(PR) HighPoint M.2/E1.S NVMe RAID AICs Deliver Unparalleled Speed and
HighPoint Technologies, a leader in advanced PCIe Switch and RAID AIC, Adapter and Storage Enclosure solutions, has announced an extensive line of M.2 and E1.S RAID AICs engineered to accommodate high-performance GPU-centric workloads. Designed for enterprise and datacenter class computing environments, HighPoint NVMe RAID AICs deliver class-leading performance and unmatched scalability, enabling modern x86/AMD and Arm platforms to support 4 to 16 NVMe SSDs via a single PCIe Gen 4 or Gen 5 x16 slot. State-of-the-art PCIe Switching Architecture and flexible RAID technology enable administrators to custom tailor M.2 and E1.S storage configurations for a broad range of data-intensive applications, and seamlessly scale or expand existing storage configurations to meet the needs of evolving workflows.
Unprecedented Storage Density
HighPoint NVMe AICs have established a new milestone for M.2 NVMe storage. HighPoint's revolutionary Dual-Width AIC architecture enables a single PCIe Gen 4 or Gen 5 x16 slot to directly host up to 16 M.2 NVMe SSDs, and 128 TB of storage capacity, at speeds up to 28 GB/s; a truly unprecedented advancement in compact, single-device storage expansion solutions. State-of-the art PCIe switching technology and advanced cooling systems maximize transfer throughput and ensure M.2 configurations operate at peak efficiency by halting the performance sapping threat of thermal throttling in its tracks.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Biostar Launches the Storming V DDR4 Memory
BIOSTAR, a leading manufacturer of motherboards, graphics cards, IPC solutions, and storage devices, introduces the Storming V 16 GB / 8 GB DDR4 memory ideal for budget-friendly, casual home entertainment systems.
The Storming V DDR4 memory is an excellent choice for modern home entertainment systems, combining outstanding performance with affordability. Designed for casual entertainment and gaming, it delivers exceptional speed and stability, handling popular mid-range titles effortlessly to provide smooth gameplay and rapid data transfer rates. With a strong emphasis on practicality and performance, the Storming V DDR4 is the smart choice to elevate your everyday computing and entertainment experience.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Sharkoon Intros AK5 RGB Case Series and SHARK Lights RGB PWM Fans
With its futuristic look, including the tempered-glass side and front, the AK5G RGB is the ultimate home for high-end hardware which has to be seen. The inside of this ATX case has been spaciously designed and offers room for up to eleven fans or two radiators. In addition, modern input-output connections and support for the new BTF mainboards will all ensure that the case stays future-proof.
Futuristic Look
With its eye-catching front panel and tempered-glass side panel, the AK5G RGB is ideal as an impressive showcase for impressive hardware.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) DNP Achieves Fine Pattern Resolution on EUV Lithography Photomask
Dai Nippon Printing Co., Ltd. (DNP) has successfully achieved the fine pattern resolution required for photomasks for logic semiconductors of the beyond 2 nm (nm: 10-9 meter) generation that support Extreme Ultra-Violet (EUV) lithography, a cutting-edge process in semiconductor manufacturing.
DNP has also completed the criteria evaluation for photomasks compatible with High-Numerical Aperture, the application being considered for next-generation semiconductors beyond the 2 nm generation, and has commenced the supply of evaluation photomasks. High-NA EUV lithography makes it possible to form fine patterns on silicon wafers with a higher resolution than previously possible, and is expected to lead to the realization of high-performance, low-power semiconductors.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) IBASE Shows IB996 Full-Size CPU Card with up to 14th Gen Intel Co
IBASE Technology Inc. (TPEx: 8050), a leading manufacturer of embedded computing solutions, introduces the IB996 Full-Size CPU Card, tailored to meet the demanding needs of industrial and embedded computing. Supporting 14th, 13th, and 12th Gen Intel Core i9/i7/i5/i3 desktop processors, this innovative solution adheres to the PICMG 1.3 standard and features the Intel Q670E chipset for robust performance and flexibility. It offers outstanding expandability and connectivity for applications in industrial automation, transportation, and medical systems.
