enigma2-plugin-extensions-youtube_h1+git550+d48f162-r0.0_all
Citar
-YouTubeVideoUrl: fix sigfunc name extraction
Based on: ytdl-org/youtube-dl@e450f6c
enigma2-plugin-extensions-youtube_h1+git550+d48f162-r0.0_all.ipk
thx @ Taapat
enigma2-plugin-extensions-youtube_h1+git556+618f008-r0.0_all
-Update language files after language removal
-YouTubeUi: get search region and language from enigma …
Use the search region and language from the enigma so you don't have to translate and maintain them.
This allows you to use all countries and languages for which a particular image is available.
-YouTubeUi: fix Russian search language display in settings …
Before that, the country was displayed, not the language.
enigma2-plugin-extensions-youtube_h1+git556+618f008-r0.0_all.ipk
thx @ Taapat
Thx @ Taapat
Youtube_h1+git609+89f4da5-r0.0 10.12.2020
● Make log more verbose
Print exceptions reasons in enigma log
enigma2-plugin-extensions-youtube_h1+git609+89f4da5-r0.0_all.ipk
Thx @ Taapat
Youtube_h1+git618+655e282-r0.0 от 19.12.2020
● YouTubeApi: fix headers in get_aut_response
● YouTubeApi: next code optimization
enigma2-plugin-extensions-youtube_h1+git618+655e282-r0.0_all.rar
Thx @ Taapat
Youtube_h1+git619+fb9d792-r0.0
15.01.2021
● YouTubeUi: use pageUp when return from download directories set
This allows you to save the settings immediately without moving to another row.
enigma2-plugin-extensions-youtube_h1+git619+fb9d792-r0.0_all.rar
Thx @ Taapat
enigma2-plugin-extensions-youtube_1+git624+18e213e-r0
-Update urlparse imports
-Use python3's backported parse_qs code only on python2
(On python3 use parse_qs from urllib.parse)
enigma2-plugin-extensions-youtube_h1+git624+18e213e-r0.0_all.ipk
enigma2-plugin-extensions-youtube_1+git624+18e213e-r0_all.deb
Thx @ Taapat
YouTube_h1+git743+4015387-r0.0 от 20.02.2021
●YouTubeSearch: allows choose playable video in suggestions list
Some users don't understand that it's just a suggestions list and are trying to specify a video to play in it.
●Update Russisn translation
●Add forgotten colon in Latvina translation
●Update Latvian translation
●Regenerate language files after added config option
●YouTubeVideoUrl change forgotten getValue usage for maxResolution
●Add option use DASH MP4 format in configs
enigma2-plugin-extensions-youtube_h1+git743+4015387-r0.0_all.ipk
Thx @ Taapat
Youtube_h1+git793+06a4a1e-r0.0 от 16.03.2021
● Fix line too long error in enigma for gui test
● Try fix gui test if video url not found
● Add GPLv2 license badge in README.md
enigma2-plugin-extensions-youtube_h1+git793+06a4a1e-r0.0_all.ipk
Thx @ Taapat
Youtube_h1+git794+65dbb5c-r0.0 от 27.03.2021
● Revert "YouTubeMain: try speed up getting recent subscriptions"
enigma2-plugin-extensions-youtube_h1+git794+65dbb5c-r0.0_all.ipk
Thx @ Taapat
Youtube_h1+git801+5c2c0f7-r0.0 20.04.2021
● Remove header and location lines in pot file
enigma2-plugin-extensions-youtube_h1+git801+5c2c0f7-r0.0_all.ipk
Thx @ Taapat
youtube_h1+git806+275e67d-r0.0
● Add svg icons and scalable screens support
enigma2-plugin-extensions-youtube_h1+git806+275e67d-r0.0_all.ipk
Thx @ Taapat
Youtube_h1+git824+9e892cb-r0.0.0 от 18.09.2021
● YouTubeSearch: fix vkey_icon problem on old images
Add workaround to keep compatibility broken with changes in new images.
● Try fix test on openatv 7.0
● Ignore line too long error in enigma.py test file
enigma2-plugin-extensions-youtube_h1+git824+9e892cb-r0.0_all.rar
Thx @ Taapat
Youtube_h1+git847+4243836-r0.0.0 от 22.10.2021
● YouTubeDownload: remove unnecessary computing
● YouTubeUi: try fix rash when downloading a video on some buildsystems
● I did not see such a problem with myself, so I cannot test this.
enigma2-plugin-extensions-youtube_h1+git847+4243836-r0.0_all.ipk
Thx @ Taapat
Youtube_h1+git866+4b9bfd1-r0.0.0 от 30.10.2021
● YouTubeUi: return flags=BT_SCALE in default skin
If MultiContentEntryPixmapAlphaTest in image support this
● YouTubeUi: return domScreens element check
Deleted in previus commit
enigma2-plugin-extensions-youtube_h1+git866+4b9bfd1-r0.0_all.ipk
Thx @ Taapat
YouTube git 904 +84fe359-r0.0 от 17.12.2021
● YouTubeUi: try fix GSOD on thumbnails or entry list update
enigma2-plugin-extensions-youtube_h1+git904+84fe359-r0.0_all.ipk
Thx @Taapat
youtube_h1+git919+c3e3141-r0.0
-YouTubeUi: ignore import shadowed by loop variable
enigma2-plugin-extensions-youtube_h1+git919+c3e3141-r0.0_all.ipk.rar
enigma2-plugin-extensions-youtube_py3+git919+c3e3141-r0.0_all.ipk.rar
Thx @Taapat
enigma2-plugin-extensions-youtube_h1+git939+b436064-r0.0_all
● Disable shallow clone on tests
-Add YouTubeVideoUrl clean_html test
-Set max resolution on python tests
-Use updateSuggestions to set suggestions list in YouTubeSearch test
-Test YouTubeSearch list methods only if it exist in image
-Remove openMenu test for YouTubeSearch
-Fix over indented in tests
-Add tests for playback to to increase YouTubeMain code coverage
-Add tests for YouTubePlayer methods to increase code coverage
-YouTubeInfo: fix key_red valign argumnet in skins
enigma2-plugin-extensions-youtube_h1+git939+b436064-r0.0_all.ipk
enigma2-plugin-extensions-youtube_py3+git939+b436064-r0.0_all.ipk
enigma2-plugin-extensions-youtube_h1+git939+b436064-r0.0_all.deb..rar
Thx @Taapat
YouTube git 959 +da1995e-r0.0 от 08.01.2022
● YouTubeUi: fix unsubscribe from channel
enigma2-plugin-extensions-youtube_h1+git959+da1995e-r0.0_all.ipk
enigma2-plugin-extensions-youtube_py3+git959+da1995e-r0.0_all.ipk
Thx @Taapat
Youtube_h1+git972+a8696e1-r0.0_22.01.2022
-Fix gsod on images without getCurrentDescription method
Thx @Taapat
enigma2-plugin-extensions-youtube_h1+git972+a8696e1-r0.0_all.ipk.zip
enigma2-plugin-extensions-youtube_py3+git972+a8696e1-r0.0_all.ipk.zip
Thx @Taapat
