Sudokoo Unveils the MACH 120 Line of 30 mm-thick Case Fans
Sudokoo today unveiled the MACH 120, a powerful 120 mm case fan that comes in a thicker 30 mm form-factor, compared to the 25 mm that's standard. The added thickness creates room for a thicker 9-blade impeller with larger sweep area. The impeller is made of liquid-crystal polymer (LCP) with fiber-glass. The motor features 3-pase winding over 10 poles with a high quality hydraulic bearing sourced from Porite Corporation of Japan. The encased bearing and winding technology of the motor allow the fan to have a transparent hubcap.
The Sudokoo MACH 120 measures 120 mm x 120 mm x 30 mm, weighing 230 g. It takes in 4-pin PWM input, and turns between 500 and 3,000 RPM, pushing up to 108 CFM of airflow at its top speed, with an air pressure of 7.31 mm H₂O, and a noise output of 39.9 dBA. At its top speed, the fan draws 6 W of power. Sudokoo is backing the MACH 120 with 6-year warranty. The fan will be sold in single units and packs of 3, given that 360 mm radiators could be their most suitable application. The company didn't reveal pricing.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) NVIDIA GeForce NOW Gets Warhammer 40,000: Dawn of War - Definitiv
Warhammer 40,000: Dawn of War - Definitive Edition is marching onto GeForce NOW, expanding the cloud gaming platform's library to over 2,300 supported titles. Battle is just a click away, as the iconic real-time strategy game joins seven new releases this week. Commanders can prepare their squads and steel their nerves on any device - including laptops, Macs, Steam Decks and NVIDIA SHIELD TVs. Microsoft's surprise announcement at Quakecon is now available in the cloud: legendary fantasy shooters Heretic + Hexen have been conjured out of the shadows and are streaming on GeForce NOW. And don't miss out on in-game rewards for the popular, free-to-play, massively multiplayer online game World of Tanks as publisher Wargaming celebrates the title's 15-year anniversary. GeForce NOW will be at Gamescom 2025 - the world's largest gaming tradeshow - starting Wednesday, Aug. 20. Stay tuned to GFN Thursday for all the latest updates.
The Emperor's Call
The grimdark future calls. Warhammer 40,000: Dawn of War - Definitive Edition storms onto the battlefield with ferocious, squad-based real-time strategy. Command the Space Marines, Orks, Chaos, Eldar and more across four legendary campaigns and nine playable armies. From bolter roars to Waaagh! cries, battles erupt with uncompromising brutality, tactical depth and a healthy dose of swagger.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Corsair Launches NAUTILUS RS LCD AIO CPU Cooler
Corsair is delighted to announce the launch of the NAUTILUS RS LCD, the latest addition to its NAUTILUS RS family of all-in-one (AIO) CPU coolers. Building on the proven performance of the original NAUTILUS RS, the NAUTILUS RS LCD adds a vibrant 2.1" IPS LCD screen to the pump cap, a native resolution of 480x480 pixels, a bright 600cd/m² backlight, and support for over 16.7 million colors. Expanding on the popular NAUTILUS RS family of coolers, the NAUTILUS RS LCD offers premium customization features to a wider audience.
More Than Just a Pretty Face
The NAUTILUS RS LCD also delivers real-time system monitoring and customization and can display system stats such as CPU temperatures and fan speeds, or custom images and animations, all easily configured through Corsair iCUE software. Whether you're monitoring performance or adding a personal touch to your build, the NAUTILUS RS LCD delivers both function and flair. At its core, the cooler retains the same high-performance cooling capabilities of the popular NAUTILUS RS. A low-noise pump and slightly convex copper cold plate, pre-applied with our XTM60 thermal interface material, ensures efficient thermal transfer and quiet operation. Available in black and white as well and in 240 mm and 360 mm radiator sizes, the NAUTILUS RS LCD CPU Coolers come equipped with Corsair RS120 fans to keep your CPU cool and prevent the dreaded thermal throttling.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
ASUS Intros GeForce RTX 5060 White Edition Graphics Cards
ASUS has quietly introduced its new Dual GeForce RTX 5060 White Edition graphics card range. This lineup includes four different models, with RTX 5060 and RTX 5060 Ti versions designed for small gaming setups, as each card measures approximately 228-229 mm in length with a 2.5-slot design and requires just one 8-pin power connector. Each card in the lineup uses 8 GB or 16 GB of GDDR7 memory, which operates at 28 Gbps through a 128-bit interface. The RTX 5060 Ti cards feature 4,608 CUDA cores and can handle AI tasks at 758 TOPs. These cards run at 2,572 MHz in normal mode and 2,602 MHz in OC mode. The RTX 5060 non-Ti cards come with 3,840 CUDA cores and manage AI tasks at 613-623 TOPs. They operate at boost clocks between 2,497 MHz and 2,535 MHz depending on the specific model variant.
