Din păcate cardurile Digi satelit sunt împerecheate cu receptoarele lor.
Pe receptoarele menționate de tine poți vedea Digi satelit prin bunăvoința altor persoane care doresc să împartă (sharing) cu tine abonamentul lor ( mai vechi, când se putea desperechea cartela Digi de receptorul lor ) prin "aplicația "oscam sau prin aplicații de iptv.
Salut,ma poti indruma ajuta cum sa configurez OCTAGON SF8008 pe Digi Satelit
Am ultima versiune openatv si as dori sa imi instalez OS CAM pe el. De unde si ce downloadez si eu ? Ma puteti ajuta ? Multumesc
SF8008 4K Image Egami 10.4-r9
SF8008 4K Image Egami 10.4-r10
Warder private image for Octagon SF8008
New
- Updated Enigma2 - Added embeded direct play streamrelay channels from normal bouquet
- Updated pre-installed plugins
- Updated Settings
Use distro: OpenATV 7.4
Enigma version: 24.10.2023
Kernel version: 4.4.35
DVB version: 02.08.2023 / 08.11.2022 - mini
GStreamer version: 1.22.6
Python version: 3.11.2
Resolution mode: 1080p
Default language: English
Default skin: HD Glass 17
Pre-installed plugins:
- AJPanel - 8.8.8
- ArchivCZSK - 2.3.4
- Chocholousek picon - 5.0.230403
- CoolTVGuide - 7.7.0
- CSFD - 18.00
- DreamSatPanel - 1.6
- E2iPlayer - 2023.24.10.01
- EPGImport - 1.0
- Freearhey - 2.8
- HDF Radio - 2.4.3
- Levi45 Addons Manager - 10.1-r17
- MediaPlayer2 - 0.90
- MediaStream - 20231007
- Multi-Stalker - 1.5a
- Multi-Stalker PRO - 1.0
- SubsSupport - 4.1.0
- XStreamity - 4.17
- Youtube - git1172
- Kodi 20.2
- under Kodi Skylink Live TV - 1.7.5
- under Kodi Netflix - 1.22.3
- under Kodi Stream Cinema - 2.3.09.1
- under Kodi Stream Cinema Community - 2.7.87
- under Kodi Peacock/SkyShowtime - 0.4.8
Pre-installed skins:
- HD Glass 17 - 9.15
- Metrix-ATV - 7.4-dev-fbda70f-r1
Pre-installed softcams:
OSCam: Oscam uni - port 8888
Login :
Password : warder
Installation:
- copy the file to a USB stick and install via Online image change.
Download:
You can download image for SF8008 from
DAB+ radio on sat for Octagon SF8008 [images]
Backup for DAB+ radio on sat Eutelsat 9E and Eutelsat 10E for Octagon SF8008 by Maumixio 2023
PureE2 7.3 backup for DAB+ radio on sat Eutelsat 9E and Eutelsat 10E for Octagon SF8008 by Maumixio 2023
OpenATV 7.3 backup for DAB+ radio on sat Eutelsat 9E and Eutelsat 10E for Octagon SF8008 by Maumixio 2023
Am OpenATV penultima sau ultima versiune. Ce program sau versiune pentru BISS Keys recomandati sa instalez ?
Simple Backup OpenPLI Release 9.1 Octagon SF8008/Supreme 4K Combo by Lav 20250311
- python version 3.9.9
- kernel version 4.4.35
- gstremer version 1.20.5 ; serviceapp: extplayer3
- channel list 3sat: Astra 19.2E; Eutelsat 16A ; Hotbird 13E
Cam:
- enigma2-plugin-cams-Oscam-Icam_2.24.12-11864-802 by Levi45
- OSCam port: 8888 [SkyDe-OK, emu-OK,SoftCamKey-OK]
Plugins:
- enigma2-plugin-extensions-oscamstatus
- enigma2-plugin-extensions-epgimport
- enigma2-plugin-extensions-backupsuite
- enigma2-plugin-extensions-xstreamity_4.88 + free m3u lists
- enigma2-plugin-extensions-vavoo 1.32
There are not many plugins and emulators here, because what is inserted works perfectly. If you want more or some other plugins, go to menu-plugins-green (download plugins)
Skins & Resolution:
- enigma2-plugin-extensions-skin- PLi FullNightHD (1920x1080) - current
- enigma2-plugin-extensions-skin- PLi FullHD
FTP:
user: root
pwd: octagon
Others info:
- network on LAN
- dvb-c & dvb-t2: ON
Download links:
Code:
Simple Backup OpenVIX 6.7.005 Octagon SF8008/Supreme 4K Combo by LAV 20250303
- python version 3.12
- gstremer version 1.24.10 ; serviceapp: extplayer3
- channel list : Astra 23.5E; Astra 19.2E; Eutelsat 16A ; Hotbird 13E; Eutelsat 9E @vhannibal (09 mar 2025)
