:) SOON AVAILABLE FOR DOWNLOAD :)
WARNING.If you install it to multiboot, you must install the Nabilosat Pure Flash DM 8000 dated 18 February 2009
download :
Nabilosat DM8000 Pure Flash 18FEB09, with Barry Allen 4.6.79
What is the Nabilosat DM8000 Pure Flash ?This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.What is included in this image ?This image is including the latest available edition of Barry Allen: 4.6.79Why should I install this image in flash ?Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.8AG of its Black Hole image. If installed to multiboot, the new Black Hole v0.8AG requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.How do I install Barry Allen with this image ?Barry Allen will be automatically installed at the end of the image Setup Wizard. A console window will provide on screen installation status progress.Will I loose the images already installed on my media ?No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.How do I install it to flash ?You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.Release Details
NEW Nabilosat HD bootlogo by MaximoII.
Barry Allen 4.6.79 included
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm8000"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.5.0"
TARGET_FPU = "soft"
COMPILED DATE = "18 February 2009"
ENIGMA2_CVS_DATE = "15 February 2009"
ENIGMA2_VERSION = "2.6 experimental"
DVB DRIVERS = "07 February 2009"
SECOND STAGE = "71-pr1"
BARRY_ALLEN_VERSION = "4.6.79"
Instructions
1) Flash your DM 8000 with Web Interface or DreamUp and serial cable
2) Complete the Default Wizard to setup the basic steps
3) Upon Wizard completion, Barry Allen will automatically install
4) Follow the on screen information
5) When the install is complete, the DM will restart and new BA version will be available in the plugin MENU.
Barry Allen will have been updated. You will find your previous images listed, choose your favorite as always.
download :
experimental-dm8000_19-02-2009.nfi
Nabilosat Enigma2 Black Hole - DM8000 v0.9
Advanced Graphics
What is new in this version 0.9 ?
Nabilosat v 0.9 is now including by default the new DMM plugins Software Manager, Network Wizard and Mount Manager.
The Samba Server is enabled by default. This solution will allow to Network Browser to locate your DM8000 on your Local Area Network
New:Devices Managment and mount startup:New: Skin revision by Matrix10
As you know in DM8000 we have these Extra Ports:
1 SD card 1 Compact Flash 3 Usb.
These devices can be "hotplugged" or used in stable mode.
In case of hotplug insertion the devices are automounted in DM8000 and you will find them in the folder /autofs.
But if you want to use these devices in stable way and you leave them connected and inserted, the Black Hole image will detect them at startup and will mount in this way:
Sd card -> /media/card
CF -> /media/cf
First Usb -> /media/usb
Second Usb -> /media/usb2
Third Usb -> /media/usb3for new SoftareManager and NetworkBrowserEnigma2 CVS date23 February 2009 2.6 experimentalDrivers date07 February 2009Second Stage #71-pr1
Main Function KeysButton 1xOK = Light Info SkinAddons
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time ShiftDedicated Addons ServerInfobar/OSD
Download and install additional packages from Nabilosat serverEnigma2 Analogic ClockNabilo Panels features
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP PanelSystem Monitor PanelCCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
ProcessSave2) Green Panel
Select/Start/Restart EMU
ShoutboxMany thanks to the Beta Testers Team
Fast Plugin
AddonsAddons Download ManagerScripts
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
^^Corrado^^,Neri73, Ferbius
Credits
E2 Sky Epg loader integration by MaxZ4.
Matrix10 for the new Black Shadow skin.
Army for the new System Monitor Panel graphics.
^^MaXiMo^^ for bootlogos.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not supported!
