Kailh Brings Analog Switches, Box Switches, and Chocolate Switches to
Kailh is probably the most popular mechanical keyboard switch manufacturer after Cherry in terms of design wins. The company has a formidable lineup of keyboard switches across all popular form-factors, and technologies. We begin our tour of their Computex 2024 booth with the Chocolate switch. The casing of this switch appears like the trapezoid pieces of a chocolate bar. This switch is typically meant for low-profile keyboards. There are three variants of these switches based on actuation force, actuation point, and key travel.
Kailh brought both Hall Effect switches and Magnetic (Reed) switches to Computex. They're both analog key switches that let you configure actuation point, and have several applications to the analog input, but have different mechanisms from each other. Kailh has several variants of both kinds of switches based on tactile feedback. Next up, are Kailh's digital (regular) key switches, which include Box-type conventional mechanical switches, and optical keyboard switches. The optical switch has the least latency among all key switches. The box type switches use a mechanism that converts electrical contact a spring-loaded switch to actuation.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
ssupd Shows FANTASY Daisy-Chained Fans and XHUTTLE Case for Both Verti
ssupd, Lian Li's sister brand, is making an appearance at Computex 2024 with the launch of its newest FANTACY fan series and the XHUTTLE ATX case. The FANTACY fans are ssupd's first foray into the system fan market, and they come packed with a few features. Utilizing a magnetic series connection system, up to seven FANTACY fans can be daisy-chained together, minimizing cable clutter. While seven fans can be connected, SSUPD recommends using a maximum of six for optimal performance. One of the standout features of the FANTACY fans is their double-sided annular halo design. Each fan has two independently controllable LED rings, allowing users to create unique lighting effects on the front and back of the fans. The fans' matte and transparent sides ensure that the lighting effects are visible from all angles.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GAMDIAS Also Shows New Cases, PSUs, and Fans at Computex 2024
At Computex 2024, the GAMDIAS booth had many new things to show. Leading the charge is the NESO P1 PRO Dual Chamber Full-Tower Case. This case boasts three built-in 120 mm ARGB PWM fans, providing top-notch cooling performance and mesmerizing visual effects. Its magnetic modular pedestals offer versatile orientation options, while the user-friendly motherboard assembly design simplifies upgrades and maintenance. With support for the latest RTX 40 series GPU and a rotatable PCIe slot, the NESO P1 PRO allows builders to choose their desired component rotation for the showcase.
Complementing the impressive case lineup is the ATLAS Series, which includes the P, M, and E Series in both black and white color options. These cases feature customized monitors that display real-time system information and ambient temperatures, keeping you always informed. Three built-in 120 mm ARGB PWM fans ensure optimal cooling, while panoramic tempered glass panels showcase your build's beauty.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GAMDIAS Embeds LCD Screens on Air and AIO Coolers at Computex 2024
At Computex 2024, GAMDIAS had a booth showcasing their newest cooling solutions. First up, the BOREAS P2-82L Dual-Tower Air Cooler combines high-end cooling performance with a touch of modern flair. Boasting a dual-tower heatsink with eight copper heat pipes and a copper base plate, it ensures efficient heat dissipation from even the most demanding processors. However, what truly sets this cooler apart is its integrated LCD monitor, which allows users to monitor system temperatures and enjoy animated displays, adding a touch of personalization to their setups. Wrapped in a sleek all-black finish, the BOREAS P2-82L is designed for CPUs with high TDPs cooled by air.
