Pai merge acum. Mai trebuie doar sa setezi cum am arătat mai sus eu.
Le: sa verifici dacă oscam este compilat cu libusb și are support pentru Phoenix
Trimis de pe al meu Nexus 5 folosind Tapatalk
usb 4-1: Setting MaxPacketSize 64
usb 4-1: FTDI USB Serial Device converter now attached to ttyUSB0
usb 4-1: USB disconnect, device number 2
ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected
ftdi_sio 4-1:1.0: device disconnected
usb 4-1: new full-speed USB device number 3 using ohci-brcm
ftdi_sio 4-1:1.0: FTDI USB Serial Device converter detected
usb 4-1: Detected FT232RL
usb 4-1: Number of endpoints 2
usb 4-1: Endpoint 1 MaxPacketSize 64
usb 4-1: Endpoint 2 MaxPacketSize 64
---------- Post added at 10:07 ---------- Previous post was at 09:58 ----------
In sfarsit,functioneaza acuma! totul era din cablu
Tin sa va multumesc pentru sfaturile utile de a face lumina pe acest forum in toate situatiile la care useri se confrunta pe diverse probleme
inca o data multumiri
... pe linga librariile usb , trebuie instalat si driverul FTDI . degeaba il vede ca device usb daca nu si ca "FTDI USB Serial Device"
fi mai atent la postul 16 ( poze ),apoi putem comenta!
nu toate receptoarele au optiunea asta in soft sau in imaginea instalata de fiecare .
Functionarea Smart Reader
reader Focussat mouse 0 / 0 / 0 / 0 0 / 0 / 0 / 0 0 / 0 / 0 / 0 0 / 0 / 0 / 0 2247 (94.45%) 132 (5.55%) 0 / 0 100
[reader]
label = Focussat
protocol = mouse
device = /dev/ttyUSB0
caid = 0B02
detect = cd
mhz = 800
ident = 0B02:000000
group = 1
emmcache = 1,3,2,0
saveemm-unknown = 1
saveemm-u = 1
saveemm-s = 1
saveemm-g = 1
dropbadcws = 1
audisabled = 1
2016/11/11 03:55:12 c Linuxsat (0B02&000000/0000/77F2/84:3BBFECC2AA842B6C995601EEC7A005F6): found (171 ms) by Focussat - Discovery Science
2016/11/11 03:57:12 c Linuxsat (0B02&000000/0000/7789/4E:B0F9BC9E727A61FCA5E2B20073140AF3): found (138 ms) by Focussat - Bucuresti 1 TV
2016/11/11 04:20:30 c Linuxsat (0B02&000000/0000/76C1/4E:B9BFC47E9A115E8ADD06906B05A6F1B0): found (138 ms) by Focussat - Antena3
Am fost intrebat de catre un user:
Din cate observ eu din poză, frecvența hardware se setează din comutatoarele de pe cititor. Acolo pe ce frecvență l-ai pus?
