Eu sunt, ti-am trimis eu pm!
Te rog un config pentru vicardd eventual PM se poate,ca sa vad ce este cu DNS-ul.
Editezi in : /usr/config/wicard/wicardd.conf
Deci pui adresa IP nu cu domeniu !Code:[global]
#log_udp = 192.168.1.92:514
syslog = 1
ecm_cache_size = 256
#ecm_dedup_delay = 1500
daemon = 0
debug = 0
[webif]
port = 8081
debug = 3
[dvb]
active = 1
type = aml
emm_filter_mode = 0
# filter = dvb,emm,ecm
ecm_info = 2
# sdt = 1
auto_update = 1
debug = 3
[reader]
active = 1
name = superserver
type = cccam
account = user:parola@111.1xx.2xx.112:port
debug = 0
auto_provider = all
auto_idents = 1
auto_update = 1
reconnect_delay = 1
emm_cache = 1
ecm_ttl = 15000
Nu rezolva ip-ul daca pui cu domeniu.
---------- Post added at 18:05 ---------- Previous post was at 17:11 ----------
Am facut un plugin oscam modificat si l-am pornit in kodi imaginea 4 in 1.
Oscamul ruleaza, ramane sa vad cine si ce stie cu el.
---------- Post added at 18:27 ---------- Previous post was at 18:05 ----------
Merge, cere vine ECM da nu lumineaza, in neutrino testez.
Kodi nu are suport CA, o sa reinstalez TVheadend.
Trebuie sa ma mai documentez nitel.
Da merge foarte bine, multumesc.
Am observat la setari network ca DNS are 127.0.0.1 si daca setezi de exemplu 8.8.8.8 la repornire nu memoreaza, o sa ma uit la drepturi de scriere..
Multumesc inca o data.
Nu iti pierde timpul, oscam rezolva in aceeasi imagine.
E o librarie lipsa sau neadaptata la wicardd.
Sa rezolv eu problema cu oscamu si uiti de asta.
E formatul CA diferit de toate celelalte.
/dev/dvb/adapter0/ca0
Code:22:21:36 4752E9C4 c (ecm) anonymous (0100@000068/5C00/379B/64:4AADBEB3C3A581FA68903FFD67A89509): found (783 ms) by ita (P/4/4/4)
22:21:46 4752E9C4 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
22:21:46 4752E9C4 c (ecm) anonymous (0100@000068/5C00/379B/64:A3D8827DF365B0769912E09B04A822FC): found (899 ms) by ita (P/4/4/4)
22:21:56 4752E9C4 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
22:21:56 4752E9C4 c (ecm) anonymous (0100@000068/5C00/379B/64:6EEB9B1B1D88336CCB9369A29E9FC63D): found (1095 ms) by i (P/4/4/4)
Neutrino
- Fixed the initial volume when the channel
- Fixed a crash sound on some channels
- Reworked decoder AC3 (can be downmix and a synchronization problem)
- Fixed switching soundtracks sat channels
- Fixed LED control
- Fixed shutdown timer
- Added on / off the TV with the prefix (tested on the Sony TV)
- Enabled search for information about the filme in IMDB
Kodi
- Kodi 16.1 release
Enigma2
- In this assembly is broken :), but work has begun corrective work combo tuner
VDR
- No changes were
Merge tunnerul in e2 pe satelit !
Mai sunt belele cu ecranele de info, cu detectia audio etc.
Deschide cu vizcam .
E destul de buna imaginea, are tastele mapate diferit de ce sunt eu invatat (de ex audio e pe tasta AUDIO nu pe galben), merge stabil dar mai trebuie periata.
Am pus manual Lista RSP, o sa ii fac un addon pentru a actualiza lista direct din internet.
Zappingul este cam lent pentru pretentiile mele si sunt inca cu wicard, e drept ca nici nu am mai incercat sa il schimb.
Una peste are si E2 functionala jucaria asta.
Am observat ca nu afiseaza subtitrarile in E2 si nu mergeau nici in Neutrino cand am incercat.
O sa testez azi si neutrino din versiunea asta.
Nu merg nici pe neutrino subtitrarile.
In rest merge binisor, desi schimba lent canalele.
In E2 si Neutrino merge perfect USALS.
Tocmai ma dadeam cu Neutrino pe 28E si am gasit CNN HD care e FTA.
sa inteleg ca in kodi [Only registered and activated users can see links. Click Here To Register...]inca nu merge pe satelit?tot incerc sa gasesc tvheadend si nu il gasesc,gasesc doar tvheadend pvr client.
Nu faci tu ceva bine, de mers merge.
Oricum poti sa il instalezi daca nu e.
Da de ce nu te dai cu e2 sau neutrino?
Va rog, cum se trece de la e2 la altceva, kodi sau neutrino, cum se revine la meniul scurt unde se alege varianta in care porneste. Multumesc.
dar unde gasesc tvheadend in vitmod?
@marcghi
Ai in meniu la fiecare din ele trecerea la KODI.
E cu probleme trecerea, daca se agatza cand treci de la una la alta intrii cu ssh si dai reboot.
Ai user root pass root.
Daca am timp o sa modific scripturile sa dea reboot automat la trecerea intre ele.
Azi am reusit sa scanez si sa receptionez Canalul 30 (546 Mhz) din multiplexul TVR in Bucuresti, cu aparatul K1 si softul VDR.
Softul DTV din Android, "vede"semnal pe 546166 MHZ, incearca sa scaneze dar nu da rezultate.
Frecventa centrala la transponderul de pe C30 in Bucuresti e 546166 MHZ dupa cum se vede si in imagini.
confirm ca merge scanat si deschide canalele libere de pe cablul pe fibra telekom.incercat cu imaginea libreelec.
Bună, am o problemă cu conectarea la receptor prin FTP cu neutrino și vdr. Introduc IP , user si parola root și nu există nicio conexiune.
Привет, У меня есть проблема с подключением к коробке через FTP по загадке, нейтрино и vdr Введите имя ip-поля: пароль root: root и нет связи
no no ! se ingroasa gluma !!! :clap:
