Oscam-1.00-svn4078
Changeset #4078
Message: cccam: updated emm code
Changeset #4079
r4079 | schlocke | 2010-12-10 18:01:59 +0100 (Fri, 10 Dec 2010) | 2 lines
r4078 | schlocke | 2010-12-10 16:34:02 +0100 (Fri, 10 Dec 2010) | 2 lines
r4081 | schlocke | 2010-12-10 22:40:46 +0100 (Fri, 10 Dec 2010) | 2 lines
cccam: fixed compile error, fixed rc6 keylen
r4080 | schlocke | 2010-12-10 18:12:52 +0100 (Fri, 10 Dec 2010) | 3 lines
cccam: fixed preferred card on non-preferred reader, e.g. when
loadbalancer is getting statistics
Oscam-1.00-svn4082
Changeset #4082
Message: cccam: fixed preferred card and blocked sids problem
Oscam-1.00-svn4085
Changeset #4083
Message: oscam-reader.c and ifd_sc8in1.c : Fix sc8in1 for 1 card in reader
Changeset #4084
Message: Config: set a minimum of 100 for lbsave. So new rule for this parameter lbsave=0|>=100
WebIf: show '+' in port config if SSL is used
Changeset #4085
Message: Documentation update for 'lb_save' parameter.
Oscam-1.00-svn4086
Changeset #4086
Message: WebIf: show inactive reader without channelinfo in statuspage
r4087 | alno | 2010-12-11 20:57:07 +0100 (Sat, 11 Dec 2010) | 1 line
WebIf: 4086 extended by respecting a not set hideclient_to parameter
Oscam-1.00-svn4090
Changeset #4088
Message: WebIf: some cosmetics in status (0000:0000 as caid:srvid if inactive element)
Changeset #4089
Message: WebIf: add oscam.tiers to files menu
Changeset #4090
Message: WebIf: show extended protocolinfo also on cccam readers. Untested - I don't use this crapy proto
---------- Post added at 13:56 ---------- Previous post was at 12:13 ----------
Changeset #4091
Message: Config: Avoid saving fallbacktimeout if default
Changeset #4092
Message: Config: fix fallbacktimeout
Oscam-1.00-svn4093
Changeset #4093
Message: WebIf: Revert 4090 because user report crash. I cannot test the cccam crap. Look for other Dev related this
Oscam-1.00-svn4098
Changeset #4094
Message: cccam: updated cccam 2.2.1 code (RC6)
Changeset #4095
Message: 'README' update.
Changeset #4096
Message: cccam: added PPC RC6 decoding
Changeset #4097
Message: cccam: fixed ppc swap
Changeset #4098
Message: cccam: removed non-working preferred card, changed keepconnected mgcamd compatibility
r4099 | landlord | 2010-12-13 09:52:10 +0100 (Mon, 13 Dec 2010) | 1 line
'README' update again, thanks to counter71.
r4100 | schlocke | 2010-12-13 11:13:07 +0100 (Mon, 13 Dec 2010) | 2 lines
cccam: fixed PPC RC6 swap
r4102 | schlocke | 2010-12-13 19:44:18 +0100 (Mon, 13 Dec 2010) | 3 lines
fixed: "cannot create pipe" causing duplicate nonconnected users (all
protos!)
r4101 | schlocke | 2010-12-13 19:40:12 +0100 (Mon, 13 Dec 2010) | 2 lines
cccam: reset receive buffer before connect
r4103 | schlocke | 2010-12-13 22:57:21 +0100 (Mon, 13 Dec 2010) | 2 lines
cccam/login/dup test fix
protos!)
Oscam-1.00-svn4104
Changeset #4104
Message: cccam: fixed blocking card exchange