Deci sunt 4 comutatoare pe acest Reader
1 = este pe 5 V ( am modificat )
2 = este pe Phoenix
3 = este pe Sageata nu pe frecventa 3.579Mzh
4 = este pe 8Mhz
dealtfel in reader oscam, se poate observa in postare de mai sus
acestea sunt setarile aferente acestui Smart Reader Smartmouse Phoenix USB
salut
Am 2 de-astea (easymouse) puse pe Vu+ cu oscam. In ele sunt doua carduri conax (Plocus si Pleesat :) )
Ambele au jumperii :
- 5v / phoenix / 3,57 / ultimul nu mai conteaza
in oscam.server (*la MHz si cardmhz poti sa pui si 357 ca tot acelasi ecm o sa ai... mare)
o vreme am avut si viaccesuri care merg (sau au mers) brici, ca tntsat, akta sau tvr(acum freesat). Freesatul via l-am pus intr-un smargo unde are ecm sub 0,100 (0,090-0,095 etc).Code:[reader]
label = FREESAT
description = FREESATCO
protocol = mouse
device = /dev/ttyUSB1
autospeed = 0
caid = 0B02
detect = cd
mhz = 600
cardmhz = 600
ident = 0B02:000000
group = 1
audisabled = 1
[reader]
label = FOCUSSAT
description = BE02
protocol = mouse
device = /dev/ttyUSB2
autospeed = 0
caid = 0B02
detect = cd
mhz = 600
cardmhz = 600
ident = 0B02:000000
group = 1
audisabled = 1
Ce n-am reusit sa vad in easymouseurile astea au fost cardurile Tivu si HD+ , habar n-am de ce. Si nici in Smartreadere (ca si de-astea as avea 2 si timpul de raspuns e considerabil mai mic) . Si cardul de Focus mai face figure in smartreader (ba e vazut ba nu e vazut), o tampenie, pentru ca Freesatul Viaccess e vazut anytime cand e scos si bagat la loc. Mi s-a luat de elastic peste smartreadere....Code:[reader]
label = Freesat
description = Freesat
protocol = smargo
autospeed = 0
detect = cd
mhz = 369
cardmhz = 369
group = 1
audisabled = 1
BTW
Nu am reusit sa fac carduri sa mearga DECAT cu jumper settings 5v / Phoenix / 3,579 :/ . Probabil ca merg ele si altfel de setari, dar sunt eu prea noob.
Si asa, ca fapt divers ecm pe Focus nu prea se duce mai jos de 0,250 in mouse-ul asta, pe cand in smartreader mai cadea sub 0,200.. Cand era in cccam, cu cardul vechi, alb complet (care a murit intre timp) aveam in smartreader 0,140ms pe Focus. Cardul pe care-l am acum (de Focus), nu e mirosit de cccam........
Pai contează. Ia pune la 800mhz pe reader mhz=800 și cardmhz=357 sa vezi 150-160 pe 4e
ok, o sa incerc si asa.
Nu a mers cu jumper 5v / phoenix / sageata / 8 MHz
error
Asta e ce am apucat sa dau copy/pasteCode:2017/01/07 23:38:19 4BB2C2AD r (reader) FOCUSSAT [mouse] ERROR: IO_Serial_GetStatus: ioctl(TIOCMGET): Input/output error2017/01/07 23:38:19 4BB2C2AD r (reader) FOCUSSAT [mouse] Error getting card status.
Si dupa restart tot nimic. Am fost atent si la device. Am scos cablul, am setat, am bagat cablul si am dat add reader cu ttyUSB de rigoare. ERROR
Am in prieten bun care are o vorba: "toate mi se'ntampla numa' mie"
pai trebuie sa pui in oscam
mhz=800
cardmhz=357
eventual pune debug 2 si dai un restart si ataseaza logul din oscam cu readerul
reader
[reader]
label = Focussat
protocol = mouse
pincode = 1234
autospeed = 0
caid = 0B02
ecmwhitelist = 4E,53,60,65,72,84,9C,97,8A
detect = cd
mhz = 800
ident = 0B02:000000
group = 2
emmcache = 2,1,0,1
blockemm-unknown = 1
saveemm-u = 1
saveemm-s = 1
saveemm-g = 1
pe reader 5v phoenix mode jumper 8mhz
Gata, am reusit.
Am oprit readerele din oscam, am scos cablurile, am setat jumperii, am editat oscam.server, prin ftp nu prin webinterface de la oscam, am salvat, am restartat oscam, am restartat receptorul (ca sa aloce din nou corect adresele device-urilor) si a mers, atat la Focus, cat si la Freesatul conax. La unele canale a scazut timpul de raspuns sub 0.170.
Multumesc
se pot pune doua easymouse2 pe acelasi usb la un receiver golden media 990 ? cu un hub usb? ce setari trebuie facute?
