(PR) MOUNTAIN Launches Ultra-Soft Plateau Palm Rest with Cooling Gel L
MOUNTAIN, creator of innovative, premium peripherals with user-centric design to enable gamers and content creators to perform at their best, expands its lineup of keyboard accessories with the launch of Plateau. Championing MOUNTAIN's mantra, Plateau excels at improving keyboard ergonomics to combat fatigue, muscle tension or strained ligaments during long hours of working or gaming. Available in two sizes, Plateau offers memory foam padding underneath a soft fabric surface, effectively alleviating pressure points and improving the user's well-being.
Surrounding the memory foam is a layer of cooling gel that helps with the dissipation of body heat. An anti-slip rubber base ensures a sturdy and reliable stand at all times, while the stitched edges round off the stylish minimalistic design. Its two size options, S and L, make Plateau a great fit for most 60-100% layout keyboards and even many notebooks, making it a truly universal solution to the ergonomic needs of gamers and content creators.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Leaked AMD Radeon RX 7700 & RX 7800 GPU Benchmarks Emerge
A set of intriguing 3DMark Time Spy benchmark results have been released by hardware leaker [Only registered and activated users can see links. Click Here To Register...]—these are alleged to have been produced by prototype Radeon RX 7700 and Radeon RX 7800 graphics cards (rumored to be based on variants of the Navi 32 GPU). The current RDNA 3 lineup of mainstream GPUs is severely lacking in middle ground representation, but Team Red is reported to be working on a number of models to [Only registered and activated users can see links. Click Here To Register...]. We expect a number of leaks to emerge as we get closer to a rumored product reveal scheduled for late August (to coincide with Gamescon).
The recently released 3DMark Time Spy scores reveal that the alleged Radeon RX 7700 candidate scored 15,465 points, while the RX 7800 achieved 18,197 points—both running on an unspecified test system. The results (refer to the [Only registered and activated users can see links. Click Here To Register...]-produced chart placed below) are not going to generate a lot of excitement at this stage when compared to predecessors and some of the competition—evaluation samples are not really expected to be optimized to a great degree. We hope to see finalized products with decent drivers putting in a good appearance and performing better later on this year.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Plugable Launches UD-4VPD, a USB4 Dual 4K HDMI Docking Station
Vibrant and immersive visuals come standard with Plugable's USB4 Dual 4K HDMI Docking Station ([Only registered and activated users can see links. Click Here To Register...]), one of the first docks on the market to support dual HDMI displays at up to 4K 120 Hz. But pristine display properties are only part of the proposition offered up by the UD-4VPD. In addition to the 11-port expansion, it supplies 100 W charging for your laptop and 20 W high-speed charging for your phone, tablet, or other USB-C peripherals.
Immersive Display Options
Leveraging the latest chipsets, the UD-4VPD delivers smooth and fluid images that are great for video editing, graphic rendering, gaming, and getting work done. The docking station can also support a single 8K display at 60 Hz to complement a wide range of professional and creative applications.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Glorious Adds Polychroma RGB Set to Keycap Collection
LET THERE BE LIGHT! Introducing the brightest addition to the Glorious keycap collection: Polychroma RGB. These Cherry profile keycaps are made with translucent polycarbonate for evenly diffused lighting and a rich typing experience. [Only registered and activated users can see links. Click Here To Register...]. Get front row seats to the light show!✨
POLYCHROMA RGB KEYCAPS
Illuminate your board with vibrant RGB goodness thanks to its translucent design.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel 14th Gen Core K-series Specs Leaked
[Only registered and activated users can see links. Click Here To Register...] claims to have obtained full specifications of Intel's upcoming 14th Gen Core series—the site kicked things off by releasing details of a trio of Raptor Lake Refresh K-series SKUs earlier today. Insiders have seemingly divulged fairly comprehensive specs for i9-14900K, i7-14700K, and i5-14600K desktop CPUs. The expected lineup-wide implementation of greater clock speeds (+200 MHz) is present on these examples according to the leaked info—i9-14900K is reportedly capable of boosting up to 6.0 GHz (via Thermal Velocity tech), while its Core i7 and Core i5 siblings are said to be hitting 5.6 GHz and 5.3 GHz (respectively).
The Core i7-14700K seems to be the only rumored model to receive a core count increase—the listed 8P+12E configuration is decked out with more Gracemont efficiency cores when compared to the 13th Gen equivalent's makeup (i7-13700K, 8P+8E). This grants a slightly increased pool of Intel's "Smart Cache"—33 MB instead of the previous gen model's 30 MB. These 125 W TDP "K" SKUs are expected to arrive mid-October alongside "KF" models (lacking iGPUs). The 65-W non-K lineup could be presented at the next CES, and launched in January 2024.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Razer Unveils New BlackWidow V4 and BlackWidow V4 X
Earlier this year we introduced the award-winning Razer BlackWidow V4 Pro. It set a new benchmark for our mission in crafting keyboards that truly enhance and immerse you in your gaming world. Today, we are expanding on that success, with the introduction of the Razer BlackWidow V4 and BlackWidow V4 X.
Designed with an emphasis on advanced control and immersive gaming, the BlackWidow V4 and V4 X feature proprietary Razer Mechanical Switches Gen-3. Our Green Clicky Switches are well-loved by Razer fans for their precise execution with a clicky, tactile feel, while our Yellow Mechanical Switches are favored for quick execution that's smooth and silent, ensuring an optimized gaming experience tailored to individual playstyles. Both keyboards come with a choice of either switch.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Gainward Unveils The New GeForce RTX 4060 Ti 16GB Panther
As the leading brand in the enthusiastic graphics market, Gainward proudly presents the brand-new GeForce RTX 4060 Ti Panther video card, powered by NVIDIA's Ada Lovelace GPU architecture.
The GeForce RTX 4060 Ti lets you take on the latest games and apps with the ultra-efficient NVIDIA Ada Lovelace architecture. Shunning all the bells and whistles, the Gainward GeForce RTX 4060 Ti Panther OC 16 GB presents itself in a sleek black finish with simple line patterns that add a touch of dynamics in the darkness. The minimalist design allows it to seamlessly blend into any builds. Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Palit Announces GeForce RTX 4060 Ti 16GB JetStream Series
Palit Microsystems Ltd. as the leading graphics card manufacturer is excited to announce the GeForce RTX 4060 Ti 16 GB version JetStream Series built with the ultra-efficient NVIDIA Ada Lovelace architecture. The GeForce RTX 4060 Ti 16 GB is an enhanced iteration of its predecessor, the RTX 4060 Ti 8 GB. With its doubled memory capacity, the new 16 GB variant provides users with abundant power to tackle graphically demanding games. Furthermore, users can fully leverage game-changing technologies such as NVIDIA DLSS 3, NVIDIA Reflex, real-time ray tracing, and more.
Sedate, silent, yet powerful. The Palit GeForce RTX 4060 Ti 16 GB JetStream fashioned in jet-black with geometric block patterns demonstrates a performance-focused design that remains the essences to achieve any gaming and creator application. Restrained from flashy lights, the JetStream reveals the philosophy of Less is More. Its stealthy approach intends to suit users who prefer function over form, or fancy to keep their pcs in dark presence.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) EK Launches New EK-Quantum Power² Kits for LGA1700 and AM5
EK, the leading manufacturer of premium liquid cooling equipment, is introducing the all-new EK-Quantum Power² Kits. These kits come equipped with full D-RGB support, feature an extensive range of award-winning Quantum Line products that share the same design language, and pack various supplementary accessories. The new Kits are aimed at enthusiasts who have powerful PC hardware and seek high-end cooling solutions without having to pick custom loop parts themselves.
