Keychron Launches K3 Max SE QMK Low Profile Mechanical Keyboard To Mat
Keychron [Only registered and activated users can see links. Click Here To Register...] wireless, low-profile mechanical and TMR keyboards on Kickstarter, both featuring the same plastic, metal, and wood construction and slated for a full launch around June. However, if you're looking to get in on the low-profile action and don't mind losing some of the specialty features of the K3 HE and Ultra, Keychron has just announced the K3 Max SE, a new QMK-powered keyboard that features a nearly identical design to the K3 Ultra. Unlike the K3 Ultra and HE, the K3 Max SE is available as of the time of writing for a relatively affordable [Only registered and activated users can see links. Click Here To Register...], which is $5 cheaper than the pre-order price of the [Only registered and activated users can see links. Click Here To Register...] and $15 cheaper than the HE.
Obviously, the K3 Max SE doesn't have the same analog input features as the K3 HE, but it is nearly identical to the K3 Ultra but for one small distinction—the battery life and firmware. The K3 Max SE is a traditional QMK keyboard, like Keychron's traditional Max keyboards have long been, while the K3 Ultra is part of Keychron's move to ZMK firmware, which is known to be significantly more efficient than QMK. The end result is that, while the K3 Ultra and K3 Max SE have the same battery capacity of 1,550 mAh, the K3 Ultra is rated for 550 hours on a charge, and the K3 Max SE is only rated for 120 hours. The other measurable difference between the two is that the K3 Ultra has 8 kHz polling, where the K3 Max SE tops out at 1 kHz—not that this is particularly important on a mechanical keyboard, anyway.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
