r4105 | alno | 2010-12-14 00:13:32 +0100 (Tue, 14 Dec 2010) | 1 line
WebIf: fix deleting a failban entry
r4104 | schlocke | 2010-12-13 23:21:43 +0100 (Mon, 13 Dec 2010) | 2 lines
cccam: fixed blocking card exchange
r4106 | schlocke | 2010-12-14 09:02:17 +0100 (Tue, 14 Dec 2010) | 2 lines
cccam: added reporting of 2.2.x compatible carddata
---------- Post added at 10:33 ---------- Previous post was at 08:57 ----------
r4107 | dingo35 | 2010-12-14 10:36:23 +0100 (Tue, 14 Dec 2010) | 1 line
ifd_sc8in1.c : Fix sc8in1 for multiple cards
Oscam-1.00-svn4110
Changeset #4108
Message: reader-common.c : Moving some sc8in1 specific stuff to csctapi
Changeset #4109
Message: ifd_sc8in1.c checked on threadsafety, threadsafe for ONE sc8in1 type reader
Changeset #4110
Message: icc_async.c : Parse_ATR needs locks for sc8in1 reader
Oscam-1.00-svn4113
Changeset #4111
Message: Failban: Add mask 8 for ban duplicate clients. Untested! Please try and report.
Changeset #4112
Message: WebIf: httpport extend to length of 6 digits
Changeset #4113
Message: WebIf: apply patch to cleanup status if client is idle (THX wonderdoc) Discussion: [Only registered and activated users can see links. Click Here To Register...]
r4115 | _network | 2010-12-14 21:05:00 +0100 (Tue, 14 Dec 2010) | 2 lines
reader-viaccess: fix compiler warnings
r4116 | schlocke | 2010-12-14 22:50:10 +0100 (Tue, 14 Dec 2010) | 4 lines
cccam: negative service check (!srvid) implemented for card exchange. Needs service
without sid. services with sids are ignored (for card exchange, not for ecms!)
r4117 | schlocke | 2010-12-15 08:46:38 +0100 (Wed, 15 Dec 2010) | 3 lines
cccam: pos/neg Services: pos.Services with Caid.Prov AND SID are not ignored
r4118 | dingo35 | 2010-12-15 13:06:05 +0100 (Wed, 15 Dec 2010) | 1 line
ifd_sc8in1: hold cards to reset state when setting clockspeed
ignored
r4119 | schlocke | 2010-12-15 13:30:14 +0100 (Wed, 15 Dec 2010) | 2 lines
webif: delete banned IP fixed
Oscam-1.00-svn4121
Changeset #4120
Message: ifd_cool.c : disable Cool_WriteSettings so nagra cards will work with new cnxt_lnx.ko driver
Changeset #4121
Message: ifd_sc8in1.c : add slot boundary checks
r4123 | schlocke | 2010-12-15 18:36:05 +0100 (Wed, 15 Dec 2010) | 2 lines
cccam: experimental: stealth mode / reshare_services
r4122 | _network | 2010-12-15 18:31:52 +0100 (Wed, 15 Dec 2010) | 4 lines
WebIf: fix crash (edit camd35tcp with ssl enabled);
dvbapi: prepare new stapi version;
r4121 | dingo35 | 2010-12-15 15:39:59 +0100 (Wed, 15 Dec 2010) | 1 line
r4124 | schlocke | 2010-12-15 21:15:44 +0100 (Wed, 15 Dec 2010) | 2 lines
cccam: parameter/port not recognized fixed
r4125 | schlocke | 2010-12-15 23:19:55 +0100 (Wed, 15 Dec 2010) | 2 lines
tcp-socket option updated
r4131 | dingo35 | 2010-12-17 08:45:48 +0100 (Fri, 17 Dec 2010) | 1 line
icc_async.c: Fix compile error for SCI devices
r4130 | alno | 2010-12-16 21:46:48 +0100 (Thu, 16 Dec 2010) | 1 line
XMLAPI: fix typo
r4129 | alno | 2010-12-16 21:34:13 +0100 (Thu, 16 Dec 2010) | 2 lines
XMLAPI: implementation of API call for statuspage. It's just to have a base for discussion with App developers (IPhone, Android, STB Plugins). Call the API with http://<Oscam IP>/oscamapi.html?part=status The API uses the normal WebIF way and the same credenticals as well as SSL if enabled.
Please test and join the discussion for requests and suggestions: [Only registered and activated users can see links. Click Here To Register...]
r4128 | alno | 2010-12-16 19:14:21 +0100 (Thu, 16 Dec 2010) | 1 line
WebIf: Fix for Ticket 1369 - THX hperez for report and suggestion
r4127 | dingo35 | 2010-12-16 15:33:59 +0100 (Thu, 16 Dec 2010) | 1 line
oscam-log.c : Stop using uninitialized value
r4126 | dingo35 | 2010-12-16 15:33:00 +0100 (Thu, 16 Dec 2010) | 1 line
icc_async.c : Stop reading TB1 since it is deprecated acc. ISO7816
r4133 | dingo35 | 2010-12-17 10:56:46 +0100 (Fri, 17 Dec 2010) | 1 line
icc_async.c : Initializing some output-variables to prevent compiler warnings
r4132 | dingo35 | 2010-12-17 09:46:50 +0100 (Fri, 17 Dec 2010) | 1 line
Partly reversing 3794 since deleting prototypes and introducing wrong datatypes is not the way to go
r4135 | dingo35 | 2010-12-17 13:50:14 +0100 (Fri, 17 Dec 2010) | 1 line
icc_async.c Reimplementing 3794 since _network had thought this better through than I
r4134 | _network | 2010-12-17 13:48:38 +0100 (Fri, 17 Dec 2010) | 2 lines
dvbapi: add thread for manual calling of signal event handler for systems that do not support it or have problems with interrupted system calls (pmt_mode=4)