With the inclusion of extra accessories, these Quantum Power² kits simplify the loop-building process, making it a hassle-free experience. Some added benefits include D-RGB lighting for customizable RGB effects, a dye pack to create a unique coolant color, two 90-degree rotary fittings, reservoir tube clamps for alternative mounting options, and much more.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Framework Laptop 16 Can be Pre-ordered Now
We're excited to share that [Only registered and activated users can see links. Click Here To Register...] are now open, with configurations powered by the latest AMD Ryzen CPUs and AMD Radeon GPUs. This is truly a notebook like no other: thin and refined, while empowering you with desktop PC-level customization, repairability, and upgradability, including a fully reconfigurable input deck and modular discrete graphics. Prices start at $1399 USD for DIY Edition and $1699 USD for pre-built systems with Ryzen 7 7840HS, and adding an AMD Radeon RX 7700S Graphics Module brings starting prices to $1799 and $2099 USD.
Pre-orders that include a Graphics Module with an eligible AMD Radeon GPU will receive a free download code for one of the biggest games of the year: Starfield Premium Edition. Quantities are limited, and we'll be sending out the code prior to the game's early access launch.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Relic Hunter Legend Closed Beta Rolling Out on Thursday
Gearbox Publishing and Brazil-based developer Rogue Snail are inviting players to gear up for a limited time Closed Beta of Relic Hunters Legend, an upcoming top-down looter-shooter for PC and available via Steam. Players worldwide can sign up for access and be among the first to get a glimpse of this epic adventure starting Thursday, July 20 at 9:00 AM CST and ending Monday, July 24 at 9:00 AM CST.
Relic Hunters Legend is an in-development top-down looter-shooter featuring exciting, fast-paced gameplay, a variety of powerful equipment and weapons with tons of customizable options, and a diverse cast of rowdy Rebels with different skills and abilities that you can fine tune to match any playstyle! Watch the new gameplay trailer below. Find more details in the blog post [Only registered and activated users can see links. Click Here To Register...]. Players can sign up for access to the Closed Beta on Steam [Only registered and activated users can see links. Click Here To Register...].[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Portal: Prelude RTX Available Today
Portal remains a timeless classic; in December we released Portal with RTX, a fully ray-traced reimagining of Valve's award winning game, which used the performance multiplication of NVIDIA DLSS 3 to power the most realistic path-traced lighting ever seen in a real-time game. Portal with RTX was created using NVIDIA RTX Remix, a free, upcoming modding platform built on NVIDIA Omniverse, which enables modders to quickly create and share #RTXON mods for classic games, each with enhanced materials, full ray tracing, NVIDIA DLSS 3, and NVIDIA Reflex.
Now, RTX Remix has been used to remaster Portal: Prelude, the highest rated Portal mod, the 2008 Portal ModDB winner, and #3 overall Player's Choice mod of 2008. Created by Nicolas "NykO18" Grevet and others, Portal: Prelude is an unofficial Portal prequel, set before the time of GLaDOS, featuring a new extremely challenging 8-10 hour campaign composed of 19 new test chambers, new advanced gameplay mechanics, a fully voiced story with NPCs, and a whole lot more. Portal: Prelude RTX is available today to download from Steam, for free![Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
URCDKeys Presents Summer Sale—Great Deals on Genuine Software
URCDKeys, a leading international merchant of genuine, globally-valid software, turns up the heat this Summer, with great deals on discount genuine software that you can use to maximize your hardware budget for your Summer gaming PC build. Get Genuine Windows 11 Pro at just $19.84. Be sure to pair it with Genuine Office 2021 Professional Plus, which is going for $59.42 on its own. Start saving!
Please use the coupon code TPUP on the following item to avail the prices you see here.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
ASUS Readies Evangelion-themed ROG Product Line
ASUS is readying a wider range of Evangelion-themed ROG product line, building on the collaboration the company built with the popular Japanese action anime in 2022. The 2023 lineup is comprehensive, and includes a special Evangelion edition of the ROG Maximus Z790 Hero motherboard, special edition variants of GeForce RTX 40-series ROG Strix graphics cards (could be anything from the RTX 4070 thru RTX 4090), a special edition ROG Hyperion GR701 case, themed ROG Ryujin II AIO CPU cooler, a themed ROG Thor ATX 3.0 power supply, and lastly, keycap and body panel sets for its various ROG gaming peripherals. ASUS is planning to showcase the 2023 Evangelion lineup at Bilibili World, later this month.[Only registered and activated users can see links. Click Here To Register...]
(PR) Cooler Master Unveils the GX III Gold Series ATX 3.0 PSUs
Cooler Master, a leading innovator in PC Hardware, today announced the launch of its GX III Gold series of power supply units (PSUs). Available at 650 W, 750 W, and 850 W, these PSUs feature a sleek, streamlined design, a highly durable 12VHPWR cable and ATX 3.0 compatibility, supporting the most powerful graphics cards in the industry.
Designed for power users, enthusiasts and custom builders, the GX III Gold builds on the legacy of Cooler Master's GX series. This innovative PSU offers all-new material and structural design, fully modular cabling and optimized thermal performance. Boasting 80 Plus Gold and efficiency certifications, as well as 80 Plus Titanium-level efficiency at light loads, the GX III Gold series is the best PSU in its class.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Witness the Perils of Rubicon 3 in a New Armored Core VI Story Trailer
The new story trailer for [Only registered and activated users can see links. Click Here To Register...] shows players the exciting and dangerous world awaiting them. The realities of turning a profit on Rubicon 3 are fraught with peril, especially when Handler Walter is involved. Watch as Walter's Hounds execute their mission with ruthless tenacity and get a glimpse of the events that will lead up to the beginning of ARMORED CORE VI FIRES OF RUBICON.
Combining FromSoftware's longstanding expertise in mech games with their signature action gameplay, ARMORED CORE VI FIRES OF RUBICON brings a brand-new action experience to the series. A new game based on the concept of the ARMORED CORE series that uses the knowledge gained from FromSoftware's recent action game development.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Dolphin Emulator Dev Comments on Steam Removal Controversy
Well that blew up, huh? If you follow emulation or just gaming on the whole, you've probably heard about the [Only registered and activated users can see links. Click Here To Register...] release and the Wii Common Key. There's been a lot of conclusions made, and while we've wanted to defend ourselves, we thought it would be prudent to contact lawyers first to make sure that our understanding of the situation was legally sound. That took some time, which was frustrating to ourselves and to our users, but now we are educated and ready to give an informed response.
We'd like to thank Kellen Voyer of [Only registered and activated users can see links. Click Here To Register...] for providing us with legal council for this matter. And to be clear, all of the analysis below is specifically regarding US law. Without further delay, let's begin.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) NVIDIA GeForce NOW Library Updated with Xenonauts 2, Viewfinder & Techtonica
It's a party this GFN Thursday with several newly launched titles streaming on GeForce NOW. Revel in gaming goodness with Xenonauts 2, Viewfinder and Techtonica, among the four new games joining the cloud this week. Portal fans, stay tuned—the [Only registered and activated users can see links. Click Here To Register...] will be streaming on GeForce NOW to members soon. Plus, find out how members can score an upcoming Guild Wars 2 premium reward.
