Folosesc dvbviewer cu licenta si va spun din propria experienta, nu se compara cu nici un altul. Atat.
Aaparut SmartDVB 0.2.5rc1.Am remarcat o chestie interesanta -download frecvente feed si una foarte proasta-nu are semnal pe canalele codate chiar daca audio este free.Are si blindscan.
v0.2.5 Release
changed: small change to show signal also when not able to decode a channel.
fixed: starting udp streaming from the new tools menu option wasn't working correctly, also the menu
checkbox was not always updated correctly.
changed: TS recording is now default on new installations (as mpeg does not yet work correctly for ac3).
changed: some changes to shutdown code as some were having problems there it seems, untested yet as
for me it worked without hickups before already.
changed: mousewheel/middle mouse button now switches between floating and main when set in settings.
fixed: latitude for newly added satellite was wrongly set to DVB-S instead of the degree value due to recent
changes (and me not testing adding new sats ofcourse).
fixed: small fix when exiting app with recording on and cancelling the exit the video
would become unstable.
fixed: some fixes to the scheduling functionality. There was a crash when adding a schedule action from the epg's.
Also now the now event scheduling will try to change the starting time so the event actually runs (before
it wouldn't as the start time was in the past and the ms scheduler in such case ignores such an event.)
fixed: blindscanner would sometimes not pick up frequencies correctly at the end of the frequency range.
min/max sr processing was not working correctly in blindscanner.
Also some fix to try to also blindscan correctly at the end of a range (sometimes a last valid
frequency was missed it seems).
fixed: some fixes to no signal processing in scanner, let me know if you still encounter problems here.
fixed: gotosat functionality in add frequencies dialog in my case was not always operational,
hopefully fixed.
updated: blindscanner strings moved to resources to make translations possible (and other recently added
strings, let me know if you're still missing something during translations).
fixed: Some fixes to the sync dialog. Some fecs were being wrongly imported in the sync dialog
(91 to smart should be 910) and modulation changes are now also reflected in color changes.
fixed: Numeric keypad should now work again on keyboard input selection (hard to find little bug).
fixed: more udp fixes as in some cases buffer overruns could be wrongly generated due to misconfiguration.
changed: setup filter.ini updated to reflect current codec use better (LAV/MS DTV etc).
changed: updated crazycat streamreader.dll installed to latest one.
fixed: some more fixes to no-signal processing.
fixed: some fixes to switch handling in blindscanner (thanks to moonchild once again for testing this).
updated: transponder lists updated (sats only).
updated: small changes to old bdas.dev stream processing (analog to my recent changes in bda.dev) should make
this also more stable with stream, but still use bda.dev for now (in future i might revise and update bdas.dev
as this module probably will work better for things like multiple devices, more modular built).
Also the smartdump.ax filter used by this was not correctly rebuilt
before (still used some older directshow sdk, so maybe this was the reason bdas.dev didn't work
that well for some).
fixed: handling of bandstacked lnb's (dbs/fss) as polarization was not always set correctly here (untested).
fixed: small fix which might affect application stability when tuning lots of no-signal or bad signal
channels in one go.
fixed: small fix in channel processing which could result in some wrongly lost channels.
fixed: various small fixes in install process (in some cases if things didn't go the default way let's say
smart needed to be restarted for the video to work correctly (eg. when failing to start the initial
device and needing to select another one).
fixed: some changes to bandstacked dishpro handling which were not working correctly (untested yet).
fixed: some little timing changes to bda.dev (for better stability hopefully).
fixed: atsc was broken due to recent clear-qam support changes (clear-qam still untested, atsc should
work again).
fixed: more changes to band-stacked lnb handling in bda.dev and blindscan.dev.
fixed: some changes after rebuild long recordings failed after some hours in the taskbar, oddly enough
i'm sure this didn't happen before the new system rebuild with the same compiler (so there
are subtle differences even if the same settings, i'll have to test this some more i'm
afraid).
fixed: some changes to bda.dev concerning clear-qam (atsc digital cable) handling as this wasn't
working yet (tuning space addition/changes, untested).
fixed: some more bugfixes and fixes to blindscan.dev among others again concerning band-stacked lnb's.
fixed: bug in bda.dev which would show zero level in some situations while there actually was level
detected.
fixed: still video filter wasn't working with audio channels.Seems to work again, not tested much.
added: alternative signal detection to bda.dev (under device settings).
fixed: some window showing problems when moving from floating to main etc under certain conditions the main
window would be hidden instead of shown.
fixed: usals changes were not enabling apply button.
changed: updated american transponder list files (thanks to ger).