All models support PCI Express 5.0 connectivity and offer three DisplayPort 2.1b outputs and one HDMI 2.1b port, HDCP 2.3 compatibility and up to 7680 x 4320 maximum resolution. For cooling the graphics cards feature dual Axial-Tech fans with longer blades to improve airflow and dual-ball bearings. A vented metallic backplate aids heat dissipation while maintaining the compact 2.5-slot form factor. Additional features include dual BIOS options and support for OpenGL 4.6. Exact availability and pricing have yet to be announced.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) XMG Intros CORE 15 and CORE 16 Laptops with Ryzen AI CPUs and GeF
XMG presents two lightweight and compact aluminium laptops: the 15.3-inch XMG CORE 15 and the slightly larger CORE 16. Both feature a choice of AMD Ryzen AI 9 HX 370, Ryzen AI 9 365 or Ryzen AI 7 350 processors, each of which can be paired with an NVIDIA GeForce RTX 5070 or 5060. Highlights include fast 300 Hz 1600p displays with high color gamut coverage, support for up to 128 GB of plug-in RAM, up to 16 TB of SSD storage and a 99.8 Wh battery.
XMG CORE 15 and CORE 16 with AMD Ryzen AI CPUs and RTX 5070 or 5060
The XMG CORE 15 (M25) and XMG CORE 16 (M25) represent XMG's new premium compact class, pairing AMD CPUs from different performance tiers with NVIDIA GPUs. Alongside the 12-core Ryzen AI 9 HX 370, customers can choose the 10-core Ryzen AI 9 365 or the 8-core Ryzen AI 7 350. Each processor can be combined with a GeForce RTX 5070 or RTX 5060, both configured for up to 115 watts graphics power including 15 watts Dynamic Boost.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Gaming Demand to Drive 86% YoY Growth in OLED Monitor Shipments i
TrendForce's latest investigations show that robust gaming demand, coupled with aggressive promotion from brands and panel makers, will boost OLED monitor shipments across all regions in 2025. However, Europe's market share is expected to climb to match North America's while China's share is projected to exceed 20% due to impacts from tariffs.
TrendForce forecasts that OLED monitor shipments will reach 2.66 million units in 2025, representing an 86% YoY increase, with a penetration rate of around 2% in the overall monitor market. Growth momentum is expected to persist over the next few years, with penetration potentially reaching 5% by 2028.[Only registered and activated users can see links. Click Here To Register...]
(PR) D-Link Unveils DXS-3130 Series Layer 3 Switches
D-Link, a global leader in networking and connectivity solutions, proudly introduces the DXS-3130 Series 10G Layer 3 Stackable Aggregation Managed Switches, a next-generation switch family engineered for high-performance enterprise, campus, and high-rise community building deployments. With powerful Layer 3 capabilities, robust hardware design, and intelligent software features, the DXS-3130 Series empowers businesses to build scalable, resilient, and secure network infrastructures.
The DXS-3130 Series includes two models, DXS-3130-28 and DXS-3130-28P, designed for organizations requiring high-throughput aggregation and core switching. Both models offer twenty-four 10G ports and four 10G/25G SFP28 ports. The DXS-3130-28P additionally supports PoE. It supports the IEEE 802.3af/at/bt PoE++ standards, providing up to 60 W of power per port. PoE support shortens deployment time and reduces the cost of electrical installation by powering devices such as IP cameras, VoIP phones, and access points directly over Ethernet. With a switching capacity of up to 680 Gbps and a forwarding rate of 506 Mpps, these switches provide ultra-fast data transfer and low latency, ideal for bandwidth-intensive environments like data centers, large enterprises, and service provider networks.[Only registered and activated users can see links. Click Here To Register...]
(PR) Thermaltake Debuts at Gamescom 2025 with Full-Scale Gaming Showca
Thermaltake, a leading PC DIY brand for premium hardware solutions, is proud to announce its first-ever appearance at Gamescom 2025, Europe's premier gaming event. From August 20-24 in Cologne, Germany, Thermaltake will present a bold and immersive presence under the theme "Beyond Immersion." Visitors who join Thermaltake's interactive booth activities will have the opportunity to win the grand prize - a G6 Direct Drive Racing Wheel with Pedals Bundle, alongside other exclusive rewards. Whether for competitive gaming or custom PC building, Gamescom attendees will be able to explore the next level of gaming, from performance-driven hardware to fully interactive experiences.
Located at Hall 10.1, Booth D060, Thermaltake's expansive booth will deliver a complete showcase of its hardware ecosystem, including high-performance simulation gear, esports-ready PC systems, new chassis designs, power solutions, and cooling technologies. This full-scale exhibition is designed to engage individual gamers with hands-on activities, exciting challenges, and personal product tours.[Only registered and activated users can see links. Click Here To Register...]
(PR) GAMEMAX Introduces GLACIER Series Liquid Coolers with Customizabl
GAMEMAX, an emerging leader in PC gaming hardware including power supply units and cases, is redefining the liquid cooling experience with the launch of its GLACIER Series all-in-one (AIO) coolers, available in 360 mm and 240 mm configurations. Designed to deliver exceptional cooling performance with premium aesthetics, the GAMEMAX GLACIER series combines a truly hidden tube design, a sharp 3.95-inch LCD, and integrated high-performance fans making it the ideal solution for PC builders who demand both function and style. It also features ARGB fans that support popular motherboard RGB sync technologies for synchronization.
Built for power and precision, the GAMEMAX Glacier 360 LCD supports 330 W TDP and the GAMEMAX Glacier 240 LCD 280 W TDP, delivering top-tier cooling for demanding CPUs. Both feature powerful PWM pumps and braided tubes for durability. Integrated fans push 85.82 CFM at 2.23mmH₂O while staying quiet at 31.5dB (A). The 3.95" 720x720 LCD runs at 60 Hz, 300 nits, and supports the latest Intel and AMD sockets.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Normal Computing Tapes Out World's First Thermodynamic Processor
Normal Computing today announced the tape-out of CN101, a thermodynamic computing ASIC that the company calls the first of its kind. The chip targets AI and HPC in modern data centers and reflects Normal's Carnot architecture, which uses physical dynamics such as thermal fluctuations, controlled dissipation, and stochastic transitions to compute. Normal claims CN101 can deliver up to 1,000x better energy efficiency on specific matrix and sampling workloads than conventional accelerators. The tape-out moves the project into silicon characterization and benchmarking, where engineers will measure sampling convergence, metastability lifetimes, and mixing times to validate the claims. Normal plans include CN201 for 2026 and CN301 for 2028, to scale higher-resolution diffusion and video models. Executives envision heterogeneous racks combining CPUs, GPUs, and physics-based ASICs so each problem runs on the most suitable substrate.
Thermodynamic computing replaces standard Boolean logic with many interconnected analog elements that start in semi-random states and settle into an equilibrium that encodes a solution. CN101 links these elements and runs a lattice random walk sampler to steer the system toward useful distributions. Instead of fighting noise, the chip uses randomness to perform tasks like Bayesian inference, probabilistic simulation, and diffusion sampling. Engineers will measure how quickly the device reaches equilibrium, how long useful metastable states last, and how accurately it samples the target distribution, as these factors determine the speed and energy cost. Early tests will also check stability across different temperatures and manufacturing variations. If the results hold up, thermodynamic ASICs could give data centers a more energy-efficient way to scale AI as conventional silicon approaches its known limits.[Only registered and activated users can see links. Click Here To Register...]