Get 'Em While They're Hot!
Choose from over 1,600 games in the GeForce NOW library, starting off with the titles making their cloud debut. Be among the first to experience Xenonauts 2, Viewfinder and Techtonica from a high-performance GeForce RTX gaming rig in the cloud, without worrying about download times or system specs.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Might & Magic: Clash of Heroes - Definitive Edition is Out Now
Greetings Mighty Warriors of Ashan! We're glad to announce that [Only registered and activated users can see links. Click Here To Register...] is available on PC starting today with a 15% launch discount for everyone and an additional 40% discount for original owners. Please note that both discounts will be available for two weeks only. Lead your armies to victory in this addictive strategy game where every move matters!
If you've never played Might & Magic: Clash of Heroes before, here's a small introduction to this incredible gem from the past...Anwen, Godric, Fiona, Aidan, and Nadia are five mighty heroes scattered around five different regions of Ashan. After the rise of the demons, these heroes battle their way through their respective kingdoms to unravel the mysteries behind the chaos threatening their world.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) QuakeCon Renews Gaming Rig Rental Partnership with Computer Upgra
We're excited to announce that we're once again partnering with [Only registered and activated users can see links. Click Here To Register...] to provide our attendees with the ability to rent either a monitor and or a full PC set up. As an added bonus to our Elite ticket holders, Computer Upgrade King is offering a special rental package with a 34" Ultrawide Monitor! For more information, and to secure yours today, visit [Only registered and activated users can see links. Click Here To Register...].
Need a rig? Reserve your computer at [Only registered and activated users can see links. Click Here To Register...]. It's official! After three years of digital-only events, QuakeCon 2023 will mark the return of the beloved BYOC, in-person at the Gaylord Texan Resort & Convention Center in Grapevine, Texas from Thursday, August 10 through Sunday, August 13.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) PlayStation VR2 Product Manager Goes Deep into Design Process
When PlayStation VR2 released earlier this year, it offered players a chance to experience virtual game worlds bristling with detail and immersive features. PS VR2 was the culmination of several years of development, which included multiple prototypes and testing approaches. To learn more, we asked PS VR2's Product Manager Yasuo Takahashi about the development process of the innovative headset and PlayStation VR2 Sense Controller, and also gained insight into the various prototypes that were created as part of this process.
PlayStation Blog: When did development for the PS VR2 headset start?
Yasuo Takahashi: Research on future VR technology was being conducted even prior to the launch of the original PlayStation VR as part of our R&D efforts. After PS VR's launch in 2016, discussion around what the next generation of VR would look like began in earnest. We went back and reviewed those R&D findings and we started prototyping various technologies at the beginning of 2017. Early that same year, we began detailed conversations on what features should be implemented in the new product, and which specific technologies we should explore further.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Atlas Fallen Combat Showcased in Latest Trailer, Limited Edition Available to Pre-order
Today, [Only registered and activated users can see links. Click Here To Register...] and its studio [Only registered and activated users can see links. Click Here To Register...] unleashed a dangerously gripping Combat Trailer for their upcoming game Atlas Fallen, the epic fantasy action-RPG where you battle legendary creatures in superpowered combat. Releasing on August 10 on PlayStation 5, Xbox Series X|S and PC, [Only registered and activated users can see links. Click Here To Register...]. Watch the Combat Trailer now for a 5-minute deep-dive into the exhilarating action of Atlas Fallen.
Rise as the ultimate champion and shape your playstyle
In a devastated, sand-covered world, seize the divine power of a mysterious Gauntlet and wield heroic abilities to defeat a tyrannic, almighty god. Tame the sands to shape them into three powerful weapons and move through the air with incredible speed and agility. Pick an implacable duo of weapons to go into battle and use the deadliest combos in a seamless flow between them. Watch your weapon grow larger as you build Momentum to unleash the full, irrepressible power of the Gauntlet.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Phanteks Extends the Revolt Series Power Supplies in Collaboration with CableMod
Phanteks, a leading manufacturer of high-performance PC components, is thrilled to announce the expansion of its Revolt Series with the introduction of the Revolt 1000 W/1200 W Platinum and 1600 W Titanium power supplies. Phanteks' Revolt Series power supplies are designed specifically for users who desire custom cables from CableMod, offering a cable-free power supply solution that eliminates the additional cost of purchasing a traditional power supply with bundled cables. This approach ensures that users have full control over their power supply and cable selection, eliminating the clutter of unnecessary cables in their systems.
The Revolt power supplies, developed in collaboration with renowned power supply manufacturer Seasonic, adhere to the highest industry standards of performance and reliability. All models within the Revolt Series fully support and exceed the latest Intel ATX 3.0 specifications, guaranteeing compatibility and ensuring seamless integration into any system. Boasting wattage capacities of 1000 W/1200 W Platinum or 1600 W Titanium certification, the Revolt power supplies deliver abundant power for even the most demanding computing systems.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Dell Technologies Announces Intent to Acquire Moogsoft
Dell Technologies announced it has signed a definitive agreement to acquire [Only registered and activated users can see links. Click Here To Register...], an AI-driven provider of intelligent monitoring solutions that support DevOps and ITOps. This transaction will further enhance Dell's AIOps capabilities, as part of its longstanding approach of embedding AI functionality within its product portfolio and as a critical component of its "multicloud by design" strategy. The transaction is expected to close in Q3. Additional details will be available at that time.
About Moogsoft
Moogsoft is the AI-driven observability leader that provides intelligent monitoring solutions for smart DevOps. Moogsoft delivers the most advanced cloud-native, self-service platform for software engineers, developers, and operators to instantly see everything, know what's wrong and fix things faster. Founded in 2012, Moogsoft has more than 140 customers worldwide including American Airlines, Fannie Mae, Fiserv, HCL Technologies, SAP SuccessFactors, and Verizon Media. It has established strategic partnerships with leading managed service providers and outsourcing organizations including AWS, Cisco, HCL Technologies, TCS and Wipro.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Xbox Games Showcase 2023 & Starfield Direct Attracted a Record Number of Views
It's been a little over a month since fans around the world enjoyed the Xbox Games Showcase and Starfield Direct and we're delighted to say that, within seven days of the broadcast, we saw over 92 million views across our first ever double feature, trailers, and segments from the shows - a 38% rise in viewership over last year's show. It's become the highest rated and most-viewed show for Xbox, ever! We can't thank you enough for being a part of that, and we hope you're as excited as we are for Xbox's future.
From our own games - like Starfield, Forza Motorsport, Hellblade II: Senua's Saga, Fable, South of Midnight, Avowed, Clockwork Revolution, Microsoft Flight Simulator 2024, Towerborne, and more - to those coming to Xbox from our partners around the world - Star Wars Outlaws, Cyberpunk 2077: Phantom Liberty, Cities: Skylines 2, 33 Immortals, and more - our show aimed to bring something for every kind of player. Whether you're an RPG obsessive, an indie curio collector, a PC player, a console owner, or even brand-new to gaming, we like to think there was something that piqued your interest.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) AIC Launches HA401-TU, a New High-availability Server Model
AIC has launched the new high-availability storage server HA401-TU, which is optimized for mission-critical, enterprise-level storage applications. This cluster-in-a-box solution with active-active failover design and eliminates single points of failure. HA401-TU is a 4U high-availability (HA) server with 2 controller nodes and supports 24 3.5" SAS 12 Gb/s drives. Each controller node is equipped with an AIC Tucana server board that is powered by dual [Only registered and activated users can see links. Click Here To Register...] and Intel C621A chipset, which supports UPI speed up to 11.2 GT/s. HA401-TU provides enterprise users with a number of crucial benefits. The redundant hardware components ensure that there is no single point of failure.
With the hot-swappable functionality, the controller canisters protect enterprises from the loss of revenue that can occur when access to mission-critical data or applications is disrupted. Both controller nodes process data input/output (I/O) operations and users can experience simultaneous and balanced access to logical devices. In the event of failover, the secondary node will automatically take over the devices, client connections and all the processes and services running in the system. This high-availability design significantly enhances the overall performance of clusters, enabling seamless handling of demanding workloads.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) The Crew Motorfest Reveals New Porsche Playlist, Super EVs & a To
When [Only registered and activated users can see links. Click Here To Register...] launches on September 14, players will get free rein to explore the Hawaiian island of O'ahu from behind the wheel of more than 600 vehicles, including a broad array of licensed cars, jeeps, buggies, motorcycles, boats, and planes. Featuring a huge open world filled with activities and freestyle stunt opportunities, The Crew Motorfest's main attractions are its Playlists, a series of self-contained, themed campaigns that each include six to 10 events focused on a specific brand, car type, or aspect of car culture, like drift racing, classic cars, or even sightseeing.
Playlists provide you with loaner vehicles appropriate to each of their events, and completing all of a playlist's events unlocks an exclusive car for you to add to your garage. Playlist events sometimes carry special victory conditions or modifiers - in the 911 Legacy: A Porsche Story Playlist, for example, you'll earn bonuses for driving clean and keeping your car free of damage. Vintage Garage turns off your GPS minimap while you drive its classic cars, and the laid-back Hawaii Scenic Tour doesn't even require you to place in its events, only to complete them.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Remnant 2 Gameplay Showcased in Surviving the Post-Apocalypse Trailer
Need a refresher on what to expect in [Only registered and activated users can see links. Click Here To Register...]? We got you! Learn everything you need to know before you explore the depths of the unknown to stop an evil from destroying reality itself in Remnant 2 -- launching on July 25. It is the sequel to the best-selling game Remnant: From the Ashes that pits survivors of humanity against new deadly creatures and god-like bosses across terrifying worlds. Play solo or co-op with two other friends to explore the depths of the unknown to stop an evil from destroying reality itself. To succeed, players will need to rely on their own skills and those of their team to overcome the toughest challenges and to stave off humanity's extinction.
A mix of methodical and frenetic ranged/melee combat returns with cunning enemies and large scale boss battles. Choose specific gear and weapons to optimize for the different biomes and battles ahead. Bosses will bring high-level players to team up to overcome the challenge and try to obtain the biggest rewards. Players can travel alone or with friends as a team through strange new worlds and beyond, overrun by mythical creatures and deadly foes while trying to stay alive. There are multiple worlds to explore with different types of creatures, weapons, and items. Utilize and upgrade discovered items to take on tougher challenges.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
NVIDIA is Looking at Samsung for HBM3 Memory and 2.5D Chip Packaging
According to news out of Korea, NVIDIA is considering Samsung as a partner not only for HBM3 memory, but also as a potential partner when it comes to 2.5D chip packaging. The latter is due to TSMC having limited capacity when it comes to handling all of its customers advanced chip packaging needs, although Samsung is apparently not the only potential partner NVIDIA is looking at. Taiwan based SPIL and US based Amkor Technology are two alternative candidates for the 2.5D chip packaging according to the Elec.
As far as HBM3 memory goes, NVIDIA doesn't have as many potential options, with SK Hynix being its current partner, who NVIDIA will continue to work with when it comes to HBM memory for its high-end AI accelerators and GPUs. It's likely that Samsung is trying to win NVIDIA back as a foundry customer, by proving that it's capable of handling the chip packaging for NVIDIA. Samsung will likely use its I-Cube 2.5D packaging technology and the Elec suggests that Samsung would still be using TSMC made GPU wafers which will be mated with Samsung HMB3 memory. Samsung has as yet not started its mass production of HMB3 memory, but have sampled customers with evaluation samples that are said to have received very positive feedback. For now, nothing has been agreed and TSMC is, as we know, looking to expand its 2.5D packaging business by over 40 percent, but the question is how quickly TSMC can move before its customers consider other competitors.[Only registered and activated users can see links. Click Here To Register...]
(PR) AMD's CTO Discusses Founding of Ultra Ethernet Consortium
Mark Papermaster, AMD's Chief Technology Officer and Executive Vice President of Technology and Engineering announced: "Over the past 50 years, Ethernet has grown to dominate general networking. One of its key strengths is flexibility - the ability to adapt to different workloads, scale and computing environments. One of the places that it hasn't been well-known, though, is in high-performance networking environments.
Now, the [Only registered and activated users can see links. Click Here To Register...] (UEC) was formed by leading technology companies to focus on tuning the Ethernet foundation for high-performance Artificial Intelligence, Machine Learning, and High-Performance Computing (AI/ML/HPC) workloads. This includes work at the Physical, Link, Transport, and Software layers with robust security and congestion protections.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Lian-Li Launches Next Gen. of AIOs with GALAHAD II TRINITY Series
LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, launches its next generation of AIO liquid cooling, the GALAHAD II TRINITY series. 3 models are available with the GALAHAD II TRINITY, GALAHAD II TRINITY SL-INF, and GALAHAD II TRINITY PERFORMANCE
[Editor's note: Our [Only registered and activated users can see links. Click Here To Register...] is now live]
The TRINITY series comes with 3 swappable caps for personalization of the pump block and 45-degree rotary fittings at the radiator for easy tube orientation. The GALAHAD II TRINITY comes in 240 and 360 mm sizes, equipped with pre-installed RGB fans with seamless cable interconnectivity, the GALAHAD II TRINITY SL-INF comes in 240 and 360 mm sizes, equipped with pre-installed UNI FAN SL INFINITY fans and controller. The GALAHAD PERFORMANCE is available in 360 mm size, equipped with pre-installed 28 mm thick high-performance LCP fans with seamless cable interconnectivity, a 32 mm thick radiator with double wave fin design and a 4,200 RPM pump.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Overwatch 2 Coming to Steam on August 10, Blizzard Hints About Adding More IPs in the Future
As Blizzard evolves as a studio, inside and out, one of the ideas pushing us forward is meeting players around the world where they are and making our games as easy as possible to access and play. We want to give everyone a chance to experience our universes with old friends while making new ones, no matter how they choose to play.
Battle.net is the home of all our PC players, and over the years, we've evolved our platform to support updated technologies, capabilities, and our communities' expectations. But as we've evolved, the industry has evolved too-gaming is no longer just for specific communities as it was when Battle.net launched over two decades ago, gaming is for everyone-and though we remain committed to continually investing in and supporting Battle.net, we want to break down the barriers to make it easier for players everywhere to find and enjoy our games. Which is why we're trying something new...[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Silicon Box Opens US$2 Billion Advanced Semiconductor Assembly Plant i
Somewhat out of the blue, Silicon Box has announced the opening of its US$2 billion semiconductor assembly plant in Singapore. The "startup" is founded by several of Marvell's founders, suggesting the company has the right pedigree to compete in what is sure to be a very competitive market over the next few years. Silicon Box is not a foundry and will at least at this point in time, not be involved in foundry services, but instead the company will focus on advanced chip packaging technologies, focusing on chiplets.
