MB618> "printenv"
bootdelay=3
baudrate=115200
board=mb618
monitor_base=0xA0000000
monitor_len=0x00080000
monitor_sec=0xa0000000 0xa007ffff
load_addr=0x80000000
unprot=protect off $monitor_sec
update=protect off $monitor_sec;erase $monitor_sec;cp.b $load_addr $monitor_base $monitor_len;protect on $monitor_sec
HOSTNAME=LINUX7109
ethaddr=00:80:E1:12:06:38
ipaddr=192.168.40.63
netmask=255.255.255.0
gatewayip=192.168.3.1
serverip=192.168.40.19
kernel_base_spark= 0xa0080000
kernel_base_enigma2=0x18000000
kernel_sec= a0080000 a077ffff
kernel_len= 0x00700000
update_kernel=protect off a0080000 a077ffff ;erase a0080000 a077ffff ;cp.b 0x80000000 0xa0080000 0x00700000 ;protect on a0080000 a077ffff
rootfs_base=0xa0800000
rootfs_sec=a0800000 a1ffffff
menucmd=update
tftp_kernel_name_spark=mImage
tftp_kernel_name_enigma2=uImage
tftp_userfs_name_spark=userfsub.img
tftp_userfs_name_enigma2=e2jffs2.img
kernel_name_spark=spark/mImage
kernel_name_enigma2=enigma2/uImage
userfs_name_spark=spark/userfsub.img
userfs_name_enigma2=enigma2/e2jffs2.img
userfs_base_spark=800000
userfs_base_enigma2=18800000
userfs_len_spark=17800000
userfs_len_enigma2=7700000
kernelnfspath=192.168.40.19:/opt/target
rootfs_name=UserFS
rootfsnfspath=192.168.40.19:/home/d22cj/workspace/target
uboot_name=u-boot.bin
ubootnfspath=192.168.40.19:/home/d22cj/workspace/target
bootfromnfs=nfs a4000000 $kernelnfspath/$kernel_name;bootm a4000000
bootargs_nfs=console=ttyAS0,115200 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:61 stmmaceth=msglvl:0,phyaddr:1:watchdog:5000 root=/dev/nfs nfsroot=192.168.40.19:/opt/target,nfsvers=2,rsize=4096,wsize=8192,tcp rw ip=192.168.40.61:192.168.40.19:192.168.3.1:255.255.0.0:LINUX7109:eth0:off bigphysarea=4000
bootargs_flash=console=ttyAS0,115200 rw ramdisk_size=6144 init=/linuxrc root=/dev/ram0 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:69 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0:off stmmaceth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000
bootargs_spark=console=ttyAS1,115200 rw ramdisk_size=6144 init=/linuxrc root=/dev/ram0 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:69 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0:off stmmaceth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000
bootargs_enigma2=console=ttyAS0,115200 root=/dev/mtdblock6 rootfstype=jffs2 rw init=/bin/devinit coprocessor_mem=4m@0x40000000,4m@0x40400000 printk=1 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:61 rw ip=172.100.100.249:172.100.100.174:172.100.100.174:255.255.0.0:LINUX7109:eth0:off bigphysarea=6000 stmmaceth=msglvl:0,phyaddr:2,watchdog:5000
magic_version=1.7
filesize=4000000
fuseburned=true
bootargs=console=ttyAS1,115200 rw ramdisk_size=6144 init=/linuxrc root=/dev/ram0 nwhwconf=device:eth0,hwaddr:00:80:E1:12:40:69 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0:off stmmaceth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000
kernel_base= 0xa0080000
kernel_name=spark/mImage
userfs_name=spark/userfsub.img
tftp_kernel_name=mImage
tftp_userfs_name=userfsub.img
userfs_len=17800000
userfs_base=800000
boot_system=spark
bootcmd=bootm 0xa0080000
stdin=serial
stdout=serial
stderr=serial
Environment size: 3127/131068 bytes
Asta nu cred ca e normal:
MB618> mtest
Testing 80000000 ... 87d00000 (125 MiB):
Pattern 00000000 Writing... Reading...
Mem error @ 0x876DFA5C: found 87F0BC90, expected 01DB7E97
Mem error @ 0x876DFA60: found 876DFA60, expected 01DB7E98
Mem error @ 0x876DFA64: found 876DFA60, expected 01DB7E99
Mem error @ 0x876DFA68: found 876DFA60, expected 01DB7E9A
Mem error @ 0x876DFA6C: found 01DB7E9A, expected 01DB7E9B
Pattern FFFFFFFF Writing...
Se poate formata memoria, asemenea unui stick usb? Sau o pot inlocui, la fel cum inlocuiesti o memorie ram de pc?
Se mai poate face ceva?
Exista 2 versiuni de enigma 2 (Flash si USB), cum pot sa instalez enigma2 pe USB si sa bootez de pe stick, nu sa o incarce in Flash?
Trebuie sa modifici parametrii de boot.
Un link/tutorial ?
Multumesc.
Descarca prietene fisierul de la postul nr: 6 al meu si scrie acolo tot ce trebuie sa faci la punctul 2.6 ...succes !
Dupa ce mai inveti cu u-boot gasesti [Only registered and activated users can see links. Click Here To Register...] cum faci sa plece de pe stick !
E foarte riscant !
Totul este riscant In viata ..fara a risca nu poti rezolva nimic !!!