Download: [Only registered and activated users can see links. Click Here To Register...]
Am instalat SmartDVB dar cand il deschid imi apare "error connecting smart filter to decoder video input'' . Ce codecuri sunt necesare si mai ales cum trebuie alese in meniul programului?
@Swerige
Uite cu ce merge perfect la mine, atat TV cat si radio:
Multumesc mult miki, spunem-mi te rog ce codecuri ai instalate. La mine nu apar si cele care sunt in imaginea atasata. Merci.
Lav merge si la sd si la hd [Only registered and activated users can see links. Click Here To Register...]
Daca esti pe w7 la video renderer alegi EVR
@Swerige, ti-a raspuns @roderttam, dar ai parcurs pasii: Tools / Settings / Directshow / Conection ? Trebuie sa ai niste liste de codecuri acolo. Sau da click pe "Add" si vezi ce codecuri ai disponibile.
Mentionez ca folosesc windows XP cu Sp3. Innainte am avut Windows 7 si Smart DVB mi-a mers fara probleme. Acum pe XP am dat de preblema legata de codecuri. Am instalat si pachetul K-Lite Codec Pack 940 Full, poate nu e suficient. De asemenea am parcurs pasii: Tools / Settings / Directshow / Conection unde am facut diverse combinatii posibile:LAV,ffdshow,Video randerer, Main Concept AVC dar tot contnua sa-mi dea eroare la video.
SmartDVB 0.4.0 Release
v0.4.0 Release:
Changelog:
fixed: Scanner update would mark MIS entries with other ID incorrectly lost.
fixed: RF scan would not take into account other defined LNB's for the current satellite and incorrect LNB limits might be set also when blindscanning.
fixed: some more RF scan fixes/cosmetic issues.
fixed: tray icon record state would not always correctly indicate recording on/off.
fixed: issue where channel icons would not be shown correctly when SID's were shown in the channellist (only for service name based icons).
modified: some modifications to bda.dev tbs and autodetection code, might detect specific tbs devices (also tbs 6983) better now (thanks to steven).
fixed: some more fixes to scanner MIS parsing (thanks to alexi).
fixed: RF Scanner resource strings added (for translations).
fixed: MIS scan scanner (bda.dev) bug which could select the wrong mis when scanning (thanks once more to alexi).
fixed: sometimes a scheduled record would use the wrong EIT entry.
fixed: some cosmetic changes to record name defaults.
fixed: updated streamreader.dll to 1.2.2.1260
fixed: some minor fixes to the SmartOSD timeshift button toggles (remote now also should toggle between play/pause).
DOWNLOAD: [Only registered and activated users can see links. Click Here To Register...]
SmartDVB 0.5.0 RC2 is available!
v0.5.0.36RC2
◾HEVC playback has been improved with this version, lentoid codec should work now also.
◾AAC playback might also work better with the LAV and MS AAC decoders.
◾Also MadVR support has been updated for the current MadVR versions.
Código:
SmartDVB 0.5.0.51 RC3 is available!
v0.5.0.51 RC3
◾Initial PLP (DVB-T2) support added.
◾Some enhancements to the normal scanner for INI management.
◾Ability to add a new channel in the channel properties dialog.
◾Various fixes and improvements to channel tuning.
◾Remotes were not working for non TBS devices, should be better now.
Código:
Pacat ca pe un tv 4K lista prg tv din stanga nu se distinge , scris foarte mic
win32 0.5.1 portable release
This 32 bit portable update should have all the recent 0.5.1 x64 build changes, such as unicode support, and (additional) fixes. Some added features or improvements include:
- better zoom capabilities through a zoom dialog. You can save zoom settings on a per channel basis.
- Somewhat better H.264 4:2:2 support, but your mileage may still vary depending on the used codecs, as usual LAV is recommended.
- XMLTV EPG/EIT importing (experimental for now, if you find issues here please report them).
0.5.3 x64/x86 beta test portable version now available.
0.5.3 x64/x86 portable versions are now available. The build includes many fixes and the following improvements:
-Added support for external splitters, including LAV Splitter support. Please note that LAV Splitter support is experimental and initial connection is slow compared to the default splitter (SmartAVSrc). So if you care most about tuning speed, and not so much about picture quality, do not use the LAV Splitter
-Added windowed EPG viewer
-Better support for 4:2:2, including 4k and 8k
-Added EVR-CP (Custom Presenter) video renderer, with support for HDR and external shaders. Including support for rendered subtitles (DVB/Teletext Subtitles)and exclusive fullscreen mode.
