EDG-NEMSSIS_4.4._Skin Rihana_Special
EDG-NEMSSIS_4.4._Skin Rihana_Special_SPCS_2.5.16_Maxvar_27.02.2010
new modification ;
-exlusive new bootlogo arabic-sat
-Emu: CCcam2.1.4 inside (start with image..in blue panel withe volume button for the built-Emu )
-send CCcam.cfg in /var/ect with ftp
-Skin Rihana_Special
-Arabic&French &English language
-new logo for (scan-radio-mp3)
-big var 81% Free espace with CCcam emu and more
-add = CCcaminfo&and Ecminfo&Mgcamdinfo&Key updater v0.4&Ngrab recording&Tuxbox Commander&Teletext=inside image (Yellow Button)
-add softcam (entv,foxlife....)
-add extra (addons:emu)
-Fast image to open channels with CCcam
-send this image with dreamup or falshwizard
Nabilosat darkstar2 with cccam 2.2.1 skin Rihana Net
New bootlogo Hd
Cccam 2.2.1 integrate with cccaminfo and ecm info hacksatkeys nagrab signal Quality .teletext
Free Espace En Var 74%
Evolution 2.6 Dreambox 500S edition
Evolution 2.6 Dreambox edition
Dreambox 500
Technical Infos:
CVS Version: 04.01.2011
Linux kernel version: 2.6.9
GCC 3.4.4 Original CVS
Web Inteface 6.0.4-Expert
Busybox 1.01
BLUE - Blue Panel (Emu Addons)
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Download Addons - Emus,keys,Plugins,Setting....
Manual Install Addons tar.bz2
Delete Addons
-------- New in Evolution 2.6 --------------
Update CVS
Update libc.so.6 (important)
Fix Oscam new version not working (symbol getaddrinfo)
Fix total tv epg
Fix not working plugins on dm500
Fix VLCF on dm500
Fixes......
New Bootlogo
Support and bug report: [Only registered and activated users can see links. Click Here To Register...]
EDG Nemesis v4.4 CCcam2.21 Max23a Wep-x-tv_By meteor
** Orginal skin yerine max 23a skin kullanilmistir...
Special Thanks maxsimuss
** Turkce ve Ingilizce diller mevcuttur...
( Diger diller addons dan indirilebilir )
** Yeni 2 Adet bootlogo kullanilmistir.
** CCcam 2.2.1 entegredir.
** CCcaminfo 1.1 entegredir.
** Ecminfo entegredir.
** Extra Addons entegredir.
** Teletex mevcuttur.
** Web-x-tv ayarlari yapilmistir.
** 4 uydulu satellite xml kullanilmistir (Turksat-Hotbird-Eutelsat W3A-Astra 19.2)
** Kanal listesindeyken help tusu ile kanal listesi yan yana yapilabilir.
** Doluluk orani %18 dir...
** Dream Up ve Flashwizard ile yuklenebilir.
--- Image test edilerek foruma verilmistir.
--- Yinede sorumluluk yukleyene aittir.
** Kurulumdan once mutlaka yedeginizi alınız...
** Kurulumdan sonra Cccam.cfg yedeginizi var/etc icine atmaniz,
LNB ayarlarinizi yapmaniz ve kanal listenizi yuklemeniz yeterlidir
Traducere din Turcă in Romană
** Disponibil in limbile engleză şi turcă ...
(Alte limbi pot fi descărcate de la addons)
** noi 2 bootlogo Piece utilizate.
** integrat cu CCcam 2.2.1.
** CCcaminfo 1.1 integrat.
** Ecminfo integrate.
** Extra addons integrate.
Teletext ** este disponibil.
** setările Web-x-tv a fost făcut.
** 4 satelit satelit utilizate in xml (Turksat-Hotbird-Astra-Eutelsat W3A 19.2)
** lista de canale, buton de ajutor se poate face cot la cot cu lista de canale.
** Rata de ocupare este de 18% ...
** Dream Up şi incărcate cu Flashwizard.
--- Image a fost testat şi dat la forum.
