Cam asa cred:
## -- This allows port 21 to be answered by (dropbear on) the router
iptables -t nat -A prerouting_wan -p tcp --dport 21 -j ACCEPT
iptables -A input_wan -p tcp --dport 1021 -j ACCEPT
Cam asa cred:
Ok ,dar unde ii zic catre ce ip din lan sa faca forwardarea ?
probabil aici "dport ip:21"
adica asa :Quote:
Originally Posted by qwess [Only registered and activated users can see links. Click Here To Register...]
iptables -t nat -A prerouting_wan -p tcp --dport 192.168.1.109 21 -j ACCEPT
iptables -t nat -A prerouting_wan -p tcp --dport 192.168.1.109:21 -j ACCEPT
iptables -A input_wan -p tcp --dport 192.168.1.109:1021 -j ACCEPT
Mersi quess.poate o fi bine.dar cam la orice config i-am pus imi scrie :
No connection could be made because the target machine actively refused it.
Connection failed.
Am dm500 pe lan-ul routerului si vreau sa fw-dez port 21 catre wan dar pe alt port.pe dm500 am nemesis .oare trebuie setat ceva si in dream ?
poate te ajuta asta:Code:http://www.sbtechsolutions.biz/more-complicated-instructions/openwrt/setting-up-port-forwarding-and-dealing-with-loopbacks-on-openwrt-kamikaze-8.09.1
---------- Post added at 20:38 ---------- Previous post was at 20:24 ----------
in /etc/config/firewall:
config rule
# option src lan
# option src_ip 192.168.1.109
# option src_mac 00:11:22:33:44:55 treci mac-ul DM
# option src_port 21
# option dest wan
# option dest_ip 192.168.1.1 treci ip WAN
# option dest_port 1021
# option proto tcp
# option target ACCEPT
asta mi se pare ok si stergi din firewall.user
Nu vrea .cred ca nu e script sa nu-l fi incercat si de pe net.
am pus pe direct dm(fara router) si am instalat, adaugat in sfarsit liniile in cccamcfg .raman fara ftp si http asta este..
Sa aiba imaginea nemesis pe dm500 vreo setare similara cu cea din oscam cu
"httpallowed = 10.0.0.1-252.0.0.1" valabila si in caz ftp,http ?
Oricum multumesc
Salutare la toata lumea. Si eu miam luat un router TOPEX BUTTY GPRS (cel cu wifi, adica deluxe). As ca cum am timp ma apuc cu postul 27 sa vad cum si ce. Va anunt daca ceva am bulit si nu merge, nu va faceti griji :)
TOPEX BUTTY GPRS (cel cu wifi, adica deluxe). Cineva cine are un firmware original pe el este ? as dori sa il folosesc untr-o locatie doar cu acoperire utms
Aveti idee daca topex deluxe-ul meu poate fi overclockat la 300 mhz si daca da ce valoare sa-i dau in nvram ,e stabil ?
Din cate am citi pe forum, raspunsul este DA, se poate.
Cat de stabil este nu stiu ca eu nu am facut asa ceva inca.
Originally Posted by technomate [Only registered and activated users can see links. Click Here To Register...]
in dd-wrt arata frecventa procesorului , nu se merita sa ii faci overclock nu vei avea un spor considerabil de viteza wan-lan iar riscul sa-l busesti este mai mare . daca il folosesti numai ca server cccam nici nu simte incarcarea procesorul :DQuote:
nvram set clkfreq=300,150
nvram commit
reboot & exit
chestia este ca am testat un suici si i beton referitor la datele ...rutar...hop..1..2..3Quote:
Bey soarece, ba fratele meu, eu cred ca tu ai avut o copilarie nefericita, ai crescut fara jucarii, te-a aruncat cineva din familie de trei ori in sus si nu te-a prins decat de doua. Ce ai ba nene de o iei pe aratura asa?