WARNING.If you install it to multiboot, you must install the Nabilosat Pure Flash DM 8000 dated 25 February 2009.
download :
http://rapidshare.com/files/202692112/NabiloBlackHole_DM8000_09.zip
Nabilosat DM8000 Pure Flash 25FEB09, with Barry Allen 4.6.83
What is the Nabilosat DM8000 Pure Flash ?This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.What is included in this image ?This image is including the latest available edition of Barry Allen: 4.6.83. System Plugins: Software Manager and new Network Wizard, Mount ManagerWhy should I install this image in flash ?Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.9 of its Black Hole image. If installed to multiboot, the new Black Hole v0.9 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.How do I install Barry Allen with this image ?Barry Allen will be automatically installed at the end of the image Setup Wizard. A console window will provide on screen installation status progress.Will I loose the images already installed on my media ?No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.How do I install it to flash ?You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.Release Details
Barry Allen 4.6.83 included
TARGET_OS = "linux"
MACHINE = "dm8000"
TARGET_FPU = "soft"
ENIGMA2_CVS_DATE = "23 February 2009"
BARRY_ALLEN_VERSION = "4.6.83"
System Plugins SoftwareManager and NetworkBrowser: included
Remember to enable the Expert Mode in the Customize Menu.
Instructions
download :
experimental-dm8000_01-03-2009.nfi
01.03.2009
Gemini2 v4.2
Enigma from 2009/04/23
Most Functions are described in our Wiki.
XXXXXX-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* long BLUE -> PiP (DM7025)
* 2x BLUE - BP -> XXXXXX Extras
* BLUE RED -> File Manager
* RED - Record
* GREEN - Quickbutton / Subservices
* Yellow - Timeshift (not for DM8000)
Extras:
* Own Addon-Server via internet.
* Cryptinfos of the Stations. Assign different Camds to Stations/Providers (AutoCam).
* Manage many Daemons / Server (BP - Services/Daemons)
* Visual improvements such as HD-Skin, icons or additional adjustments to the station list
* Manager for formatting, setting up or integration of devices (BP-> Device Manager)
* additional EPG functions, such as Autosave, Refresh, or connect different EPG formats
* Own Addons e.g. Dreamnetcast, jukebox, calendar, e-mail or eTorrent to name just a few
* Quick button (select the function of the green button via the menu)
* detailed information about your Dreambox (Menu-> information)
* File Manager, it is possible to handle all formats, regardless of whether images, sound, film material, playlists, Torrents, scripts or DVDs (BP-> File Manager)
Many other functions, such as "the GP2 Controlr" Rezapp or the many options can in IHAD board or our Wiki to be read.
New:
* added more daemons to BP Menu-> Services / Daemons
* NFS server, and port options for MAC-user expanded
* simple Samba configuration on BP -> Services / Daemons-> Samba (Samba must be installed))
* Quick button can also work as a menu when more than 1 point is activated (Note new quickbutton.xml))
* In the file manager can be the Favorites menu as a starting set.
* Function of the exit button in the file manager (in Movie Mode) can be changed
* almost all menus, in which the settings are unified.
* Jukebox now works as a browser, there is no need more to create playlists.
* Selection of the drivers/kernel modules as a wizard on first start of the box integrated.
Handling of complete respect block USB devices (HDD, USB, CDROM, Printer) redenominated
This has the following effects:
* Folder "/media" is empty, all the folders in "/media" are created by the system.
* Tile "/etc /fstab" is empty and shouldn't be need to register devices yourself.
* All equipment, including hotplug devices will receive depending on the number of partitions in the folder "/ media".
* To switch to the new system easier, are currently or 2 links to hard drive.
The Root of the link "/hdd" and the link "/media /hdd", both are really no longer necessary. smile
* Autofs will only be used for network drives. Means there is no folder "/autofs" more in the Root.
In the folder /etc are only 2 files needed for autofs (auto.master and auto.network).
About the Editor Automount in XXXXXX can only drives network which, in the file "/etc /auto.network" saved. Network drives on the autofs mount
are now in the folder "/ media / net".
* Media-scanner and Media Player no longer in the image, this is the DVD player is already integrated in the image (to be found in the BP). This must and should also no longer be installed separately (specifies otherwise noted problems with the built-in).
* If you have a printer connected to the Dreambox, it is no longer worry about the printer. This will be started and stopped automatically when a printer is detected. The status of the daemon can continue in the daemon list in BP's Profile. This printer is ever on the Dreambox work, must be the kernel module loaded.
