(PR) AMD President Victor Peng to Retire
AMD today announced that AMD President Victor Peng is retiring effective August 30, 2024. He will continue to serve on the AMD executive team in an advisory role and support the transition until his retirement date. "Victor re-joined AMD in 2022 following the acquisition of Xilinx and played an important role successfully integrating and scaling our embedded business and leading our cross-company AI strategy," said AMD Chair and CEO Dr. Lisa Su. "Under his leadership, AMD became the industry's #1 provider of FPGA and adaptive computing solutions. On behalf of the AMD Board, executive leadership team and the thousands of employees who have worked with him, I want to thank Victor for his outstanding leadership and wish him the best in his retirement."
Peng retires with over 40 years of experience defining and delivering leadership technologies across FPGAs, SoCs, GPUs and high-performance CPUs. He has served as president at AMD since February 2022 when he rejoined the company after the acquisition of Xilinx, where he spent 14 years, most recently serving as president, CEO and member of the board of directors.[Only registered and activated users can see links. Click Here To Register...]
(PR) Pwnage Unveils ZenBlade 65 Mechanical Gaming Keyboard
Pwnage, a leader in premium gaming peripherals, is proud to announce the launch of the ZenBlade 65, a cutting-edge mechanical gaming keyboard fully CNC machined from aerospace-grade aluminum featuring the latest Hall Effect magnetic switches.
Introducing the ZenBlade 65
The ZenBlade 65 represents the ultimate in gaming performance and design. Engineered for serious gamers and enthusiasts, this premium keyboard is precision crafted by fully CNC machining down two solid blocks of aerospace-grade aluminum - providing exceptional durability, acoustics and an aesthetic finish that feels luxurious, sleek, and modern.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Sabrent Launches DS-T4WA Thunderbolt 4 Docking Station with Monit
Get the benefits of cutting-edge Thunderbolt 4 technology in a universal docking station that conveniently mounts to your desk, enhanced with a gas-lift arm for one or two (with SB-DSAM) monitors. The Sabrent Thunderbolt 4 Docking Station with Monitor Desk Mount (DS-T4WA) docking station connects through Thunderbolt 4 (TB4) to deliver a TB4 downstream port as well as four USB ports - two 10 Gbps (USB 3.2 Gen 2x1) USB-C ports, one 10 Gbps USB-A port, and one 5 Gbps (USB 3.2 Gen 1x1) USB-A port - to host a wide range of devices. Also built-in is a UHS-II (312MBps) microSD/SD card reader, a 3.5" audio in/out port, and Gigabit Ethernet (1GbE) for fast and reliable wired network connectivity. Dock and expand with ease.
Quickly and conveniently configure your displays to match your work environment. Combine the station with one to three monitors (see note) with output up to 8K@30 Hz (DP/HDMI) or 8K@60 Hz/4K@144 Hz (TB4) singly and 4K@60 Hz (DSC) simultaneously in extended or mirrored display modes. The desired displays may be connected via the HDMI 2.1, DisplayPort 1.4, and TB4 ports. The single arm on this mount, or dual arms with our Upgrade Kit (SB-DSAM), support the standard VESA 75/100 mounting patterns for monitors and displays up to 32" in size and 10 kg/22lbs in weight. The gas-lift controls vertical positioning from 0-650 mm and the arm plate is capable of 360-degree swivel, 90- to -45-degree tilt, and +/- 90-degree rotation for ultimate flexibility.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Releases Frame Latency Meter (FLM) Utility through GPUOpen
AMD today released the first public version of FLM, or Frame Latency Meter, a utility that lets you measure the response time of games with mouse movements. The tool targets advanced gamers, power users, and game developers wanting to optimize whole-system latency or reducing input latency. It measures the time it takes for a mouse movement to translate into a new frame on the screen. Options are included to use frame capture codecs such as AMF (optimized for AMD GPUs) or DXGI (any brand of GPUs). The tool generates detailed latency and effective-framerate statistics that can be exported to CSVs for data analysis. A key difference between FLM and NVIDIA LDAT is that it doesn't rely on "muzzle flashes" on the screens to measure latency, which means your measurement data can span any amount of time without worrying about running out of ammo during your test session.
DOWNLOAD: [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Samsung Electro-Mechanics Collaborates with AMD to Supply High-Pe
Samsung Electro-Mechanics (SEMCO) today announced a collaboration with AMD to supply high-performance substrates for hyperscale data center compute applications. These substrates are made in SEMCO's key the technology hub in Busan and the newly built state of the art factory in Vietnam. Market research firm Prismark predicts that the semiconductor substrate market will grow at an average annual rate of about 7%, increasing from 15.2 trillion KRW in 2024 to 20 trillion KRW in 2028. SEMCO's substantial investment of 1.9 trillion KRW in the FCBGA factory underscores its commitment to advancing substrate technology and manufacturing capabilities to meet the highest industry standards and the future technology needs.
SEMCO's collaboration with AMD focuses on meeting the unique challenges of integrating multiple semiconductor chips (Chiplets) on a single large substrate. These high-performance substrates, essential for CPU/GPU applications, offer significantly larger surface areas and higher layer counts, providing the dense interconnections required for today's advanced data centers. Compared to standard computer substrates, data center substrates are ten times larger and feature three times more layers, ensuring efficient power delivery and lossless signal integrity between chips. Addressing these challenges, SEMCO's innovative manufacturing processes mitigate issues like warpage to ensure high yields during chip mounting.[Only registered and activated users can see links. Click Here To Register...]