---------- Post added at 20:44 ---------- Previous post was at 20:15 ----------
cu cele doua readere conectate imi indica adresele respective. Eu am setat pentru un reader asa /dev/ttyUSB0 , usb0 trebuie inlocuit cu 001 respectiv 002 ?
Salut
Pe Raspberry am un Hub de 10, la care sunt si 2x Easymouse 2.
In etc/udev/rules.d/ am adaugat fisiereul "10.usbadapter.rules" -644- in care am scris in cazul meu:
SUBSYSTEMS=="usb", KERNEL=="ttyUSB*", ATTRS{serial}=="A400fFkd", SYMLINK+="REDLIGHT"
SUBSYSTEMS=="usb", KERNEL=="ttyUSB*", ATTRS{serial}=="AH01345F", SYMLINK+="Sky"
Poate te ajuta.
Numai bine
In oscam:
device = /dev/Sky
device = /dev/REDLIGHT
la mine se gaseste in lib/udev/ dar rules.d nu exista trebuie creat?
---------- Post added at 23:05 ---------- Previous post was at 22:56 ----------
Salut,
Am pus digi 1802 pe un easymouse 2. Jumperii sunt 5v, phoenix. Pe cel cu frecventele l-am testat, schimband de pe 3.57 pe 600, 800, modificand setarea corecta Mhz la reader in oscam . Timpii de raspuns sunt mari din carduri sunt mari, peste 800ms. Focus in schimb, cu acelasi reader, jongland cu frecventele, are timpi sub 200. Am schimbat cititoarele intre ele (sunt puse pe ubuntu), acelasi rezultat. Am incercat cardul digi intr-un receptor, si timpii sunt ok, sub 300ms. Pun si setarile la reader:
[reader]
label = digi
protocol = mouse
device = /dev/digi
caid = 1802
boxkey =
rsakey =
ecmwhitelist = 1802:92
ecmheaderwhitelist = 81308F078D,80308F078D
detect = cd
cardmhz = 357
mhz = 600 # aici am modificat in functie de jumper
ident = 1802:000000,002011,002111
group = 1
lb_weight = 150
ratelimitecm = 15
ecmunique = 1
ratelimittime = 15000
srvidholdtime = 500
Imi puteti comfirma ca, cardul digi are timpi mari pe easymouse sau gresesc eu undeva?
Am avut aceeasi situatie si eu si un alt prieten (care a schimbat cardu din 1802 in 1880) cu acceasi problema,
eu am setat ratelimitecm si am scapat de aceasta problema.
Reader quad byGeluvis. (se pregateste o versiune cu quarz reglabil si display)
[reader]
label = digitv
protocol = mouse
device = /dev/ttyUSB3
caid = 1802
boxkey =
rsakey =
fix07 = 0
readtiers = 0
detect = cd
nagra_read = 1
detect_seca_nagra_tunneled_card= 0
group = 1
emmcache = 1,3,2,0
blockemm-s = 1
blockemm-g = 1
saveemm-u = 1
saveemm-s = 1
saveemm-g = 1
use_gpio = 1
cccreshare = 2
auprovid = 002011
read_old_classes = 0
Am si eu un quad Geluvis, nu mi-a reusit treaba cu udev. Nu stiu daca Gelu mai face readere, versiunea cu quarz reglabil si display parca nu e noua. Referitor la easymouse 2, pe acelasi pc, doar cardurile nagra au timpi mari (am si un tivusat), focus si tvr au timpi buni. Am setat si eu cererile pe reader dar nu am rezolvat.
Eu personal ma găsesc foarte ok cu quad-urile de la geluvis, nu am avut probleme, de ce ? Le folosesc in PC in locul unui cd-rom unde am adăugat un "HUB USB ALIMENTAT" nu am probleme, timpi sunt acceptabili. Modelul pregătit este cu stabilizator, nu cred ca, aceasta versiune a mai fost expus, poate m-a înșel.
Poți face o poză la reader, sunt curios cum arata. Ms.
Desigur
Exista si STL cine doreste.
