PwrContol pentru IpBox 9000HD
IPBOX 9000HD
The script and your menu to change the automatic settings acco***ng to ity from the time of day in:
MENU -> System Settings -> STB Power Control
or press on unit switch circuit on the remote control at night
tuner to receive mode poweroff while during the day to stand-by mode
hours determined in the script,
CHECK_INT - at how many seconds a script is to verify the time
NIGHT_START - time-off mode night
NIGHT_STOP - time mode end of the night
ACTIVE - value 1 -> script active, other values -> script is not activated after take-off tuner
IPBOX9000HD_pwrcontrol_v2a
NEW / FIX:v0.0.2a improved detection of the state tuner automatic transition from standby mode to poweroff tuner if you receive czyliœmy to standby hours before your "NIGHT_START" w / w option, you can lock the unit AUTOPWROFF set to "0" the problem was corrected an hour ¹ ¹ readable by the script
Bitrate plugin for ipbox9000/cuberevo
bitrate plugin for ipbox9000/cuberevo
This is a bitrate plugin for the cuberevo/ipbox9000, which displays
the current video and audiobitrate from the TV station.
USAGE:
The plugin updates the values every 2 seconds, you can switch from a
larger view, which displays current, average, min, max values and
audiodata, to a smaller view with only current and average values with
the "OK" button.
Keep im mind, that the plugin will switch to the other mode on the next
value udpate, so it might take up to 2 seconds, before the mode is switched.
To quit the plugin press exit.
INSTALL:
copy the bitrate.plugin file to the /var/plug-in directory
Release-notes:
0.0.1:
- initial release
Have fun...
kneubi 12.11.08
1 Attachment(s)
Plug-in: New Favourites channellist panel
This plug-in provides an alternative to the favourites channellist in the firmware.
Its main advanteges
- Sorts your favourites groups as defined in PCEditor
- Allows to switch channels in PiP or live mode (and filters channels which cannot be opened in PiP mode).
So it can also be used as alternative to the Sub channel list.
Key Mapping
Up/Down -> figure it out yourselves [Only registered and activated users can see links. Click Here To Register...]
Left/Right -> jump 5 entries in list
Red/Green -> change Favourites group
Blue -> switch live/Pip mode
Licence
GPL
RELEASE 0.5
- initial release
Enjoy it,
pacco
PS: rev 26 of plugin sdk is needed to compile the source
2 Attachment(s)
New Favourites channellist panel 0.5.2
RELEASE 0.5.2 (Mod by COoLoSER)
- added information about current and total fav groups, it is shown in left upper corner, before group name
- yellow button shows/hides order numer of channel
- added information about current channel order number, it is shown in right bottom corner. Numbering is exactly like in DGS soft.
- PgUp/PgDown works like Left/Right button
- added ability to jump to channel by giving its order number.
How to use.
1. Put channel order number, with digit buttons.
What is input will be shown on the bottom/right with '*' asterisk character as a marker
2. Press 'OK' button to switch to channel or 'Exit' to cancel.
- checking of current channel, to not switch when there is no need for it.
Favourites channellist panel 0.7
RELEASE 0.7
- all mods from coOLOser included!!
- added basic skin support
- increased timeout when leaving with ok button
- reordered icons in legend, increased font size
Favpip plugin release 1.0.0
RELELASE 1.0.0===========- fixed bug which caused start/stop recording hanged up osd for a while- new configuration option 'show_format_icon' which is used to show or hide channel format icon. Icons are 'mp2' or 'mp4'- separation of RADIO and TV channels. What is shown depends on current TV/RADIO mode- new configuration option 'hide_empty_groups' which is used to show or hide empty groups- parental control -> hide channels settings is respected by plugin. If it is enabled then hidden channels are hide all the time and cannot be show. If it is disabled then FILE key controls showing and hiding of that channels
Re: Ipbox 9000&900 **PLUG IN**
Bitrate plugin 0.0.3