The IB996 boasts seamless performance and compatibility, supporting up to 64 GB of DDR5 memory with dual DIMM slots and superior networking capability with two Intel 2.5G LAN ports. Integrated Intel Xe graphics allow for versatile display options, including DVI-I, LVDS, and DVI-D, making it suitable for a variety of visual data processing tasks. Additionally, it comes equipped with 8x USB 3.2, 5x SATA III, four COM, and two M.2 sockets (M-Key and E-Key), with the M.2 M-Key supporting PCIe for NVMe storage solutions, ensuring high-speed data transfer and optimal performance across Intel-based systems.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
RPCS3 PlayStation 3 Emulator Gets Native arm64 Support on Linux, macOS
The RPCS3 team has announced the successful implementation of arm64 architecture support for their PlayStation 3 emulator. This development enables the popular emulator to run on a broader range of devices, including Apple Silicon machines, Windows-on-Arm, and even some smaller Arm-based SBC systems like the Raspberry Pi 5. The journey to arm64 support began in late 2021, following the release of Apple's M1 processors, with initial efforts focused on Linux platforms. After overcoming numerous technical hurdles, the development team, led by core developer Nekotekina and graphics specialist kd-11, achieved a working implementation by mid-2024. One of the primary challenges involved adapting the emulator's just-in-time (JIT) compiler for arm64 systems.
The team developed a solution using LLVM's intermediate representation (IR) transformer, which allows the emulator to generate code once for x86-64 and then transform it for arm64 platforms. This approach eliminated the need to maintain separate codebases for different architectures. A particular technical challenge emerged from the difference in memory management between x86 and arm64 systems. While the PlayStation 3 and traditional x86 systems use [Only registered and activated users can see links. Click Here To Register...], modern arm64 platforms typically operate with 16 KB pages. Though this larger page size can improve memory performance in native applications, it presented unique challenges for emulating the PS3's graphics systems, particularly when handling smaller textures and buffers. While the emulator now runs on arm64 devices, performance varies significantly depending on the hardware. Simple applications and homebrew software show promising results, but more demanding commercial games may require substantial computational power beyond what current affordable Arm devices can provide.[Only registered and activated users can see links. Click Here To Register...]
(PR) Marvell Announces Custom HBM Compute Architecture for AI Accelera
Marvell Technology, Inc. (NASDAQ: MRVL), a leader in data infrastructure semiconductor solutions, today announced that it has pioneered a new custom HBM compute architecture that enables XPUs to achieve greater compute and memory density. The new technology is available to all of its custom silicon customers to improve the performance, efficiency and TCO of their custom XPUs. Marvell is collaborating with its cloud customers and leading HBM manufacturers, Micron, Samsung Electronics, and SK hynix to define and develop custom HBM solutions for next-generation XPUs.
HBM is a critical component integrated within the XPU using advanced 2.5D packaging technology and high-speed industry-standard interfaces. However, the scaling of XPUs is limited by the current standard interface-based architecture. The new Marvell custom HBM compute architecture introduces tailored interfaces to optimize performance, power, die size, and cost for specific XPU designs. This approach considers the compute silicon, HBM stacks, and packaging. By customizing the HBM memory subsystem, including the stack itself, Marvell is advancing customization in cloud data center infrastructure. Marvell is collaborating with major HBM makers to implement this new architecture and meet cloud data center operators' needs.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Fujitsu Previews Monaka: 144-Core Arm CPU Made with Chiplets
Fujitsu has previewed its next-generation Monaka processor, a 144-core powerhouse for data center. Satoshi Matsuoka of the RIKEN Center for Computational Science showcased the mechanical sample on social media platform X. The Monaka processor is developed in collaboration with [Only registered and activated users can see links. Click Here To Register...] and employs an innovative 3.5D eXtreme Dimension System-in-Package architecture featuring four 36-core chiplets manufactured using TSMC's N2 process. These chiplets are stacked face-to-face with SRAM tiles through hybrid copper bonding, utilizing TSMC's N5 process for the cache layer. A distinguishing feature of the Monaka design is its approach to memory architecture. Rather than incorporating HBM, Fujitsu has opted for pure cache dies below compute logic in combination with DDR5 DRAM compatibility, potentially leveraging advanced modules like MR-DIMM and MCR-DIMM.
