lower prices of the GTX 1660 and GTX 1660 Super. It would be interesting to see if AMD can outfox NVIDIA in the sub-$300 market.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LeeNczoidZ5Way79.jpg" data-width="463" data-height="322" target="_blank"><img src="https://www.techpowerup.com/img/LeeNczoidZ5Way79_thm.jpg" width="187" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/n2YLf8rLAk6Z4r5m.jpg" data-width="454" data-height="449" target="_blank"><img src="https://www.techpowerup.com/img/n2YLf8rLAk6Z4r5m_thm.jpg" width="131" height="130" alt="" /></a></div>
(PR) Transcend Announces JetFlash 910 High-Endurance USB Flash Drive
Transcend Information Inc. (Transcend ), a leading manufacturer of storage and multimedia products, is proud to present the market-redefining JetFlash 910, a USB flash drive that packs incredible performance and endurance into a compact USB form factor. The flash drive utilizes the latest 3D NAND technology for up to 420 MB/s and 400 MB/s read and write speeds and an excellent endurance level of 3,000 P/E cycles - the equivalent of MLC NAND flash. With capacities up to 256 GB, the JetFlash 910 is ideal for storing a trove of 4K videos and high-resolution images, transferring them in a flash. Housed in lightweight aluminium with a sandblasted finish for extra durability and a sleek look, the JetFlash 910 takes the USB storage experience to a brand new level.<br />
<br />
At 10 times the lifespan of a regular TLC flash drive, the JetFlash 910 offers superior and persistent protection of key data, making it great everyday carry for work and life. Having a high endurance rating also makes the JetFlash 910 well-suited for write-intensive applications, such as dashcams or surveillance systems. The aluminium metallic housing makes the USB flash drive less prone to wear, while gracing it with an extra touch of sleekness.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/v52OJuYQ6mzTEGjc.jpg" data-width="600" data-height="450" target="_blank"><img src="https://www.techpowerup.com/img/v52OJuYQ6mzTEGjc_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="/262501/transcend-announces-jetflash-910-high-endurance-usb-flash-drive">Read full story</a></div>
(PR) EVGA Formally Launches the SR-3 DARK Motherboard for Xeon W-3175X
The DARK rises again. Not content to merely shatter records and competition in the consumer market, the EVGA SR-3 DARK merges two extreme performance lines of EVGA motherboards to bring balance to the force with exceptional performance and engineering. Featuring the Intel C622 chipset, hexa-channel memory support, 23 phase power design, 16-layer PCB, dual-10 GbE LAN ports, a waterblock to passively or actively cool the DARK's VRM, and so much more, this board is packed with everything and is still compact enough to fit in a full E-ATX form factor.<br />
<br />
With the EVGA SR-3 DARK, you don't need to see its identification to know that the next evolution of the X299 and Z390 DARK motherboards features the latest improvements for performance and enthusiast needs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fQdaWqHa3pW9XF5N.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/fQdaWqHa3pW9XF5N_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QJ7ZL9SfAKUCLfgP.jpg" data-width="1049" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/QJ7ZL9SfAKUCLfgP_thm.jpg" width="142" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Io2j7JkEFL2MmtIZ.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/Io2j7JkEFL2MmtIZ_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sVm3MQuLcmqQvKAU.jpg" data-width="988" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/sVm3MQuLcmqQvKAU_thm.jpg" width="134" height="130" alt="" /></a> </div><div class="readmore"><a href="/262500/evga-formally-launches-the-sr-3-dark-motherboard-for-xeon-w-3175x">Read full story</a></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
AMD Financial Analyst Day 2020 Live Blog
AMD Financial Analyst Day presents an opportunity for AMD to talk straight with the finance industry about the company's current financial health, and a taste of what's to come. Guidance and product teasers made during this time are usually very accurate due to the nature of the audience. In this live blog, we will post information from the Financial Analyst Day 2020 as it unfolds.<br />
<br />
<b>Update 22:43 UTC</b>: AMD chronicles the today and tomorrow of console gaming.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/w4v51BKVunBuCNDF.jpg" data-width="1262" data-height="708" target="_blank"><img src="https://www.techpowerup.com/img/w4v51BKVunBuCNDF_thm.jpg" width="232" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PHPSEPZoifC8Jt3e.jpg" data-width="1260" data-height="705" target="_blank"><img src="https://www.techpowerup.com/img/PHPSEPZoifC8Jt3e_thm.jpg" width="232" height="130" alt="" /></a> </div><b>Update 22:39 UTC</b>: Brief overview of Navi. Big push for VSR, ray-tracing, and process improvements iwth RDNA2<div class="imgcontainer"><a href="https://www.techpowerup.com/img/MCv0NKXUxiUyiQgZ.jpg" data-width="1259" data-height="708" target="_blank"><img src="https://www.techpowerup.com/img/MCv0NKXUxiUyiQgZ_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/isEG5j1GE3Ln3eUa.jpg" data-width="1260" data-height="701" target="_blank"><img src="https://www.techpowerup.com/img/isEG5j1GE3Ln3eUa_thm.jpg" width="234" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/F5skYXT2ZDjp0FbB.jpg" data-width="1267" data-height="709" target="_blank"><img src="https://www.techpowerup.com/img/F5skYXT2ZDjp0FbB_thm.jpg" width="232" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lwXUjbIbWQa1lxXu.jpg" data-width="1259" data-height="707" target="_blank"><img src="https://www.techpowerup.com/img/lwXUjbIbWQa1lxXu_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/12aRqpUfPK8JFLAu.jpg" data-width="1262" data-height="708" target="_blank"><img src="https://www.techpowerup.com/img/12aRqpUfPK8JFLAu_thm.jpg" width="232" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/P9ySzC0abwGtgJAU.jpg" data-width="1262" data-height="709" target="_blank"><img src="https://www.techpowerup.com/img/P9ySzC0abwGtgJAU_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/264529/amd-financial-analyst-day-2020-live-blog">Read full story</a></div>
(PR) EK Water Blocks Announces EK-Furious Meltemi 120 High-speed Fan
EK, the premium liquid cooling gear manufacturer is launching its most extreme fan to date, the EK-Furious Meltemi 120. This 38 mm thick extreme high-static pressure radiator cooling fan is designed purely for highest-performance computer liquid cooling systems. Developed in-house on the basis of the renowned EK-Vardar fans, they have a wide PWM range of operation and the highest speed of up to 3500 rpm. Due to a 38 mm thick frame, there is space for an upgraded motor and far superior performance compared to any standard 25 mm thick fan at the same RPM range.<br />
<br />
The Meltemi family of cooling fans carries the name of a type of strong, dry northern winds of the Aegean Sea. The name Meltemi is derived from Italian mal tempo meaning "bad weather", while we can say that the EK's Meltemi fans are "bad news" for high temperatures. These fans provide the best possible performance in pull mode. Such a regime evens out the airflow through the entire surface of the radiator since the motor hub dead zone effect is lessened. The fan is equipped with a red sleeved cable just to warn off those curious little fingers from getting hurt. Seriously, 3500 rpm is no joke, and you should be extra careful around these fans if they are in operation.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4AOlLRryOCFqMIZT.jpg" data-width="572" data-height="546" target="_blank"><img src="https://www.techpowerup.com/img/4AOlLRryOCFqMIZT_thm.jpg" width="136" height="130" alt="" /></a> </div><div class="readmore"><a href="/264528/ek-water-blocks-announces-ek-furious-meltemi-120-high-speed-fan">Read full story</a></div>
AMD Radeon Software Adrenalin 20.2.2 Released as WHQL
AMD Radeon Software Adrenalin 20.2.2 got re-released as a WHQL-signed driver by AMD. The company had originally released it as a beta on February 28. The drivers come with optimization for "Zombie Army 4: Dead War," but more importantly, fix a large number of software bugs plaguing Adrenalin 2020 Edition since its December 2019 release. These include several black-screen errors, bugs with Radeon Software, its various game optimization, recording, and streaming features, and more. Version 20.2.2 WHQL otherwise has an identical change-log to the 20.2.2 beta.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/N58Ju87V3wFOFMCI.jpg" data-width="900" data-height="450" target="_blank"><img src="https://www.techpowerup.com/img/N58Ju87V3wFOFMCI_thm.jpg" width="260" height="130" alt="" /></a> </div><b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/amd-radeon-graphics-drivers/" target="_blank">AMD Radeon Software Adrenalin 20.2.2 WHQL</a><br />
<br />
The change-log is identical to 20.2.2 beta.<div class="readmore"><a href="/264525/amd-radeon-software-adrenalin-20-2-2-released-as-whql">Read full story</a></div>
In Win Intros SR24 AIO CPU Cooler with Twin Turbine Pump
In Win today rolled out the SR24, an all-in-one liquid CPU cooler featuring a patented "twin turbine pump" feature. These are basically two pump turbines attached on both ends of the DC motor's shaft, which in turn are located on either ends of the CPU block. One of the turbine pushes coolant into the block, while the other pulls heated coolant from it. In Win claims that even if one of the two fails over time, the other will provide sufficient coolant pressure to cool your CPU, while a warning LED lights up. With both turbines operational, the SR24 offers double the coolant pressure, and a markedly superior P-Q curve. The pump block is capped off with an RGB illuminated In Win logo. <br />
<br />
The innovative pump-block of the In Win SR24 is tubed to a 240 mm x 120 mm aluminium radiator. Ventilating it are a pair of included In Win Jupiter 120 mm fans that each spin at speeds of 500 to 2,500 RPM, with up to 101.5 CFM of air-flow, and as low as 23 dBA of noise output. The fans feature double ball bearings and feature addressable RGB LEDs in their hubs. A single 3-pin ARGB connection handles lighting for the two fans and the pump-block. The company didn't mention thermal load numbers, but among the CPU socket types supported are TR4, sTRX4, LGA2066, AM4, and LGA115x. The company didn't reveal pricing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Eh93H3A7nTgs48rk.jpg" data-width="854" data-height="662" target="_blank"><img src="https://www.techpowerup.com/img/Eh93H3A7nTgs48rk_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PIsrHagojb264t9H.jpg" data-width="774" data-height="720" target="_blank"><img src="https://www.techpowerup.com/img/PIsrHagojb264t9H_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fiLsIrG971mHRdr0.jpg" data-width="1644" data-height="1050" target="_blank"><img src="https://www.techpowerup.com/img/fiLsIrG971mHRdr0_thm.jpg" width="204" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EDKuxEuE3sAkhBjA.jpg" data-width="1547" data-height="946" target="_blank"><img src="https://www.techpowerup.com/img/EDKuxEuE3sAkhBjA_thm.jpg" width="213" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nEJAO6KKWyApMt6D.jpg" data-width="1146" data-height="720" target="_blank"><img src="https://www.techpowerup.com/img/nEJAO6KKWyApMt6D_thm.jpg" width="207" height="130" alt="" /></a></div>
Valve Index VR back on Sale on Monday for $999
Valve's Index VR headset is expected to go back on sale on Monday, March 9th, when Valve will again re-fill its stock of Index VR headsets, according to Engadget. Just in time for the Half-Life: Alyx launch, Valve has decided to supply all of the gamers with a stock of the headsets so everyone can experience the new Half-Life game with Valve's Index VR. Considering that Half-Life: Alyx is dropping on March 23rd, Valve thought of everyone in need of a new VR headset and decided to offer it on Monday. Valve is expecting the headset to sell out completely, so its best to be early if you want to get one too, for $999. The sale will begin at 1PM eastern time.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YG48ESSYdRNSx1fU.jpg" data-width="1591" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/YG48ESSYdRNSx1fU_thm.jpg" width="215" height="130" alt="" /></a></div>
TechPowerUp and Montech Mega Spring Giveaway: The Winners
TechPowerUp and Montech welcomed Spring with a Mega Giveaway, giving eighteen lucky winners a chance to give their battlestations a sweet new beginning. Up for grabs were three sets of Montech's premium Air 900 Mesh Black cases + Z3 ARGB fans + ML900 mouse-mats; five Fighter 400 mid-tower cases, and ten ML900. These represent Montech's strong entry to the PC hardware space with several new cases and gaming peripherals under development. Without further ado, the winners:<ul><li>First Prizes (Air 900 Mesh Black cases + Z3 ARGB fans + ML900 mouse-mats): Michael from North Carolina, Mike from the US, and Braxston from New York.</li><li>Second Prizes (Fighter 400 cases): Justin from the US, Matthew from Massachusetts, Jorell from Nevada, Jeremy from Michigan, and Mark from California</li><li>Third Prizes (ML900 mouse-mats): Kenneth from Colorado, Leonard from Colorado, Jacob from Virginia, Justin from Florida, Jack from New York, Colin from Wisconsin, Rodney from Virginia, Aaron from Utah, Michael from West Virginia, and John from Florida</li></ul>A Huge Congrats for all 18 of you! TechPowerUp and Montech will return with more such interesting giveaways!<div class="imgcontainer"><a href="https://www.techpowerup.com/img/gIA5uAGtpWrSbT54.jpg" data-width="800" data-height="800" target="_blank"><img src="https://www.techpowerup.com/img/gIA5uAGtpWrSbT54_thm.jpg" width="130" height="130" alt="" /></a></div>
(PR) UNISOC Launches Next-Gen 5G SoC T7520 on 6 nm EUV Manufacturing Node
UNISOC, a leading global supplier of mobile communication and IoT chipsets, today officially launched its new-generation 5G SoC mobile platform - T7520. Using cutting-edge process technology, T7520 enables an optimized 5G experience with substantially enhanced AI computing and multimedia imaging processing capabilities while lowering power consumption. <br />
<br />
T7520 is UNISOC's second-generation 5G smartphone platform. Built on a 6 nm EUV process technology and empowered by some of the latest design techniques, it offers substantially enhanced performance at a lower level of power consumption than ever.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/MCZLzN2WKQJjv9e6.jpg" data-width="678" data-height="415" target="_blank"><img src="https://www.techpowerup.com/img/MCZLzN2WKQJjv9e6_thm.jpg" width="212" height="130" alt="" /></a> </div><div class="readmore"><a href="/264513/unisoc-launches-next-gen-5g-soc-t7520-on-6-nm-euv-manufacturing-node">Read full story</a></div>
(PR) Western Digital Announces the WD Gold Series U.2 NVMe Enterprise
Western Digital is enabling small and medium-sized enterprises (SMEs) to easily transition to NVMe storage and dramatically improve application performance with a new addition to its portfolio of data center NVMe SSDs: the first enterprise-class NVMe SSD in the WD Gold family. Industry analyst firm IDC expects NVMe unit shipments to reach more than 79 percent of the market by 2023. With advancements in multi-core, multi-threaded CPUs, legacy storage technology has become a bottleneck to maximum application performance.<br />
<br />
Shipping in early cQ2 2020, the new WD Gold NVMe SSDs will be available in four capacities to channel partners and end customers. The WD Gold NVMe SSD is designed to be the primary storage in servers delivering superior response times, higher throughput and greater scale than existing SATA devices for enterprise applications. WD Gold NVMe SSDs complement recently launched WD Gold HDDs by providing a high-performance storage tier for applications and data sets that requires low latency or high throughput.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/bIaCC83FxThR7oQr.jpg" data-width="1061" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/bIaCC83FxThR7oQr_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JOmangdcll550fd2.jpg" data-width="1063" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/JOmangdcll550fd2_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JDy2A9mgASdrWKcM.jpg" data-width="1059" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/JDy2A9mgASdrWKcM_thm.jpg" width="143" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nDEW2K1vYoy2iacg.jpg" data-width="1063" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/nDEW2K1vYoy2iacg_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hEnh6dm5Au1sfHC9.jpg" data-width="932" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/hEnh6dm5Au1sfHC9_thm.jpg" width="126" height="130" alt="" /></a> </div><div class="readmore"><a href="/264510/western-digital-announces-the-wd-gold-series-u-2-nvme-enterprise-ssds">Read full story</a></div>
A Peek Under the Hood of Intel IGCC Game Capture (beta) Feature
Late last week, Intel <a href="https://www.techpowerup.com/264301/intel-adds-game-capture-and-broadcasting-features-to-graphics-command-center" target="_blank">released</a> a public beta of its own low-'cost' game capture and streaming feature that's part of Intel Graphics Command Center (IGCC) application that's distributed through Microsoft Store. At the time, Intel claimed that those gaming on Intel Graphics can yet record or stream their games with negligible performance impact. We now have a couple of under the hood details on how this feature works. The Game Capture and Streaming feature lets people record their gameplay or stream it to popular social networks such as Twitch, YouTube, etc. <br />
<br />
Intel's game capture and streaming feature leverages the VDEnc hardware AVC encoder featured in the company's Gen9 (and later) iGPUs, found on "Skylake" (or later) microarchitectures. At default quality settings, the feature only needs VDEnc, and hence offers practically zero iGPU performance impact when rendering 3D. At higher quality settings by the user, however, the feature switches to a dual-pipe encoder that taps into the compute power of the iGPU's execution units (EUs). These hence come with a performance impact on the iGPU when rendering 3D. We've also learned that IGCC game capture tech does not leverage discrete GPUs of other brands.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/nQm2rJvU3qy7JXms.jpg" data-width="1024" data-height="536" target="_blank"><img src="https://www.techpowerup.com/img/nQm2rJvU3qy7JXms_thm.jpg" width="248" height="130" alt="" /></a></div>
AMD Scores Another EPYC Win in Exascale Computing With DOE's "El Capitan" Two-Exaflop Supercomputer
AMD has been on a roll in both consumer, professional, and exascale computing environments, and it has just snagged itself another hugely important contract. The US Department of Energy (DOE) has just announced the winners for their next-gen, exascale supercomputer that aims to be the world's fastest. Dubbed "El Capitan", the new supercomputer will be powered by AMD's next-gen EPYC Genoa processors (Zen 4 architecture) and Radeon GPUs. This is the first such exascale contract where AMD is the sole purveyor of both CPUs and GPUs, with AMD's other design win with EPYC in the Cray Shasta being paired with NVIDIA graphics cards.<br />
<br />
El Capitan will be a $600 million investment to be deployed in late 2022 and operational in 2023. Undoubtedly, next-gen proposals from AMD, Intel and NVIDIA were presented, with AMD winning the shootout in a big way. While initially the DOE projected El Capitan to provide some 1.5 exaflops of computing power, it has now revised their performance goals to a pure 2 exaflop machine. El Capitan willl thus be ten times faster than the current leader of the supercomputing world, <a href="https://www.techpowerup.com/245470/with-summit-us-regains-leadership-from-china-in-top500-supercomputers-listing" target="_blank">Summit</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BlLjFXryRyIamR4w.jpg" data-width="970" data-height="546" target="_blank"><img src="https://www.techpowerup.com/img/BlLjFXryRyIamR4w_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4HjONa7sFFkjq1Vh.jpg" data-width="970" data-height="546" target="_blank"><img src="https://www.techpowerup.com/img/4HjONa7sFFkjq1Vh_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AnXRrkccbOtzHZXM.jpg" data-width="678" data-height="381" target="_blank"><img src="https://www.techpowerup.com/img/AnXRrkccbOtzHZXM_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/264500/amd-scores-another-epyc-win-in-exascale-computing-with-does-el-capitan-two-exaflop-supercomputer">Read full story</a></div>
Hold on to Your Aliens: SETI@Home to Enter Hibernation March 31st
Well, folks, if you've had your GPU happily cycling through computations for Berkeley SETI Research Center's Search for ExtraTerrestrial Intelligence program, you can start counting the watts you'll now be saving. In a post on the SETI@Home page, the researchers explained the reason they'll be politely refusing any additional computations: one, that they're already hitting the point of diminishing returns on computational uptime and have already analyzed all the required data; two, that they require all hands on deck to actually peruse the already gathered data for work on research papers, instead of hard at work managing the distributed processing of data.<br />
<br />
SETI@Home recommends users to attach their freely given computing power to another BOINC-based project, but I'd say there is no need to ask that: people who contribute to distributed computing projects such as these always want to do all their can for us all. Kudos to all of you who added your PC hardware to this project. Now, it's time to find a new home - and might I suggest Folding@Home's new project to <a rel="nofollow" href="https://foldingathome.org/2020/02/27/foldinghome-takes-up-the-fight-against-covid-19-2019-ncov/" target="_blank">thwart the current Coronavirus scourge</a>? And also, remember to make use of the TechPowerUp! team ID with Folding@Home (id 50711). If you want to take part in our folding community, feel free to hit up our <a href="https://www.techpowerup.com/forums/forums/folding-home.67/" target="_blank">forums</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8gImOnPHh9AuQDsf.jpg" data-width="1440" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/8gImOnPHh9AuQDsf_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qkmLVqEREcJe57D3.jpg" data-width="744" data-height="603" target="_blank"><img src="https://www.techpowerup.com/img/qkmLVqEREcJe57D3_thm.jpg" width="160" height="130" alt="" /></a> </div>PS: No wording on whether aliens have been found, so we'll all have to wait for these actual research papers to come out.
Three Unknown NVIDIA GPUs GeekBench Compute Score Leaked, Possibly Ampere?
(<b>Update, March 4th:</b> Another NVIDIA graphics card has been discovered in the Geekbench database, this one featuring a total of 124 CUs. This could amount to some 7,936 CUDA cores, should NVIDIA keep the same 64 CUDA cores per CU - though this has changed in the past, as when NVIDIA halved the number of CUDA cores per CU from Pascal to Turing. The 124 CU graphics card is clocked at 1.1 GHz and features 32 GB of HBM2e, delivering a score of 222,377 points in the Geekbench benchmark. We again stress that these can be just engineering samples, with conservative clocks, and that final performance could be even higher.)<br />
<br />
NVIDIA is expected to launch its next-generation Ampere lineup of GPUs during the GPU Technology Conference (GTC) event happening from March 22nd to March 26th. Just a few weeks before the release of these new GPUs, a GeekBench 5 compute score measuring OpenCL performance of the unknown GPUs, which we assume are a part of the Ampere lineup, has appeared. Thanks to the twitter user "_rogame" (@_rogame) who obtained a GeekBench database entry, we have some information about the CUDA core configuration, memory, and performance of the upcoming cards.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wGcsMYXrH0vpXjIM.jpg" data-width="1113" data-height="737" target="_blank"><img src="https://www.techpowerup.com/img/wGcsMYXrH0vpXjIM_thm.jpg" width="196" height="130" alt="" /></a><a href="https://www.techpowerup.com/img/UV4WmAwHSh91FG9h.jpg" data-width="603" data-height="244" target="_blank"><img src="https://www.techpowerup.com/img/UV4WmAwHSh91FG9h_thm.jpg" width="321" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jotvwy9t2bNblxzG.jpg" data-width="810" data-height="376" target="_blank"><img src="https://www.techpowerup.com/img/jotvwy9t2bNblxzG_thm.jpg" width="280" height="130" alt="" /></a> </div><div class="readmore"><a href="/264359/three-unknown-nvidia-gpus-geekbench-compute-score-leaked-possibly-ampere">Read full story</a></div>
(PR) EK Water Blocks Announces the EK Quantum Momentum TRX40 Monoblock for ASUS ROG Zenith II Extreme Motherboard
EK Water Blocks, the Slovenia-based premium computer liquid cooling gear manufacturer, makes another push into the HEDT market by releasing the world's first Socket sTRX4 based monoblock made for made for the ROG Zenith II Extreme motherboard. This is a complete all-in-one (CPU and motherboard) liquid cooling solution for the ASUS motherboard that is based on AMD TRX40 chipset for AMD Ryzen Threadripper processors. This monoblock is compatible with the ASUS ROG Zenith II Extreme motherboard.<br />
<br />
Designed and engineered in cooperation with ASUS, this monoblock uses Velocity sTR4 cooling engine to ensure the proper cooling of the large IHS that hides the spread-out chiplets. This water block directly cools AMD sTR4X type CPU, as well as the voltage regulation module (VRM). This kind of efficient VRM cooling on a TRX40 platform opens up even greater overclocking capabilities. Using a monoblock gets rid of the small fans that can be found on these TRX40 motherboards, hidden under the VRM heatsink grill.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ReNShEvPhQ59D7W2.jpg" data-width="900" data-height="350" target="_blank"><img src="https://www.techpowerup.com/img/ReNShEvPhQ59D7W2_thm.jpg" width="334" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FIDnrM0BWxVPQWXu.jpg" data-width="1440" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/FIDnrM0BWxVPQWXu_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bBUjN4WudYToU4lz.jpg" data-width="1440" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/bBUjN4WudYToU4lz_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="/264495/ek-water-blocks-announces-the-ek-quantum-momentum-trx40-monoblock-for-asus-rog-zenith-ii-extreme-motherboard">Read full story</a></div>
Bitspower Rolls Out the Touchaqua Notos 120 Fans with ARGB Lighting
Bitspower today rolled out the Touchaqua Notos 120 fans. Available in single-piece, 3-piece, and 5-piece packs, the fans are optimized for ventilating radiators. These 120 mm fans spin between 800 to 1,800 RPM, with a noise output ranging between 25-28 dBA. The company didn't mention air-flow specs or bearing type, but rates these fans with a 30,000-hour operational lifetime. The frames feature rubberized vibration-dampeners, while the LEDs are located in the hub. The fans take in 4-pin PWM for their prime function, and 3-pin ARGB for the lighting. <br />