Important:
If any devices to the Dreambox does not work or can not mount, please always check whether the appropriate drivers are loaded (BP-> Settings-> kernel modules). Caution complete handling of Camden redenominated
* Changes to the Camden-scripts to e.g. Ecm several info files read out (advantage is that, when a recording, streaming, or PIP still the right ad in the coming infobar)
* AutoCamd also converted, Camden on individual channels can be assigned to
* Select the Start / Stop can be set (BP-> Settings-> General)
* Starting / Stopping the Camden now in a separate process, thus no blocking of Enigma
Fix + Update:
* eTorrent now completely skinbar and sizes > 2GB fixed
* Download-Routine
* read from script, config files
* see CVS
Backups or other modified Images are not from us
and won't be supported!
Nabilosat DM8000 Pure Flash 02MAY09, Barry Allen 4.8.2 Nabilosat DM8000 Pure Flash 02MAY09, Barry Allen 4.8.2
What is the Nabilosat DM8000 Pure Flash [Only registered and activated users can see links. Click Here To Register...]
What is included in this image [Only registered and activated users can see links. Click Here To Register...]
This image is including the latest available edition of Barry Allen: 4.8.2. System Plugins: Software Manager and new Network Wizard, Mount Manager
Why should I install this image in flash [Only registered and activated users can see links. Click Here To Register...]
Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.10 of its Black Hole image. If installed to multiboot, the new Black Hole v0.10 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.
How do I install Barry Allen with this image [Only registered and activated users can see links. Click Here To Register...]
Will I loose the images already installed on my media [Only registered and activated users can see links. Click Here To Register...]
How do I install it to flash [Only registered and activated users can see links. Click Here To Register...]
Release Details
NEW Nabilosat HD bootlogo by Army.
Barry Allen 4.8.2 included
TARGET_OS = "linux"
MACHINE = "dm8000"
TARGET_FPU = "soft"
ENIGMA2_CVS_DATE = "29 April 2009"
DVB DRIVERS = "30 April 2009"
SECOND STAGE = "73-r0"
BARRY_ALLEN_VERSION = "4.8.2"
Instructions
4) Wait for Barry Allen to be installed
5) When the install is complete, you must wait for the E2 to restart and new BA version will be available in the plugin MENU. Make sure to wait till E2 is restarted, as it may take some time.
Nabilosat Enigma2 Black Hole - DM8000 v0.10
What is new in this version 0.10 ?Nabilosat Black Hole socket system creates a communication with Enigma 2 for the management of the EMU restart and Nabilosat API'sEMU Management: the Black Hole Socket system allows EMU's to be run externally to Enigma2.This solution offers a better EMU performance. As an example, when you start the EMU, the spinner will not displayArmy Fantasy HD Skinintroducing the first HD skin with large size fonts and panelsNEW EPG Panel introducing new features for the control of EPGDownload Now reset EPG download timer and immediately start a downloadNEW EPG Provide list available in EPG main panelEPG settings global setting for all provider, and single provider settingsEPG Cron for each single providerEPG search buttons enable/disable the epg search buttonsPanic Button quickly zap to a fixed channel and clear zap historyAnalogue Clock: the analogue clock and gauge needles have been rewritten to offer a clear readingIncreased Performance: all Nabilosat panel have been recoded to offer better performanceSystem Pop Ups: using Nabilosat socket system nowExtra Info Bar: new systemManual Install IPK: added Enigma2 consoleCCcam Info now available directly from the Green Panel (1x Green + 1x Red )New:Nabilosat Black Hole System: this system represents a new approach to the communications exchange between the image core, the external environment and Enigma2. Making the image faster and more efficient.The Nabilosat Black Hole Socket allows also the following:
1) Introduction of Nabilosat Black Hole API
2) EMU and Application enhanced management, as they run externally to Enigma2
The following diagram represents the communication flow[Only registered and activated users can see links. Click Here To Register...]What are the benefits ? When you start or restart your default EMU, Enigma2 will be busy at controlling this process, until it is started and initialized. As Enigma2 is busy with this process, the spinner will display. With Nabilosat Black Hole System, when you start/restart your default EMU, Enigma2 will only send a short signal to the Socket, and this Socket will be responsible for starting the EMU. Therefore, Enigma2 is free to keep running, and the spinner will not display. Additionally, the EMU will also be more efficient as it does not depend from Enigma2.New:
Another benefit is represented by the possibility to send command to Enigma2 from the Linux shell, or from a schedule custom script. This system is the new Nabilosat Black Hole API.Nabilosat API: you can now start a Telnet or SSH session and send a command to execute any of the following available API's:
- Restart EMU
- Restart E2
- Reboot DM
- Standby
- Shutdown
To launch each of the available API's, start a Telnet or SSH session, and type the following commands:
Nabilocmd restartemu
Nabilocmd restartenigma2
Nabilocmd standby
Nabilocmd reboot
Nabilocmd shutdown
Each API can also be executed manually via Telnet or SSH. It can also be included in your custom script. It can be executed automatically and regularly with the new Nabilosat Black Hole Cron Manager, at a set time, and every day.