The company is promising "faster time-to-market, lower new device design cost" on its very rudimentary website, something the company has yet to prove to be capable of. However, its new plant in Singapore covers 73,000 square metres and is said to feature state of the art production equipment for turning chiplets into chips. The factory is said to create some 1,200 jobs in Singapore, suggesting that this is a company that means business. According to a comment by company founder and CEO BJ Han to Reuters, "customers had been lining up" since before the completion of the assembly plant. Silicon Box is expecting to have several AI chipset companies as its customers, including Tenstorrent, which so far is the only officially mentioned client. Time will tell if Silicon Box can compete with established chip packaging businesses and if they can deliver on their promise to be faster and cheaper than the competition.[Only registered and activated users can see links. Click Here To Register...]
(PR) JSAUX Launches Steam Deck RGB Docking Station
Electronics brand JSAUX is celebrating its seventh anniversary during July and it has announced a new batch of Steam Deck accessories: the RGB Docking Station and the RGB transparent backplate are now available, following the release of the transparent front plate and the redesigned transparent backplate. JSAUX is also planning to release an anti-glare screen for Steam Deck later this month. More info about each product below:
The RGB docking station is the latest feature on JSAUX's family of docks for the Steam Deck. This new product features better compatibility, a total customization of the RGB lighting, and comes in two versions: 12-in-1 and 8-in-1, offering different connectivity options.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) MSI Announces Multiple New Cubi Mini PCs
MSI, a world leader in high-performance and innovative computing solutions, has recently launched its Mini PC line-up, featuring the Cubi 5, Cubi N, PRO DP10, and PRO DP21 series. This array of minis caters to the requirements of the SMB, offices, hostels, restaurants, educational institutions, medical facilities, science labs, kiosks, and more. This collection of mini computers is designed with productivity in mind and featuring a miniature chassis, powerful processor options, exclusive software, and Thunderbolt 4, the Cubi and PRO DP series have raised the bar in terms of compact computing.
Unleashing Power in a Compact Package: Cubi 5 & Cubi N
The Cubi series offers remarkable power with a small footprint of only 0.66 liters, making it effortless to access high-performance capabilities at your fingertips. Equipped with up to the latest Intel Core i7 processors, the Cubi series boasts incredible performance that rivals many full-sized desktop computers. The Cubi 5 boasts a noteworthy feature: an extensive range of connectivity options. Despite its mini size, it offers an impressive selection of ports, such as Thunderbolt 4, USB-C, HDMI, and DisplayPort. In addition, Dual Ethernet ports on both Cubi series can improve network security by keeping the internet and intranet connections separate and preventing unauthorized access. It is also a reliable backup in case one port fails as the other one will be activated immediately.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Releases Arc GPU Graphics Drivers 101.4575 as a WHQL
Intel Graphics released the Arc GPU Graphics Drivers version 101.4575 that it originally released as a beta late last week, as a WHQL. What's interesting is that while the driver version number hasn't changed when compared to the 101.4575 beta drivers from last week, the new 101.4575 comes with a different change-log. It mentions Game On (day-one) optimization for "Ratchet & Clank: Rift Apart," and "Remnant II," in addition to optimization for "Exoprimal" and "Jagged Alliance 3." that were announced last week. Besides this, the "fixed isses" and "known issues" lists between the beta and WHQL are identical.
DOWNLOAD: [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
ROG Ally Gets BIOS Update that Fixes Multiple Usability Issues
ASUS has issued a BIOS update for the ROG Ally that should help resolve multiple usability issues, most of them being fairly minor issues, but they're all quality of life improvements nonetheless. To start with, ASUS has made optimisations to the performance mode with the Ally plugged in to a power source, although the company didn't explain exactly what this means. Another minor improvement allows the "Memory Assigned to GPU" setting to be kept when updating to a new BIOS version, a setting that used to get reset prior to this BIOS release.
Another minor quality of life update is the ability to reduce the backlight to 10 nits now, down from the previous 25 nits, which should make it more comfortable to use the ROG Ally in dark rooms. Finally and possibly the most important part of this update is the ability to charge at 30 W from 65 W or higher rated USB-PD chargers. What ASUS has done here is improvements to the USB-PD "handshake" to make sure that the ROG Ally gets the right power from the power adapter. This was apparently not working as intended previously and the ROG Ally would charge at a slower rate. It should be noted that not all chargers will provide enough power to the ROG Ally, especially if other devices are charging at the same time. ASUS points out that if the battery is draining when the Ally is plugged in, a different charger should be used.[Only registered and activated users can see links. Click Here To Register...]
(PR) Cerebras and G42 Unveil World's Largest Supercomputer for AI Training with 4 ExaFLOPS
Cerebras Systems, the pioneer in accelerating generative AI, and G42, the UAE-based technology holding group, today announced Condor Galaxy, a network of nine interconnected supercomputers, offering a new approach to AI compute that promises to significantly reduce AI model training time. The first AI supercomputer on this network, Condor Galaxy 1 (CG-1), has 4 exaFLOPs and 54 million cores. Cerebras and G42 are planning to deploy two more such supercomputers, CG-2 and CG-3, in the U.S. in early 2024. With a planned capacity of 36 exaFLOPs in total, this unprecedented supercomputing network will revolutionize the advancement of AI globally.
"Collaborating with Cerebras to rapidly deliver the world's fastest AI training supercomputer and laying the foundation for interconnecting a constellation of these supercomputers across the world has been enormously exciting. This partnership brings together Cerebras' extraordinary compute capabilities, together with G42's multi-industry AI expertise. G42 and Cerebras' shared vision is that Condor Galaxy will be used to address society's most pressing challenges across healthcare, energy, climate action and more," said Talal Alkaissi, CEO of G42 Cloud, a subsidiary of G42.[Only registered and activated users can see links. Click Here To Register...]
(PR) Cadence to Acquire Rambus PHY IP Assets
Cadence Design Systems, Inc. and Rambus Inc., a premier chip and silicon IP provider making data faster and safer, today announced that they have entered into a definitive agreement for Cadence to acquire the Rambus SerDes and memory interface PHY IP business. Rambus will retain its digital IP business, including memory and interface controllers and security IP. The expected technology asset purchase also brings Cadence proven and experienced PHY engineering teams in the United States, India and Canada, further expanding Cadence's domain-rich talent base.
"Memory and SerDes IP design and integration continues to be integral to the design of AI, data center and hyperscale applications, CPU architectures and networking devices, and the addition of the Rambus IP and seasoned team further accelerates Cadence's Intelligent System Design strategy, which drives design excellence," said Boyd Phelps, senior vice president and general manager of the IP Group at Cadence. "The acquisition of the Rambus PHY IP broadens Cadence's well-established enterprise IP portfolio and expands its reach across geographies and vertical markets, such as the aerospace and defense market, providing complete subsystem solutions that meet the demands of our worldwide customers."[Only registered and activated users can see links. Click Here To Register...]