<br />
The single-unit packs include just the fan, while 3-piece and 5-piece packs include fan-controllers and LED lighting hubs. The BPTA-DRGBMFC lighting controller included with the 3-piece and 5-piece packs takes in a single 3-pin ARGB and SATA power connection, and puts out eight 3-pin headers, with SMD buttons that let you cycle through presets. The BPTA-PFANMFH fan-controller module included with the 3-piece and 5-piece packs splits a single PWM signal among 10 downstream 4-pin PWM headers. It draws power from a SATA power connector. The single-piece, 3-piece, and 5-piece packs of the Bitspower Touchaqua Notos 120 are priced at NTD 310, 1,240, and 2,170, respectively.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/5maEwdbkM0DizLS0.jpg" data-width="641" data-height="594" target="_blank"><img src="https://www.techpowerup.com/img/5maEwdbkM0DizLS0_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uEVqZ82Na2hhiZld.jpg" data-width="1024" data-height="768" target="_blank"><img src="https://www.techpowerup.com/img/uEVqZ82Na2hhiZld_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/srtdHJyPDYIAyfru.jpg" data-width="1024" data-height="768" target="_blank"><img src="https://www.techpowerup.com/img/srtdHJyPDYIAyfru_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jyGoLhU0emTLsYe8.jpg" data-width="1024" data-height="768" target="_blank"><img src="https://www.techpowerup.com/img/jyGoLhU0emTLsYe8_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gjjE3K5a1bw8kJBl.jpg" data-width="1024" data-height="768" target="_blank"><img src="https://www.techpowerup.com/img/gjjE3K5a1bw8kJBl_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Kingston Releases DC1000M U.2 NVMe SSDs for Mixed-use in Data Centers
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., a world leader in memory products and technology solutions, today announced the availability of DC1000M, a new U.2 data center NVMe PCIe SSD. DC1000M is designed to support a wide range of data-intensive enterprise workloads, including Cloud computing, web hosting, high-performance computing (HPC), virtual infrastructures, artificial intelligence and deep learning applications. DC1000M joins the recently released DC1000B NVMe boot drive, the VMware Ready DC500 series SATA SSDs and DC450R to form the most complete range of superior enterprise-class data center storage solutions in the market. <br />
<br />
"Mission critical services and Cloud-based applications depend not only on lightning-fast IOPS and bandwidth, but also on the consistency and predictability of the data being serviced," said Keith Schimmenti, enterprise SSD business manager, Kingston. "DC1000M provides the stability and low latency for the evolving data center, while powering the workloads that require one drive write per day (1 DWPD) endurance."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/75PBVgfFTxi2gRCg.jpg" data-width="1660" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/75PBVgfFTxi2gRCg_thm.jpg" width="225" height="130" alt="" /></a> </div><div class="readmore"><a href="/264476/kingston-releases-dc1000m-u-2-nvme-ssds-for-mixed-use-in-data-centers">Read full story</a></div>
Ampere Computing Uncovers 80 Core "Cloud-Native" Arm Processor
Ampere Computing, a startup focusing on making HPC and processors from cloud applications based on Arm Instruction Set Architecture, today announced the release of a first 80 core "cloud-native" processor based on the Arm ISA. The new Ampere Altra CPU is the company's first 80 core CPU meant for hyper scalers like Amazon AWS, Microsoft Azure, and Google Cloud. Being built on TSMC's 7 nm semiconductor manufacturing process, the Altra is a CPU that is utilizing a monolithic die to achieve maximum performance. Using Arm's v8.2+ instruction set, the CPU is using the Neoverse N1 platform as its core, to be ready for any data center workload needed. It also borrows a few security features from v8.3 and v8.5, namely the hardware mitigations of speculative attacks.<br />
<br />
When it comes to the core itself, the CPU is running at 3.0 GHz frequency and has some very interesting specifications. The design of the core is such that it is 4-wide superscalar Out of Order Execution (OoOE), which Ampere refers to as "aggressive" meaning that there is a lot of data throughput going on. The cache levels are structured in a way that there is 64 KB of L1D and L1I cache per core, along with 1 MB of L2 cache per core as well. For system-level cache, there is 32 MB of L3 available to the SoC. All of the caches have Error-correcting code (ECC) built-in, giving the CPU a much-needed feature. There are two 128-bit wide Single Instruction Multiple Data (SIMD) units, which are there to do parallel processing if needed. There is no mention if they implement Arm's Scalable Vector Extensions (SVE) or not.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/RPJH6WI4ud9JdYmY.jpg" data-width="2000" data-height="1125" target="_blank"><img src="https://www.techpowerup.com/img/RPJH6WI4ud9JdYmY_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/264474/ampere-computing-uncovers-80-core-cloud-native-arm-processor">Read full story</a></div>
Seasonic Rolls Out its First Connect 750W Power Supply
Way back in Computex 2019, Seasonic <a href="https://www.techpowerup.com/256065/seasonic-connect-a-godsend-for-cable-management-novices" target="_blank">showed us</a> the Connect, a concept PC power-supply that greatly de-clutters your build's power cabling spaghetti by introducing the Connect device. This is essentially a power connector spinal back-plane that runs along the height of your tower, with shorter cables emerging from it. The company announced the product's market release with a 750-Watt model, the SSR-750FA. The contraption connects to the main unit through fewer, high-gauge cables. <br />
<br />
The business-end of the Seasonic Connect SSR-750FA is a slightly modified Prime 750 W, which is just 14 cm long, and has just the high-gauge cable emerging from it, which leads to the Connect module. Under the hood, the Prime 750 W offers single +12V rail design, 80 Plus Gold efficiency, DC to DC switching, most common electrical protection mechanisms, and a 135 mm fluid dynamic bearing fan to keep cool. Downstream connectivity of the SSR-750FA include a 24-pin ATX, two 4+4 pin EPS, four 6+2 pin PCIe power, 8-10 SATA power, and up to three 4-pin Molex. Seasonic is backing this PSU with a 10-year warranty.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Vw4ayAZzpOIfSkRh.jpg" data-width="1624" data-height="1200" target="_blank"><img src="https://www.techpowerup.com/img/Vw4ayAZzpOIfSkRh_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/i4a7pfaQfmOrrD4v.jpg" data-width="1624" data-height="1200" target="_blank"><img src="https://www.techpowerup.com/img/i4a7pfaQfmOrrD4v_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a39X7yZ2f9VNnn41.jpg" data-width="1135" data-height="1143" target="_blank"><img src="https://www.techpowerup.com/img/a39X7yZ2f9VNnn41_thm.jpg" width="129" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FEt1whgFnsr5D760.jpg" data-width="1624" data-height="1200" target="_blank"><img src="https://www.techpowerup.com/img/FEt1whgFnsr5D760_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BRDO7dKcGgupsopM.jpg" data-width="887" data-height="824" target="_blank"><img src="https://www.techpowerup.com/img/BRDO7dKcGgupsopM_thm.jpg" width="140" height="130" alt="" /></a></div>
Google Pulls the Plug on I/O 2020 Amidst COVID-19 Concerns
Google announced cancellation of the 2020 edition of Google I/O, the company's largest annual expo and trade-show. The announcement comes in light of the COVID-19 (novel coronavirus) outbreak that is now quantitatively affecting all regions of the world. Google I/O was originally scheduled for May 12-14, held on Google's home turf of Mountain View, California. Google I/O is an annual gathering of software- and web developers, and consumer electronics manufacturers from within Google's various ecosystems, such as Android. Paying attendees will be given the option to get a full refund, or an option to buy a ticket to the 2021 edition of Google I/O.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/goCm6rsmhxfd8rBU.jpg" data-width="1920" data-height="1080" target="_blank"><img src="https://www.techpowerup.com/img/goCm6rsmhxfd8rBU_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) EVGA Announces the B5 Series 80 Plus Bronze Power Supplies
Introducing the EVGA B5 power supplies, the latest power supplies to carry on the EVGA tradition of reliability, performance, and affordability. Here are 5 Facts about the new flagship for EVGA 80 PLUS Certified Bronze power supplies. The B5 power supplies provide maximum flexibility for system builders with a fully modular design and a small chassis across all models. At 150 mm length, the B5 power supplies provide solid, affordable power for all manner of system builds and cases. <br />
<br />
Next, the B5 power supplies feature one of the most important standards for reliability - Japanese capacitors. Featuring 100% Japanese capacitors on the 850 W and 750 W models, the B5 power supplies will provide a safe and reliable power for years to come. (650 W B5 and 550 W B5 models use a Japanese main capacitor.) The ultra-quiet 135 mm FDB fan becomes silent when coupled with EVGA ECO mode to turn off the fan in low to medium loads. The larger fan and carefully tuned profile creates a quieter experience than the B3 power supplies.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/aWWn3VPtsRd19Zmd.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/aWWn3VPtsRd19Zmd_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/B3O7bQ4nup80IvIr.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/B3O7bQ4nup80IvIr_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/guZLkdabPp8XUgd5.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/guZLkdabPp8XUgd5_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/45r1O3sgYGH1l2ow.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/45r1O3sgYGH1l2ow_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iz3tOqKBEzkx6UZf.jpg" data-width="960" data-height="960" target="_blank"><img src="https://www.techpowerup.com/img/iz3tOqKBEzkx6UZf_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="/264467/evga-announces-the-b5-series-80-plus-bronze-power-supplies">Read full story</a></div>
Intel Restarts 14 nm Operations in Costa Rica, Aims to Increase Capacity for Xeon Output
Intel has decided to restart operations in its previously <a href="https://www.techpowerup.com/199694/intel-transforms-its-operations-in-costa-rica" target="_blank">winded-down Costa Rica facilities</a>. An Intel Product Change Notification (PCN) for their Cascade Lake Xeon Scalable processors shows that the company has added Costa Rica to its three other "Test and Finish" sites - the other three are located in Penang (Malaysia), Kulim (Malaysia) and Vietnam. Intel's aim is to guarantee a "continuous supply" of the affected processors - namely, Cascade Lake second-generation Xeon Scalable processors in the Silver, Gold and Platinum lines (in both boxed and tray SKUs).<br />
<br />
This move, which will be done in phases. The first implementation of the Costa Rica operations will be effective on April 19th, with the remaining operations to come online on August 3rd. Intel expects to reduce dependency on their other three Test and Finish sites, while being able to bolster final production capacity by some 25% with this move.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cGnOrCAdgpY7LPJi.jpg" data-width="750" data-height="449" target="_blank"><img src="https://www.techpowerup.com/img/cGnOrCAdgpY7LPJi_thm.jpg" width="217" height="130" alt="" /></a></div>
(PR) EK Launches Direct Vector Waterblock - Developed for Reference De
EK Water Blocks, the premium computer liquid cooling gear manufacturer, is introducing a new variant of the extended compatibility high-performance water block specially designed for reference design based NVIDIA GeForce RTX 2080 Ti graphics cards. The EK-Quantum Vector Direct RTX RE Ti D-RGB. <br />
<br />
<b>EK-Quantum Vector Direct RTX RE Ti D-RGB</b><br />
EK-Quantum Vector Direct RTX RE Ti D-RGB water block is the version of EK-Quantum Vector water block from which the terminal is removed for added compatibility with space-constrained cases. Instead, the fittings are screwed directly into the top, allowing for a narrower enclosure. This water block uses the signature EK single-slot slim look and covers the entire PCB length. This sophisticated cooling solution will transform your powerful NVIDIA graphics card into a minimalistic, elegant piece of hardware with addressable D-RGB LED lighting.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/heo2R0FkuOo2oxJS.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://tpucdn.com/img/heo2R0FkuOo2oxJS_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UDEbCGwecDXvGlRp.jpg" data-width="1600" data-height="1067" target="_blank"><img src="https://tpucdn.com/img/UDEbCGwecDXvGlRp_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FgA7gVvttbMp64el.jpg" data-width="1200" data-height="400" target="_blank"><img src="https://tpucdn.com/img/FgA7gVvttbMp64el_thm.jpg" width="390" height="130" alt="" /></a> </div><div class="readmore"><a href="/264742/ek-launches-direct-vector-waterblock-developed-for-reference-design-nvidia-rtx-2080-ti-graphics-cards">Read full story</a></div>
(PR) Get POWERED Up with Logitech's Family of Wireless Chargers
