SilverStone Intros XE360-TR5 AIO CPU Cooler for Ryzen Threadripper 700
SilverStone today introduced the XE360-TR5, an all-in-one liquid CPU cooler for AMD Ryzen Threadripper 7000-series processors in the Socket TR5 and SP6 packages. The cooler's design consists of a 1U-friendly waterblock, and a 360 mm radiator that integrates the pump and coolant reservoir, which is connected to the block over Nylon-sleeved tubing. The block features a nickel-plated copper main material, with metal alloy top. The cold-plate makes contact with the entire IHS of an sTR5/SP6 processor, providing cooling to all twelve CCDs and the large central sIOD. The pump integrated with the radiator is made as thin as possible using a 6-pole motor.
The 360 mm x 120 mm radiator is 28 mm-thick, and is made of aluminium, and connects to the water block over a 42 cm-long tubing. Each of the three included 120 mm fans turns at speeds ranging between 600 RPM to 2,800 RPM, pushing up to 87.72 CFM of airflow, at a radiator-friendly 3.09 mm H₂O static pressure, and 46 dBA maximum noise output. The company didn't reveal pricing.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Starfield's Next Big Update Comes May 15 With Improvements Galore
Bethesda had already promised a big update for Starfield, and yesterday, it announced all the goodies to come, including the May 15th launch date. The May Update, as it is called, will bring detailed surface maps, new gameplay difficulty options, new display settings, new features for ship customizations, and more, as well as an extensive list of bug fixes.
According to Bethesda, the Starfield May Update comes with improved surface maps, new gameplay options which allow fine-tuning for those looking for an extra challenge or want to make certain aspects of the game a bit easier, and a new Ship Decoration mode for the interior of ships that now allows players to decorate the ship in the same way as outposts. The update also adds tabs to container menus for easier inventory management, adds an ability to change traits and appearance after entering the Unity, a new Dialogue camera toggle in settings, and new display settings for the Xbox Series X.[Only registered and activated users can see links. Click Here To Register...]
(PR) Alphacool Launches New Eisblock Aurora 180° Terminal
With the new Alphacool Eisblock Aurora 180° terminal, you can give your Eisblock Aurora GPU cooler a new look and gain additional options for connecting your Eisblock Aurora GPU cooler to your water cooling circuit. The Alphacool Aurora 180° terminal allows flexible connection options for all Eisblock GPU coolers. Perfect for extensive modding projects or for systems with limited space. The elegant design is perfected by a magnetic cover.
Flexible connections
The Alphacool Eisblock Aurora 180° terminal replaces the standard terminal of the Eisblock GPU cooler. It positions the connections above the backplate, significantly reducing the depth of the cooling block. With three possible connection options for each input and output - top, side and rear - the terminal offers maximum flexibility.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) SK hynix Presents CXL Memory Solutions Set to Power the AI Era at
SK hynix participated in the first-ever Compute Express Link Consortium Developers Conference (CXL DevCon) held in Santa Clara, California from April 30-May 1. Organized by a group of more than 240 global semiconductor companies known as the CXL Consortium, CXL DevCon 2024 welcomed a majority of the consortium's members to showcase their latest technologies and research results.
CXL is a technology that unifies the interfaces of different devices in a system such as semiconductor memory, storage, and logic chips. As it can increase system bandwidth and processing capacity, CXL is receiving attention as a key technology for the AI era in which high performance and capacity are essential. Under the slogan "Memory, The Power of AI," SK hynix showcased a range of CXL products at the conference that are set to strengthen the company's leadership in AI memory technology.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Prepares Core Ultra 9 285K, Core Ultra 7 265K, and Core Ultra 5
Hardware leaker Raichu, known for accurately predicting Intel's moves, has unveiled intriguing details about the company's forthcoming desktop CPU lineup. According to the leaks, Intel is supposed to introduce a big shift in its desktop CPU naming convention with the arrival of the Core Ultra 200 series, codenamed Arrow Lake-S. This next-generation lineup promises to deliver one of the most significant performance leaps for desktop processors in recent years, marking a substantial departure from Intel's current naming strategy—a change that hasn't been witnessed in over a decade. The Core Ultra 200 series is expected to encompass a diverse range of tiers and variants, catering to various user needs. This includes the overclockable K models for enthusiasts, F variants without integrated graphics, and potentially low-power T models for energy-efficient SKUs. According to Raichu's leaks, the unlocked K-Series models are rumored to include the high-end Core Ultra 9 285K, the mid-range Core Ultra 7 265K, and the budget-friendly Core Ultra 5 245K. While the absence of a 290K part has raised eyebrows, these names resemble Intel's mobile CPU naming conventions.
To enjoy the Core Ultra 200 series, users will need to upgrade to new motherboards featuring the 800-series chipsets and the LGA-1851 socket. Unlike the Core Ultra 200V Lunar Lake models for mobile devices, details about the desktop version have remained scarce, shrouding the impending launch in an air of mystery. While Raichu's leaks carry significant weight, it's essential to approach such information cautiously. There's a possibility that SKUs like the 290K may still be introduced, as a new KS version, aligning with Intel's traditional naming conventions. The Core Ultra 200 series promises to cater to a wide range of desktop users, from the performance-hungry enthusiasts eyeing the Core Ultra 9 285K to budget-conscious consumers seeking the value proposition of the Core Ultra 5 245K. The Core Ultra 7 265K is expected to strike a balance between performance and affordability, targeting the mid-range segment. As more leaks and official information surface, we will continue to provide updates on this release from Intel.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) BenQ Debuts Newly Redesigned 24-inch Photography Monitor
BenQ, a global leader in display technology, unveiled today its newest photo and video monitor, the SW242Q. Joining BenQ's SW series, the 24.1-inch 2K monitor is designed with professional photographers and videographers in mind and features BenQ's exclusive AQCOLOR technology, third generation uniformity technology and Paper Color Sync for accurate color reproduction.