Nabilosat API are also useful if your DM hangs. Instead of choosing to Power OFF, you can now simply restart Enigma2 or reboot using the required API.
New:Nabilosat Black Hole Cron Manager: you can now schedule recurring standard events ( restart e2, reboot, stand by, shutdown, restart emu ) or your custom commands, and execute them automatically. The scheduling of standard events will automatically execute Nabilosat Enigma2 API's. The custom command option gives you the option to run any script of your choice automatically and at your set time
NewNabilosat Black Hole EPG Panel: this new panel allows you to have full control of the EPG for the following providers
Sky IT
Sky UK
Cyfra+
Csat
Canal Digitaal
Digital+
You can now schedule an automatic download for each of these providers. You can also perform an immediate download with the new Download Now feature.
You can now enable/disable the EPG Search button, through the Gloabl Settings panel
NewSkin Army Fantasy HD: introducing the first HD skin with large size fonts and panels
New:New Boot logo and Switch Off logo by Army
NewNabilosat Black Hole Panic Button: this new feature, if enabled, will map your 0 key to zap to the first channel of your first bouquet, and clear the history
NewNabilosat CCcam Switch: this plugin has been recoded for HD skin and added by default to the image
Enigma2 CVS date29 April 2009 2.6 experimentalDrivers date23 April 2009Second Stage #73-pr0
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
1) Blue PanelSetup
OSD Settings
LCD Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
Service Info
Enigma2 Settings
About
Memory
Space
CPU
ProcessSave2) Green PanelSelect/Start/Restart EMUCCcam InfoMany thanks to the Beta Testers Team
Fast Plugin
Credits
Army for the new Fantasy HD skin.
WARNING.Nabilosat Team highly reccomends to install this image to flash. It will be perform at its best, and you will fully enjoy all the features. Else, if you install it to multiboot, you must install the Nabilosat Pure Flash DM 8000 dated 02 May 2009. Nabilosat Pure Flash DM8000 02May2009 is available [Only registered and activated users can see links. Click Here To Register...].
Code:
Attached Thumbnails [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
LS E2 Image dm8000 20090505
ls e2 image dm8000 20090505
versione = experimental 2.6
enigma2 = 05/05/09 (mod by linsat team) <new!>
plugins = 05/05/09 <new!>
drivers = 05/05/09 <new!>
secondstage 73-r0
distro-opendreambox (git) = 1.5
bb_version = 1.6.8
+ per tutti gli aggiornamenti del cvs vedere [Only registered and activated users can see links. Click Here To Register...]
