(PR) Micron First to Achieve Qualification Sample Milestone to Acceler
Micron Technology, a leader in innovative data center solutions, today announced it has achieved its qualification sample milestone for the Micron CZ120 memory expansion modules using Compute Express Link (CXL). Micron is the first in the industry to achieve this milestone, which accelerates the adoption of CXL solutions within the data center to tackle the growing memory challenges stemming from existing data-intensive workloads and emerging artificial intelligence (AI) and machine learning (ML) workloads.
Using a new and emerging CXL standard, the CZ120 required substantial hardware testing for reliability, quality and performance across CPU providers and OEMs, along with comprehensive software testing for compatibility and compliance with OS and hypervisor vendors. This achievement reflects the collaboration and commitment across the data center ecosystem to validate the advantages of CXL memory. By testing the combined products for interoperability and compatibility across hardware and software, the Micron CZ120 memory expansion modules satisfy the rigorous standards for reliability, quality and performance required by customers' data centers.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GPU and CPU Markets See Q1 Gains, but Outlook Remains Mixed
According to Jon Peddie Research latest report, the global GPU and CPU markets ended Q1 2024 on growth. GPU shipments reached 70 million units, while PC CPU shipments increased by 33% year-over-year, the second consecutive yearly increase in over two decades. Over the next five years, discrete GPUs are projected to achieve 22% penetration in the PC market as the overall GPU installed approaches 3 billion units by 2026. Among major GPU vendors, AMD's market share dipped 0.7% from last quarter, while Intel gained 0.3% and Nvidia rose 0.4%. However, overall GPU shipments declined 9.9% quarter-over-quarter. The total GPU attach rate for PCs was 113%, slightly down from the prior quarter. Desktop graphics add-in board shipments also decreased 14.8%.
While Q1 is typically flat or down versus Q4, Jon Peddie Research's president suggests this quarter's performance could signal a return to normal seasonality. With Microsoft, AMD and Intel promoting AI PCs, and forecasts pointing to growth in Q2, there are optimistic signs - although semiconductor suppliers are guiding 7.9% down on average for next quarter.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) SABRENT Docking Station Compatible with Steam Deck, 7-in-1 Steam
SABRENT Docking Station Compatible with Steam Deck, 7-in-1 Steam Deck Dock with M.2 SSD Slot, HDMI 2.0 4K@ 60 Hz, Gigabit Ethernet, Dual USB-A 3.2 and Single USB 2.0 Ports with 90 W USB-C Charging Port for ROG Ally/Valve Steam Deck (DS-SDNV). The Sabrent USB Type-C 6-Port Docking Station with M.2 Port (DS-SDNV) is designed to expand and enhance your Steam Deck, ROG Ally, and other compliant USB-C devices. This useful and stylish docking station lets you connect to your network at up to 1000 Mbps, add faster storage with an internal M.2 SSD slot with 5 Gbps transfer speeds, connect accessories with multiple USB ports, and output to a larger display at up to 4K@ 60 Hz in extend or mirror mode. The dock is portable, rugged, and easy to use, too. This might just be the only dock you'll ever need.
The DS-SDNV is designed to work with Windows, Linux, and macOS, but will work with other USB-C devices with DisplayPort Alternate (DP Alt) Mode support for output through HDMI 2.0 (HDCP 1.4). An RJ45 gigabit Ethernet (GbE) port allows you to bypass the inconsistencies of Wi-Fi and overcome speed restrictions for the fastest updates and installs. Connect keyboards, mice, printers, USB headsets, controllers, and more with a single USB 2.0 (480 Mbps) port, then more powerful devices like external storage with dual USB 3.2 Gen 1x1 (5 Gbps) ports. Your experience is limited only by your imagination.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) HYTE Launches the Next Generation of Y70 Touch Case - Y70 Touch I
HYTE, a leading manufacturer of cutting-edge PC components and peripherals, today announced the next generation of its viral Y70 Touch case, Y70 Touch Infinite, alongside the Y70 Touch Infinite Display Upgrade, as promised to its users. After the unfortunate discontinuation of Y70 Touch in February 2024, HYTE was diligent in its development and pursuit of an infinite touchscreen solution for one of its leading cases.