-improved 4:2:2 support (LAV Splitter in combination with the LAV Video Decoder plays 4:2:2 quite well)
-improved 4k and 8k support
-MDAPI improvements/enhancements (including x64 build fixes)
-Extended zooming support dialog. Zoom settings can be saved per channel.
-Improved MadVR support (also works well with the LAV Splitter)
-Support for external multiplexers (including Microsoft MPEG2 demux, Elecard demux, Mainconcept demux etc)
-Graph performance settings (experimental, leave the default settings if you don't really know what you're doing here)
-Blindscan.dev improvements/fixes, added blindscan.dev device settings to set the defualt blindscan.dev tuning method.
-Initial (experimental) CAM Menu support for TBS CI CAM devices only. Please report if you have issues with this feature as it has not been tested extensively.
-Improvements to DVB Transport Stream file play mode video quality/stability, play HEVC DVB File option added. Please do not use transport stream recordings of sizes lower than about 100Mb as otherwise transport stream playback can be somehwat unstable.
-Improvements to SmartOSD default scaling. Default OSD graphics changed, including EPG.
Please note that this is a beta build, mainly due to the new features like EVR-CP which have not been tested extensively yet, otherwise the app should be stable.
x64:
x86:
De 2 zile smart-dvb 0.5.3.26 si v-plug 2.4.6 nu mai lumineaza pe film now si film now hd. Pare ca citeste si decripteaza streamul dar nu lumineaza. Pe celelalte programe criptate din pachet e totul OK, bineinteles cele doua 4K nu intra in discutie.
La dvb viewer, dvb dream nu sunt probleme cu acelasi softcam, acelasi v-plug, aceleasi setari Cred ca problema este de la vreo modificare din engine-ul intern smart dvb, nicidecum de la v-plug care isi vede de treaba. Dar cum s-a intamplat nu inteleg. Am incercat si pe alt PC dar este la fel.
---------- Post added at 19:54 ---------- Previous post was at 19:14 ----------
Adaug ca fenomenul este notat doar pe versiunea beta x64, pe 86 este totul OK
nici Progdvb x64 nu merge cu vplug, ia varianta x32 si nu observi nicio diferenta
Numai la filmnow si filmnow hd se intampla fenomenul. celelalte programe criptate sunt deschise la fel ca si mai inainte.
V-plug e OK pe alte playere, a fost si pe smart-dvb dar acum a deraiat si nu stiu de ce.
Nu cred ca e de la v-plug, sunt sigur ca trebuie cautat in alta parte. Poate vreo actualizare de windows sau un conflict din alta parte, e ciudat.
Nu stiu cum e pe progdvb, nu-l mai folosesc de multi ani.
ma refeream la smartdvb x32 sa folosesti, nu sa schimbi playerul.
cand scanezi cablu, ce setari de tara folosesti, oricum aleg imi pune in lista fiecare program de doua ori.
acum observ ca nici subtitrarea dvb nu apare, chiar daca aleg din optiuni
Cred ca nu ne-am inteles, nu ne referim la alte playere. Nu am zis de schimbat player-ul, vorbim strict doar despre Smart DVB, unde doar cele doua programe, repet FilmNow si FilmNow HD sunt problematice si nu inteleg de ce anume!
Dar cert nu din cauza de V-Plug care citeste si decodeaza streamingul respectiv.
Iar ce spui de subtitrare este alt subiect, functioneaza la smart dvb, pe video render EVR sau EVR-C (EVR Custom) pe x64, iar pe x86 beta functioneaza si pe VR9.
Am schimbat pe evr si merge subtrarea
Cu lista de canale se intampla la fel ?
De ce nu folosesti varianta x32 ? Ce are in plus x64?
Sau vrei sa sapi sa afli care este problema, daca te pricepi atunci spor la treaba. Undeva exista un conflict intre vplug si aplicatiile x64, cum spuneam se intampla la fel si la alte playere.
Am spus clar ce urmaresc, ti-am raspuns si ce sa faci pentru a avea subtitrare iar tu imi tot spui sa schimb playerul. Nu asta urmaresc, ci ca sa rezolv acest conflict sau sa inteleg de unde vine. Lista scanata se memoreaza normal nu dublata indiferent de versiunea folosita. Editezi personal lista de frecvente pentru cablul tau sau folosesti optiunea de scanare full dar dureaza mult scanarea.