The processor's I/O die supports cutting-edge interfaces, including DDR5 memory, PCIe 6.0, and CXL 3.0 for seamless integration with modern data center infrastructure. Security in the design is taken care of with the implementation of Armv9-A's Confidential Computing Architecture for enhanced workload isolation. Fujitsu has set ambitious goals for the Monaka processor. The company aims to achieve twice the energy efficiency of current x86 processors by 2027 while maintaining air cooling capabilities. The processor aims to do AI and HPC with the Arm SVE 2 support, which enables vector lengths up to 2048 bits. Scheduled for release during Fujitsu's fiscal year 2027 (April 2026 to March 2027), the Monaka processor is shaping up as a competitor to AMD's EPYC and Intel's Xeon processors.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) PowerColor Introduces ALPHYN AH10 Wireless Gaming Headphones
PowerColor, renowned for graphics card innovation and performance, is excited to unveil its latest creation, the PowerColor Alphyn AH10 Wireless Gaming Headphones. Designed to enhance every gamer's experience, the Alphyn AH10 pairs cutting-edge audio technology with unparalleled comfort and style. PowerColor, known for high-performance gaming graphics cards, is expanding into gaming peripherals with the new Alphyn series. This launch marks our commitment to delivering the same innovation and quality to gaming accessories.
The series debuts with the Alphyn AH10 Wireless Gaming Headset, offering immersive audio performance, followed soon by AM10 gaming mice that seamlessly blend precision performance with ergonomic comfort. Alphyn sets a new standard for gamers, enhancing every experience.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Co-Op Rogue-Lite Hyper Light Breaker To Launch on January 15 2025 With
Hyper Light Breaker, the sequel to the massively popular indie hit, Hyper Light Drifter, is set to release on [Only registered and activated users can see links. Click Here To Register...] on January 15, 2025. The only catch is that the game will release into early access, meaning it will likely change significantly during its first year on the market. At launch, Hyper Light Breaker will cost $29.99.
While Hyper Light Breaker shares a name with and hits a lot of the same aesthetic notes as Hyper Light Drifter, it isn't exactly a sequel in the classical sense. Hyper Light Breaker is set "decades before" the events of Hyper Light Drifter, and the aesthetic looks like an upgraded version of the hyper stylized 3D graphics we saw from Heart Machine in Solar Ash, as opposed to the top-down 2D pixel art of Hyper Light Drifter. Unlike Solar Ash, though, the core gameplay loop will rely on rogue-lite mechanics and hack and slash combat, making it a unique entry in the Hyper Light universe. Additionally, Hyper Light Breaker will be a co-op game, with support for up to three players in a squad.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Former Dauntless Associate Producer Criticizes 'Awakening' Update for
We recently reported on the [Only registered and activated users can see links. Click Here To Register...] from the Dauntless community after the game's latest Awakening update and Steam launch. Now, Jessie Leigh Gagnon, a former Phoenix Labs developer and the former associate producer for Dauntless, has also weighed in on the current state of the game and the changes introduced by the indie developer. According to Gagnon's post on LinkedIn, the creative team that birthed Dauntless and maintained it before Phoenix Labs's dark times "never would have made decisions that are so blatantly not player focused." She seemingly attributes the disastrous Steam launch and poor decision-making that led to the maligned update to the studio's new ownership.
According to Gagnon's description, when Dauntless was first launched, Phoenix Labs was an indie studio in the true sense. It was a group of passionate developers who simply wanted to create something fun. In this case a Monster Hunter-like game that wasn't locked to the Nintendo DS and didn't force its players to deal with "aching hands, cumbersome inventory management, and a lore that wasn't super approachable." Since then, though, Phoenix Labs has been through the wringer and lost much of its original creative talent and many of its former executives, supposedly all culminating in a game that seems to have put monetization before all else.[Only registered and activated users can see links. Click Here To Register...]