Today Logitech unveils a line of beautifully-crafted wireless chargers to make your charging experience simple and effortless. Introducing the Logitech POWERED family of wireless chargers - Logitech POWERED 3-in-1 Dock, Logitech POWERED Stand and Logitech POWERED Pad. These wireless chargers are designed to be simple, reliable and look great in any room, whether it be your bedroom, kitchen, office or living room.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/bZ47WsOoNErCfQ35.jpg" data-width="974" data-height="650" target="_blank"><img src="https://tpucdn.com/img/bZ47WsOoNErCfQ35_thm.jpg" width="195" height="130" alt="logitech qi wireless charger" /></a> </div><div class="readmore"><a href="/264736/get-powered-up-with-logitechs-family-of-wireless-chargers">Read full story</a></div>
(PR) Everest Sets Stretch Goal for a Midnight Black Edition of its Innovative Keyboard
Everest is a fully customizable, mechanical gaming keyboard that is a revolution in choice. Brought to you by Mountain, Everest can be pre-ordered here, from 95€ ($90 / £85 - depending on exchange rate). The Everest keyboard is available in Barebone, Core (TKL) and Max versions. The new stretch goal enables a variant of Everest in Midnight Black, a deep black anodized aluminium design, if the campaign reaches at least 100,000€ before it ends on April 2nd. If reached, the stretch goal will enable every backer to choose between Gunmetal Gray and Midnight Black. <br />
<br />
Many backers requested stretch goals and a large part of the community asked for an all-black version of Everest. Mountain's focus on the user-centric approach doesn't end with the product design. "We appreciate all the support we have received so far and continue to listen to customer feedback," says Tobias Brinkmann, Founder & CEO of Mountain. "With the incredible success of Everest on Kickstarter, it didn't take long until we received the first inquiries of stretch goals and a Black version was in particular high demand. We are all about freedom of choice and delivering products that customers ask for, so we are pleased to be able to do so with the Midnight Black Edition!"<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wowXf54rzU3byydc.jpg" data-width="1205" data-height="960" target="_blank"><img src="https://tpucdn.com/img/wowXf54rzU3byydc_thm.jpg" width="163" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6hlpOjUJKZ2jyk7g.jpg" data-width="1540" data-height="960" target="_blank"><img src="https://tpucdn.com/img/6hlpOjUJKZ2jyk7g_thm.jpg" width="209" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tVSv1nZazKgcVqBK.jpg" data-width="1389" data-height="960" target="_blank"><img src="https://tpucdn.com/img/tVSv1nZazKgcVqBK_thm.jpg" width="188" height="130" alt="Everest keyboard full midnight black" /></a> <a href="https://www.techpowerup.com/img/qUGGsjM9z6YlG1A1.jpg" data-width="1176" data-height="960" target="_blank"><img src="https://tpucdn.com/img/qUGGsjM9z6YlG1A1_thm.jpg" width="159" height="130" alt="Everest Keyboard core midnight black" /></a> <a href="https://www.techpowerup.com/img/O1Pmm31CZC5xTb60.jpg" data-width="1522" data-height="960" target="_blank"><img src="https://tpucdn.com/img/O1Pmm31CZC5xTb60_thm.jpg" width="206" height="130" alt="" /></a> </div>Support the Everest keyboard Midnight Black Kickstarter goal stretch <a rel="nofollow" href="https://www.kickstarter.com/projects/mountaingg/everest-the-worlds-most-innovative-customizable-keyboard?ref=znggcz&token=892f28b0" target="_blank">here</a>.<div class="readmore"><a href="/264734/everest-sets-stretch-goal-for-a-midnight-black-edition-of-its-innovative-keyboard">Read full story</a></div>
TechPowerUp GPU-Z 2.30.0 Released
TechPowerUp today released the latest version of GPU-Z, the popular graphics subsystem information and diagnostic utility. Version 2.30.0 introduces several new feature- and stability updates, and adds support for new GPUs. To begin with, support is added for AMD Radeon RX 590 GME, Radeon Pro W5500, Pro V7350x2, FirePro 2260, and Instinct MI25 MxGPU; Intel UHD (Core i5-10210Y), and a rare GeForce GTS 450 Rev 2. TechPowerUp GPU-Z 2.30.0 introduces support for reporting hardware-accelerated GPU scheduling in Windows 10 20H1 in the Advanced tab. The tab now also has the ability to show WDDM 2.7, Shader Model 6.6, DirectX Mesh Shaders, and DXR tier 1.1. A workaround for the DirectML detection on Windows 10 19041 built has been added. Graphics driver registry path is now displayed in the General section of the Advanced tab.<br />
<br />
In the Sensors tab, the NVIDIA VDDC sensor has been renamed to "GPU voltage," and AMD's "GPU only power draw" sensor to "GPU chip-only power draw" to clarify that the sensor only measures the power draw of the GPU package and not the whole graphics card. AMD "Renoir" based processors and their iGPUs now show up as 7 nm. Windows Basic Display driver now no longer reports its status as WHQL or Beta. A crash during DirectX 12 detection has been fixed.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/M9Dlb2AMeUvGndaJ.jpg" data-width="532" data-height="576" target="_blank"><img src="https://tpucdn.com/img/M9Dlb2AMeUvGndaJ_thm.jpg" width="120" height="130" alt="TechPowerUp GPU-Z 2.23.0 main window" /></a> </div><b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/techpowerup-gpu-z/" target="_blank">TechPowerUp GPU-Z 2.30.0</a><br />
<br />
The change-log follows.<div class="readmore"><a href="/264733/techpowerup-gpu-z-2-30-0-released">Read full story</a></div>
Give Your PCs the Refreshment of Genuine Windows 10 and Office 2019 with GoodOffer24
Spring is the season of new beginnings and cleaning up. Why not give your PCs the functional boost they need with genuine Windows 10 and Office 2019 software? With GoodOffer24, you can have genuine, globally-valid software at highly discounted prices sweetened further with exclusive discounts to TechPowerUp readers. Get genuine Windows 10 Pro for as little as $12.03, and the very latest Office 2019 Professional Plus for as little as $47.52. Combine the two for $50.58 and save even more. Give your business computers the edge they need with Windows 10 Enterprise LTSC for $11.49. Don't need the latest versions? No problems, check out Office 2016 and Windows 10 Home at great prices. GoodOffer24 protects your privacy and payment instruments with PayPal.<br />
<br />
Don't forget to apply the TechPowerUp-exclusive coupon code <b>TP30</b> on the following items to avail the prices you see here. <br />
<br />
<a rel="nofollow" href="https://www.goodoffer24.com/windows-10-pro-professional-cd-key-deals.html?currency=USD" target="_blank">Buy Windows 10 Pro for $12.03</a> | <a rel="nofollow" href="https://www.goodoffer24.com/windows-10-enterprise-2019-ltsc.html?currency=USD" target="_blank">Buy Windows 10 Enterprise LTSC for $11.49</a> | <a rel="nofollow" href="https://www.goodoffer24.com/windows-10-pro-professional-cd-key-32-64-bit-2-pc-1.html?currency=USD" target="_blank">Buy Windows 10 Pro twin-pack for $19.31</a> | <a rel="nofollow" href="https://www.goodoffer24.com/windows-10-home-32-64-bit-new.html?currency=USD" target="_blank">Buy Windows 10 Home for $11.29</a> | <a rel="nofollow" href="https://www.goodoffer24.com/microsoft-office-2016-pro-plus-c-deal-key.html?currency=USD" target="_blank">Buy Office 2016 Professional Plus for $26.19 | Buy Windows 10 Pro + Office 2016 Professional for $29.89</a> | <a rel="nofollow" href="https://www.goodoffer24.com/windows-10-home-office-2016-pro-bundle.html?currency=USD" target="_blank">Buy Windows 10 Home + Office 2016 Professional for $27.59</a> | <a rel="nofollow" href="https://www.goodoffer24.com/microsoft-office-2016-home-and-student.html?currency=USD" target="_blank">Buy Office 2016 Home and Student for $20.69</a> | <a rel="nofollow" href="https://www.goodoffer24.com/microsoft-office-2019-professional-plus-cd-key-1pc.html?currency=USD" target="_blank">Buy Office 2019 Professional Plus for $47.52</a> | <a rel="nofollow" href="https://www.goodoffer24.com/windows-10-pro-office-2019-pro-bundle.html?currency=USD" target="_blank">Buy Windows 10 Pro + Office 2019 Professional for $50.58</a> | <a rel="nofollow" href="https://www.goodoffer24.com/windows-10-home-office-2019-pro-bundle.html?currency=USD" target="_blank">Buy Windows 10 Home + Office 2019 Professional for $48.29</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/QkAE1OxznrPw2Jit.jpg" data-width="1200" data-height="630" target="_blank"><img src="https://tpucdn.com/img/QkAE1OxznrPw2Jit_thm.jpg" width="248" height="130" alt="" /></a> </div><div class="readmore"><a href="/264732/give-your-pcs-the-refreshment-of-genuine-windows-10-and-office-2019-with-goodoffer24">Read full story</a></div>
New U.S. Regulation Prevents Huawei Buying from TSMC, Could Backfire: Chinese Press
Huawei is planning a response to a recent administrative move by the U.S. Department of Commerce that makes it impossible for foreign companies such as Taiwan's TSMC to serve it. Huawei's mobile SoC design house subsidiary, HiSilicon, is highly dependant on TSMC to contract manufacture its SoCs on the company's 7 nm (N7), and various 10 nm-class FinFET nodes. Huawei is preparing to port some of its SoC designs to a 14 nm node of China's state-owned Semiconductor Manufacturing International Corp (SMIC) as contingency. Without access to 7 nm, Huawei's plans to lead the global 5G infrastructure market would hit severe roadblocks. The U.S. move has triggered a heated (and somewhat loaded) reprisal from Global Times, a newspaper that's regarded in diplomatic circles as a platform for hawkish unofficial messaging by the Chinese government. <br />
<br />
China could blackmail the U.S. into lifting its trade ban and a more recent supplier-access denial to Huawei, with potential shortages of essential medical supplies, particularly face masks. An eminent Chinese industrial analyst, Ma Jihua, told Chinese newspaper Global Times: "The Huawei problem has been elevated to one of national interests and Chinese firms may stop supplying much-needed face masks if the U.S. provokes [a fight with Huawei]." In addition to Chinese suppliers, American firms such as 3M manufacture face masks in China, besides several other consumables needed to fight epidemics, such as gloves, hazmat suits, goggles, etc.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/j6yaCdosydx4Rpc3.jpg" data-width="678" data-height="382" target="_blank"><img src="https://tpucdn.com/img/j6yaCdosydx4Rpc3_thm.jpg" width="231" height="130" alt="No huawei, no face masks: China to the US" /></a> </div><div class="readmore"><a href="/264730/new-u-s-regulation-prevents-huawei-buying-from-tsmc-could-backfire-chinese-press">Read full story</a></div>
Microsoft Patches Critical SMBv3 Protocol Vulnerability
Microsoft today released updates to Windows 10 patching a critical vulnerability found in its Server Message Block (SMB) version 3 protocol. Released to Windows 10 versions 1903 and 1909, the Cumulative Update KB4551762 includes a patched SMB 3.1.1 protocol component. The update mitigates a security vulnerability with SMBv3 chronicled under CVE-2020-0796, which enabled remote code execution. "To exploit the vulnerability against a server, an unauthenticated attacker could send a specially crafted packet to a targeted SMBv3 server. To exploit the vulnerability against a client, an unauthenticated attacker would need to configure a malicious SMBv3 server and convince a user to connect to it," reads the Microsoft security advisory. To get the update, simply make Windows Update "check for updates," or get the msu files from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a rel="nofollow" href="http://www.catalog.update.microsoft.com/Search.aspx?q=KB4551762" target="_blank">Windows 10 and Windows Server Cumulative Update KB4551762</a>
As Stock Markets Tank Near Double-Digits, Tech Stocks Tank With Them
Stock markets around the world are experiencing a spectacular crash riding on COVID-19 investor fears, wiping out trillions of Dollars in investor wealth worldwide. Prominent indices around the world report some of the highest intra-day falls since the 2008 financial crisis. Tech stocks are hardly immune, with AMD reporting a 14.64% fall in share price settling down at 39.01 (it was over 48 right after the company's 2020 Financial Analyst Day just last week). NVIDIA is another big loser at the markets, with a 12.24% fall and 216.31 share price. Intel is right behind, with a 11.85% fall down to 45.54, and Micron Technology down 11.23% at 38.81.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/mKeZbYVacYRcK6Go.jpg" data-width="600" data-height="500" target="_blank"><img src="https://tpucdn.com/img/mKeZbYVacYRcK6Go_thm.jpg" width="156" height="130" alt="" /></a></div>
(PR) Micron Samples the Industry's First uMCP Product With LPDDR5 to Increase Performance and Battery Life in 5G Smartphones
Micron Technology, Inc., today announced it began sampling the industry's first universal flash storage (UFS) multichip package (uMCP) with low-power DDR5 (LPDDR5) DRAM. The uMCP provides high-density and low-power storage designed to fit on slim and compact midrange smartphone designs.<br />
<br />
Micron's new uMCP5 packaging builds on the company's innovation and leadership in multichip form factors. Micron uMCPs combine low-power DRAM with NAND and an onboard controller, using 40% less space compared to a two-chip solution. This optimized configuration saves power, reduces memory footprint and enables smaller and more agile smartphone designs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/tFiH9eFjSmuwlzio.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://tpucdn.com/img/tFiH9eFjSmuwlzio_thm.jpg" width="231" height="130" alt="RAM Production" /></a> </div><div class="readmore"><a href="/264715/micron-samples-the-industrys-first-umcp-product-with-lpddr5-to-increase-performance-and-battery-life-in-5g-smartphones">Read full story</a></div>