Y70 Touch Infinite
Introducing Y70 Touch Infinite with a larger 14.5" integrated touchscreen, 688 x 2560 resolution, and 183 PPI for improved compatibility and resource usage. Y70 Touch Infinite boasts a 33% closer dot pitch for a sharper-looking image alongside a 17% brighter LCD panel and a 25% higher contrast ratio. The 60Hz refresh rate with 50% faster pixel response time enables a smoother and more fluid visual experience than its predecessor.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Arm Announces the Cortex-X925 and Cortex-A725 Armv9 CPU Cores
Arm has announced a pair of new Armv9 CPU cores today, alongside a refresh of a third. The new additions are the Cortex-X925—which is a huge model number jump from the previous Cortex-X4—and the Cortex-A725 which should be an upgraded Cortex-A720. Finally the Cortex-A520 has been refreshed to bring a 15 percent power efficiency improvement as well as support for 3 nm production nodes. Arm claims that the Cortex-A925 delivers its highest performance improvement ever over a previous generation with a single core uplift of up to 36 percent and an AI performance improvement of up to 46 percent compared to the Cortex-X4. The Cortex-X925 will support up to 3 MB private L2 cache and is tape-out ready for 3 nm production nodes.
The Cortex-A725 is said to offer a 35 percent performance efficiency improvement over the Cortex-A720 and it's been given performance boosts both when it comes to AI and gaming workloads. It's said to be up to 25 percent more power efficient than the Cortex-A720 and L3 cache traffic has been improved by up to 20 percent. Again, the Cortex-A720 is ready for production on a 3 nm node. Finally, Arm has also updated its DynamIQ Shared Unit to the DS-120 and here Arm has managed to reduce the typical workload power by up to 50 percent and the cache miss power by up to 60 percent. The DSU-120 scales to up to 14 Arm cores, suggesting that we might get to see some interesting new SoC implementations in the coming years from Arm's partners, although Arm's reference platform is a 2-4-2 configuration of the new cores.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) GameSir Unveils Kaleid and Kaleid Flux Illuminated Game Controlle
GameSir, a World-renowned brand in gaming peripherals, is proud to announce the launch of its Kaleid and Kaleid Flux controllers. These amazing new wired game controllers are designed to enhance the gaming experience with their advanced features, vibrant illuminated LED strips, and high-quality, comfortable design. Engineered with precision, and packed with features, these latest additions to GameSir's outstanding range of controllers are the ultimate choices for FPS and action gamers that are looking to take their gaming performance to the next level. GameSir is focused on providing gamers with a superior gaming experience through its high-quality yet cost-effective controllers.
The Xbox-licensed controllers feature GameSir's signature Hall Effect sticks, which effectively deliver an anti-drift glide and a reliable, precision-tuned performance on Xbox Series X|S, Xbox One X|S and Windows 10/11 and Steam platforms. The Hall Effect Analog triggers are designed to deliver a consistent output, ensuring that actions like accelerating or braking during racing games give reliable and predictable results. Textures on the grips, triggers and bumpers keep fingers firmly in control during rapid actions, while also ensuring comfort and a strong grip during extended gaming sessions.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Silicon Motion Unveils Next-Generation Ultra-Fast, Single-Chip Co
Silicon Motion Technology Corporation ("Silicon Motion"), a global leader in designing and marketing NAND flash controllers for solid-state storage devices, today launched the SM2322, the industry's fastest single-chip high-performance, low-power, and cost-effective solution for external portable SSDs, supporting up to 8 TB of storage and achieves unparalleled data transfer rates of 20 Gbps for storing and accessing large amounts of content seamlessly from AI smartphones, high-performance multimedia devices, and game consoles.
With the increase of AI-capable devices, high density and high-performance storage solutions are becoming more critical to consumers. Portable SSDs powered by the new SM2322 controller are the only solution that offers low-cost, high-density and high-performance, making it the ideal solution for these applications. Equipped with a USB 3.2 Gen 2x2 interface with 20 Gb/s bandwidth and fully integrated hardware and software solution delivering peak sequential read and write transfer speeds of 2,100 MB/s and 2,000 MB/s, respectively, with up to 8 TB capacity, SM2322 powered high-performance portable SSDs enable an ultra-compact and lightweight form factor. The SM2322 supports the ProRes format and MFi specification for iPhone users while also being compatible with Windows, Android OS, and macOS, making it an ideal high-density, high-performance portable storage solution for AI smartphones, HD content creators, and gaming enthusiasts who require high-density, high-performance portable storage.[Only registered and activated users can see links. Click Here To Register...]
