Changeset #4031
Message: WebIf: fix small bug in last commit
Changeset #4031
r4032 | alno | 2010-12-02 23:48:56 +0100 (Thu, 02 Dec 2010) | 1 line
General: move sigpipe message to debug 255
r4031 | alno | 2010-12-02 22:04:35 +0100 (Thu, 02 Dec 2010) | 1 line
r4034 | schlocke | 2010-12-03 08:57:43 +0100 (Fri, 03 Dec 2010) | 2 lines
cccam: client disconnect more forced
r4033 | schlocke | 2010-12-03 08:38:25 +0100 (Fri, 03 Dec 2010) | 2 lines
cccam: modified card reporting
r4035 | _network | 2010-12-03 11:59:04 +0100 (Fri, 03 Dec 2010) | 2 lines
io_serial: disable tcflush on error, smargo stops working after calling tcflush
Changeset #4036
Message: cccam: updated card reporting, updated cccam 2.2.x code
Changeset #4037
Message: cccam: updated cccam 2.2.x code: block loop for rc6
Changeset #4038
Message: log ecm answer after it was send to client
r4039 | schlocke | 2010-12-03 22:42:47 +0100 (Fri, 03 Dec 2010) | 2 lines
cccam: another cccam 2.2.x code update
r4038 | _network | 2010-12-03 21:15:04 +0100 (Fri, 03 Dec 2010) | 2 lines
Changeset #4040
Message: some cosmetics for "oscam -h"
Changeset #4041
Message: set max reader count to 128 on all platforms
postat pentru @djczefre
[Only registered and activated users can see links. Click Here To Register...]PHP Code:r3090 | landlord | 2010-09-18 14:02:41 -0700 (Sat, 18 Sep 2010) | 1 line
Added documentation for 'lb_mode', 'lb_save', 'lb_nbest_readers', 'b_nfb_readers', 'lb_min_ecmcount', 'lb_max_ecmcount', 'lb_reopen_seconds' and 'double_check'.
r4042 | schlocke | 2010-12-05 14:53:07 +0100 (Sun, 05 Dec 2010) | 2 lines
r4041 | _network | 2010-12-04 17:12:55 +0100 (Sat, 04 Dec 2010) | 2 lines
r4043 | schlocke | 2010-12-06 07:55:45 +0100 (Mon, 06 Dec 2010) | 2 lines
cccam: updated 2.2.x code
r4044 | schlocke | 2010-12-06 20:50:50 +0100 (Mon, 06 Dec 2010) | 2 lines
cccam: fixed some emm handlings
r4046 | schlocke | 2010-12-06 22:58:57 +0100 (Mon, 06 Dec 2010) | 2 lines
cccam: fixed some emm issues
r4045 | schlocke | 2010-12-06 22:39:11 +0100 (Mon, 06 Dec 2010) | 2 lines
cccam: fixed some emm probs, fixed timeouts
---------- Post added at 05:55 ---------- Previous post was at 04:49 ----------
r4047 | schlocke | 2010-12-06 23:17:21 +0100 (Mon, 06 Dec 2010) | 2 lines
r4048 | schlocke | 2010-12-06 23:24:06 +0100 (Mon, 06 Dec 2010) | 2 lines
cccam/webif: fixed "emmwritten" compile error if webif is disabled
r4049 | schlocke | 2010-12-07 07:50:51 +0100 (Tue, 07 Dec 2010) | 2 lines
cccam: Fixed card reporting
