Ala e forumul. Incearca si aaf.
Din pacate si acolo ( forum aaf ) alti nemti.....
e un produs nemtesc cu suport nemtesc:)...e logic sa fie numa nemtzalai
---------- Post added at 12:39 ---------- Previous post was at 12:24 ----------
nu am vazut aceasta imagine postata,doar ce a de la AAF,poate ma insel..e poate sterge postu daca exista postata imaginea
Team RED E2 Image 17.02.2012 HD800 SE
team RED presents :
Gigablue² FW 1.1.2 2012-02-17
GIGABLUE HD 800 SE
Quoted
or FORUM DATABASE
BEFORE U START FLASHING BOX PLEASE TAKE A LOOK WHAT U DOWNLOAD, U MUST HAVE FILES FOR SE EDITION,
DO NOT TAKE SOLO EDITION E2 !!!!!!!!!!!!!!!!!!!!!!!!!
This Release Includes:
• fix fix fix
• added multiboot ( i will publish how to later )
• removed full backup, new changes will arive so new plugin needed
• Software manager added
SUPPORTET CHIPSETS IN FIRST RUN !!!!!!!!!!!!!!!!!!!!
--------------------more to come----------------------------------
a867 a102 a800 af9005 af9015 au6610 az6027 ce6230 cinergyT2
dib0700 dibusb-mb dibusb-mc dtt200 dtv5100 dw2102
ec168 gl861 nova-t-usb2 vp702x vp7045
General Technical Info:
• Build date : 17.02.2012
• Linux version 2.6.36
• Drivers date : 16.01.2012
Main features:
• REDPANEL
• No reboot after installing the "Gigablue² Firmaware" settings from REDPANEL
• Support for your own scripts
• Manage Start / Stop Services
• Manage Start / Stop Services on boot
• Manage kernel modules
• New Information System
• Support for a private server addons
• GIGA_VFD plugin, control you VFD display
• Support for swap files
• Support for EZ-Inadyn IpUpdate
• Support Proxy
• Support OpenVPN
• Replaced with OpenSSH Dropbear
• Support for SFTP
• Support for readers Smargo
• Support for readers Omnikey
• Support for USB WiFi
• Samba server, Samba client, NFS Server
• Running Linux commands
• Support for formatting USB Device
• latest CROSSEPG included
• latest DDamir Subtitle Player V3 included
Kernel Modules:
• OpenVpn (tun)
• Usb To Serial (usbserial, ftdi-sio, pl2303)
• Nfs Server (nfsd)
• smbfs
• udf
• Wifi
• And more
DISCLAIMER
TEAM RED "GIGABLUE² FIRMWARE" IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE TEAM RED "GIGABLUE² FIRMWARE" DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
TEAM RED "GIGABLUE² FIRMWARE" IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO TEAM RED "GIGABLUE² FIRMWARE" THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THEREWOKE OF THIS LICENSE.
CREDITS
thx to EDG-NEMESIS for OPENSOURCE they maintain and that we use inside our FW such as redpanel and other plugins, thx to supporters, thx to beta testers , @ilje for graphics and many many others, special thanks to S-Team for helping with drivers, to Matrix10 for using us one of his skins
and thx to all others that have supported us all this time
yours
Team RED
Download: [Only registered and activated users can see links. Click Here To Register...]
---------- Post added at 12:48 ---------- Previous post was at 12:39 ----------
apropo e si ptr SOLO fw de mai sus,acolo in director e sectiunea solo si se
revin sa rectific o afirmatie de mai devreme: Decodeaza 2 canale simultan de pe satelit, problema apare la combinatia 1 canal DVB-S si unu DVB-C, la cel DVB-C se inverzeste norma de decodare dar nu decodeaza. Tind sa cred mai degraba ca e o limitare a batranului CCcam. Cand o sa am timp o sa testez si oscam sa vad daca apare aceeasi problema.
cine are solo sau 800 SE sa-mi spuna daca pe AAF se pot dezinstala pluginurile pe ultima imagine de la Team RED n-am reusit. Apas pe butonul ROSU cum este indicat dar in functie de skin zice ori ca n-a gasit nici un plugin nou ( ??? nici n-ar trebui ,ca doar n-am dat sa instaleze) ori nu apare nimic.
La acest receptor cum se instaleaza imaginile? Iar pentru lista de canale se foloseste aceleasi programe (dreambox edit) ca la dm800? Banuiesc ca da, fiind imagini bazate pe enigma 2.
Multumesc.
dreambox edit se poate folosi fara nicio problema, exact ca la orice alt receptor cu enigma pe el. sa tii cont ca trebuie sa ai setari de receptor cu enigma II la settings.
succesuri! :drinks:
cum pot sa fac lumina pe acest receptor cu cardul TVR , in extra addons am numai mgcamd 135,138 fara newcs 162 , am extras din dm500hd cu imginea newnigma camul mg130d_newcs162 , dar nu reusesc sa vad camul in gigablue , daca stie cineva cum se procedeaza ,rog ajutor Multumesc!.
openMips public beta 1.0 23-04.2012 HD800 SE
what is new ??