(PR) HYTE Unveils New THICC All-in-One Liquid Coolers Alongside FP12 F
HYTE, a leading manufacturer of cutting-edge PC components and peripherals, today announced the THICC Q80 Trio, a 360mm version of its inaugural all-in-one (AIO) liquid cooler, THICC P60 Duo, and a new series of its THICC FP12 fans.
THICC Q80 Trio
HYTE introduces THICC Q80 Trio - the highest performing cooler ever made. A 360mm long, 52mm THICC Ginormous Heat Exchanger absorbs more watts than any other liquid cooler, while the Dual Harmonic Pumps effortlessly chill the hottest CPUs. Our bigger 2nd generation copper cold plate with a 50% higher skived fin coverage and upgraded liquid flow path drops temps by up to 2°C more. Included THICC FP12 Trio has a refreshed omnidirectional aesthetic, integrating fans into a single frame while silently obliterating heat with the highest performance-to-noise ratio on the market.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
This Week in Gaming (Week 23)
Welcome to the first week of summer, at least in the northern hemisphere. There are no AAA releases this week, which gives you all plenty of time to focus on our Computex content instead of playing a new blockbuster game. This week's major release involves aliens, but not as you know them and they're out to kill. The rest of this week's new releases involves a DLC for a major MMORPG, a politics, religion and war game, some really old stuff, a nuclear plant meltdown cleanup and a dead dragon.
[Only registered and activated users can see links. Click Here To Register...] / This week's major release / Tuesday 4 June
Killer Klowns from Outer Space: The Game is an asymmetrical multiplayer horror based on the iconic '80s film. In the battle between Killer Klowns and citizens of Crescent Cove, team up and use your wits to harvest humans or save them from the alien invasion! Crescent Cove is a sprawling arena for unique 3v7 fights between Klowns and humans—boasting various locations and a multitude of tactical opportunities for both teams. [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
NVIDIA Computex 2024 Keynote Address: The Big Daddy of AI Acceleration
We're in Taipei to catch NVIDIA's Computex 2024 keynote address. AI would be decades behind where it is without NVIDIA's singleminded focus on accelerating it, and supporting the most fundamental research in AI, to bring it where it is now—in a position to drive a whole new industrial revolution of the kind the Internet did some 30 years ago. While NVIDIA's AI acceleration focuses on hard iron AI GPUs for the data-centers, the company hasn't lost sight of the hundreds of millions of gamers with a GeForce RTX GPU that's capable of accelerating AI faster than any NPU could by far. The company has set sights on the AI PC. It's already been running AI-based applications for gamers for over 5 years now, with DLSS, but has been consistently releasing AI-based apps, such as the most recent ChatRTX. The company is looking to make gamers' lives even more enjoyable with the magic of AI. Join us in this live blog as we unwrap NVIDIA's latest toys for gamers.[Only registered and activated users can see links. Click Here To Register...]
ASUS Announces the ROG Ally X: Improved Performance, Ergonomics, and B
ASUS today announced the ROG Ally X, its ambitious new handheld game console that's a step up from the ROG Ally that the company launched last year. The ROG Ally X is powered by the same AMD Ryzen Z1 Extreme processor as the ROG Ally, but with 50% more unified memory—now up to 24 GB of LPDDR5X-7500, which runs at an 18% higher speed than the 16 GB LPDDR5-6400 of the original. The designers also implemented an M.2-2280 NVMe SSD slot, which opens the console up to the widest possible selection of NVMe SSDs. The console includes a 1 TB drive, which is double that of the 500 GB that the ROG Ally comes with. The company has also significantly upgraded the thermal solution of the console with a larger fan, and better thermal venting, which offers 6°C lower gaming temperatures.
Perhaps the biggest feature upgrade is the battery, which is 80 Wh, a 100% increase from the 40 Wh of the original ROG Ally. This may not be a linear 100% increase in battery life from the ROG Ally (due to the various hardware upgrades), but should still pose significant improvements to it. Other hardware updates include USB4, which includes DisplayPort passthrough from the iGPU; besides a separate USB 3.2 Gen 2 type-C. The console supports USB-PD with 140 W fast-charging, and is paired with a first-party GaN-based 140 W fast-charger. Dimensions are similar to those of the ROG Ally, except for 4 mm added thickness, and 70 g added weight (608 g vs. 678 g). Available from July, the ROG Ally X is priced at $799, and includes a 3-month Xbox Game Pass. We went hands on with the console at ASUS's pre-Computex event. Stay tuned for several more announcements form the company in the coming days.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