In Light of COVID-19, MSI Extends Warranty Protection for Customers With Warranties Expiring in March
COVID-19 has brought many industries in the world to an almost standstill as quarantine mechanisms are put in place in both public and private sectors. The economic impact of the - now declared pandemic by the World Health Organization - outbreak will likely be felt for years to come. Thank to that globalization and the interconnectedness of various markets, including the global supply chain.<br />
<br />
In light of this, MSI has decided to extend the warranty period for products falling in the categories of desktops, motherboards, AIO computers, PC cases and monitors (this excludes graphics cards and laptops, which are also quite important in the overall companies' outlook). Furthermore, this warranty extension is limited to countries that have been the most affected by the recent outbreak - U.S., Australia, Bahrain, Belgium, Canada, France, Germany, Hong Kong, Italy, Japan, Kuwait, Malaysia, Netherlands, Norway, Singapore, South Korea, Spain, Sweden, Switzerland and the UK.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/TSWCyyxA9Me4YYhM.jpg" data-width="960" data-height="540" target="_blank"><img src="https://tpucdn.com/img/TSWCyyxA9Me4YYhM_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="/264712/in-light-of-covid-19-msi-extends-warranty-protection-for-customers-with-warranties-expiring-in-march">Read full story</a></div>
Microsoft Part of Global Operation to Disrupt World's Largest Online Criminal Network
Microsoft today announced it was part of a global operation meant to disrupt the world's largest online criminal network. Dubbed Necurs, the network functioned as a botnet - a number of computers infected by malware or otherwise malicious software that are functioning on behalf of a botmaster. The botmaster is basically akin to an administrator - but for nefarious purposes. <br />
<br />
Thought to be controlled by criminals based in Russia, Necurs spanned more than nine million computing devices across 35 countries, making it one of the largest spam email threat ecosystems known to authorities - besides being used for pump-and-dump stock scams, fake pharmaceutical spam email and "Russian dating" scams. Necurs was such a well-oiled machine that it was seen sending 3.8 million spam messages to over 40 million targets across a 58-day long time frame in the investigation.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/GBwpAt3OC2034kxc.jpg" data-width="2000" data-height="1000" target="_blank"><img src="https://tpucdn.com/img/GBwpAt3OC2034kxc_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kg58MNBUDDRVnHkp.jpg" data-width="1000" data-height="698" target="_blank"><img src="https://tpucdn.com/img/kg58MNBUDDRVnHkp_thm.jpg" width="186" height="130" alt="" /></a> </div><div class="readmore"><a href="/264710/microsoft-part-of-global-operation-to-disrupt-worlds-largest-online-criminal-network">Read full story</a></div>
TSMC to Kickstart 5 nm Volume Production in April, Production Capacity Already Fully Booked
TSMC will be doing good on their <a href="https://www.techpowerup.com/260575/tsmc-5-nm-on-track-for-q2-2020-hvm-ramping-faster-than-7-nm" target="_blank">previous expectations</a> for a H2 2020 ramp-up for high volume production (HVM) on their 5 nm manufacturing process. The new 5 nm fabrication process is an Extreme Ultraviolet lithography (EUV) one, with up to 14 layers being etchable onto the silicon wafers, as opposed to five and six, respectively, for TSMC's N7+ and N6 processes.<br />
<br />
Volume production will start with Apple's A14 SoC, meant to be driving next-generation iPhones that should hit shelves by September this year (should the COVID-19 pandemic let it be so). Apple is using two thirds of TSMC's capacity for 5 nm as is with this SoC; it's currently unclear which client (or clients) are getting the leftover one third capacity. TSMC announced back in December that they were seeing yields upwards of 80% in 5 nm EUV fabrication, so now it's "just" a matter of monetizing the process until their 3 nm iteration comes online, expectedly, in 2022.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/f7II8jYSsNQ4ovRF.jpg" data-width="678" data-height="464" target="_blank"><img src="https://tpucdn.com/img/f7II8jYSsNQ4ovRF_thm.jpg" width="190" height="130" alt="" /></a></div>
With E3 2020 in Tatters, Xbox E3 Event to Go Ahead Online
Microsoft's Xbox business head Phil Spencer announced that the company is planning to take the Xbox E3 Event online with a Digital Event. The 2020 edition of the Electronics Entertainment Expo (E3), the world's largest video gaming industry trade show, was cancelled for the first time since its 1995 debut, in the wake of the COVID-19 global pandemic. <br />
<br />
Microsoft Xbox is one of its latest participants with an E3 event almost every year. The 2020 edition of E3 was particularly important for Microsoft, as the company was expected to shed more light on its next-generation game console platform (or platforms, according to some rumors). Particularly since Sony had already announced absence from the show, it would be a Microsoft-focused event. "E3 has always been an important moment for Team Xbox. Given this decision, this year we'll celebrate the next generation of gaming with the @[Only registered and activated users can see links. Click Here To Register...] community and all who love to play via an Xbox digital event," tweeted Spencer. He added that details on the timing of the Digital Event will be put out in the coming weeks.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/caoTI0AUFpA2xP3j.jpg" data-width="640" data-height="376" target="_blank"><img src="https://tpucdn.com/img/caoTI0AUFpA2xP3j_thm.jpg" width="221" height="130" alt="" /></a></div>
CD Projekt Red Confirms a "The Witcher" Title Will Follow "Cyberpunk 2
Polish gaming powerhouse CD Projekt confirmed that it has no plans of sitting idle after finishing work on its magnum opus and the year's most anticipated game, "Cyberpunk 2077." In an interview with journalists, CD Projekt president Adam Kiciński announced that the company will begin work on the next chapter in "The Witcher" franchise. Kiciński wouldn't take names or call the game "The Witcher 4," but simply that the game will be set in the fictional universe by Andrzej Sapkowski. Kiciński stated that a small team within CDPR will be tasked with preparatory work on this game, while larger teams will focus on DLCs and content additions for "Cyberpunk 2077" over an extended period of time.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/eEOtkpkBEkVNX6Vy.jpg" data-width="1500" data-height="877" target="_blank"><img src="https://tpucdn.com/img/eEOtkpkBEkVNX6Vy_thm.jpg" width="222" height="130" alt="" /></a></div>
E3 2020 Cancelled due to Coronavirus
The world's largest gathering of video game publishers, developers, gamers, and associated artists, the Electronic Entertainment Expo, or E3, won't be held this year, according to an ArsTechnica report citing sources among members of ESA, the show's organizers. At the time of this writing, ESA made no formal announcement from the ESA about the show's fate - whether it's cancelled, delayed, or transformed into an online event like many other trade-shows this year. Most trade-shows scheduled for 2020 have suffered one of these three due to the COVID-19 outbreak that has recently gained "global pandemic" status by the World Health Organization. COVID-19 is a highly contagious respiratory tract infection that has claimed over 3,000 lives globally. This would be the first time that E3 has been cancelled since its debut edition in 1995. <br />
<br />
<b>Update Mar 12th</b>: It's official, E3 2020 has been cancelled. "After careful consultation with our member companies regarding the health and safety of everyone in our industry - our fans, our employees, our exhibitors and our longtime E3 partners - we have made the difficult decision to cancel E3 2020, scheduled for June 9-11 in Los Angeles," says organizer ESA in its statement announcing the cancellation<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3XMEUqST0GLFWXqF.jpg" data-width="820" data-height="312" target="_blank"><img src="https://tpucdn.com/img/3XMEUqST0GLFWXqF_thm.jpg" width="342" height="130" alt="E3 2020 cancelled" /></a></div>
Keep an Eye Out for March 19, Says NVIDIA
NVIDIA's ANZ (Australia and New Zealand) Twitter handle posted a curious-looking teaser of something to look forward to on March 19. The now-deleted Tweet contained an animation showing the shape of an eye tracking two points of light crossing its iris. This date falls just a couple of days ahead of the March 22 debut of GTC 2020, the NVIDIA-promoted trade-show covering all things graphics tech. As many on the tweet and online forums discussing have pointed out, the announcement could probably be related to a commercial release of NVIDIA's foveated rendering technology that was demonstrated way back at SIGGRAPH 2016, at a time when VR and related technologies were all the rage. <br />
<br />
The concept of foveated rendering is straightforward: eye-tracking is leveraged to ensure that areas of the frame you're looking at are rendered in greater detail than the others, to conserve system resources and improve performance. This is achieved by tracking your foveal vision (the primary part of your vision focused on detail), while shedding resources on parts of the frame that fall within your peripheral vision. Compared to 2016, rendering technologies to facilitate foveated rendering have advanced. A related technology is variable shading rate (VRS), which allows an application to render different parts of the scene at different levels of detail, and improve performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/K0TteBpks1EYGNaC.jpg" data-width="440" data-height="224" target="_blank"><img src="https://tpucdn.com/img/K0TteBpks1EYGNaC_thm.jpg" width="255" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wcs8OhWGqRtIQnvL.jpg" data-width="1200" data-height="675" target="_blank"><img src="https://tpucdn.com/img/wcs8OhWGqRtIQnvL_thm.jpg" width="231" height="130" alt="" /></a> </div>A video presentation detailing NVIDIA's foveated rendering tech from 2016 follows.<div class="readmore"><a href="/264699/keep-an-eye-out-for-march-19-says-nvidia">Read full story</a></div>
(PR) Xilinx Announces World's Highest Bandwidth, Highest Compute Density Adaptable Platform for Network and Cloud Acceleration
Xilinx, Inc. today announced Versal Premium, the third series in the Versal ACAP portfolio. The Versal Premium series features highly integrated, networked and power-optimized cores and the industry's highest bandwidth and compute density on an adaptable platform. Versal Premium is designed for the highest bandwidth networks operating in thermally and spatially constrained environments, as well as for cloud providers who need scalable, adaptable application acceleration. <br />
<br />
Versal is the industry's first adaptive compute acceleration platform (ACAP), a revolutionary new category of heterogeneous compute devices with capabilities that far exceed those of conventional silicon architectures. Developed on TSMC's 7-nanometer process technology, Versal Premium combines software programmability with dynamically configurable hardware acceleration and pre-engineered connectivity and security features to enable a faster time-to-market. The Versal Premium series delivers up to 3X higher throughput compared to current generation FPGAs, with built-in Ethernet, Interlaken, and cryptographic engines that enable fast and secure networks. The series doubles the compute density of currently deployed mainstream FPGAs and provides the adaptability to keep pace with increasingly diverse and evolving cloud and networking workloads.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/GA3FjFMsfsLCb12M.jpg" data-width="800" data-height="553" target="_blank"><img src="https://tpucdn.com/img/GA3FjFMsfsLCb12M_thm.jpg" width="188" height="130" alt="Xilinx Versal ACAP FPGA" /></a> </div><div class="readmore"><a href="/264677/xilinx-announces-worlds-highest-bandwidth-highest-compute-density-adaptable-platform-for-network-and-cloud-acceleration">Read full story</a></div>
Intel Processors Hit with LVI Security Vulnerabilities, Mitigation Hits Performance Hard
A new class of security vulnerabilities affect Intel processors, which can cause them to leak out sensitive information if probed in a certain way, but that's not the worst news for Intel and its users. The software- or firmware-level mitigation for this vulnerability can inflict performance reductions "ranging from 2x to 19x," according to a report by The Register. A full mitigation for the new Load Value Injection (LVI) class of vulnerabilities requires Intel to redesign software compilers. The vulnerability is chronicled under CVE-2020-0551 and Intel-SA-00334. It is not a remote code execution threat, however, it puts multi-tenant machines, such as physical servers handling multiple tenants via virtual servers. <br />
<br />