Cam:
- enigma2-plugin-cams-Oscam-Icam_2.25.03-11871-802 by Levi45
- OSCam port 8888 - [SkyDe-OK, emu-OK,SoftCamKey-OK]
Plugins:
- enigma2-plugin-extensions-epgimporter
- enigma2-plugin-extensions-vavoo 1.33
Skins & Resolution:
- enigma2-plugin-extensions-skin- Simple_Ten_Eighty (1920x1080) - current
FTP:
user: root
pwd: octagon
Others info:
- network on LAN
Code:
Simple Backup OpenBH 5.5.1.005 Octagon SF8008/Supreme 4K Combo by @Lav 20250312
- python version 3.12.8
- gstremer version 1.24.10 ; serviceapp: exteplayer3
Cams:
- enigma2-plugin-cams-Oscam-Icam_2.25.03-11871-802 by Levi45 [SkyDe-OK] <Default Cam>
- enigma2-plugin-cams-CCcam 2.3.9 [SkyDe-OK]
Plugins:
- enigma2-plugin-extensions-subsupport
- enigma2-plugin-extensions-xklass
- enigma2-plugin-extensions-xcplugin
- enigma2-plugin-extensions-bouquetmakerxstream
Skins & Resolution:
- enigma2-plugin-extensions-skin- MX SLIM-Line NP (1920x1080) <Current>
FTP:
user: root
pwd: octagon
Others info:
- network on LAN
Download :
Code:
Multiboot Backup OpenDroid 7.6 Octagon SF8008/Supreme 4K Combo by @Lav 20250316
- python version 3.13.2
- gstremer version 1.24.12 ; serviceapp: exteplayer3
- channel list : Astra 19.2E & Hotbird 13E; @vhannibal (16 mar 2025)
Cam:
Plugins:
- enigma2-plugin-extensions-weatherplugin
- enigma2-plugin-extensions-vhannibalautosettings 1.4
- enigma2-plugin-extensions-bitratesetup
- enigma2-plugin-extensions-filecommander
- enigma2-plugin-extensions-imdbsetup
- enigma2-plugin-extensions-multitranscodingsetup
- enigma2-plugin-extensions-steampunkhdconfigtool
Skins & Resolution:
- enigma2-plugin-extensions-skin- Glamour Aura Sky (1920x1080) <Current>
- enigma2-plugin-extensions-skin- Steampunk HD (1920x1080)
FTP:
user: root
pwd: octagon
Others info:
- network on LAN
Download :
Code:
Code:
Multiboot Backup OpenATV 7.5.1 Octagon SF8008/Supreme 4K Combo by @Lav 20250318
- build date 2025-03-18
- gcc version 14.2.0
- openssl version 3.3.1-r0.1
Channel list :
Cam:
- enigma2-plugin-cams-Oscam-Icam_2.25.03-11874-802 by Levi45 [SkyDe-OK] <Default Cam>
Plugins:
- enigma2-plugin-extensions-Bouquet Maker Xtream 1.46
- enigma2-plugin-extensions-Multi Stalker Pro 1.1
- enigma2-plugin-extensions-XStreamity 4.88
- enigma2-plugin-extensions-XKlass 1.39
- enigma2-plugin-extensions-Vavoo Stream Live 1.33
- enigma2-plugin-extensions-Sub Support 1.5.8
- enigma2-plugin-extensions-EPG Import 1.0
- enigma2-plugin-extensions-Programmlisten Updater 1.3
Skin & Resolution:
- enigma2-plugin-extensions-skin-Metrix HD (FHD 1920x1080)<Current>
FTP:
user: root
pwd: octagon
Download :
Code:
Multiboot Backup Cobraliberosat 9.1 Octagon SF8008/Supreme 4K Combo by @Lav 20250320
- build date 2025-03-11
- gstremer version 1.20.05 ; serviceapp: exteplayer3
Channel list :
Cam:
Plugins:
- enigma2-plugin-extensions-Backup Suite
- enigma2-plugin-extensions-Bouquet Maker Xtream 1.41
- enigma2-plugin-extensions-Oscam Status 1.3.3
- enigma2-plugin-extensions-Aglare CBL Skin
- enigma2-plugin-extensions-GioppioGio Setting & Picon V 12.5
- enigma2-plugin-extensions-Vhannibal Auto Setting 2.7
- enigma2-plugin-extensions-Software Managment
- enigma2-plugin-extensions-You Tube
Skins:
- enigma2-plugin-extensions-skin-PLi-FullHD (FHD 1920x1080) <Current>
- enigma2-plugin-extensions-skin-Aglare-FHD-CBL <Default>
FTP:
user: root
pwd: octagon
Download :
Code:
Multiboot - OK
Salut!Vreau sa incarc o imagine pe multiboot... Pe sf8008 imi spune la usb ....no usb bin. Desi usb... e fat32.... incarc imaginea multiboot zip. [am incarcato si dezarhivata] si intampin aceiasi problema. no usb storage device found,please insert usb device first. Orice sfat e binevenit!!! Multumesc!
