Oscam-1.00-svn4186
r4186 | landlord | 2010-12-21 20:40:13 +0100 (Tue, 21 Dec 2010) | 1 line
Removed start parameter '-m' from documentation.
r4187 | alno | 2010-12-21 21:40:09 +0100 (Tue, 21 Dec 2010) | 1 line
WebIf: implement some useless code just to stop the guys open tedious tickets for warnings related to unused variables xD
Oscam-1.00-svn4188
r4188 | schlocke | 2010-12-21 22:55:26 +0100 (Tue, 21 Dec 2010) | 3 lines
ecm distribution: fixed issue with clients in same group, but different
servives
r4189 | schlocke | 2010-12-22 10:42:49 +0100 (Wed, 22 Dec 2010) | 2 lines
restart: just exit, no killing of threads (dbox problem)
servives
r4190 | _network | 2010-12-22 23:11:53 +0100 (Wed, 22 Dec 2010) | 2 lines
fix segfaults on oscam exit
r4191 | hapeba | 2010-12-23 06:15:08 +0100 (Thu, 23 Dec 2010) | 1 line
#4190 (openssl) --> oscam.version
Oscam-1.00-svn4192
r4192 | alno | 2010-12-23 20:59:07 +0100 (Thu, 23 Dec 2010) | 2 lines
XMLAPI: add cccam card output. Call with <oscamaddress>oscamapi.html?part=entitlement&label=<readername>
non cccam reader and disabled cccam reader return an xml errormessage
Oscam-1.00-svn4194
r4194 | alno | 2010-12-23 22:35:51 +0100 (Thu, 23 Dec 2010) | 1 line
XMLAPI: Fix issue with acumulating providers and nodes
r4193 | alno | 2010-12-23 21:13:44 +0100 (Thu, 23 Dec 2010) | 1 line
XMLAPI: fix some typo
r4195 | lattjo | 2010-12-24 11:19:34 +0100 (Fri, 24 Dec 2010) | 1 line
Fixed log buffer overflow in some case
Oscam-1.00-svn4196
r4196 | lattjo | 2010-12-24 12:11:30 +0100 (Fri, 24 Dec 2010) | 1 line
Fixed PCSC support
r4197 | lattjo | 2010-12-24 15:00:01 +0100 (Fri, 24 Dec 2010) | 1 line
Fixed a compilation warning and added two newcamd client id's
Fixed PCSC support
Oscam-1.00-svn4198
r4198 | alno | 2010-12-24 15:15:17 +0100 (Fri, 24 Dec 2010) | 2 lines
failban: add new parameter 'failbancount=0|<integer value>' (default 0) beside of failbantime. This parameter reflect the number of allowed violations from an IP Address (default blocked on first violation). Please set parameter in oscam.conf [global] - not implemented in WebIf yet
Merry Christmas
r4202 | schlocke | 2010-12-24 18:00:42 +0100 (Fri, 24 Dec 2010) | 2 lines
config cccam stealth/reshare mode
r4201 | lattjo | 2010-12-24 16:02:53 +0100 (Fri, 24 Dec 2010) | 1 line
Fixed EOL win -> unix
r4200 | schlocke | 2010-12-24 15:33:37 +0100 (Fri, 24 Dec 2010) | 2 lines
reshare_mode and stealth now written by config
r4199 | lattjo | 2010-12-24 15:24:55 +0100 (Fri, 24 Dec 2010) | 1 line
Use the Azbox openxcas open and close functions only if HAVE_DVBAPI is defined. Use the openxcas_open_with_smartcard only if WITH_CARDREADER is defined.
Oscam-1.00-svn4204
r4204 | alno | 2010-12-24 21:03:35 +0100 (Fri, 24 Dec 2010) | 1 line
WebIf: add failbancount to configuration
r4203 | alno | 2010-12-24 20:54:33 +0100 (Fri, 24 Dec 2010) | 1 line
WebIf: add failban count to failban overview
r4205 | schlocke | 2010-12-25 11:36:31 +0100 (Sat, 25 Dec 2010) | 3 lines
cccam: reshare_mode=3 for resharing user services. Also fixed
reshare_mode2=2, resharing reader services