"LVI turns previous data extraction attacks around, like Meltdown, Foreshadow, ZombieLoad, RIDL and Fallout, and defeats all existing mitigations. Instead of directly leaking data from the victim to the attacker, we proceed in the opposite direction: we smuggle — "inject" — the attacker's data through hidden processor buffers into a victim program and hijack transient execution to acquire sensitive information, such as the victim's fingerprints or passwords," the reasearchers write in the abstract of their <a rel="nofollow" href="https://lviattack.eu/lvi.pdf" target="_blank">paper</a> describing the vulnerability. Anti-virus manufacturer BitDefender independently discovered LVI and shared its study with Intel. The company could publish its findings in February. Additional technical details are found in the group's website <a rel="nofollow" href="https://lviattack.eu/" target="_blank">here</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lXNrW86hh1Pyk4ed.jpg" data-width="1088" data-height="667" target="_blank"><img src="https://tpucdn.com/img/lXNrW86hh1Pyk4ed_thm.jpg" width="212" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QUhzyu6NYrBFfuSt.jpg" data-width="1175" data-height="960" target="_blank"><img src="https://tpucdn.com/img/QUhzyu6NYrBFfuSt_thm.jpg" width="159" height="130" alt="" /></a> </div><small>Many Thanks to biffzinker for the tip.</small>
(PR) Biostar Announces the A10N-9630E MINI ITX Quad Core SoC Motherboard
BIOSTAR has been a manufacturer of robust and highly reliable motherboards for many years and has a wide range of models on both Intel and AMD platforms to choose from and a plethora of supplementary components catering to many user preferences.<br />
<br />
Designed in the Mini-ITX form factor, the new BIOSTAR A10N-9630E motherboard is built with form and functionality to rival everything else in the market. With an inbuilt AMD A10-9630P quad-core processor and support for AMD Radeon R5 graphics, the BIOSTAR A10N-9630E is sleek, reliable and affordable suited for consumers who like to run basic tasks such as browsing the web, sending emails and running office applications and is perfect for many industrial applications because its ultra-small Mini-ITX form factor suited for small builds that save office space creating a neat, tidy workspace. The A10N-9630E motherboard is also designed for edge computing with better performance and low power consumption.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BPSH1OpfVEv6PGpD.jpg" data-width="1024" data-height="926" target="_blank"><img src="https://tpucdn.com/img/BPSH1OpfVEv6PGpD_thm.jpg" width="144" height="130" alt="Biostar Bristol Ridge motherboard" /></a> <a href="https://www.techpowerup.com/img/wADZ4im8RyzgygEO.jpg" data-width="1024" data-height="961" target="_blank"><img src="https://tpucdn.com/img/wADZ4im8RyzgygEO_thm.jpg" width="139" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tZsQWvQzpIYmfTal.jpg" data-width="922" data-height="656" target="_blank"><img src="https://tpucdn.com/img/tZsQWvQzpIYmfTal_thm.jpg" width="183" height="130" alt="" /></a> </div><div class="readmore"><a href="/264675/biostar-announces-the-a10n-9630e-mini-itx-quad-core-soc-motherboard">Read full story</a></div>
(PR) MSI Expands its B450 MAX Series with Gaming Pro Carbon MAX WiFi and Bazooka MAX WiFi
MSI, a world-leading motherboard manufacturer, proudly introduces two new B450 MAX motherboards, B450 GAMING PRO CARBON MAX WIFI and B450M BAZOOKA MAX WIFI. For the 3rd Gen Ryzen processors, the new MAX motherboards are optimized with best compatibility in every aspects. These two new MAX motherboards can satisfy more gamers and users.<br />
<br />
As the most iconic motherboard for mainstream gamers, this time GAMING PRO CARBON also includes a MAX version for stylish gamers to perfectly match with 3rd Gen Ryzen processors. With millions colors and 17 LED effects, Mystic Light offers customization options for ever-changing RGB experience. B450 GAMING PRO CARBON MAX WIFI is also equipped with USB 3.2 Gen2 solution with up to 10 Gbps transfer speed. Audio Boost 4 with Nahimic 3 provides stable and high quality sound effects with premium components. Furthermore, concerning the higher performance-based 3rd Gen Ryzen processors, B450 GAMING PRO CARBON MAX WIFI includes Extended Heatsink Design and M.2 Shield to ensure better heat dissipation effects and lower temperature for CPUs and M.2 devices. Flash BIOS Button becomes more and more important and gives more convenience for BIOS updates.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/WsscnbYtIMG786nx.jpg" data-width="772" data-height="661" target="_blank"><img src="https://tpucdn.com/img/WsscnbYtIMG786nx_thm.jpg" width="152" height="130" alt="MSI B450 Gaming Pro Carbon MAX WiFi" /></a> <a href="https://www.techpowerup.com/img/yHhPeKuWgeD7vRVR.jpg" data-width="1024" data-height="651" target="_blank"><img src="https://tpucdn.com/img/yHhPeKuWgeD7vRVR_thm.jpg" width="204" height="130" alt="MSI B450 Gaming Pro Carbon MAX WiFi" /></a> <a href="https://www.techpowerup.com/img/kfEDw6Faf71fPwzX.jpg" data-width="500" data-height="448" target="_blank"><img src="https://tpucdn.com/img/kfEDw6Faf71fPwzX_thm.jpg" width="145" height="130" alt="MSI B450M Bazooka MAX WiFi" /></a> </div><div class="readmore"><a href="/264674/msi-expands-its-b450-max-series-with-gaming-pro-carbon-max-wifi-and-bazooka-max-wifi">Read full story</a></div>
URCDKeys Spring Sale: Great Prices on Genuine Software
URCDKeys maintains great prices on genuine software year-round, Spend less on genuine software and allocate more of your new PC build budget on hardware. Use TechPowerUp-exclusive discount codes to avail special prices on per-PC licenses of Windows 10 Pro, Office 2019 Professional Plus, combinations of the two, or even combinations with other editions of Office. Have both a desktop and notebook to upgrade? Save more on twin-packs. URCDKeys prices on globally-valid, lifetime licenses of Office in particularly should save you big compared to annually renewing Office 365 subscriptions. Windows 10 Pro the preferred operating system for gamers and enthusiasts. URCDKeys safeguards your payment instruments with PayPal. Grab what fits your needs best from the links below. <br />
<br />
Don't forget to use the discount code <b>TP20 </b>at checkout to avail the prices you see here.<br />
<br />
<a rel="nofollow" href="https://www.urcdkeys.com/microsoft-windows-10-pro-oem-cd-key-global_1966-20.html#techpowerup" target="_blank">Buy Windows 10 Pro for $13.99</a> | <a rel="nofollow" href="https://www.urcdkeys.com/microsoft-windows-10-pro-oem-cd-key-global-2-pc-.html#tp" target="_blank">Buy Windows 10 Pro 2-pack for $21.68</a> | <a rel="nofollow" href="https://www.urcdkeys.com/office2016-professional-plus-cd-key-global_1980-20.html#techpowerup" target="_blank">Buy Office 2016 Professional Plus for $33.21</a> | <a rel="nofollow" href="https://www.urcdkeys.com/office2019-professional-plus-cd-key-global_2183-20.html#techpowerup" target="_blank">Buy Office 2019 Professional Plus for $58.06</a> | <a rel="nofollow" href="https://www.urcdkeys.com/windows10-pro-office2016-professional-plus-cd-keys-pack_2002-20.html#techpowerup" target="_blank">Buy Windows 10 Pro + Office 2016 Professional Plus Combo for $39.18</a> | <a rel="nofollow" href="https://www.urcdkeys.com/windows10-pro-oem-office2019-professional-plus-cd-keys-pack_2329-20.html#techpowerup" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus for $64.54</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/JismQdeelYCJwhA0.jpg" data-width="556" data-height="491" target="_blank"><img src="https://tpucdn.com/img/JismQdeelYCJwhA0_thm.jpg" width="147" height="130" alt="" /></a></div>
GDC Rescheduled to a Three Day "GDC Summer" Set for August 4-6
2020's Game Developers Conference (GDC), originally set to be live from March 16th through March 20th, was one of the first tech shows to be cancelled in wake of the Sars-Cov-2 outbreak. Now, the organization has announced that the event has been rescheduled a full 5 months later for August 2020. The event has been set for a three-day "GDC Summer" still taking place in Moscone Center in San Francisco, USA, starting August 4th and ending August 6th. Passes for the exhibition are already available, with early takers being offered heavy discounts over the on-floor passes.<br />
<br />
GDC has been the stage for a number of high-profile gaming and services announcements, with the 2019 edition seeing announcements for Google's Stadia, EPIC Games detailing new features for its Unreal engine, and AMD taking the lid of their (then) upcoming 3rd generation Ryzen CPUs. Intel was first expected to detail their Xe graphics architecture at GDC 2020. It remains to be seen whether the blue giant will still be doing so in wake of this delay, or if the company will find an in-house (albeit likely online) alternative to get word of mouth flowing on their upcoming high performance graphics architecture.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/xa7kdPGi9I7MbVVE.jpg" data-width="1236" data-height="496" target="_blank"><img src="https://tpucdn.com/img/xa7kdPGi9I7MbVVE_thm.jpg" width="324" height="130" alt="" /></a></div>
Goodram Introduces Value Series PX500 NVMe SSDs Available up to 1 TB
It's been a while since we've had a post on a Goodram product at TechPowerUp, with the company's releases mainly falling off the radar. However, the company's new PX500 series of NVMe SSDs are being positioned as value options in the segment, whilst being quoted with some respectable transfer speeds - provided you don't acquire the lowest capacity version. Available in 256 GB, 512 GB and 1 TB capacities, the Goodram PX500 are DRAM-less SSDs driven by Silicon Motion's SMI 2263XT controller.<br />
<br />
Quoted numbers for the 256 GB version stand at 1,850 MB/s sequential read, 950 MB/s sequential write, 102,000 IOPS 4K random read and 230,000 IOPS 4K random write. The 512 GB version posts 2,000 MB/s, 1,600 MB/s, 173,000 IOPS and 140,000 IOPS in the same performance metrics, while the 1 TB version maxes out at 2,050 MB/s, 1650 MB/s, 240,000 IOPS and 280,000 IOPS, respectively. The Goodram PX500 series of NVMe SSDs are backed by a three-year warranty, and prices have not yet been announced.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Q4UuKt87yTCBF3MI.jpg" data-width="783" data-height="613" target="_blank"><img src="https://tpucdn.com/img/Q4UuKt87yTCBF3MI_thm.jpg" width="166" height="130" alt="" /></a></div>
Free Game Alert: Watch Dogs, The Stanley Parable Now Free to Grab from the EPIC Games Store
The current quarantine situation can be cut in two ways: as a major setback for your life, or as an opportunity. An opportunity, for instance, to mow down all the games you've got on backburner. To that end, and in case you're running low in Triple-AAA or quirky, interesting game experiments, the EPIC Games Store has now made available for free download both Ubisoft's Watch Dogs and Galactic Cafe's The Stanley Parable. Both offer a distinct gameplay experience, with EPIC thus catering to two completely different gamer demographics.<br />
<br />
Watch Dogs is a well-known action-adventure RPG launched back in 2014, set in a fictionalized version of Chicago. Playing as Aiden Pierce, a hacker with a personal revenge motivation, you hack your way through security systems in a somewhat dystopian society. The game was not very well received, standing with a 77 score on Metacritic and a 4.9 user score (in no small part due to the considerable graphics downgrade seen between the showcased version and the final graphics the game shipped with). The Stanley parable, on the other hand, is a quirky first-person exploration game based on a mod to the Half Life 2 engine that seems set on exploring a quantum approach to storytelling. This one features a much healthier 88 score in Metacritic and an 8.0 in user score.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lEdZ7JEdxCppEME9.jpg" data-width="695" data-height="463" target="_blank"><img src="https://tpucdn.com/img/lEdZ7JEdxCppEME9_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vwobN9upIsIPEkbd.jpg" data-width="616" data-height="353" target="_blank"><img src="https://tpucdn.com/img/vwobN9upIsIPEkbd_thm.jpg" width="227" height="130" alt="" /></a></div>
AMD RDNA 2 GPUs to Support the DirectX 12 Ultimate API
AMD today announced in the form of a blog post that its upcoming graphics cards based on RDNA 2 architecture will feature support for Microsoft's latest <a href="https://www.techpowerup.com/264932/microsoft-directx-12-ultimate-why-it-helps-gamers-pick-future-proof-graphics-cards" target="_blank">DirectX 12 Ultimate API</a>. "With this architecture powering both the next generation of AMD Radeon graphics cards and the forthcoming Xbox Series X gaming console, we've been working very closely with Microsoft to help move gaming graphics to a new level of photorealism and smoothness thanks to the four key DirectX 12 Ultimate graphics features -- DirectX Raytracing (DXR), Variable Rate Shading (VRS), Mesh Shaders, and Sampler Feedback." - said AMD in the blog.<br />
<br />
Reportedly, Microsoft and AMD have worked closely to enable this feature set and provide the best possible support for RDNA 2 based hardware, meaning that future GPUs and consoles are getting the best possible integration of the new API standard.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/nkrVa85fS6vvuF5y.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://tpucdn.com/img/nkrVa85fS6vvuF5y_thm.jpg" width="231" height="130" alt="AMD RDNA 2 supports DirectX12 Ultimate" /></a> <a href="https://www.techpowerup.com/img/PWfw3ztewjJgEnzH.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://tpucdn.com/img/PWfw3ztewjJgEnzH_thm.jpg" width="231" height="130" alt="AMD RDNA 2 supports DirectX12 Ultimate" /></a> <a href="https://www.techpowerup.com/img/Jg3SaW2VlhI4PJ0J.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://tpucdn.com/img/Jg3SaW2VlhI4PJ0J_thm.jpg" width="231" height="130" alt="AMD RDNA 2 supports DirectX12 Ultimate" /></a> <a href="https://www.techpowerup.com/img/exRqKdiZW1hhXuKD.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://tpucdn.com/img/exRqKdiZW1hhXuKD_thm.jpg" width="231" height="130" alt="AMD RDNA 2 supports DirectX12 Ultimate" /></a><br />
