NVIDIA GeForce RTX 3050 6GB Formally Launched
NVIDIA today formally launched the GeForce RTX 3050 6 GB as its new entry-level discrete GPU. The RTX 3050 6 GB is a significantly different product from the original RTX 3050 that the company launched as a mid-range product way back in January 2022. The RTX 3050 had originally launched on the 8 nm GA106 silicon, with 2,560 CUDA cores, 80 Tensor cores, 20 RT cores, 80 TMUs, and 32 ROPs; with 8 GB of 14 Gbps GDDR6 memory across a 128-bit memory bus; these specs also matched the maximum core-configuration of the smaller GA107 silicon, and so the company launched the RTX 3050 based on GA107 toward the end of 2022, with no change in specs, but a slight improvement in energy efficiency from the switch to the smaller silicon. The new RTX 3060 6 GB is based on the same GA107 silicon, but with significant changes.
To begin with, the most obvious change is memory. The new SKU features 6 GB of 14 Gbps GDDR6, across a narrower 96-bit memory bus, for 168 GB/s of memory bandwidth. That's not all, the GPU is significantly cut down, with just 16 SM instead of the 20 found on the original RTX 3050. This works out to 2,048 CUDA cores, 64 Tensor cores, 16 RT cores, 64 TMUs, and an unchanged 32 ROPs. The GPU comes with lower clock speeds of 1470 MHz boost, compared to 1777 MHz on the original RTX 3050. The silver lining with this SKU is its total graphics power (TGP) of just 70 W, which means that cards can completely do away with power connectors, and rely entirely on PCIe slot power. NVIDIA hasn't listed its own MSRP for this SKU, but last we heard, it was supposed to go for $179, and square off against the likes of the Intel Arc A580.[Only registered and activated users can see links. Click Here To Register...]
(PR) Gigabyte Launches the GeForce RTX 40 EAGLE OC ICE Series Graphics
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of premium gaming hardware, today launches the GeForce RTX 40 EAGLE OC ICE series graphics cards powered by NVIDIA ADA Lovelace architecture. The latest EAGLE OC ICE series presents a white iteration of the well-received EAGLE OC graphics card series. With exceptional performance catering to the diverse requirements of gamers, creators, and AI developers, it features an extensive integration of white materials in its design. This introduces an alternative choice for gamers who appreciate white-themed setups.
GIGABYTE has introduced four models in the GeForce RTX 40 EAGLE OC ICE series, corresponding to the GeForce RTX 4070 Ti SUPER, GeForce RTX 4070 SUPER, GeForce RTX 4060 Ti, and GeForce RTX 4060 GPUs. The EAGLE OC ICE series features a brand-new white exterior design inspired by space technology and incorporates futuristic design elements. The graphics cards come with white covers and backplates, complemented by cosmic-themed graphics, symbols, and geometric shapes, providing a unique and personalized appearance for white-themed desktop setups.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Gigabyte Launches GeForce RTX 3050 6G graphics cards
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of premium gaming hardware, today announced new GeForce RTX 3050 6G graphics cards. The GeForce RTX 3050 EAGLE OC 6G and GeForce RTX 3050 OC Low Profile 6G graphics cards are powered by Ampere- NVIDIA's 2nd gen RTX architecture, featuring dedicated RT cores, AI Tensor cores, and fast GDDR6 graphics memory. They deliver the most realistic ray tracing graphics and advanced AI features with DLSS. In addition to providing gamers with a visually stunning and smooth 1080p gaming experience, creators can also indulge in the joy of creative expression.
The GIGABYTE GeForce RTX 3050 EAGLE OC 6G graphics card incorporates futuristic design elements, presenting distinctive and personalized features through cosmic-themed graphics, symbols, and geometric shapes. The GIGABYTE GeForce RTX 3050 EAGLE OC 6G is equipped with the GIGABYTE WINDFORCE cooling system. Featuring unique blade fans, alternate spinning, and fan stop functionalities, this cooling system efficiently lowers the working temperature of the graphics card, ensuring stable performance even under high-demand operations.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Alphacool Announces Seamless RTX 4080 SUPER Compatibility
Alphacool confirms the first cooling blocks that are compatible with the new RTX 4080 Super models. Thanks to the particularly filigree fin structure, the cooling surface has been enlarged and a very good water flow has been achieved. The jet plate with revised inflow distributes the water perfectly over the cooling fins. This means that the enormous waste heat from the new generation of graphics cards is dissipated excellently with the cooler. The full-surface chrome plating of the copper base not only offers resistant protection against acids, scratches and damage, but also achieves a beautiful homogeneity and a striking shine.
In addition to the technical improvements, the Eisblock has been given a facelift: The Aurora design is kept visually calm and simple, as only one O-ring runs around the entire cooler. The design of the cooling fins and the jetplate also ensures a clean look. Thanks to the chrome plating, the illumination using digitally addressable RGB LEDs spreads evenly throughout the cooler.[Only registered and activated users can see links. Click Here To Register...]
Scythe Unveils Mugen 6 and Mugen 6 Black Edition CPU Coolers
Scythe unveiled the 6th generation of its Mugen line of premium air CPU coolers. These include the Mugen 6, and Mugen 6 Black Edition. The Mugen 6 features chrome finished aluiminium fins and nickel-plated copper heatpipes; while the Mugen 6 Black Edition is a more premium variant, with all-black fins, heatpipes, and two included fans for push-pull ventilation, instead of just one in the Mugen 6.
Both coolers feature a large aluminium fin-stack, to which heat drawn from a nickel-plated copper base is conveyed by six 6 mm-thick heatpipes. This is ventilated by a 120 mm Scythe Wonder Tornado 120 PWM fan that features a fluid-dynamic bearings, turns at speeds of up to 2,000 RPM, pushing up to 60.29 CFM of airflow, with up to 2.45 mm H₂O static pressure, and up to 26.88 dBA noise output. The Black Edition includes two of these. With the fan(s) in place, the Mugen 6 measures 132 mm x 106 mm x 154.5 mm (WxDxH), weighing 1.01 kg; while the Mugen 6 Black Edition measures 132 mm x 132 mm x 154.5 mm, weighing 1.2 kg. Among the CPU socket types supported are LGA1700, AM5, LGA1200, and AM4. The company didn't release pricing information.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) QNAP Releases the 30-bay ZFS-based All-Flash TS-h3077AFU SATA SSD
QNAP Systems, Inc., a leading computing, networking, and storage solution innovator, today introduced the TS-h3077AFU, a highly reliable 30-bay SATA 6 Gb/s all-flash SSD NAS with a ZFS-based operating system, cutting-edge AMD Ryzen Embedded 7000 Series processors and integrated AMD Radeon Graphics. With up to 1.6M/1.2M iSCSI 4K random read/write IOPS, DDR5 RAM, built-in dual-port 10/2.5 GbE, upgradability to 100 GbE, PCIe Gen 4 expandability, and scalability to petabyte-scale storage, the TS-h3077AFU meets uncompromising performance demands in 4K/8K video workflows, storage centers, and virtualization. The QuTS hero operating system also features ZFS data reduction and SSD optimization, ensuring the utmost performance, lifespan, and efficiency from all-flash investments.
"The TS-h3077AFU redefines the landscape of storage solutions, offering not just capacity but also efficiency and performance for the most demanding business environments. Its capabilities in graphics processing, connectivity, and reliability, provided by the powerful AMD Ryzen Embedded 7000 Series Processor, position it as a game-changer in the industry," said Meiji Chang, General Manager of QNAP.[Only registered and activated users can see links. Click Here To Register...]
(PR) Raytheon works with AMD to develop next-gen Multi-Chip Package
Raytheon, an RTX business, has been awarded a $20 million contract through the Strategic and Spectrum Missions Advanced Resilient Trusted Systems (S2MARTS) consortium to develop a next-generation multi-chip package for use in ground, maritime and airborne sensors. Under the contract, Raytheon will package state-of-the-art commercial devices from industry partners like AMD to create a compact microelectronics package that will convert radio frequency energy to digital information with more bandwidth and higher data rates. The integration will result in new system capabilities designed with higher performance, lower power consumption and reduced weight.
"By teaming with commercial industry, we can incorporate cutting-edge technology into Department of Defense applications on a much faster timescale," said Colin Whelan, president of Advanced Technology at Raytheon. "Together, we will deliver the first multi-chip package that features the latest in interconnect ability - which will provide new system capabilities to our warfighters."[Only registered and activated users can see links. Click Here To Register...]
NVIDIA Readying H20 AI GPU for Chinese Market
NVIDIA's [Only registered and activated users can see links. Click Here To Register...] AI GPU was rolled out last year to appease the Sanction Gods—but later on, the US Government deemed the cutdown "Hopper" part to be far too potent for Team Green's Chinese enterprise customers. Last October, newly amended export conditions banned sales of the H800, as well as the slightly older (plus similarly gimped) A800 "Ampere" GPU in the region. NVIDIA's engineering team returned to the drawing board, and developed a new range of compliantly weakened products. An [Only registered and activated users can see links. Click Here To Register...] suggests that Team Green is taking pre-orders for a refreshed "Hopper" GPU—the latest China-specific flagship is called "HGX H20." NVIDIA web presences have not been updated with this new model, as well as Ada Lovelace-based L20 PCIe and L2 PCIe GPUs. Huawei's competing Ascend 910B is said to be slightly more performant in "some areas"—when compared to the H20—according to insiders within the distribution network.