About Moogsoft
Zenbleed Vulnerability Affects All AMD Zen 2 CPUs
A new vulnerability has been discovered in AMD Zen 2 based CPUs by Tavis Ormandy, a Google Information Security researcher. Ormandy has named the new vulnerability Zenbleed—also known as CVE-2023-20593—and it's said to affect all Zen 2 based AMD processors, which means Ryzen 3000, 4000 and 5000-series CPUs, as well as EPYC server chips. The reason why Zenbleed is of concern is because it doesn't require a potential attacker to have physical access to the computer or server in question and it's said to be possible to trigger the vulnerability via executing a javascript on a webpage. This means that the attack vector ends up being massive, at least when we're talking about something like a webhosting company.
Zenbleed is said to allow a potential attacker to gain access to things like encryption keys and user logins via triggering something called "the XMM Register Merge Optimization2, followed by a register rename and a mispredicted vzeroupper". Apparently this requires some precision for the vulnerability to work, but due to these registers being used system wide, even a sandboxed attacker can gain access to them. AMD has already issued a patch for its EPYC server CPUs, which obviously are the most vulnerable systems in question and the company is planning to release patches for all of its Zen 2 based CPUs before the end of the year. Hit up the source links for more details about Zenbleed.[Only registered and activated users can see links. Click Here To Register...]
Intel Arc GPU Graphics Drivers 101.4576 Released
Intel today released the Arc GPU Graphics Drivers 101.4576 beta. These drivers do not introduce Game On (day-zero) optimizations or improvements for any new games, but address a couple of glaring issues. "Remnant 2" exhibits texture corruption during gameplay, which has been fixed. In a similar light, "World War Z" exhibits flickering textures during gameplay, which has been fixed. Intel also identified a few more issues with this release, as detailed in the release notes, below.
NVIDIA Names Melissa Lora to Board of Directors
NVIDIA today announced that it has named to its board of directors Melissa Lora, who spent three decades as an executive at Taco Bell Corp., a subsidiary of Yum! Brands, Inc., before retiring in 2018 as president of Taco Bell International.
She has also been appointed to the board's Audit Committee.
"Melissa is a great addition to our board of directors," said Jensen Huang, founder and CEO of NVIDIA. "She brings senior management and operating experience, as well as extensive finance expertise, gained in a large corporate setting. We will benefit immensely from her guidance."[Only registered and activated users can see links. Click Here To Register...]
Radeon RX 7900 GRE Confirmed to Debut New Navi 3X GPU
It turns out that the upcoming Radeon RX 7900 GRE (Golden Rabbit Edition) is built on the mysterious Navi 31 + Navi 32 hybrid GPU that's been in the news for a few weeks now. AMD has reportedly developed its answer to NVIDIA's AD103 silicon in the form of a new MCM that combines the 5 nm GCD of the "Navi 31," along with the substrate of the "Navi 32," which is physically smaller, and only has four 6 nm MCDs. This hybrid MCM could power AMD's mobile Radeon RX 7900 series. The chip physically only has a 256-bit wide GDDR6 memory interface. AMD felt the need for such a contraption as the "Navi 31" is likely too big for mobile platforms, and because the "Navi 32" GCD with its 60 CU (3,840 stream processors) might prove inadequate against a maxed out AD104 or cut-down AD103.
VideoCardz caught whiff of the new GPU by comparing the back sides of the Sapphire RX 7900 GRE from [Only registered and activated users can see links. Click Here To Register...], with that of the production Sapphire RX 7900 XT/XTX NITRO+. There are visible differences in the layout of the SMDs, and the reinforcement brace behind the GPU has a square cutout, compared to the rectangular one behind the "Navi 31" powering the RX 7900 XT/XTX NITRO+. On the RX 7900 GRE, the GCD is configured with 84 CU, or the same core-config as the RX 7900 XT, albeit with the narrower 256-bit memory interface, and 64 MB of Infinity Cache memory. It's highly likely that AMD uses this GPU to carve out the Radeon RX 7800 XT (with fewer than 84 but higher than 60 CU); while creating the RX 7800 with a maxed out "Navi 32," and the RX 7700 series with a cut-down "Navi 32" (including by narrowing the memory bus width to 192-bit by disabling one of the four MCDs). AMD is reportedly planning to launch the RX 7900 GRE in China, on July 28, 2023.[Only registered and activated users can see links. Click Here To Register...]
(PR) Sony Electronics Unveils WF-1000XM5 Truly Wireless Earbuds "For The Music"
Sony Electronics Inc. today announced the WF-1000XM5 earbuds - the latest truly wireless model of the award-winning 1000X series. This new model offers the Best Noise Canceling by reducing external noise over a wide bandwidth, from low to high frequencies so you can focus on your music. Following its predecessor, the WF-1000XM4, the WF-1000XM5 raises industry standards with astonishing sound and Sony's best ever call quality, despite a smaller and lighter design.
The WF-1000XM5 earbuds deliver cutting-edge technology and premium sound quality with the best noise-canceling performance. Real-time audio processors and high-performance mics power the specially designed driver unit, Dynamic Driver X, for wide frequency reproduction, deep bass, and more detailed vocals.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Logitech Announces First Quarter FY 2024 Results
Logitech International (SIX: LOGN) (Nasdaq: LOGI) today announced financial results for the first quarter of Fiscal Year 2024. "While the markets are still challenging, I am proud of the team's achievements during our first quarter," said Guy Gecht, Logitech interim chief executive officer. "Our high-caliber seasoned team, design-led engineering and strong execution truly sets us apart. Our latest innovations and elevated outlook are just a glimpse of Logitech's full potential as we execute our strategic vision."
"This solid first quarter highlights steady progress on many important metrics," said Charles Boynton, Logitech chief financial officer. "We delivered another quarter of reduced inventory and operating expenses while continuing to drive strong cash generation, further fortifying our balance sheet. With one quarter completed, we are pleased to provide a full-year and updated first-half outlook."[Only registered and activated users can see links. Click Here To Register...]
AMD Expected to Increase Microcode Size for Future Processor Technologies
[Only registered and activated users can see links. Click Here To Register...] has recently uncovered an intriguing Linux update, with kernel improvements being prepared to handle greater microcode payloads—they believe that "future AMD CPUs will be getting larger microcode patches." The timing could suggest that upcoming Zen 5 processors will be likely candidates to meet new requirements: "Right now the Linux kernel has a maximum microcode patch size for AMD CPUs that is three times the kernel's page size (typically 4K). But with a patch (published on July 20) that will "increase substantially" to eight times the page size. The increase is intentionally quite a magnitude larger in order to avoid future patches further having to bump the patch size limit in later generations." Earlier this month, some GitHub entries demonstrated that AMD engineers had patched Linux 6.5 with updates for "[Only registered and activated users can see links. Click Here To Register...]," which Phoronix believes to be for next-gen platforms (Zen 5): "It's also not elaborated on why the CPU microcode size will be increasing. In any event the [Only registered and activated users can see links. Click Here To Register...] to bump the AMD CPU microcode limit is now out for review. It's also marked for back-porting to existing stable kernel versions."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Sony Intros Marvel's Spider-Man 2 Limited Edition PS5 Console Bundle
What an exciting moment for PlayStation players, as the Insomniac team just wrapped up a captivating panel at San Diego Comic-Con with fantastic new reveals from Marvel's Spider-Man 2. This includes a first look at the PS5 Console - Marvel's Spider-Man 2 Limited Edition Bundle, which features a custom PS5 console cover design and matching DualSense wireless controller.