Biwin Launches Mini SSD: NVMe Speeds in a SIM-Tray Style Card
Biwin's new Mini SSD squeezes NVMe-class performance into a SIM-tray style card barely larger than a MicroSD, offering quoted sequential read speeds of up to 3,700 MB/s and write speeds of up to 3,400 MB/s over PCIe 4.0 x2 in 512 GB, 1 TB, and 2 TB options. The 15 × 17 × 1.4 mm module ejects with a pin, similar to a smartphone SIM, allowing for easy swapping without tools. Biwin markets this module as IP68 dust and water-resistant, with three-meter drop protection for rugged mobile use. The format promises a sweet spot between MicroSD convenience and M.2 speed, and early support from handhelds such as GPD's Win 5 and the OneXPlayer Super X means we could soon see whether controllers, firmware, and thermal limits let the tiny drives live up to their claims. Additionally, if the format lives up to the promise, we could see adoption from more handheld device makers.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
SK hynix Surpasses Samsung as Leading DRAM Manufacturer
SK hynix has taken the lead from Samsung Electronics as the top DRAM maker worldwide signaling the first change in leadership in over three decades. The main reason for this market shift is high bandwidth memory (HBM) where SK hynix has an exclusive deal to supply NVIDIA while Samsung hasn't yet secured this partnership (it does however supply [Only registered and activated users can see links. Click Here To Register...] to AMD and Broadcom). Samsung's slice of the global DRAM market dropped significantly from 41.5% at the end of 2024 to 32.7% in the first half of 2025. This 8.8% drop is Samsung's biggest [Only registered and activated users can see links. Click Here To Register...] since they started keeping track in 1999. The company's market position has gone back to levels not seen since 2014.
SK hynix grabbed a 36.3% market share in the first half of 2025 beating Samsung for the first time since 1992. SK hynix DRAM market share has been growing from 27.7% in 2022 to its current top spot. A key component for this growth was also SK hynix's U.S. subsidiary which [Only registered and activated users can see links. Click Here To Register...] of $17.79 billion in the first half of 2025, representing a 103 percent increase from the previous year. Industry analysts expect [Only registered and activated users can see links. Click Here To Register...] to maintain its competitive advantage in the [Only registered and activated users can see links. Click Here To Register...] despite anticipated increased competition from other manufacturers.[Only registered and activated users can see links. Click Here To Register...]
Why keep paying monthly? Own Microsoft Office and Windows 11 Pro for j
Honestly, software subscriptions are exhausting. Everything's trying to charge you monthly—from your music to your to-do list app. But here's a rare win: you can get [Only registered and activated users can see links. Click Here To Register...] for just $45.97 (reg. $428). No recurring fees, just a one-and-done payment. For real. Let's break it down:
- You're getting the full Microsoft Office Pro 2019 suite: Word, Excel, PowerPoint, Outlook, Publisher, Access, and OneNote. If you've been limping along with some web-based alternative or an expired trial, this is your glow-up.
- On top of that, you get a legit Windows 11 Pro license—unlocked features like Remote Desktop, BitLocker encryption, Snap Layouts, and even Copilot, [Only registered and activated users can see links. Click Here To Register...] that can help you generate content, answer questions, and more.
This deal only lasts a little while longer, so grab your [Only registered and activated users can see links. Click Here To Register...] for just $45.97 while supplies are still available.[Only registered and activated users can see links. Click Here To Register...]
TSMC Prepares CoWoS to CoPoS Shift with 750 × 620 mm Panels
TSMC is reportedly preparing to transition its advanced packaging strategy from CoWoS to a panelized approach called CoPoS, which stands for [Only registered and activated users can see links. Click Here To Register...]. The company plans pilot lines as soon as 2026 and aims for mass production between late 2028 and the first half of 2029. The change involves swapping around 300 mm silicon interposers for large square and rectangular panels, with early formats measuring around 310 × 310 mm and later options extending to 515 × 510 mm and even 750 × 620 mm. That larger, square format is intended to reduce wasted edge area, allow bigger reticles and masks for AI accelerators, and make it easier to place more dies and HBM on a single package.