-- openpli based latest e2
-- 3.1.1 kernel
-- ubifs
-- software managment
-- fully update via net
-- drivers 23-04-2012
ATENTIE: Necesita bootloaderul din 4.04.2012
---------- Post added at 08:59 ---------- Previous post was at 08:26 ----------
OpenAAF 23.04.2012 (first kernel 3.11 image)
mage Update 04/22/2012
Gigablue
- Update to kernel 3:11
- Enable GB800se Image Backup (gb800solo coming soon)
- Enable USB DVB-tuner support
- Enable Wireless Support
- LED and VFD support completely new plugin
- UBIFS filesystems GB800SE
- Start SpeedUp
- Speedup Mix
- Fixed bug in many E2 see change logs from previous weeks.
Known problems here, we are waiting for manufacturers fixed
- Deep Time in UTC has shown time and not from the region
- SCAM is not yet
- RC functions, not all surrounded
- Problems with using demux DVB-USB devices, sometimes no sound, etc.
Ceva impresii despre noile imaginii ?
Din pacate vad in continuare ca tot vreo 2/3 echipe/imaginii , nu stiu ce succes scontat va aveea vers. qautro cand va aparea
Fiindca nici la cele 2 modele actuale nu prea se "inghesuie" userii
am pus openMips. momentan n-am avut prea mult timp de teste, dar ce am observat ca pe noul kernel booteaza mai repede si se misca in gereral foarte rapid: navigare,menu,zapping etc. nu sunt nici eu pe deplin multumit ca alfel ar fi recieverul perfect ,dar este cam 90% functional si avand in vedere ca-l folosesc strict pentru vizioanre pe satelit si cablu, cam in procent de 99% pentru mine. zeci de imagini de la 10 de echipe pe luna nu e suport software, fiecare ia baza si umfla cu floricele. eu unu n-am nevoie. ma intereseza doar sa functioneze LCD4linux, oscam ,streaming si rapiditate in comenzi. n-am nevoie de alte dracii inutile.
dupa cateva zile de openMips pot sa spun ca lucrurile incep sa mearga bine la acest reciever din punctul meu de vedere. foarte rapida noua imagine, are mici lipsuri care probabil se vor rezolva in timp (softcam panel saracacios cu putin informatii,lips panelurilor cu informatii amanuntide despre sistem). fiind deja 4 echipe care lucreaza la imagini pentru acest reciever eu zic ca merita o sectiune numai a lui pe forum, mai ales ca sunt deja alte vechituri care au asa ceva , iar gigablue nu. or sa mai scoata vreo 2 recievere se pare. aici e prea ascuns, daca nu posteaza unu zi de zi, un nou venit nu da de threadul asta prea usor.
deja sa scumpit 10 euro:clap:.....zic de solo ptr moment:)
La imaginea asta imi poti spune daca are camuri instalate?, s-au trebuie instalat extra adonss.Quote:
Originally Posted by apoklyps3 [Only registered and activated users can see links. Click Here To Register...]
Este tot cu ceva gen extra-addon . Trebuie copiat un fisier si instalat.
Aveti idee ce diferente exista intre imaginile de pe gigablue 800 solo si SE ? Am o problema ciudata cu imaginea Openmips pe gigablue800solo : la softcam nu imi apare nimic niciodata . Am reinstalat imaginea si tot asa ...gol , nimic nimic . Ma refer la Meniu--->setup-->Softcam/CI -->Softcam Setup -->Select softcam. Nu-mi intra decat pana aici . Daca dau click sa aleg softcam nu se intampla nimic, ca si cum nu e nimic instalat. Am verificat prin ftp si exista scripturi pt softcam. Am vorbit cu cineva care are varianta SE si la el apare ce instaleaza. E totdeauna mai incomod sa selectez softcam pentru ca trebuie s-o fac exclusiv din telnet.
alt team cunoscut incepe sa lucreze la imagini pentru acest aparat:
- Sifteam cloud system (You can connect your sifteam forum account on your stb, in the future release you can backup your image,share channels settings etc etc in your personal account storage)
- Graphic skin by daconi.
- SifTeam Panel Menu
- Software Manager.Added possibility to rank your favourite plugin, you can consult top rated,most downloaded plugin etc etc
- Bouquets and Channels Menu. Now you can download your favourite channel list settings.
- Exclusive possibility to use Original Sky Ita channel list numeration starting from number 100 like skybox stb
- OpenWebIf
- System to detect and install Usb devices
- Mount Disk manager
- Temporary-Static Mount.
- Airplay Server
- Add NEW Support for Gigablue 800SE, Gigablue 800UE, Gigablue 800 Solo, Gigablue Quattro
- Fixed many bugs
Stiti careva dintre voi care ar fii diferentele asemanarile intre GibaBlue HD 800 SE si 800 UE ( UE=? ) ?
din ce am citit la specificatii pare acelasi 800SE doar ca are ecranu ala LCD color in loc de displayu ala infect cu 4 cifre pe care il are 800SE. daca nu o sa vina ca inlocuitor la pret similar, mai degraba mergi pe 800SE, dai 10$ si iei o rama LCD de pe ebay si ii faci modare la 800 SE. chiar vreau sa fac asta la al meu, momentan il tin conectat p afara ,displayul LCD.
Sorry nu citisem raspunsul lui Apoklyps3 legat de afisaj/diferenta intre cele 2 modele