We were thrilled to debut these stunning designs to our fans today because of how they capture the look and feel of Marvel's Spider-Man 2. The threat of Venom and the symbiote will be one of the most formidable challenges that our two Spider-Men will face in Marvel's Spider-Man 2. This is why we wanted to reflect the intensity of the symbiote and its capacity for transformation and power with a takeover design for the PS5 console and DualSense wireless controller.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) The Walking Dead: Betrayal Revealed, Closed Beta Starting August 10
[Only registered and activated users can see links. Click Here To Register...] is a third-person action game of cooperation and deception for up to 8 players. Out of resources, with a herd of walkers fast approaching, players must work together to complete objectives and make their escape. They'll need to work fast, as walkers aren't the only threat.
Incognito "traitors" lurk among them, plotting to do everything in their power to delay repairs and prevent anyone from leaving. With so many creative ways to sabotage the team, the walkers are the most predictable threat. As evidence of their sabotage becomes apparent, paranoia and accusations threaten to tear the survivors apart as they desperately work towards escaping. Can you make it out alive?[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Report Suggests German Government Prepping $22 Billion Aid Package for Native Chip Production
According to a report published by [Only registered and activated users can see links. Click Here To Register...], the German government has formed plans to create €20 billion ($22 billion) of investments to aid in the growth of local semiconductor manufacturing. The article proposes that the organization is racing to bolster the country's technology sector, and is attempting to secure essential supplies of components. Various geopolitical issues have complicated matters in recent times. Funding will be made available to German and international companies, from Germany's (now diversified) Climate and Transformation reserve, over the next four years. The finance ministry responded to Bloomberg's query, and stated: "The draft for the economic plan 2024 and the financial plan until 2027 for the Climate and Transformation Fund are currently being prepared...This process has not yet been completed." Germany's economy ministry did not provide a statement/response to Bloomberg's queries.
Around 75% of the fund is reportedly set aside for multinational semiconductor firms including Intel Corporation (USA) and Taiwan Semiconductor Manufacturing Company Limited (TSMC). Bloomberg believes that Team Blue is due an allocation of €10 billion for investments in its [Only registered and activated users can see links. Click Here To Register...], located close to Magdeburg, Germany. The government is allegedly deep into talks with TSMC regarding the foundation of a proposed €10 billion production base in the Dresden area—the likes of BMW, Mercedes-Benz and Volkswagen AG would benefit greatly with quicker access to (localized) microcontrollers manufacturing facilities. The government could subsidize half of that total investment (€5 billion). Infineon is possibly in line to receive a €1 billion aid package, since it is building a new fab location in Dresden.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Arc A580 GPU Reportedly Appears in GFXBench Database
The Intel [Only registered and activated users can see links. Click Here To Register...] was revealed alongside its Alchemist siblings—A380 A750 and A770—last year, but remains the only one out of that lineup to not have reached the retail market. Things have been quiet on the Intel Arc 5-series "Advanced Gaming" front for a while now—TechPowerUp's GPU-Z utility was [Only registered and activated users can see links. Click Here To Register...] for the A580 last September, and an evaluation sample was [Only registered and activated users can see links. Click Here To Register...] a month prior to that. A supposed sample Intel Arc A580 was [Only registered and activated users can see links. Click Here To Register...] via a Vulkan-based renderer in GFXBench 5.0, perhaps not the best platform to gauge PC performance on.
Has an owner of a rare curiosity unit chosen to bench the unreleased GPU, or is a manufacturer evaluating a sample with a very delayed product launch in mind? The test results are not all that impressive, with the A580 performing poorly compared to the range-topping Arc A770 (placed in Intel's "high performance gaming" tier), although it does much better than the A380 (not a big boast). The likely prototype nature of the evaluated card or immature state of drivers could be to blame for shortcomings in GFXBench 5.0.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Techland Announces Tencent's Majority Investment in the Studio
Techland CEO Pawel Marchewka [Only registered and activated users can see links. Click Here To Register...] earlier today: "Dear Gamers, I want to share some really exciting news that will mark the start of a new chapter of Techland's history. Techland has been a huge part of my life for more than 30 years now and it is something I truly cherish. Techland is our games, the amazing team behind them, and you, the people playing these games. You're the reason why we're making them. Whenever I think about the future of Techland, I want the best for our games, the team, and you. And while I am very proud of our achievements as an independent studio over all these years, I believe the best is yet to come.
We dream of turning Dying Light into the ultimate zombie game experience for players worldwide, providing you with multiple astonishing adventures and pushing the boundaries of solo and online modes to a totally new level. Our open world action-RPG in a fantasy setting is already shaping up to become something truly special, and the goal here is to make sure it will live up to the expectations for our first new IP in almost a decade. Can we make these dreams come true? Yes, we can. But what we realized is that the best, boldest dreams can only be achieved while working side-by-side with like-minded friends and strong partners, who share the same vision, passion, and have the willingness to back it up with their knowledge, experience, and capabilities.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 9 7945HX3D Outed by ASUS ROG Laptop Specs
Tipsters have noticed that ASUS is preparing a new high-end laptop with an unannounced AMD processor—the upcoming ROG Strix SCAR 17-inch model (G733PYV-LL046W,) will apparently sport a Ryzen 9 7945HX3D APU (with 128 MB of L3 cache). The inclusion of "X3D" in the processor's name has generated a lot of interest, given that Team Red's 3D V-Cache technology has existed mainly within mainstream desktop-oriented Ryzen 7000 and 5000 processor lineups. This leaked dual-CCD APU is probably being lined up to take on upper-echelon Intel Raptor Lake-HX processors, as well as refreshed variants.
The leak indicates that this APU will likely sit at the top of the Zen 4-based Dragon Range-H lineup—being a 5.4 GHz max. boost clock, 16-core/32-thread CPU, with a configurable TDP (between 55 W and 75 W) and [Only registered and activated users can see links. Click Here To Register...] iGPU. The host ASUS ROG Strix SCAR 17 laptop is no slouch thanks to some very generous hardware specifications, including a mobile NVIDIA RTX 4090 GPU, 32 GB of DDR5 memory, 2 TB SSD, and a 17.3" 240 Hz IPS display. Listed at 5599 AUD (~$3800) on Computer Alliance, or £3904.79 (~$5000) chez Lamba-Tek, you would expect the best possible performance for those prices. The two online retailers have not confirmed any concrete release dates for the high-end ASUS laptop.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
ASUS Sneaks Out Intel W680 Based mATX Motherboard for LGA-1700 Workstations
For those looking to build something more professional than your average run of the mill PC, ASUS new Pro WS W680M-ACE SE motherboard might be the thing you've been looking for. The Intel W680 chipset based board sports a mATX form factor and packs in a range of rather unusual features that you more often would find on a board from Supermicro or Tyan than ASUS. One such feature is onboard BMC remote management via an ASpeed AST2600 SoC which features a pair of Arm Cortex A7 cores and a Cortex M3, as well as a dedicated 2D graphics chip. The board also sports a SlimSAS port which supports either four SATA drives or a single PCIe 4.0 x4 storage device, although ASUS doesn't support any cables in the box for the port.
