Re: Receptii Terestre-Pareri Vechi Si Actuale
[Only registered and activated users can see links. Click Here To Register...] tropo p1
[Only registered and activated users can see links. Click Here To Register...] tropo partea 2
[Only registered and activated users can see links. Click Here To Register...] tropo partea 3
[Only registered and activated users can see links. Click Here To Register...] tropo partea 4
88.2 hr botev
88.3 k
88.7 varna
89.8 favorit
90.3 shumen
90.4 targoviste
90.5 shlager
90.6 zu
91.1 kiss
91.5 21
92.9 srr
93.3 kiss
93.8 focus
93.9 magic
93.9 info pro
96.3 galaxy
96.5 pro fm
96.6 orion
99.0 campus
99.2 kisskozia
99.9 gorila
100.9 europa
101.1 voces
101.7 sos
103.0 cultural
103.2 wil
103.3 horizont
104.3 horizont
104.5 itzi miti
105.0 oltenia
105.2 21
105.6 magic
105.6 rock mda
105.6 fresh
106.6 rra
107.7 darik
SUPER tropo at -6.2 - -8.1°C in south romania !
[Only registered and activated users can see links. Click Here To Register...] o bulgaria 2 undeva dupa tvr kostilaraia
[Only registered and activated users can see links. Click Here To Register...] propagare cu bazdaci oo si cu balamuk
[Only registered and activated users can see links. Click Here To Register...] semiluna pe 37
[Only registered and activated users can see links. Click Here To Register...] ia prazu pe batz
[Only registered and activated users can see links. Click Here To Register...] bulgaria unu de la turtucoaia de deal in canal uopt :lol:
care ma ajuta si pe mine cu un raspuns corect
100kw par in 50mhz cat acopera fara tropo , si cat se intinde peste granita de receptie normala pe tropo .. nu reusesc sa deslusesc rusia 1 pe primul canal cum se prinde in prima banda! FARA SPORADIC
propagation in bucuresti !
tropo in bucuresti!
R3 in action [Only registered and activated users can see links. Click Here To Register...]
ch 44 scattere mastodont .. nu se stie ale cui [Only registered and activated users can see links. Click Here To Register...]
scattere tampite [Only registered and activated users can see links. Click Here To Register...] zici ca e luata la p antena de pe varfu dili senila
[Only registered and activated users can see links. Click Here To Register...] imagine triplata nu dublata .. sub party , imagini cu o fata care statea pe un scaun si se misca , daca e cablu nui de la rcs .. hehehehe
cum a inceput tropo in canal 1 [Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...] uite aici maxim de r1 cu imagine slaba
scattere pe 88,7 cu turci [Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...] dance ucraina .. received correct with first layer in bucuresti
[Only registered and activated users can see links. Click Here To Register...] niste stiloz demicoiez
[Only registered and activated users can see links. Click Here To Register...] si o receptie facuta zob de ceatza
:wellcome: in real reception !! [Only registered and activated users can see links. Click Here To Register...]
primul sporadic cu TUNISIENI
nu se stie exact care a lovit dintre ei romania
RADIO ARDAR sau RADIO ANNABA [Only registered and activated users can see links. Click Here To Register...]
CLUSTERLE au indicat in germania si in croatia sporadice lente la 16:12-16:23 astazi 20.1.2009
cauza exacta - temperaturile aproape caniculare ce traverseaza de la tunisia pana spre egipt .
best old pictures 1996-2001
[Only registered and activated users can see links. Click Here To Register...] TVR2
E-skip
moment istoric pentru mine !
antena cea mai tare dintre toate este - directiva - 4.22db cu cablu de test la .. 90.278Mhz
antena cea mai slaba - verticala de dx acea cu semnal de 1.58Cm si fara masa .. 0.1041db la 93.0462Mhz
antena medie - circulara - 1.7582dB la 95.2337Mhz
antena de sporadic fara amplificare - 1.7869db la 55.937Mhz , cu amplificare 7.6172db si cu noise de 1.6331dB
antena de sporadic prima fara reflector - 0.2763db la 51.384Mhz
antena verticala din telescopicele de la tvdxtols uk - 0.1762db la 91.3361Mhz
antena de UHF - rezoneaza exact pe 614.9227 si are 0.3241dB normal si cu reflector 1.7236dB si cu amplificare 16.4239db si noise de 2.3810dB
am folosit , coaxiale de test BNC-BNC in B1 - B3 - UHF - analizor spectric "confidential seria" tektronix
O data cu sfarsitul de ianuarie , in zonele sudice , bucuresti , teleorman , lehliu , apare fenomenul de propagare NATURALA , audcand corect statiile din harhita pana peste granitile romaniei , ajungand partial si spre shumen .