</div><div class="readmore"><a href="/264934/amd-rdna-2-gpus-to-support-the-directx-12-ultimate-api">Read full story</a></div>
Microsoft DirectX 12 Ultimate: Why it Helps Gamers Pick Future Proof Graphics Cards
Microsoft Thursday released the DirectX 12 Ultimate logo. This is not a new API with any new features, but rather a differentiator for graphics cards and game consoles that support four key modern features of DirectX 12. This helps consumers recognize the newer and upcoming GPUs, and tell them apart from some older DirectX 12 capable GPUs that were released in the mid-2010s. For a GPU to be eligible for the DirectX 12 Ultimate logo, it must feature hardware acceleration for ray-tracing with the DXR API; must support Mesh Shaders, Variable Rate Shading (VRS), and Sampler Feedback (all of the four). The upcoming Xbox Series X console features this logo by default. Microsoft made it absolutely clear that the DirectX 12 Ultimate logo isn't meant as a compatibility barrier, and that these games will work on older hardware, too. <br />
<br />
As it stands, the "Navi"-based Radeon RX 5000 series are "obsolete", just like some Turing cards from the GeForce GTX 16-series. At this time, the only shipping product which features the logo is NVIDIA's GeForce RTX 20-series and the TITAN RTX, as they support all the above features.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/n2mOqJmZaCA93p3B.jpg" data-width="487" data-height="484" target="_blank"><img src="https://tpucdn.com/img/n2mOqJmZaCA93p3B_thm.jpg" width="131" height="130" alt="" /></a> </div><div class="readmore"><a href="/264932/microsoft-directx-12-ultimate-why-it-helps-gamers-pick-future-proof-graphics-cards">Read full story</a></div>
NVIDIA GeForce RTX GPUs to Support the DirectX 12 Ultimate API
NVIDIA graphics cards, starting from the current generation GeForce RTX "Turing" lineup, will support the upcoming DirectX 12 Ultimate API. Thanks to a slide obtained by our friends over at VideoCardz, we have some information about the upcoming iteration of the DirectX 12 API made by Microsoft. In the new API revision, called "DirectX 12 Ultimate", it looks like there are some enhancements made to the standard DirectX 12 API. From the leaked slide we can see the improvements coming in the form of a few additions. <br />
<br />
The GeForce RTX lineup will support the updated version of API with features such as ray tracing, variable-rate shading, mesh shader, and sampler feedback. While we do not know why Microsoft decided to call this the "Ultimate" version, it is possibly used to convey clearer information about which features are supported by the hardware. In the leaked slide there is a mention of consoles as well, so it is coming to that platform as well.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ea1F0mWPCcwOxkPh.jpg" data-width="1855" data-height="800" target="_blank"><img src="https://tpucdn.com/img/ea1F0mWPCcwOxkPh_thm.jpg" width="301" height="130" alt="" /></a></div>
AMD Releases Radeon Software Adrenalin 20.3.1 Drivers for DOOM Eternal
AMD released the Radeon Software Adrenalin 2020 Edition drivers just in time for Asia and ANZ regions to begin "razing hell" with DOOM Eternal. Version 20.3.1 adds day-one optimization for DOOM Eternal, including an up to 5 percent performance improvement with "Ultra Nightmare" graphics settings. Optimization is also added for "Half Life: Alyx" and the Vulkan API mode of "Ghost Recon: Breakpoint." The drivers also add a few Vulkan extensions: VK_EXT_post_depth_coverage (only supported on RDNA or later graphics architectures); VK_KHR_shader_non_semantic_info, VK_EXT_texel_buffer_alignment, and VK_EXT_pipeline_creation_cache_control. Grab the drivers from the link below and raze hell!<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/amd-radeon-graphics-drivers/" target="_blank">AMD Radeon Software Adrenalin 20.3.1 Beta</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/1Z8s4U7mOzb9qsno.jpg" data-width="1200" data-height="744" target="_blank"><img src="https://tpucdn.com/img/1Z8s4U7mOzb9qsno_thm.jpg" width="210" height="130" alt="" /></a> </div>The change log follows.<div class="readmore"><a href="/264918/amd-releases-radeon-software-adrenalin-20-3-1-drivers-for-doom-eternal">Read full story</a></div>
NVIDIA Releases GeForce 442.74 Game Ready Drivers for DOOM Eternal
NVIDIA today posted GeForce 442.74 WHQL Game Ready drivers. These come with optimization and bug fixes for the weekend's biggest release, "DOOM Eternal," which goes live in Asia and ANZ in a few minutes from now. Besides this, the 442.74 WHQL drivers address just one bug: an issue with "Red Dead Redemption 2," where task-switching with alt+Tab in the middle of the game may result in a black screen. Grab the drivers from the link below and start slaying!<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/" target="_blank">NVIDIA GeForce 442.74 WHQL</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/rxnAdJp4b9ZnJWjH.jpg" data-width="1200" data-height="744" target="_blank"><img src="https://tpucdn.com/img/rxnAdJp4b9ZnJWjH_thm.jpg" width="210" height="130" alt="Doom Eternal" /></a> </div>The change-log follows.<div class="readmore"><a href="/264916/nvidia-releases-geforce-442-74-game-ready-drivers-for-doom-eternal">Read full story</a></div>
(PR) Intel Scales Neuromorphic Research System to 100 Million Neurons
Today, Intel announced the readiness of Pohoiki Springs, its latest and most powerful neuromorphic research system providing the computational capacity of 100 million neurons. The cloud-based system will be made available to members of the Intel Neuromorphic Research Community (INRC), extending their neuromorphic work to solve larger, more complex problems.<br />
<br />
"Pohoiki Springs scales up our Loihi neuromorphic research chip by more than 750 times, while operating at a power level of under 500 watts. The system enables our research partners to explore ways to accelerate workloads that run slowly today on conventional architectures, including high-performance computing (HPC) systems." -Mike Davies, director of Intel's Neuromorphic Computing Lab.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oFW0d9ZGglLVEfcs.jpg" data-width="1403" data-height="960" target="_blank"><img src="https://tpucdn.com/img/oFW0d9ZGglLVEfcs_thm.jpg" width="190" height="130" alt="Intel Pohoiki Springs" /></a> <a href="https://www.techpowerup.com/img/Of6WuU8IlRZiG1ZU.jpg" data-width="1523" data-height="960" target="_blank"><img src="https://tpucdn.com/img/Of6WuU8IlRZiG1ZU_thm.jpg" width="206" height="130" alt="Intel Pohoiki Springs" /></a> <a href="https://www.techpowerup.com/img/4LMKuUhDjTE1vDUw.jpg" data-width="1437" data-height="960" target="_blank"><img src="https://tpucdn.com/img/4LMKuUhDjTE1vDUw_thm.jpg" width="195" height="130" alt="Intel Pohoiki Springs" /></a> <a href="https://www.techpowerup.com/img/ddULgam9gSqZA3AQ.jpg" data-width="1588" data-height="960" target="_blank"><img src="https://tpucdn.com/img/ddULgam9gSqZA3AQ_thm.jpg" width="215" height="130" alt="Intel Pohoiki Springs" /></a> </div><div class="readmore"><a href="/264909/intel-scales-neuromorphic-research-system-to-100-million-neurons">Read full story</a></div>
(PR) BIOSTAR Announces the A68N-2100K SoC Motherboard
BIOSTAR, a leading brand of motherboards, graphics cards, and storage devices, today announces the A68N-2100K SoC motherboard that comes with an in-built AMD E1-6010 Processor. Throughout many decades, BIOSTAR has been revered as one of the best manufacturers of robust, highly reliable motherboards with a wide array of models on both Intel and AMD platforms to choose from and a plethora of supplementary components catering to many user preferences globally.<br />
<br />
Modern technology meets sleek, refined form factor as BIOSTAR's A68N-2100K SoC Mini-ITX motherboard is unveiled to the world with an inbuilt AMD E1-6010 Processor and support for AMD Radeon R2 Graphics.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cgPxk3Mi9PTfZtzc.jpg" data-width="886" data-height="659" target="_blank"><img src="https://tpucdn.com/img/cgPxk3Mi9PTfZtzc_thm.jpg" width="175" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nFmgXlrWiMwlIH2H.jpg" data-width="1024" data-height="911" target="_blank"><img src="https://tpucdn.com/img/nFmgXlrWiMwlIH2H_thm.jpg" width="146" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/M7v2fjqiUI7XhvsM.jpg" data-width="908" data-height="656" target="_blank"><img src="https://tpucdn.com/img/M7v2fjqiUI7XhvsM_thm.jpg" width="180" height="130" alt="" /></a> </div><div class="readmore"><a href="/264908/biostar-announces-the-a68n-2100k-soc-motherboard">Read full story</a></div>
AMD Trims Prices of 3rd Gen Ryzen PIBs in the US, Drops in Xbox Game P
AMD earlier this week trimmed prices of its retail 3rd generation Ryzen desktop processors in the US, through promotions exclusive to Newegg and Amazon. The company is also including 3-month Xbox Game Pass subscriptions with select models. The discounts see the 12-core/24-thread Ryzen 9 3900X go for $449, $50 lower than its MSRP of $499. The company's fastest 8-core/16-thread part, the Ryzen 7 3800X, is now going for $359, or $40 lower than its $399 MSRP. The popular Ryzen 7 3700X 8-core/16-thread chip is selling for $304, a $25 discount from its $329 MSRP. AMD is applying similar $25 cuts to its 6-core/12-thread parts, with the Ryzen 5 3600X going for $224 compared to its $249 MSRP, and the popular Ryzen 5 3600 priced at $174 compared to its $199 MSRP.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JDnTWR5uZk7lz7od.jpg" data-width="915" data-height="580" target="_blank"><img src="https://tpucdn.com/img/JDnTWR5uZk7lz7od_thm.jpg" width="205" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/P1ANHDssUowy0dKl.jpg" data-width="1510" data-height="849" target="_blank"><img src="https://tpucdn.com/img/P1ANHDssUowy0dKl_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) Team T-Force Xtreem Mirror ARGB Memory Wins 2020 German RED DOT Design Award
The world's leading memory brand, TEAMGROUP today announces that the T-FORCE XTREEM ARGB Full Mirror Gaming Memory has won the Red Dot Design Award 2020. The XTREEM ARGB has earned an enthusiastic response from gamers around the globe ever since its release. It stands out among 6,500 entries worldwide and overwhelmingly praised by international experts. TEAMGROUP's strength and creativity in product research and development make the T-FORCE gaming brand shine at international design awards once again.<br />
<br />
The German Red Dot Design Award, one of the world's four major design awards, has an extraordinary influence in the industry and is also an important indicator for designers. It was founded by the famous German design association, Design Zentrum Nordrhein Westfalen in 1955. Global professional jury judge entries based on creativity, solutions, product communication design and concept. The award has attracted over six thousand entries from more than 60 countries. And T-FORE XTREEM ARGB Full Mirror Gaming Memory has won the award with product uniqueness and rich creativity, and shines in the design field.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/88oVWkn2tUGygyY5.jpg" data-width="800" data-height="435" target="_blank"><img src="https://tpucdn.com/img/88oVWkn2tUGygyY5_thm.jpg" width="239" height="130" alt="Team T-Force Xtreem Mirror ARGB Memory" /></a> <a href="https://www.techpowerup.com/img/yGLgEHIzE41NVNeN.jpg" data-width="1000" data-height="1000" target="_blank"><img src="https://tpucdn.com/img/yGLgEHIzE41NVNeN_thm.jpg" width="130" height="130" alt="Team T-Force Xtreem Mirror ARGB Memory" /></a> <a href="https://www.techpowerup.com/img/lIZsryX7zAuteGdn.jpg" data-width="1000" data-height="1000" target="_blank"><img src="https://tpucdn.com/img/lIZsryX7zAuteGdn_thm.jpg" width="130" height="130" alt="Team T-Force Xtreem Mirror ARGB Memory" /></a> </div><div class="readmore"><a href="/264901/team-t-force-xtreem-mirror-argb-memory-wins-2020-german-red-dot-design-award">Read full story</a></div>
(PR) Fractal Design Cases Get a D5 Powered EK Distribution Plate
EK, a premium water cooling gear manufacturer, in partnership with the prestigious Swedish case manufacturer Fractal Design, is launching the EK-Quantum Reflection Fractal ATX D5 PWM D-RGB - a custom-designed water cooling reservoir, routing and pump solution made to fit several Fractal Design ATX-size cases. This distro plate is specifically designed to provide an advanced water cooling solution with a market-leading D5 pump for users who are building custom loop liquid cooling in Fractal Design cases.<br />
<br />
It is designed to simplify the process for beginner PC builders who are entering the hard tubing custom loop liquid cooling world, as well as to bring the slim-lined EK Quantum aesthetics to an already elegant case.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/b7n9qATQ4e4l5hMe.jpg" data-width="1002" data-height="960" target="_blank"><img src="https://tpucdn.com/img/b7n9qATQ4e4l5hMe_thm.jpg" width="136" height="130" alt="EK distro plate for Fractal Design cases" /></a> <a href="https://www.techpowerup.com/img/PGb4lVwYDUAmqosz.jpg" data-width="1042" data-height="960" target="_blank"><img src="https://tpucdn.com/img/PGb4lVwYDUAmqosz_thm.jpg" width="141" height="130" alt="EK distro plate for Fractal Design cases" /></a> <a href="https://www.techpowerup.com/img/rny1vQ9Dupc0MEGv.jpg" data-width="1083" data-height="960" target="_blank"><img src="https://tpucdn.com/img/rny1vQ9Dupc0MEGv_thm.jpg" width="147" height="130" alt="EK distro plate for Fractal Design cases" /></a> <a href="https://www.techpowerup.com/img/2tOpbGlU5KcUArye.jpg" data-width="810" data-height="957" target="_blank"><img src="https://tpucdn.com/img/2tOpbGlU5KcUArye_thm.jpg" width="110" height="130" alt="EK distro plate for Fractal Design cases" /></a> <a href="https://www.techpowerup.com/img/GqUkjiZEANtQSXX2.jpg" data-width="1006" data-height="960" target="_blank"><img src="https://tpucdn.com/img/GqUkjiZEANtQSXX2_thm.jpg" width="136" height="130" alt="EK distro plate for Fractal Design cases" /></a> </div><div class="readmore"><a href="/264900/fractal-design-cases-get-a-d5-powered-ek-distribution-plate">Read full story</a></div>