As this is a workstation motherboard, it obviously supports ECC memory and in this case we're talking DDR5 with full transactional ECC support, rather than the on-die ECC that all DDR5 features. Other more common motherboard features include a pair of PCIe 4.0 x4 NMVe M.2 slots, a single PCIe 5.0 x16 slot, a PCIe 4.0 x4 slot and a PCIe 3.0 x1 slot. The board also has a pair of 2.5 Gbps Ethernet port and a third 1 Gbps Ethernet port which is connected the AST2600, a 10 Gbps USB 3.2 Gen 2 Type-C port, as well as a DisplayPort and HDMI port, plus a VGA port which again is connected to the AST2600. ASUS promises 24/7 reliability at ambient temperatures of up to 45 degrees C and a relative humidity of up to 80 percent. The board also comes with ASUS' Control Center Express, which is ASUS' IT management software. No word on pricing, but the ATX sized version retails for around US$330, suggesting that the mATX version should be somewhat cheaper.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Intel Speeds AI Development with Reference Kits
Intel now offers a set of 34 open source AI reference kits to the community, the result of a yearslong collaboration with Accenture, enabling developers and data scientists to deploy artificial intelligence (AI) faster and more easily. Each kit includes model code, training data, instructions for the machine learning pipeline, libraries and oneAPI components to optimize AI and make it accessible to organizations in multiarchitecture on-premises, cloud and edge environments.
"Intel AI reference kits give millions of developers and data scientists an easy, performant and cost-effective way to build and scale their AI applications in health and life sciences, financial services, manufacturing, retail and many other domains. Intel is committed to enabling an AI everywhere future through not just our portfolio of AI-accelerated processors and systems but also our contributions to an open AI software ecosystem. The reference kits are built using components of Intel's AI software portfolio and on the foundation of the open, standards-based, oneAPI multiarchitecture programming model," said Wei Li, Ph.D., Intel vice president and general manager of AI and Analytics.[Only registered and activated users can see links. Click Here To Register...]
Leaked Footage Shows Sony Project Q Handheld Running on Android OS
A significant Sony Project Q leak has revealed an alleged prototype running on an undisclosed version of the Android operating system—the remote play-oriented handheld device was first revealed in late May's PlayStation showcase, but Sony's games division has so far kept stum about the Q's means of operation. [Only registered and activated users can see links. Click Here To Register...] has (prematurely) pulled back the curtain by uploading various images and video footage of a working unit.
A very simple version of Android seems to be displayed on the device's 8-inch 1080p LCD screen (a protective film is still attached), with a prominent QR code featured on its home window. The streaming device has the potential to be quite flexible, in terms of functionality, thanks to Sony's apparent wise choice of operating system selection. Zuby_Tech also took the time to open up their sample unit—without the screen in place, there appears to be not much going on inside there. Previous rumors have the Project Q accessory costing somewhere in the $200-300 region, with a battery life of 3-4 hours—this could be a tough one to market and sell, even to the most ardent of PlayStation platform supporters.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
MSI Arc A310 Low Profile 2X Graphics Card Unboxed in YouTube Short
An MSI Arc A310 4 GB Low Profile 2X graphics card is now available to purchase at a couple of Russian PC hardware retailers (for roughly $140), and a local YouTuber has already produced a quick [Only registered and activated users can see links. Click Here To Register...]. Intel's board partners have been sluggish in adopting lower-end Alchemist GPU variants, with only a handful of companies bothering to produce cards based on the [Only registered and activated users can see links. Click Here To Register...].
Sparkle displayed an unnamed super compact model at Computex 2023, and presentation slides have recently revealed that their "Industrial Low-Profile" series will be introduced under the [Only registered and activated users can see links. Click Here To Register...], comprised of single slot/fan A310 and A380 variants. Sparkle has not outlined a possible Western release for these budget cards, and other manufacturers have been reluctant to move beyond the Chinese OEM market. The [Only registered and activated users can see links. Click Here To Register...] series is reportedly a Russian market exclusive for the moment, so it will be interesting to see if MSI is only targeting that territory with its competing dual fan design Arc A310 4 GB Low Profile model.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Xbox Running Pizza-Scented Controller Giveaway - TMNT: Mutant Mayhem Themed
Paramount Pictures' upcoming "[Only registered and activated users can see links. Click Here To Register...]" and Xbox is serving up a totally righteous gamers' welcome for the fearless foursome. In celebration of the movie's August 2023 release, we are giving away a limited number of exclusive ooze green, pizza-scented Xbox Wireless Controllers that pair perfectly with game content that immerses fans in the Turtles' latest adventures.
Amp Up Your Gaming with TMNT: Mutant Mayhem Pizza-Scented Controller
Satisfy your hunger for kicking butt with the world's first ever pizza-scented controller! Designed to deliver the smell of the Turtles' beloved meal to your game time, these exclusive Xbox Wireless Controllers come with a built-in scent diffuser shaped like a slice of delicious New York 'za. The controller comes in four variations, each representing the signature colors, weapons, and personality of a Turtle brother: Leonardo, Raphael, Donatello, and Michelangelo. [Only registered and activated users can see links. Click Here To Register...] and retweeting the official Xbox Game Pass sweepstakes tweet. The giveaway will run from July 24 through August 13, 2023. For official rules and eligibility details, [Only registered and activated users can see links. Click Here To Register...]. For fans in NYC, you can join the celebration and check out in-person the pizza-scented controllers, load up on pizza and play on in the Xbox Gaming Lounge at the Microsoft Experience Center on Fifth Avenue from 4-7 pm ET on August 2, 2023.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Venom Showcased in Marvel's Spider-Man 2 Story Trailer
San Diego Comic-Con has always been one of the most exciting times for Marvel fans. We had an amazing time in 2018 with the original Marvel's Spider-Man, and we were thrilled to make a return trip to Hall H today to talk about Marvel's Spider-Man 2. For those of you who couldn't join us - here's a recap of what happened! We wanted to start the panel off with a bang, debuting our brand-new Story Trailer. Take a look (below)!
The trailer sets up our story in the game while also giving you your first full look at the monstrous Venom in Marvel's New York! Here's Marvel's Spider-Man 2 Senior Narrative Director Jon Paquette to offer a deeper look: "At the beginning of our story, our Spider-Men are at the top of their game," said Paquette. "But both Peter Parker and Miles Morales are struggling with their personal lives. Miles is trying to find time to write his college entrance essay, but he keeps procrastinating and focusing on Spider-Work instead. Meanwhile, Peter is underwater on payments for Aunt May's house, but he can't sell, it means too much to him. And just like Miles, Peter tries (and fails) to find balance with so many responsibilities. MJ wants to help Pete with the mortgage, but her job is on the line now that J. Jonah Jameson is back at the Bugle and looking to clean house. Our heroes have arrived at a confluence of crossroads, with uncertain futures, and some tough decisions ahead."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) BenQ Introduces ZOWIE G-SR II Mouse Pad, Designed for Esports
We are pleased to announce the new G-SR II mousepad. The G-SR II adopts G-SR, offering a consistent smooth and controlled glide during mouse movements. The G-SR II has been improved to increase its resistance to humidity. Moreover, the new tighter cloth surface reduces issues with glide inconsistency after frequent use and enhances durability.
G-SR II's slightly smoother glide feel makes it easier to start moving the mouse; with less friction for mobility in multiple angle movement and long distance aiming, while at the same time maintaining similar stopping power for stable control. Check out more information [Only registered and activated users can see links. Click Here To Register...].[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