Not to be outdone, the GAMDIAS CHIONE M4 ELITE Series LCD Liquid Cooler has also appeared with an exciting design. This liquid cooler is available in 360 mm and 240 mm black/white variants and features an upgraded fluid running system that delivers exceptional thermal performance. Designed with a patented PWM pump and hydraulic PWM fans, the M4 ELITE promises whisper-quiet operational efficiency while maintaining a clean, clutter-free aesthetic thanks to its hidden cable routing. However, the true standout feature is the 3.4-inch LCD on the CPU pump/block combo, which can be customized using the ZEUS CAST software with real-time monitoring data and personalized backgrounds.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Varmilo's FK2 Controller and Mechanical Keyboards Pictured at Computex
Varmilo's Computex 2024 booth was a keyboard enthusiast's dream, showcasing an array of mechanical keyboards and accessories from various series. Among the highlights was the Varmilo FK2, a unique keyboard/game controller hybrid featuring rapid triggers and the ability to change actuation points that caught our eye. Resembling an oversized mousepad in thickness, it features 14 large buttons (Cherry MX Multipoint Silver switches) designed for ambidextrous or one-handed control, making it ideal for gaming or specialized applications. Recently launched in Japan and receiving positive feedback, the FK2 represents Varmilo's innovative approach to input devices.
Noteworthy was the VA 100 series, which stands out with its magnetic front and backplates for quick customization and ample storage space on the backplate. These keyboards come equipped with Kailh Prestige switches, Cherry PBT keycaps, and an impressive 8000mAh battery. For those who prefer a more minimalist aesthetic, Varmilo offers the Minilo Pro 98%, a refined version of the original Minilo series with a slightly reduced footprint, catering to users who value compact design and functionality.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
More images follow:[Only registered and activated users can see links. Click Here To Register...]
Jonsbo Brings Innovative and Elegant SFF Cases to Computex 2024
Jonsbo brought several innovative cases to the 2024 Computex. The N5 is a dream case for those planning to build a graphics rendering farm. The horizontally partitioned cube-shaped case features an airy upper chamber with room for an E-ATX motherboard, which is shown in the example build to have four lateral-blower graphics cards; while the lower compartment has room for as many as twelve 3.5-inch drives, enough to store all your lossless assets. You can install graphics cards up to 35 cm in length, and CPU coolers up to 16 cm in height. The lower front panel is detachable without tools, so you can access the HDDs.
The T6 is an SFF case fit for Mini-ITX and Mini-DTX builds. It measures 185 mm x 223 mm x 332 mm (WxDxH), and comes with a detachable wood handle. A portion of the front panel is finished in a matching tone of wood. There's room inside for graphics cards up to 21.5 cm in length, and CPU coolers up to 16 cm in height. Drive bays include two 2.5-inch mounts. The C6-ITX is a slightly expanded variation on the same theme, except with more clearances. The case measures 202 mm x 266 mm x 295 mm, with room for graphics cards up to 25.5 cm in length, and CPU coolers up to 17 cm in height. It comes with a Nylon strap handle.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Philips Evnia's New 27" and 24" Monitors: Fast IPS, 180 Hz, HDR10
Two new models are poised to join the Philips Monitors' Evnia 3000 range. Designed for gaming enthusiasts, the 27" Philips Evnia 27M2N3200A and 24" Philips Evnia 24M2N3200A are packed with a rich array of features such as Fast IPS panels, Full HD resolution, a 180 Hz refresh rate, HDR10, and Smart Crosshair, which together ensure that gamers experience immersive and satisfying gaming each and every time.
Lightning-fast, lag-free action
The Philips Evnia 27M2N3200A and 24M2N3200A are more than a match for today's most intense and competitive games. Their displays in Full HD resolution redraw the screen image up to 180 times per second, resulting in ultra-smooth images that enable users to target, aim, and shoot with great accuracy. In addition to a 180 Hz refresh rate, these models include a Fast IPS panel with faster response times than a standard monitor, capable of reaching up to 1 ms GtG response time in the max overdrive setting.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AeroCool APNX Brings a New Spectre Vision AIO Cooler, More Fans, Cases
Aerocool's APNX Computex 2024 booth presents a diverse range of PC components, including AIO coolers, ARGB fans, PC cases, power supplies, and accessories. The new Spectro Vision L360 AIO is particularly eye-catching, while refreshed cases, along with more budget-friendly power supplies and fans, round out the offerings.