--- Cu toate acestea, responsabilitatea aparţine descărcat.
** Inainte de a instala o copie de siguranţă ar trebui să caute ...
** După instalare, CCcam.cfg există backup / etc ieşi din
Face ajustările dumneavoastră trebuie să instalaţi LNB şi lista de canale
SifTeam-1.9.4C-500MV__2011-Mar-01
SifTeam-1.9.4C-500MV.img.zip__2011-Mar-01
Code:
IPBOX200S:
Usable to flash
* Enigma of: 28.02.2011 (patched for native version)
* Linux version 2.6.17 (patched from sandali)
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* U-BOOT 1.2.0 (patched from sandali)
* New driver from sandali
* MMC Drivers included with script for load
* Have to SET mID 20
IPBOX200S 64mb:
* For ipbox-200@64mb you have:
1) Install normal image (32mb)
2) Install "serial_uboot_64.img"
* Thanks to Sandali for serial_uboot_64.img
IPBOX250S:
Usable to HDD (CF) or flash
* Busybox 1.01
* Tuxtxt v. 1.99
* Have to SET mID 25
IPBOX350S:
Usable to HDD, USB or flash
* Busybox 1.01
* Tuxtxt v. 1.99
* Have to SET mID 26
IPBOX400S:
Usable to HDD or flash
* Busybox 1.01
* Tuxtxt v. 1.99
* Have to SET mID 40
DB500:
Usable to flash
* Linux version 2.6.9
* GCC 3.4.4 Original CVS
* Busybox 1.01
* Tuxtxt v. 1.99
DB5620:
Usable to flash
* Busybox 1.01
* Tuxtxt v. 1.99
DB7000:
Usable to HDD, USB, CF or flash
* GCC 3.4.4 Original CVS 1.1.0
* Busybox 1.01
* Tuxtxt v. 1.99
DB7020:
* Usable to HDD, USB, CF or flash
* OE Build Configuration:
BB_VERSION = "1.6.2"
OE_REVISION = "format_version "1"
new_manifest [0000000000000000000000000000000000000004]
old_revision [8384ee468ef9c285a8c9b35ef333e53be78b6445]"
TARGET_ARCH = "powerpc"
TARGET_OS = "linux"
MACHINE = "dm7020"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.4.0"
TARGET_FPU = "soft"
DB600PVR:
* Usable to HDD or flash
TARGET_OS = "linux"
MACHINE = "dm600pvr"
TARGET_FPU = "soft"
DB500PLUS:
* Usable to flash
TARGET_OS = "linux"
MACHINE = "dm500plus"
TARGET_FPU = "soft"
Qbox-one:
Usable to flash
* Busybox 1.01
ALL DECODER ( same options not present to Qbox-one - IPBOX200s - DM500 - DM500+ - DM5620 ):
Buttons:
* 1 x BLUE = Emu Panel
* 1 x Yellow = Plugins
* 1 x Green = Addons Panel
* 1 x Red = EPG ( settable from Control Pannel )
* BLUE > 1 sec = Control Panel ( new version "visual" )
* Yellow > 1 sec. = Personal Plugin ( settable from Control Pannel )
* Green > 1 sec. = Personal Plugin ( settable from Control Pannel )
Features:
* Advanced MINICROND system configuration, with more script added (restart cam, restart openvpn ecc..)
