SATLODGE 15.3 DM920
ENIGMA2 SATLODGE 18-02-2026
GSTREAMER 1.26.10
OPENSSL 3.6.0
PYTHON 3.14.3
TEST FLASH OK
AGGIORNAMENTO SOURCE
NOVITA AGGIORNATI TUTTI I PLUGIN SATLODGE
AGGIUNTO SATLODGE WEBPLUS PANNELLO
AGGIORNATO IL SOFTCAMANAGER ALLA VERSIONE 1.9 FIX CRASH IL PLUGIN SI TRASFORMA IN UN PANNELLO ADDONS DAL TASTO GIALLO
AGGIUNTO IL PLUGIN SATLODGE VIDEOPLAYER PRESO SPUNTO DAL VIDEOPLAYER SIMPLE
UPDATE BUG FIX
FIX MINOR BUG
Abertis de pe 30 w poate fi receptionat si cu tunerul BCM45308X
Pot fi receptionate si programele T2MI cipriote de pe Hellasat
[IMG][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...][/IMG]
programele T2MI cipriote de pe Hellasat ,receptionate cu acelasi Dm920,cu tunerul BCM45308X
[IMG][Only registered and activated users can see links. Click Here To Register...][/IMG]
Programul elen ANT1 este criptate BISS, nu este T2MI si nu este cipriot.
Nu stiu daca canalele T2MI de pe 11760 si 11779 H 30000 mai sunt operationale, nu le-am testat de multa vreme, nici macar cu placa TBS 5927
La raportul de receptie, te rog pune si parametri de transmisie. Pozitie orbitala, frecventa, s/r....etc
Totul a pornit de aici cand am vazut intrebarea pe un forum strain
What is your experience using the NIM tuner (45308X) to receive 11760H/11778H from 39E (or 11330H/11491V from 30W), which use MIS-0 ?
Codate biss ,sunt actualizate de luna aceasta ......sunt T2MI. si pot fi vizionate doar cu ajutorul astra sm