ACUM 2 ANI , PE DATA DE 26 IANUARIE prindeam prima oara 93.0 TRINITAS de la gheorgheni
acum 1 an pe 28 ianuarie prindeam partial radio targu mures in bucuresti
ANUL acesta la 27 ianuarie TRINITAS harghita se aude slab si mediu pe stereo in bucuresti de mai bine de 9 ore . ora este 16:50
buna treba
deschid un modulator ES2008 in vederea reglari antenei de digital , sa aud semnalul TV sus pe casa ca sa stiu in ce pozitie nu mai balbaie ch54 .
in fine dupa vreo 17 min ma trezesc cu o goarna de "militie" jos la usa , adica un echipaj al leilor grei veniti sa intrebe de sanatate .. :twisted:
le-am explicat exact cum sta treaba si mi sa spus asa " inceteaza emisia ca perturb banda de UUS .
bravos si la mai mare .. traim in romania .. evident , nu ma mir ! :lol:
ai lov iu .. te pooop romania .. ..
traiasca neamtzu ce emite non stop cu solnitza de 200mw , traiasca grecu care sta belfer cu 1w pe cartier si asa mai departe .. noi insa cu 38mW tre sa avem un kilogram de morcovi pentru a astupa o gaura de .. :mrgreen:
deci urmeaza iar urmarirea generala ca in filme a masinilor cu modulatoare sa mai dea o amenda micaa .. :D uuuuuaaaauuu :lol:
daca vreti sa radem , cu blaupunkurile ce le am exact langa modulatr .. de la un cap la altul al benzi nu am nici fosnet si nici brum , deci 87.50 transmite si atat , 0 noise 0 intermodulare si asa mai departe , iar cu antena in blaupukt 87.6 shumen e cu rds ..
Logs 2.01.2009
87.7 unid arabic
88.2 bsm allah
88.3 izaat al shark lebanon
88.7 sawt almadena
88.7 unid power fm , english jingle
89.9 unid language unid music .. asiatic
TV
E3 - JORDANIAN TV
good dx
Daniel Zvartoshu
radio sporadic :dance:
ordinea filtrelor de DX
10.7 A - 230+5khz
10.7 S - 180+7khz punct dreapta sus , 10.7S ' - 230khz - 8khz maxim punct stanga sus
10.7 J - dublu punct - 150khz - 6khz diferenta de caldura poate adauga +2khz
10.7JA - 150khz +4khz , diferenta de caldura tine spre 149khz
SKN4N - SK10.7N4M - 150khz - 18khz diferenta de caldura [ canicula ] 128-134khz [ daca aparatul de radio nu receptioneaza sau fuge ± 50khz [ overload ]
SKN5N - SKN5H - SKN5K - SK10.7N5N - 110khz - 8khz diferenta de caldura poate atinge la unele si cote alarmante -12 sau cu defecte +7khz [ acesta daca este pus si frecventa are tendinta +50khz peste F base = OVERLOAD
73's
Това същото се повтори и снощи между 22 и 23:10, при положение че времето над Русе бе кофти, плътна мъгла, а румънците с перфектен сигнал от Букурещ, Buzau и от върховете! Към горния списък мога да добавя и UNID arabic на 87.6 който напълно заставаше "над" радио Шумен!
deci dupa cata tranta sporadica a fost in romania , iauzi la bulgari ca si peste shumen a cantat "camila" :gathering:
iata si ceva materiale echivalente cu augsburgul , amplificare mai mare de 1.4µV
selectoare de mare putere:
revenind la traditionala simetrizare de dipol aceea cu adaptarea tipica pentru alimentarea cu energie a fiderului avand la baza n adaptior Ø din ferita bobina am reusit pe langa bucla tipica de 75 ohm sa cobor din 300ohm cat are dipolul o tenisune de rf ce este egala cu cea culeasa pentu a impinge cu putere pana jos pe cablu fatza de naturala bucla ce o aveam :gathering: , rezultate sunt satisfacatoare adica shumenul fara tropo ziua a urcat de la 48dB undeva spre 58dB ajungand la cote acu noaptea spre 60dB , nu mai spun de srr 91.1 tipic de 32db ziua ajungand la 37dB acu noaptea spre 39dB :arrow1:
terminam cu astea , si va spun ca ziua asta a fost super la scatter meteor adica o zi foarte interesanta dpdv a unor semnale de la 300 - 500km
am prins europa de botosani , am prins turcul trt1 zonguldak mam tarasy , am prins neidentificate , si in utimul rand starazagora radioul unde speakerii vorbesc langa :cheers:
21:09
NEW tropo scatter in 90.5mhz with clasic program !!! [Only registered and activated users can see links. Click Here To Register...]
cel mai lung vazut de mine pana acu
new version poin from reception TROPO/SCATTER/SPORADIC-E