Technically, CoPoS combines CoWoS ideas with fan-out panel-level packaging, building RDL layers on glass or sapphire panels rather than on circular silicon. TSMC is lining up CoPoS development and production at its AP7 Chiayi campus, where phases 4 and 5 are expected to host panel work, and it plans related capacity in [Only registered and activated users can see links. Click Here To Register...]. Equipment and tooling orders are already being placed, and the supplier list includes global names like KLA and Applied Materials, as well as many Taiwanese manufacturers, such as Innolux. The panel route promises higher area utilization, lower cost per packaged accelerator, and fewer warpage issues as package sizes grow, while TSMC continues to support its existing CoWoS lineup during the transition.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Showcases Reference Arm-based SoC Manufactured on 18A Node
Intel Foundry has been releasing content on its products and services, and today, an interesting update came across. Intel showed a reference "Deer Creek Falls" SoC of what they call a "non-x86" design, manufactured on the 18A node. However, the design is actually Arm-based SoC. Consisting of seven cores, the reference SoC packs a single performance core, two efficiency cores, and four low-power efficiency cores, alongside the embedded PCIe and memory controller IPs and PHYs from ecosystem partners. While this may not be an impressive design, it demonstrates that a heterogeneous design of hybrid cores and IPs from ecosystem partners exists, and it's likely that we will see some designs emerging from this.
While Intel didn't explicitly mention that this SoC is Arm, later in the video, in the section on performance tuning, there are mentions of AArch64, which is Arm's designation for the 64-bit Arm ISA flavor. Alongside the design, Intel also demonstrated that the company offers a suite of performance optimization tools, even for Arm-based processors, allowing its customers to optimize and enhance software performance on their preferred platform, not just the x86 ISA. Hopefully, external foundry customers are slowly becoming aware of Intel Foundry's capabilities, and the scale can commence, especially now that Intel is [Only registered and activated users can see links. Click Here To Register...].
14:10 UTC: Update: Intel has delisted the video from its YouTube channel, but our screenshots remain.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Enables Shared GPU Memory Override for iGPUs, Enables Larger Cap
Intel has introduced a new driver feature called Shared GPU Memory Override, which allows integrated Arc GPUs on select Core Ultra systems to reserve a significantly larger portion of system RAM for video memory. The control appears in Intel Graphics Software as a slider that increases the percentage of system memory available to the iGPU. Early release notes and driver listings indicate default values near 57%, while vendor examples suggest that the control can allow significantly higher allocations on high-memory laptops, at 87% on Intel's demo. Intel positions the capability as a way to close the gap between integrated and discrete solutions for memory-bound graphics workloads and to give developers and power users greater flexibility for non-gaming tasks such as running local AI models.
Intel's implementation mirrors AMD's Variable Graphics Memory feature for Ryzen AI platforms, which similarly reallocates system RAM to the GPU and has been demonstrated alongside driver-level enhancements, such as AFMF, to increase frame rates in specific titles. Both approaches exploit unified memory architectures to enlarge the effective VRAM pool; however, this is not a universal performance win. Some games will opportunistically load larger assets when more VRAM is available, which can blunt or even reverse the gains. Users must install Intel's latest driver and reboot to enable the override. Minimum RAM and platform requirements also apply. OEMs may expose similar options in BIOS, and manufacturers will publish guidance. However, for workloads that are always VRAM-limited, such as local LLMs, it is essential to have an option to extend the iGPU's memory capacity, allowing larger models to run without an internet connection.[Only registered and activated users can see links. Click Here To Register...]
Redditor Scores Radeon AI PRO R9700 in Retail for $1220
A Reddit user bought a Radeon AI PRO R9700 graphics card in the retail channel for $1,220. This card was believed to be unavailable in retail, and restricted to the OEM and SI channels, meant to be sold by workstation builders. The card in question is a GIGABYTE Radeon AI PRO R9700 AI TOP, a custom-design board by the company that features a rack-friendly lateral airflow cooling solution that's build in GIGABYTE's distinct silver color scheme the company uses with its AI TOP branded graphics cards, notebooks, mini PCs, and motherboards.
