SifTeam 0.1.9 r8728 9000HD
1. Support *.mkv with video player.
- If the file needs higher class CODEC, the file will not be playback with video player .
- In case of too higher [Only registered and activated users can see links. Click Here To Register...] file, it possible to make a problem for playback (especially *.vob and *.mkv.).
2. Fixed crashing problem with higher [Only registered and activated users can see links. Click Here To Register...] as 30,000(S/R) TP.
3. Fixed some bug for schedule recording.
4. Fixed record subtitle.
known issue : [Only registered and activated users can see links. Click Here To Register...] subtitle color problem.
SifTeam 0.1.9 r8833 9000HD
fixed are
- Recording bug fixed
- DVB subtitels ok now
and added
- new scan options
- rewind function in Video Player
blind scan replaced by
default scan
advanced scan
reset scan
fast forward/back only works ok on divx, on vob files it crashes box.
- They have added age range symbol in livebanner too (small change)
- photo menu got background now.
Sifteam 0.1.9 r8873 9000HD
SifTeam 0.1.9 r8873 released ipbox9000-910-900-250HD-200HD SifTeam 0.1.9 r8873 released
1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
press once FF or REW button, the interval is 10 seconds.
press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
2. Add Scan option on Channel Scan Menu
When there is no channel list, all these options create with the same result.
- Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
- Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
- Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
3. Add USB upgrade menu
- Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
it is useful for software upgrade with USB morory stick.
4. Fixed EPG contents Display
- inserted new line on the screen for EPG and extended EPG information as well
5. Fixed DVB subtitle - color table
6. Fixed OSD teletext - some old data not updated occassionally
7. Fixed wrong duration with the file after schedule recording with EPG
8. Fixed Local time auto update
- When the last channel time of the Satellite is different from the STB time within 10 minutes,
the STB time is automatically adjusted with the Satellite time during the STB booting.
9. Updated Polish language table.
10. Updated Web-interface
11. Fixed small bugs
known issues : sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
no audio with such as Digifilm channel
adjust color table of DVB subtitle for some channels
SifTeam 0.2.0 r8873 9000HD
Version 0.2.0
Added default password as "sifteam"
Added script "advanced.command.sh" ..for:
Add NFS disk
Remove NFS disk
Make USB for use as Disk (in congiuntion with NFS option is very good)
Move /var in part1 of disk or USB (part1 = first partition)
Removed any files (script)
Added script for see proper card permission
SifTeam 0.2.0 r9047 9000HD
SiFTeam image 9047