Multiboot Backup PurE2 7.4.001 Octagon SF8008 by @Lav 20250321
- build date 2025-03-21
- python version 3.12.4
- gstremer version 1.24.6 ; serviceapp: exteplayer3
Channel list :
Dual: Astra 19.2E & Hotbird 13E; @vhannibal (16 mar 2025)
Cam:
- enigma2-plugin-cams-Oscam-Icam_2.25.03-11874-802 by @levi45
Plugins:
- enigma2-plugin-extensions-AJ Panel 9.4.0
- enigma2-plugin-extensions-XStreamity 4.89
- enigma2-plugin-extensions-airnet-fnc (2.1-r0)
- enigma2-plugin-extensions-dreamcc (2.0-r8)
- enigma2-plugin-extensions-imdb-fnc (4.0-r2)
- enigma2-plugin-extensions-livefeeds-fnc (1.4-r1)
- enigma2-plugin-extensions-wazzup-fnc (2.1-r2)
- enigma2-plugin-extensions-subsupport (2.1-r0)
- enigma2-plugin-extensions-pmanager (2.8-r0)
Skin:
- enigma2-plugin-extensions-skin-Estuary v7.5.10 (FHD 1920x1080)
FTP:
user: root
pwd: octagon
Download :
Code:
OpenVIX 6.7.007 Multiboot Image for Octagon SF8008 4K Combo @Lav 20250322
Channel list :
Astra 23.5E; Astra 19.2E; Eutelsat 16A ; Hotbird 13E; Eutelsat 9E @vhannibal (16 mar 2025)
Cam:
- enigma2-plugin-cams-Oscam-Icam 2.25.03-11877-802 by @levi45
- enigma2-plugin-cams-CCcam 2.3.9-r.1-de
Plugins:
- enigma2-plugin-extensions-vhannibal-auto-setting 2.6
- enigma2-plugin-extensions-epgimport 1.0
- enigma2-plugin-extensions-xstreamity 4.89
- enigma2-plugin-extensions-xklass 1.40
- enigma2-plugin-extensions-imdb 6.7
- enigma2-plugin-extensions-e2iplayer git4472
- enigma2-plugin-extensions-bouquet-maker-xdream 1.46
- enigma2-plugin-extensions-sub-support 1.5.8
- enigma2-plugin-systemplugins-serviceapp 0.5 (exteplayer3)
Skin:
- enigma2-plugin-extensions-skin- PLi-HD-Night
FTP:
user: root
pwd: octagon
Download:
Code:
Multiboot Backup OpenBH 5.5.1.007 Octagon SF8008 4K Combo by @Lav 20250325
- release 5.5.1.007-sf8008-ec76d2eb-20250323
Channel list :
Astra 23.5E; Astra 19.2E; Eutelsat 16A ; Hotbird 13E; Eutelsat 9E (20250323) @vhannibal
Cams:
- enigma2-plugin-cams-Oscam-Icam 2.25.03-11877-802 by Levi45
Plugins:
- enigma2-plugin-extensions-bouquetmakerxstream 1.46
- enigma2-plugin-extensions-subsupport 1.58
- enigma2-plugin-extensions-youtube git1295
Skins & Resolution:
- enigma2-plugin-extensions-skin- Black Shadows SE (1920x1080) <Current>
- enigma2-plugin-extensions-skin- MX SLIM-Line NP (1920x1080) <Default>
FTP:
user: root
pwd: octagon
Download :
Code:
Multiboot Backup OpenPLI Release 9.1 Octagon SF8008 by @Lav 20250328
- Python version 3.9.9
- Kernel version 4.4.35
- Gstremer version 1.20.5
Channel list : Astra 23.5E; Astra 19.2E; Eutelsat 16A ; Hotbird 13E; Eutelsat 9E (20250323) @vhannibal
Cam: OSCam 2.25.03-11878-802 by @levi45 (port:8888)
Plugins:
- Oscam Status (1.3.3)
- Vhannibal AutoSettings (2.6)
- XStreamity playlists player (4.91)
- XKlass playlists player (1.43)
- Vavoo Stream Live (1.33)
- YouTube (1+git1247)
- Multi-StalkerPro (1.2)
For example my box ip is: 192.168.0.15 so the web interface url is:
Code:
Skin: PLi FullNightHD (1920x1080)
FTP: user: root / pwd: octagon
Download:
Code:
/all images are tested on octagon sf8008/
/insert image from flash online/