nb:queste immagini contengono i drivers piu' recenti, quindi consigliamo di metterle solo in flash, oppure in pen/cf ma usando unicamente il "multiboot di thowi". in alternativa si puo' usare il "barryallen" ma solo avendo in flash una img con lo stesso secondstage e drivers (o successivo)
caratteristiche principali img ls rispetto a una cvs:
pannello ls extra (comprende emumanager e scriptstarter)
emumanager integrato con gestione separata softcam/cardserver (no emu inside - no emu direct download)
menu scriptexecuter (basta inserirne di nuovi nella cartella /usr/script), script già presenti:
*backup flash image
*delete backup
*delete hdd crashlog
*emu info
*diritti cccam
*diritti newcs
*free memory
*free space
*grab video
*hdd temp
*ipk install
*ipk clear
*module info
*mountpoints info
*process
*remove .py
*spinner on/off
*creating 32mb swap on hdd/usb/cf
*deactivate swap
*uptime
*openvpn on/off
scelta modalità telecomando: Neutrino (default) / enigma
indicazioni avanzate nello skin:
* posizione orbitale del canale
* info dati frequenza attiva (anche dvb-t e dvb-c)
* info avanzate emu
* info avanzate codifica
* info nome emu e cardserv attivi (separato)
* info tempo di risposta card (ms)
* risoluzione video
openepg by musicbob per l'epg di sky italia con funzionalità avanzate (vedere più sotto per le info dettagliate)
italiano come prima lingua di default
skin eagle.megalight (default) , dreamtv-hd e infinity by kerni (mod by ferbius)
bitrateviewer
moduli per smargo reader usb inclusi nel kernel (avvio immediato)
swap abilitato al boot
plugin aggiuntivi inclusi di default:
- direttagol interactive v1.2
- openepg 0.93 + myepg 0.2.4
- tg24 interactive 1.2
- cccaminfo v1.2
- youtubeplayer
- vlc
- movieplayer
- multiremotecontrol (vedere [Only registered and activated users can see links. Click Here To Register...] per le istruzioni d'uso)
- dyndns
- tuxcom 1.16
- moviecut
- movieretitle
- videomode
- videotune
- satellitesequipmentcontrol
- networkwizard
- autoresolution (only dm800 and dm8000)
- commoninterfaceassignment
- startuptostandby
- tageditor
aggiornamenti rispetto alla ls-20090429:
+ nuovo ls panel softcam 1.10
+ openepg 0.93 by musicbob con integrato myepg 0.2.4 by skaman:
news :
- 2 epg in una ! la velocità e la completezza di openepg (vedere [Only registered and activated users can see links. Click Here To Register...]) e l'integrazione in enigma2 grazie a myepg
- epg enigma2 aggiornata senza riavviare enigma2 !
- entrambe le epg sono attivabili o disattivabili da finestra config:
Cioè si possono scaricare i dati solo per myepg oppure solo per openepg, oppure naturalmente per entrambe
- autodownload perfezionato perfettamente funzionante in tutte le modalità
- il plugin effettua il caricamento della cache epg dopo il reboot totale non gestito (es.: Spegnendo il dream o dando "reboot" da telnet)
- le linee comando per myepg sono inseriti nei due files "downloader.sh" e "dbconverter.sh" presenti nella cartella del plugin /usr/lib/enigma2/python/plugins/systemplugins/openepg/
editare questi due files inserendo le linee comando con le opzioni necessarie, che possono cambiare ad ogni update di skaman.
+ visualizzazione epg sulla infobar anche dei canali mediaset (al posto dell'insulso "disponibile sul digitale terrestre"
+ traduzione italiana aggiornata al 05/05/09 by spaeleus
promemoria tasti:
pressione lunga (ls):
tasto menu -> softcam setup
tasto verde -> lista timer
tasto giallo -> lista plugins
tasto blu -> openepg (epg estesa sky)
tasto info -> scelta del tipo di griglia epg (normale / multiepg grafico)
pressione normale (default):
tasto menu -> menu principale
tasto verde -> sottoservizi
tasto giallo -> traccia audio
tasto blu -> extensions
tasto info -> descrizione evento
credits esterni:
ronaldd per i sorgenti del suo "emumanager" e l' "expert-tuner infobar"
lukkino per loadepg opentv e la traduzione del dizionario
skaman per myepg
pli team per l'indicazione della posizione orbitale nello skin, per il menu telecomando e per il "bitrateviewer"
aliabdul per lo "scriptexecuter", per il "cccaminfo" e per il "numero canale nei bouquet"
dreg per il tuxcom e2
reinh@rd per il satellites.xml aggiornato
vali per le info frequenza avanzate
attenzione:
i firmwares in oggetto non contengono chiavi o emulatori di nessun genere
download :
linsat.net non e' responsabile in nessun caso dell'uso che gli utenti faranno di questi programmi.