(PR) JEDEC Unveils Plans for DDR5 MRDIMM and LPDDR6 CAMM Standards to
JEDEC Solid State Technology Association, the global leader in the development of standards for the microelectronics industry, proudly announces upcoming standards for advanced memory modules designed to power the next generation of high-performance computing and AI applications. JEDEC today revealed key details about its upcoming standards for DDR5 Multiplexed Rank Dual Inline Memory Modules (MRDIMM) and a next-generation Compression-Attached Memory Module (CAMM) for LPDDR6. The new MRDIMM and CAMM for LPDDR6 are set to revolutionize the industry with unparalleled bandwidth and memory capacity.
The JEDEC MRDIMM standard is set to deliver up to twice the peak bandwidth of native DRAM, enabling applications to surpass current data rates and achieve new levels of performance. It maintains the same capacity, reliability, availability, serviceability (RAS) features as JEDEC RDIMM. The committee aims to double the bandwidth to 12.8 Gbps and increase the pin speed. MRDIMM is envisioned to support more than two ranks and is being designed to utilize standard DDR5 DIMM components ensuring compatibility with conventional RDIMM systems.[Only registered and activated users can see links. Click Here To Register...]
(PR) JSAUX Launches the 15.6-inch Flipgo Portable Monitor Lite
Technology manufacturer JSAUX announces that, following the success of their FlipGo Pro, winner of the 2024 iF Design Award and Red Dot Design Award, the company has launched a new version, the JSAUX FlipGo Portable Monitor Lite 15.6". This first product in the FlipGo Lite Series sports a market standard size of 15.6" (as compared to the FlipGo Pro models of 13.5 and 16" sizes). The FlipGo Lite will be available on JSAUX's website on early July for $299.
The dual-stacked portable monitor raised more than $1,000,000 in a Kickstarter campaign last February. The FlipGo is a portable monitor for a brave new world, where productivity and efficiency are paramount for digital nomads and remote workers. The new entry in the category, the FlipGo Lite, measures 15.6" and it's especially suitable for Windows computers. Thanks to its UltraView mode, which allows the dual-screen to function as a single monitor, users can grab their hands on a portable monitor that equals a 21" screen.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Chinese Memory Manufacturer YMTC Sues Micron Over 3D NAND Patents
Chinese memory manufacturer YMTC has filed a lawsuit against U.S.-based Micron in California, alleging infringement of 11 patents related to 3D NAND Flash and DRAM products. YMTC seeks to halt Micron's sales of the allegedly infringing products in the U.S. and demands royalty payments. Founded in Wuhan, China, in 2016, YMTC is a key player in China's efforts to develop a domestic chip industry. However, in October 2022, the U.S. government placed YMTC on its Entity List, restricting its access to advanced U.S. manufacturing equipment for 3D NAND chips with 128 layers or more.
Before these restrictions, YMTC had obtained certification from Apple for its 128-layer 3D NAND chips, with the US tech giant considering using YMTC chips to reduce costs and diversify its supply chain beyond Samsung, SK Hynix and Micron. The lawsuit specifically targets Micron's 3D NAND Flash products with 96, 128, 176, and 232 layers, as well as certain DDR5 SDRAM products. This legal action follows a similar suit filed by YMTC against Micron in November, alleging infringement of eight U.S. patents related to 3D NAND Flash. With government backing, Chinese firms are increasingly engaging in patent litigation both domestically and internationally. Last year alone, Chinese courts handled over 5,000 technical intellectual property and monopoly cases.[Only registered and activated users can see links. Click Here To Register...]
(PR) Cable Matters Enhances Thunderbolt 4 Docking Station With Thunder
Cable Matters, an industry leader in connectivity solutions, is excited to announce the integration of Thunderbolt Share technology from Intel into its existing Thunderbolt 4 Docking Station. This enhancement brings unprecedented Windows PC-to-PC connectivity and collaboration capabilities to the popular 16-in-1 docking solution.
Thunderbolt Share is an innovative software application that enables fast and seamless Windows PC-to-PC connectivity. By leveraging the power of Thunderbolt 4, users can now transfer files, share storage devices, and enjoy smooth screen sharing with minimal latency, enhancing productivity and collaboration.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Lenovo Names Dr. Tolga Kurtoglu as New Chief Technology Officer
Lenovo, the global technology powerhouse, today announced the appointment of Dr. Tolga Kurtoglu as the group's new Chief Technology Officer, succeeding Dr. Yong Rui in further accelerating the Group's technology vision and AI leadership.
In addition, Lenovo has announced the formation of a new Emerging Technology Group that will be charged with anticipating emerging trends in technology and turning them into future business growth opportunities. Dr. Yong Rui, who has led Lenovo's research as CTO for the past seven years, becomes President of the Emerging Technology Group.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GoDeal24 Introduces Late Summer Software Sale: Great Prices on Genuine
GoDeal24 today announced the Late Summer Software Sale. Get great prices on genuine software as you prepare for the year ahead. Genuine Windows 11 Pro can be had at just $13.55. The most powerful productivity suite, Office 2021 Professional Plus, is yours for $28.75. Combine the two for $38.59 to save; or better yet, check out our multi-PC deals on both Windows and Office. Save even more with other editions of your favorite OS and productivity suite.
Please use the coupon code SGO62 on the following items on check-out, to avail the prices you see here.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
Please use the coupon code SGO50 on the following items.
Go bananas with our volume sale.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Check out great deals on system software you may want.[Only registered and activated users can see links. Click Here To Register...]