(PR) CHIEFTEC Announces the Scorpion 3 and Hawk Gaming Cases
CHIEFTEC, a world-wide renowned brand for reliable PC chassis and power supplies, today announces two remarkable models to their gaming-chassis line. The Scorpion 3 (GL-03B-OP) furthers the legacy of the highly-successful gaming Scorpion-series by adding 4x pre-installed +5V A-RGB Rainbow fans and slide-to-open side door features. Along with Scorpion 3, CHIEFTEC also announces the revised HAWK (AL-02B-TG-OP), upgraded with tempered glass side panel as special edition.<br />
<br />
Scorpion 3 (GL-03B-OP, ATX), the new iteration of the Scorpion-series upgrades with 4x preinstalled A-RGB Rainbow fans from our Tornado fan set. Each fan is furnished with shock-absorbing and anti-vibration rubbers and special fan blades design, which guarantee a whisper-quiet operation. Thanks for the certified control box (DF-908) and an RF remote control, the color modes and fan speed can be easily controlled via the buttons on the control box or the remote control. Fur more personalized illumination experience, all conventional 3 PIN +5V A-RGB motherboard technologies such as ASUS AURA, ASRock RGB Sync, MSI Mystic Light Sync, and Gigabyte RGB FUSION are supported.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CGuOFaqoqrkmk9Dz.jpg" data-width="1320" data-height="720" target="_blank"><img src="https://tpucdn.com/img/CGuOFaqoqrkmk9Dz_thm.jpg" width="238" height="130" alt="Chieftec Scorpion 3" /></a> <a href="https://www.techpowerup.com/img/1MfTuZVKbmATm6Px.jpg" data-width="1128" data-height="615" target="_blank"><img src="https://tpucdn.com/img/1MfTuZVKbmATm6Px_thm.jpg" width="238" height="130" alt="" /></a> </div><div class="readmore"><a href="/264899/chieftec-announces-the-scorpion-3-and-hawk-gaming-cases">Read full story</a></div>
(PR) Fractal Design Announces the Era ITX Case
Taking aim at Creators, Gamers and other DIY-ers, Fractal Design today launched an innovative, small form factor chassis through close collaboration with Intel. "We were very excited about partnering with Intel in developing this case," says Fractal Design founder Hannes Wallin. "It inspired us to take on a project that challenges the convention that elegant design can't be combined with flexible functionality, and we're very happy with the result."<br />
<br />
Available today, the Era ITX is the next generation of Mini-ITX case design. This compact chassis is free from the configuration limitations traditionally associated with small form factor systems. This unique product brings the perfect combination of elegant design and technical engineering to PC hardware innovation. Era's design presents a surfaced, aluminium exterior that is paired with top inserts ranging from wood to tempered glass. This combination of materials along with a variety of colorways presents a spectrum of choices to the user.<br />
<br />
We've just posted our <a href="https://www.techpowerup.com/review/fractal-design-era-itx-chassis/" target="_blank">Fractal Design Era case review</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vxtXnDjpHTm3UWcE.jpg" data-width="1157" data-height="960" target="_blank"><img src="https://tpucdn.com/img/vxtXnDjpHTm3UWcE_thm.jpg" width="157" height="130" alt="Fractal Design Era ITX cobalt blue" /></a> <a href="https://www.techpowerup.com/img/XjvPaa3WmAhvSvng.jpg" data-width="600" data-height="372" target="_blank"><img src="https://tpucdn.com/img/XjvPaa3WmAhvSvng_thm.jpg" width="210" height="130" alt="Fractal Design Era ITX" /></a> <a href="https://www.techpowerup.com/img/kTZF4T7WN2o69mn1.jpg" data-width="1057" data-height="960" target="_blank"><img src="https://tpucdn.com/img/kTZF4T7WN2o69mn1_thm.jpg" width="143" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fgO7JLJHa0wzwywl.jpg" data-width="795" data-height="960" target="_blank"><img src="https://tpucdn.com/img/fgO7JLJHa0wzwywl_thm.jpg" width="108" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/GEiIWElomwwi5Eih.jpg" data-width="942" data-height="960" target="_blank"><img src="https://tpucdn.com/img/GEiIWElomwwi5Eih_thm.jpg" width="128" height="130" alt="" /></a> </div><div class="readmore"><a href="/264897/fractal-design-announces-the-era-itx-case">Read full story</a></div>
Sony Reveals PS5 Hardware: RDNA2 Raytracing, 16 GB GDDR6, 6 GB/s SSD,
Sony in a YouTube stream keynote by PlayStation 5 lead system architect Mark Cerny, detailed the upcoming entertainment system's hardware. There are three key areas where the company has invested heavily in driving forward the platform by "balancing revolutionary and evolutionary" technologies. A key design focus with PlayStation 5 is storage. Cerny elaborated on how past generations of the PlayStation guided game developers' art direction as the low bandwidths and latencies of optical discs and HDDs posed crippling latencies arising out of mechanical seeks, resulting in infinitesimally lower data transfer rates than what the media is capable of in best case scenario (seeking a block of data from its outermost sectors). SSD was the #1 most requested hardware feature by game developers during the development of PS5, and Sony responded with something special. <br />
<br />
Each PlayStation 5 ships with a PCI-Express 4.0 x4 SSD with a flash controller that has been designed in-house by Sony. The controller features 12 flash channels, and is capable of at least 5.5 GB/s transfer speeds. When you factor in the exponential gains in access time, Sony expects the SSD to provide a 100x boost in effective storage sub-system performance, resulting in practically no load times.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vtnIX6szoKolnDAp.jpg" data-width="1843" data-height="1117" target="_blank"><img src="https://tpucdn.com/img/vtnIX6szoKolnDAp_thm.jpg" width="214" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Imt98hhiGyx2HAQx.jpg" data-width="1994" data-height="1118" target="_blank"><img src="https://tpucdn.com/img/Imt98hhiGyx2HAQx_thm.jpg" width="232" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iQIxPyAkvtlEzQOm.jpg" data-width="1928" data-height="1110" target="_blank"><img src="https://tpucdn.com/img/iQIxPyAkvtlEzQOm_thm.jpg" width="226" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/m8CRVUY6E1YCAgTy.jpg" data-width="1989" data-height="1116" target="_blank"><img src="https://tpucdn.com/img/m8CRVUY6E1YCAgTy_thm.jpg" width="232" height="130" alt="" /></a> </div><div class="readmore"><a href="/264881/sony-reveals-ps5-hardware-rdna2-raytracing-16-gb-gddr6-6-gb-s-ssd-2304-gpu-cores">Read full story</a></div>
(PR) Apple Unveils new iPad Pro with Breakthrough LiDAR Scanner
Apple today announced its most advanced iPad Pro. Now with the A12Z Bionic chip, iPad Pro is faster and more powerful than most Windows PC laptops. The new iPad Pro adds an Ultra Wide camera, studio-quality mics and a breakthrough LiDAR Scanner that delivers cutting-edge depth-sensing capabilities, opening up more pro workflows and supporting pro photo and video apps. The LiDAR Scanner, along with pro cameras, motion sensors, pro performance, pro audio, the stunning Liquid Retina display and powerful apps, extends the lead of iPad Pro as the world's best device for augmented reality (AR). The new iPad Pro is available to order starting today on apple.com.<br />
<br />
With iPadOS 13.4, Apple brings trackpad support to iPad, giving customers an all-new way to interact with their iPad. Rather than copying the experience from macOS, trackpad support has been completely reimagined for iPad. As users move their finger across the trackpad, the pointer elegantly transforms to highlight user interface elements. Multi-Touch gestures on the trackpad make it fast and easy to navigate the entire system without users ever lifting their hand.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jlZsFgrvdfH4dH7K.jpg" data-width="1707" data-height="960" target="_blank"><img src="https://tpucdn.com/img/jlZsFgrvdfH4dH7K_thm.jpg" width="231" height="130" alt="Apple iPad Pro" /></a> <a href="https://www.techpowerup.com/img/l7n3NAMGbGzXCtkT.jpg" data-width="1040" data-height="960" target="_blank"><img src="https://tpucdn.com/img/l7n3NAMGbGzXCtkT_thm.jpg" width="141" height="130" alt="Apple iPad Pro" /></a> </div><div class="readmore"><a href="/264876/apple-unveils-new-ipad-pro-with-breakthrough-lidar-scanner">Read full story</a></div>
(PR) Internet Exchange Operator DE-CIX Sees COVID-19 Causing Customers to Order Higher Data Caps
DE-CIX, the operator of the world's largest Internet Exchange in Frankfurt am Main, Germany, is taking stock for the first time since the tightening of public measures in the fight against the spread of the COVID-19 virus. DE-CIX has noted a strong change in data traffic and also in Internet user behavior. The average data traffic at the world's largest Internet Exchange in Frankfurt has increased by 10% since last Wednesday. Compared to the previous few weeks, there has also been a significant increase in video conferencing traffic - such as Skype, Teams, and WebEx - of about 50%, and a rising number of VPN users has also been registered. In addition, since Friday last week there has also been an increase of about 25% in online and cloud gaming, and there has also been a significant increase in traffic from the use of social media platforms. Similar results are expected for the other DE-CIX locations.<br />
<br />
"Capacities in our own network are regularly expanded on a long-term basis. We always plan for about twelve months in advance. We continue expanding as soon as 63% of the existing capacities are reached. The remaining 37% free capacity is needed to create redundancy and to ensure that we always have enough free capacity for traffic growth. In addition to our network for the Internet Exchange, customers also need to expand capacity in their own network. These expansions are carried out by the customers themselves, according to their own processes and procedures," comments Dr Thomas King, CTO at DE-CIX, on the increasing data traffic.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/n1dIOEifPKIUH14V.jpg" data-width="1739" data-height="876" target="_blank"><img src="https://tpucdn.com/img/n1dIOEifPKIUH14V_thm.jpg" width="258" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rsH864P9luAguJ0D.jpg" data-width="1753" data-height="877" target="_blank"><img src="https://tpucdn.com/img/rsH864P9luAguJ0D_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CnM7sCryfrypGDpR.jpg" data-width="1765" data-height="892" target="_blank"><img src="https://tpucdn.com/img/CnM7sCryfrypGDpR_thm.jpg" width="257" height="130" alt="DE-CIX traffic growth due to COVID-19" /></a> </div><div class="readmore"><a href="/264874/internet-exchange-operator-de-cix-sees-covid-19-causing-customers-to-order-higher-data-caps">Read full story</a></div>
(PR) Apple Announces the 2020 MacBook Air
Apple today updated MacBook Air, the world's most loved notebook, with faster performance, the new Magic Keyboard, twice the storage and a new lower price of $999, and $899 for education. The new MacBook Air delivers up to two times faster CPU performance and up to 80 percent faster graphics performance, letting customers breeze through daily activities and play more games. Now starting with 256 GB of storage, MacBook Air allows customers to store even more movies, photos and files. With its brilliant 13-inch Retina display for vivid images and sharp text, Touch ID for easy login and secure online purchases, spacious trackpad, and all-day battery life combined with the power of macOS Catalina, it's the best MacBook Air ever made. <br />
<br />
"From students and consumers buying their first computer to customers looking to upgrade, everyone loves the Mac, and they especially love MacBook Air. Today we're giving it a huge update, with two times faster performance, the new Magic Keyboard, double the storage, a new lower price of $999 and an even lower price of $899 for education," said Tom Boger, Apple's senior director of Mac and iPad Product Marketing. "With its stunning, thin and light design, brilliant Retina display, all-day battery life and the power and ease-of-use of macOS, MacBook Air is the world's best consumer notebook."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/GhKT3YNV7FwIkanj.jpg" data-width="1394" data-height="960" target="_blank"><img src="https://tpucdn.com/img/GhKT3YNV7FwIkanj_thm.jpg" width="189" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uDwSN2WyZjwKjLks.jpg" data-width="1306" data-height="868" target="_blank"><img src="https://tpucdn.com/img/uDwSN2WyZjwKjLks_thm.jpg" width="196" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MrucBMXNhNxbUrZX.jpg" data-width="1306" data-height="916" target="_blank"><img src="https://tpucdn.com/img/MrucBMXNhNxbUrZX_thm.jpg" width="185" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dglheQAOlWwISSp0.jpg" data-width="1016" data-height="960" target="_blank"><img src="https://tpucdn.com/img/dglheQAOlWwISSp0_thm.jpg" width="138" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pFo4KA3Ub6qo3N0C.jpg" data-width="1016" data-height="960" target="_blank"><img src="https://tpucdn.com/img/pFo4KA3Ub6qo3N0C_thm.jpg" width="138" height="130" alt="" /></a> </div><div class="readmore"><a href="/264873/apple-announces-the-2020-macbook-air">Read full story</a></div>