Milo Image DM8000-- 09.05.09
New in this release:
Lots of updates from the central repository
Added 'groups' command to keep WinSCP happy
FLV files supported by media player (audio only)
CCcam 2.1.1 embedded in image
Features:
EPG Search works for non-UTF8 encodings like Freesat
NETcaster that does not crash
Standard Dutch favourites list instead of German
Rearranged settings menu
Upgraded tuxtxt which enables teletext cache
Plugin download screen gets server list no more than once per hour
Symlinks in /var to satisfy some softcams
Driver updates for DM8000
Experimental switch to enable a "home page" service
MovieList enhancements: Auto-tagging, playback state icons (beta), directory selection
Picons can be downloaded from feed to CF, USB or HDD
Dutch translations
Downloadable skins
Mount manager
DVD player
Mediaplayer
Auto-recovers CCCam.cfg, .ssh dir and dropbear_rsa_key from /hdd/backup
Enigma2 (and other components) from 2009-05-08
CCcam 2.1.1
Freesat EPG
Mediahighway EPG
EPG import patch
NZBGet in feed (commandline, use "ipkg install nzbget")
ctorrent in feed (commandline)
djmount in feed (commandline)
Milo Image DM8000 09.05.09
download :
LS-E2 Images DM8000 13.05.2009
Caratteristiche principali img LS rispetto a una CVS:
Pannello LS Extra (comprende Emumanager e Scriptstarter)
Emumanager integrato con gestione separata softcam/cardserver (NO EMU INSIDE - NO EMU DIRECT DOWNLOAD)
Menu Scriptexecuter (basta inserirne di nuovi nella cartella /usr/script), script già presenti:
*Backup flash image
*Delete Backup
*Delete hdd crashlog
*Emu info
*Diritti CCcam
*Diritti NewCS
*Free memory
*Free space
*Grab video
*Hdd temp
*Ipk install
*Ipk clear
*Module info
*Mountpoints info
*Process
*Remove .py
*Spinner On/Off
*Creating 32MB Swap on hdd/usb/cf
*Deactivate Swap
*Uptime
*OpenVPN On/Off
Scelta modalità telecomando: Neutrino (default) / Enigma
Indicazioni avanzate nello skin:
* info dati frequenza attiva (anche DVB-T e DVB-C)
* info avanzate emu
* risoluzione video
OpenEPG by Musicbob per l'epg di Sky Italia con funzionalità avanzate (vedere più sotto per le info dettagliate)
Italiano come prima lingua di default
Skin default Eagle.Megalight
BitrateViewer
Moduli per Smargo Reader USB inclusi nel kernel (avvio immediato)
Swap abilitato al boot
Plugin aggiuntivi inclusi di default:
DirettaGol Interactive v1.2
OpenEPG 0.93 + MyEpg 0.2.4
TG24 Interactive 1.2
CCcaminfo v1.2
Youtubeplayer
VLC
MoviePlayer
MultiRemoteControl (Vedere QUI per le istruzioni d'uso) (solo dm7025 e dm800)
DynDNS
Tuxcom 1.16
Moviecut
Movieretitle
Videomode
Videotune
SatellitesEquipmentControl
NetworkWizard
CommonInterfaceAssignment
StartupToStandby
TagEditor
Autoresolution (solo dm800 e dm8000)
+ OpenEPG 0.93 by Musicbob con integrato MyEpg 0.2.4 by Skaman:
NEWS :
- 2 EPG IN UNA ! la velocità e la completezza di OpenEPG (vedere QUI) e l'integrazione in enigma2 grazie a MyEpg
cioè si possono scaricare i dati solo per MyEPG oppure solo per OpenEPG, oppure naturalmente per entrambe
- il plugin effettua il caricamento della cache epg dopo il reboot totale non gestito (es.: spegnendo il dream o dando "reboot" da telnet)
- le linee comando per MyEPG sono inseriti nei due files "downloader.sh" e "dbconverter.sh" presenti nella cartella del plugin /usr/lib/enigma2/python/Plugins/SystemPlugins/OpenEPG/
Editare questi due files inserendo le linee comando con le opzioni necessarie, che possono cambiare ad ogni update di Skaman.