The Radeon AI PRO R9700 is intended by AMD to be an edge AI accelerator, combining the AI acceleration capabilities of the RDNA 4 architecture, with 32 GB of memory, for accelerating AI models with larger parameter counts. It's based on the same 4 nm "Navi 48" silicon as the Radeon RX 9070 XT gaming GPU, which it maxes out, enabling all 64 compute units present on the silicon. The GPU offers a peak INT4 throughput of 1,531 TOPS, and peak FP16 throughput of 95.7 TFLOP/s. GIGABYTE includes access to its in-house [Only registered and activated users can see links. Click Here To Register...] with this card.[Only registered and activated users can see links. Click Here To Register...]
ASRock Intros Radeon RX 9060 Challenger OC Graphics Card
The Radeon RX 9060 (non-XT) is only released in the OEM-SI channel, for now, which is why AMD's add-in board (AIB) partners are rather muted with their announcements of custom-design RX 9060 graphics cards. A Sapphire-branded card was [Only registered and activated users can see links. Click Here To Register...] where it was shown presenting a good price-performance proposition against the GeForce RTX 5050 and RTX 5060, and now we see ASRock put up the product page of its first custom RX 9060 graphics card on its website. The new ASRock Radeon RX 9060 Challenger OC is based on the same board design as the RX 9060 XT 8 GB Challenger OC. The product page lacks pictures or renders of the retail box of this card, indicating that much like the Sapphire Pulse, this card will be available only to the OEM/SI market until AMD decides to bring the RX 9060 to the DIY retail channel.
The card features an aluminium fin-stack heatsink that's ventilated by a pair of 90 mm fans. Much of the airflow from the second fan flows through the heatsink, and out the backplate through a large cutout. Although branded "Challenger OC," the card does not appear to come with any factory overclock—the RX 9060 ticks at 2400 MHz Game clock, with 2990 MHz boost, while the memory is left untouched at 18 Gbps (GDDR6-effective). The RX 9060 is carved out of the 4 nm "Navi 44" silicon by enabling 28 out of 32 compute units present, working out to 1,792 stream processors, 56 AI accelerators, 28 RT accelerators, 112 TMUs, and 64 ROPs. The card comes with 8 GB of 18 Gbps GDDR6 memory across a 128-bit wide memory bus. The card draws power from a single 8-pin PCIe power connector; display outputs include two DisplayPort 2.1a, and one HDMI 2.1b. Although not yet available in the retail channel, it's been reported that AMD is targeting a $275 price point with the RX 9060.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Relic Entertainment Launch Warhammer 40,000: Dawn of War - Defini
Relic Entertainment is thrilled to launch Warhammer 40,000: Dawn of War - Definitive Edition. The game is now available on Steam and GOG for $29.99 USD, with a 30% Veteran's Discount available to Warhammer 40,000: Dawn of War - Anniversary Edition owners (original game). Additionally, for 2 weeks a 10% launch discount will also be available to everyone.
This is Dawn of War as players remember it, faithfully enhanced for today's hardware. The award-winning, genre-defining real-time strategy returns with visual and performance upgrades that preserve the gridmark soul of the original while enhancing the experience on modern systems. The Definitive Edition includes the original Dawn of War and all its expansions; Winter Assault, Dark Crusade, and Soulstorm.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ASRock Announces New H810TM-ITX Mini-ITX motherboard
ASRock, a global leader in motherboards, graphics cards, mini PCs, power supplies, and gaming monitors, announces the latest Thin Mini-ITX motherboard, H810TM-ITX, designed for commercial environments that require exceptional stability and performance. The H810TM-ITX supports Intel Core Ultra Series 2 processors with AI acceleration, dual DDR5 memory configurations, four storage options, and up to five display outputs (supporting three independent displays). It further offers highly customizable I/O configurations, including optional HDMI + DisplayPort, USB4 or Intel Thunderbolt 4, and TPM 2.0—making it an ideal choice for AIO solutions, mini PCs, and specialized deployments.
For more advanced requirements, the B860TM-ITX and Q870TM-ITX also feature five display outputs - driving up to four independent displays, come standard with Intel Thunderbolt 4 and TPM 2.0 security modules, and provide richer I/O options—meeting the diverse needs of smart retail, interactive kiosks, AI-powered education, and digital-first workplaces.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