* Advanced FIREWALL with graphics start/stop/configuration
* Advanced HDD with graphics configuration
* Advanced SWAP with graphics start/stop/configuration
* Advanced OPENVPN with graphics start/stop/configuration (have to install online package)
* Advanced DROPBEARSSH with graphics start/stop/configuration (have to install online package)
* Advanced INADYN-DNS with graphics start/stop/configuration
* Advanced NFS with graphics start/stop/configuration (have to install online package)
* Settable PICON directory
* Automount HDD USB CF
* Advanced SCRIPT options for personal set ( name to button is modifiable from Control Panel)
* Formatting USB ( into 500 and 200 not have USB option, have manage remote control and free memory)
* Advanced EPG options (is possible set personal EPG from Control Panel or use standard EPG)
* Advanced Manage of Button Yellow and Green, is possible add one plugin to this buttons
* Simple BACKUP with graphics start/stop/configuration (for save one dir. to extern support)
* Advanced SAMBA with graphics start/stop/configuration (7020 - 600pvr - 500plus have samba installed from
default)
* Color set to RGB from default ( for lcd TV)
* Inserted DM7020 Network Fix
* Reiserfs and VFAT supported
* Synchronize date from Internet
* WebIf information (ecm.info with reload option)
* New Button for second url (for download personel addons)
* Autostandby if decoder turn off in bad mode (crash power ecc..)
* Lock EMU panel from Parental Control option
* Save downloaded packages (settable from expert menu)
* See info package before install from online (settable from expert menu)
* See last package present online from "news" button
* Compatible with Upnp (Server/Client)
Display Function:
* Set zap without OSD (if press OK return OSD)
* Set OSD always on when OK is pressed (required from nokia9k8)
* Display Snr, Agc, Ber
* Display video information
* Display frequency, polarization, symbol rate
* Display emu in use
* Display service providers name
* Display CaID, ProvID, PID (you can hide from options)
* Display Decoding Source (you can hide from options)
* Picon, already inserted to enigma code (thanks to jlmota)
* SkinPreview (thanks to jlmota)
* Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full (thanks to tension for help)
* Emu Panel now have image with icon report of decode
* Fulltime
* Analogic Clock
* Move OSD (thanks to tension9000)
* Always 16:9 settable in all decoder
* Time visible in screen
* Name channel visible in screen
EMU:
* Set Default CAM
* Set channel CAM
* Set provider CAM
* Stop active CAM
Addons:
* Internet addons download
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Picon for -skyit+italian channel- is already installed
* Several Plugins/Games/Addons installed
* IPBOX200S have UHF in/out
* IPBOX200S ...for free memory (if is necessary):
1) Go to free channel
2) Click to "Free Memory"
...now is possible to start/stop install/remove visualize script ecc..
* For use your personal Addons server, create file:
/var/etc/SifTeam/tmp/url2 (that it contains your link)
after, into server have write your cpanel-dream.xml (for dream decoder)
or cpanel-ipbox.xml (for ipbox decoder), that contains your packages
(for simple system, download cpanel*.xml from sifteam URL)
THANKS TO:
See Yellow from Control Panel for other help into this work.
All IPBOX > ..special thanks to sandali for its branch of development.
FOR ALL > See About in Control Panel (blue > 1 sec.)
Thanks to all and good fun :)
VARIOUS:
This image is based, beyond that my "much" code and hard work, to Dream-cvs, parts of old Hydra
source (EMU/ADDONS ...emubroker is this) ...and other?
DOWNLOAD ==>> [Only registered and activated users can see links. Click Here To Register...]
Gemini 470 DM500 Carbon Trans
Bu imaj serjoga arkadasimiz icin editlenmistir...
** Herhangi bir emulator kurulu degildir...!!!
** No Time Bomb
** Turkce ve Ingilizce ve Rusca diller mevcuttur...
** Guncel cok uydulu satellite xml kullanilmistir.
** Kanallar help tusu ile yan yana yapilabilir.
** Doluluk orani %16 dir..
Addons dan herhangibir emulator kurmaniz,
LNB ayarlarinizi yapmaniz ve kanal listenizi yuklemeniz yeterlidir.
Kurulumdan once mutlaka yedeginizi aliniz...!!!
Download:
SifTeam-1.9.4C-500MV - 05-07-2011
The images contain ONLY the update of CVS.
[Only registered and activated users can see links. Click Here To Register...] SifTeam-1.9.4C-500MV - 05-07-2011