NEW!
+ Visualizzazione epg anche dei canali Mediaset (al posto dell'insulso "Visibile in analogico e digitale terrestre") SU TUTTE LE FINESTRE, compresa WebIf, e skin OSD
Addio alla noiosa frase che da mesi impediva di leggere la programmazione degli eventi correnti per i canali Mediaset
download :
Milo Image May 16, 2009
Again, lots of updates from the central repository
Changed LCD screen (will do some serious work next week on this)
Features:
Dutch translations
Downloadable skins
Mount manager
DVD player
Mediaplayer
Enigma2 (and other components) from 2009-05-15
CCcam 2.1.1
Freesat EPG
Mediahighway EPG
EPG import patch
* Magic skin: Infobar
Features:
* LCD screen: Blinking R when recording, changed layout
* EPG Search works for non-UTF8 encodings like Freesat
* NETcaster that does not crash
* Standard Dutch favourites list instead of German
* Rearranged settings menu
* Upgraded tuxtxt which enables teletext cache
* Plugin download screen gets server list no more than once per hour
* Symlinks in /var to satisfy some softcams
* Driver updates for DM8000
* Experimental switch to enable a "home page" service
* MovieList enhancements: Auto-tagging, playback state icons (beta), directory selection
* Picons can be downloaded from feed to CF, USB or HDD
* Dutch translations
* Downloadable skins
* Mount manager
* DVD player
* Mediaplayer
* Auto-recovers CCCam.cfg, .ssh dir and dropbear_rsa_key from /hdd/backup
* Enigma2 (and other components) from 2009-06-18
* CCcam 2.1.1
* Freesat EPG
* Mediahighway EPG
* EPG import patch
* NZBGet in feed (commandline, use "ipkg install nzbget")
* ctorrent in feed (commandline)
* djmount in feed (commandline)
Nabilosat Enigma2 Black Hole - DM8000 v0.11
What is new in this version 0.11 ?
Army Ghost HD Skin awesome HD skin with large size fonts and panelsNabilosat Black Hole Device Manager gives you full control over all your connected media: USB, CF, SD, HDD, DVDNabilosat Black Hole Kernel Modules Manager allows you to setup all the modules required by additional features and devicesNabilosat Black Hole AutoCam allows you to assign a different CAM/EMU to each channelNTFS support allows you to mount a device formatted to Windows NTFSSmargo Phoenix & others Usb Card Readers enable your Smargo or other USB Card Readers, based on chipsets Ftdi and Pl2303Virtual Keyboard is a new CVS feature enabling you to type in data through an on screen keyboardViasat EPG is now available for downloadSubtitles White Large Fonts TXT subtitles with HD skins. Large DVB subtitles HD full size (CVS last fix)New:Nabilosat Black Hole Device Manager: this system will scan your DM for connected media, such as USB keys, CF, SD, HDD, DVD, and automatically identify them. Once identified, each media can be formatted, mounted and unmounted. Thus, you are no longer required to run a script or a command line to install any external memory device. Nabilosat Black Hole will handle this for you.Press 2x Blue, and select Black Hole Device Manager[Only registered and activated users can see links. Click Here To Register...]
New:Nabilosat Black Hole Kernel Modules Manager: this new feature allows you to control the kernel modules, to support the NTFS file system, and enable the Smargo as well as other USB Card Readers, Ftdi and Pl2303 chipset based. If there are features you are not using, such as OpenVPN or NFS server, then you can disable their modules. Disabling unused modules will optimize your memory usage. The Kernel Module panel provide too an useful function to show all the kernel modules current running on your dreambox and relative size and informations. Press 2x Blue for the Kernel Modules Manager[Only registered and activated users can see links. Click Here To Register...]
New:Nabilosat Black Hole AutoCam: this new feature allows you to use a different CAM/EMU for each channel. When you zap, Nabilosat Black Hole API system will handle the different EMU, and start the selected one. To assign an EMU to a channel, zap to the channel, press 1x Blue, and 1x Green[Only registered and activated users can see links. Click Here To Register...]