The leakers reckon that NVIDIA's mainland distributors will be selling H20 models within a price range of $12,000 - $15,000—Huawei's locally developed Ascend 910B is priced at 120,000 RMB (~$16,900). One Reuters source stated that: "some distributors have started advertising the (NVIDIA H20) chips with a significant markup to the lower end of that range at about 110,000 yuan ($15,320). The report suggests that NVIDIA refused to comment on this situation. Another insider claimed that: "distributors are offering H20 servers, which are pre-configured with eight of the AI chips, for 1.4 million yuan. By comparison, servers that used eight of the H800 chips were sold at around 2 million yuan when they were launched a year ago." Small batches of H20 products are expected to reach important clients within the first quarter of 2024, followed by a wider release in Q2. It is believed that mass production will begin around Spring time.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Korea Quantum Computing Signs IBM watsonx Deal
IBM has announced (on January 29) that Korea Quantum Computing (KQC) has engaged IBM to offer IBM's most advanced AI software and infrastructure, as well as quantum computing services. KQC's ecosystem of users will have access to IBM's full stack solution for AI, including watsonx, an AI and data platform to train, tune and deploy advanced AI models and software for enterprises. KQC is also expanding its quantum computing collaboration with IBM. Having operated as an IBM Quantum Innovation Center since 2022, KQC will continue to offer access to IBM's global fleet of [Only registered and activated users can see links. Click Here To Register...] quantum systems over the cloud. Additionally, IBM and KQC plan to deploy an [Only registered and activated users can see links. Click Here To Register...] on-site at KQC in Busan, South Korea by 2028.
"We are excited to work with KQC to deploy AI and quantum systems to drive innovation across Korean industries. With this engagement, KQC clients will have the ability to train, fine-tune, and deploy advanced AI models, using IBM watsonx and advanced AI infrastructure. Additionally, by having the opportunity to access IBM quantum systems over the cloud, today—and a next-generation quantum system in the coming years—KQC members will be able to combine the power of AI and quantum to develop new applications to address their industries' toughest problems," said Darío Gil, IBM Senior Vice President and Director of Research. This collaboration includes an investment in infrastructure to support the development and deployment of generative AI. Plans for the AI-optimized infrastructure includes advanced GPUs and IBM's Artificial Intelligence Unit (AIU), managed with Red Hat OpenShift to provide a cloud-native environment. Together, the GPU system and AIU combination is being engineered to offer members state-of-the-art hardware to power AI research and business opportunities.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Tianbo GOD88 Mini PC Listed in China, Sports Ryzen 7 8845HS APU & "Cyb
Tianbo has prepared a very an intriguing Cyberpunk 2077-themed Mini PC for the Chinese gaming hardware market—the [Only registered and activated users can see links. Click Here To Register...] (as reported by [Only registered and activated users can see links. Click Here To Register...]) showcases black and white enclosures with a sci-fi aesthetic and plenty of RGB lighting courtesy of the slimline internal cooling solution's illuminated 9 cm fan. It is not immediately clear whether [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...] have jointly approved the GOD88 Mini PC's prominent usage of their Cyberpunk title/logo/font. The specification sheet and accompanying imagery place emphasis on the Cyber GOD88's APU of choice: an [Only registered and activated users can see links. Click Here To Register...] mobile processor—this sits at second place within Team Red's [Only registered and activated users can see links. Click Here To Register...], their [Only registered and activated users can see links. Click Here To Register...] chip takes principal position here.
The GOD88's Ryzen 7 8845HS APU is no slouch when compared to the Ryzen 9 sibling—it runs the same 8-core/16-thread configuration, with a 5.1 GHz max boost (only trailing behind by 100 MHz). The spec sheet mentions a configurable TDP of 35 - 54 W. Tianbo's Mini PC is sold as a barebones system, according to the JD.com product page—customers are expected to plug in their own choice of RAM and storage. Dual-channel DDR5-5600 memory is supported, while the cramped interior can accommodate a single full-sized M.2 2280 PCIe 4×4 SSD. The Tianbo GOD88 "High Performance" Cyberpunk Mini PC will be open to pre-orders (via JD.com) on February 5—barebones pricing is set at 2688 RMB (~$378.50).[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) GeForce NOW Celebrates Fourth Birthday, 27 New Titles Added to Ca
[Only registered and activated users can see links. Click Here To Register...] is celebrating its fourth anniversary all month—plus an extra day for leap year—during February's GFN Thursdays, with 2 new games joining the cloud. Keep an eye out for more new games and other announcements for members to come. Diablo IV and Overwatch 2 heat up the cloud this GFN Thursday to kick off the anniversary celebrations. They're the next Activision and Blizzard games to join GeForce NOW as part of the [Only registered and activated users can see links. Click Here To Register...], following [Only registered and activated users can see links. Click Here To Register...].
The titles join the RAGE franchise as part of five new games joining the ever-expanding GeForce NOW library this week. Follow the #4YearsofGFN celebration and get the latest cloud gaming news on the newly launched GeForce NOW [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...] channels. Use #GFNShare and tag these accounts for a chance to be featured.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