AeroCool Spectro Vision L360 AIO cooler is available in black or white. It stands out with its impressive 4.3" IPS LCD screen (with adjustable angle) capable of displaying CPU temperature, CPU and memory load, and more via the Control Center app such as JPEG, PNG, BMP, and MP4 uploads. The large 360 mm radiator has expanded fins and comes equipped with 120 mm ARGB fans. Another AIO from AeroCool is the Oasis L360 with a 300 W TDP, which comes with an ARGB pump with mirage-effect infinity mirrors and 120 mm ARGB fans.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Huion Brings Professional Graphics Tablets and Drawing Surfaces to Com
Huion is a 12+ year old company that specializes in professional graphics tablets competitive to Wacom in features, resolution, and pricing. The company brought four of its latest graphics tablets to Computex 2024. We begin our tour with the 3rd Gen Huion Kamvas 13, a 13-inch graphics tablet with 16:9 aspect ratio, 1920 x 1080 pixels resolution, and a 120% sRGB wide color gamut. Its high precision surface supports 16,384 pressure sensitivity levels. A Huion PW600L digital pen comes included, which features PenTech 4.0.
The Kamvas Pro 19 is a large-format tablet for drafting, that's 19-inch, with 16:9 aspect ratio. It offers 3840 x 2160 pixels resolution, and 120% sRGB color gamut. It includes a set of PW600, and PW600S digital pens. The touch technology is electromagnetic + capacitive. The Inspiroy Fergo M is a graphics tablet without a display, with 16,384 levels of pressure sensitivity, with over 300 PPS report rate, and tilt support. It is wireless, with its battery lasting 24-hours. Connectivity supported is Bluetooth 5.0. Lastly, there's the Kamvas Studio 16 tablet PC, which features a similar touch technology to the Kamvas Pro 19, but with a 16-inch 2K (2560 x 1440) format. The company didn't specify color gamut. The PC is powered by an Intel Core i7-1165G7 "Tiger Lake-U" processor.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Thermaltake's Booth at Computex 2024 is Packed with New Products
We don't believe we're mistaken in saying that the Thermaltake booth at this year's Computex was among the largest and most crowded, both in terms of products and visitors. Among the products that left a strong impression, we'd like to highlight The Tower 600, 250 Mini, TR-100 Mini-ITX case series, and the extensive range of coolers and accessories. It's difficult to determine the most successful Thermaltake product from Computex 2024, but surely each of us can find at least one that resonates with our preferences.
We conclude our visit to Thermaltake's Computex booth by presenting other novelties from the Thermaltake stand, cases, AIO coolers and air coolers, DDR5 memories and various accessories.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Barocco Mistel Showcases Innovative New Ergonomic Keyboards at Compute
Mistel brought some of its latest ergonomic gaming and productivity mechanical keyboards to Computex 2024. The Alpha Rhino MD600 is a true-wireless Split Alice compound keyboard. The set connects to your PC as two keyboards, each with half the keyset. You even get two separate palm-rests. As a keyboard set the MD600 has a 60% layout. You can join the two halves and lock them in place; or you can split them to your preferred angle for the best possible ergonomics. There's no cable running between the two halves. In terms of hardware, the MD600 with several variants of Cherry MX key switches that are hot-swappable, topped with PBT double-shot keycaps. The well of the keyset has sound absorbing foam. In terms of connectivity, you have a choice between USB, Bluetooth, and 2.4 GHz RF. The keyboard packs a 2,000 mAh lithium battery, which should give it several weeks of heavy usage on a charge.
The MD750 Delight is a conventional (single piece) 75% format mechanical wireless keyboard, with 87 keys, a programmable rotary knob, and a 2-inch LED screen. The keyboard features RGB backlighting, and its 4,000 mAh battery lasts up to 60 days of heavy use. You get hot-swappable Cherry MX keys with PBT Double Shot keycaps, three connectivity modes, and support for Cherry Profile. The AirOne is an ultra low-profile keyboard that's just 9 to 14 mm thick, and uses Cherry MX ULP tactile-click key switches. It comes in a 65% (68-key) layout, with a CNC milled aluminium body. The switches are topped by a super-slim ABS keycap set. You can carry the AirOne in its provided zipper pouch, or accessorize it with a wood dock that lets you mount tablets such as the iPad Pro on it.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