With wide gamut space at 99% Adobe RGB, 98% DCI-P3 and Display P3 along with an aspect ratio of 16:10 at a maximum resolution of 2560 x 1600, the SW242Q ensures color precision in every pixel. To achieve screen-wide color accuracy, BenQ's uniformity technology adjusts color and brightness in hundreds of sub-regions to maintain fine-tuning of the screen. The SW242Q's fine-coated panel also reduces reflections of the ambient light for less distractions, while BenQ's proprietary Paper Color Sync software helps photographers accurately and efficiently edit photos to showcase the screen-to-print transition in a preview.[Only registered and activated users can see links. Click Here To Register...]
(PR) UMC Introduces Industry's First 3D IC Solution for RFSOI, Acceler
United Microelectronics Corporation ("UMC"), a leading global semiconductor foundry, today announced the industry's first 3D IC solution for RFSOI technology. Available on UMC's 55 nm RFSOI platform, the stacked silicon technology reduces die size by more than 45% without any degradation of radio frequency (RF) performance, enabling customers to efficiently integrate more RF components to address the greater bandwidth requirements of 5G.
As mobile device manufacturers pack more frequency bands in newer generations of smartphones, the company's 3D IC solution for RFSOI addresses the challenge of integrating more RF front-end modules (RF-FEM) - critical components in devices to transmit and receive data - in a device by vertically stacking dies to reduce surface area. RFSOI is the foundry process used for RF chips such as low noise amplifiers, switches, and antenna tuners. Utilizing wafer-to-wafer bonding technology, UMC's 3D IC solution for RFSOI resolves the common issue of RF interference between stacked dies. The company has received multiple patents for this process, which is now ready for production.[Only registered and activated users can see links. Click Here To Register...]
(PR) Logitech G Celebrates the 10th Anniversary of the Iconic G502 Gam
Today, Logitech G, a brand of Logitech and leading innovator of gaming technologies and gear, is celebrating the 10th anniversary of the legendary G502 gaming mouse. In its first decade, the G502 became beloved by the gaming community for delivering unrivaled performance, innovative technologies, and unparalleled design breakthroughs for maximum comfort and incredible responsiveness, becoming the world's best-selling gaming mouse, with more than 21 million mice sold since its launch.
"The G502 has been my go-to mouse for years, and it's the perfect balance for me when it comes to getting some extra buttons while not overwhelming me. This mouse is extremely comfortable to use for extended periods of time. The G502 has a sleek and cool-looking design. It has always been an incredible go-to for gamers who want a couple of extra, easy-to-reach buttons and a smooth experience that allows them to game without interruption!" said Meg Kaylee, a popular gaming streamer and producer who has been using a G502 since 2019.[Only registered and activated users can see links. Click Here To Register...]
(PR) SK hynix CEO Says HBM from 2025 Production Almost Sold Out
SK hynix held a press conference unveiling its vision and strategy for the AI era today at its headquarters in Icheon, Gyeonggi Province, to share the details of its investment plans for the M15X fab in Cheongju and the Yongin Semiconductor Cluster in Korea and the advanced packaging facilities in Indiana, U.S.
The event, hosted by theChief Executive Officer Kwak Noh-Jung, three years before the May 2027 completion of the first fab in the Yongin Cluster, was attended by key executives including the Head of AI Infra Justin (Ju-Seon) Kim, Head of DRAM Development Kim Jonghwan, Head of the N-S Committee Ahn Hyun, Head of Manufacturing Technology Kim Yeongsik, Head of Package & Test Choi Woojin, Head of Corporate Strategy & Planning Ryu Byung Hoon, and the Chief Financial Officer Kim Woo Hyun.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Sins of a Solar Empire II to Release on Steam this Summer
The battle for galactic supremacy continues as Stardock and Ironclad Games will bring Sins of a Solar Empire II to Steam this Summer. Sins of a Solar Empire II seamlessly combines real-time strategy and 4X depth, delivering sprawling empires, huge tactical fleet battles, and unforgettable gameplay moments that can only be found in Sins II. Interested players can add the game to their wishlists now.
In Sins of a Solar Empire II, players must guide their faction against the threat of extinction with three distinct races: the Trader Emergency Coalition, the Vasari Empire, or the Advent Unity. Each race has been updated with their own asymmetric playstyle including unique starting conditions, units, abilities, and game-changing Empire Systems.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) PCI-SIG Announces CopprLink Cable Specifications for PCIe 5.0 and
PCI-SIG, the organization responsible for the widely adopted PCI Express (PCIe) standard, today announced the release of the CopprLink Internal and External Cable specifications. The CopprLink Cable specifications provide signaling at 32.0 and 64.0 GT/s and leverage well-established industry standard connector form factors maintained by SNIA.
"The CopprLink Cable specifications integrate PCIe cabling seamlessly with the PCIe electrical base specification, providing longer channel reach and topological flexibility," said Al Yanes, PCI-SIG President and Chairperson. "The CopprLink Cables are intended to evolve with the same connector form factors, scale for future PCIe technology generations and meet the demands of emerging applications. The Electrical Work Group has already begun pathfinding work on CopprLink Cables for PCIe 7.0 technology at 128.0 GT/s, showcasing PCI-SIG's commitment to the CopprLink Cable specifications."[Only registered and activated users can see links. Click Here To Register...]
