La adresa:
instructiuni si sursa de la simplebuild
s-a ajuns la 1.32
La adresa:
s-a ajuns la 1.32
simplebuild 1.33
-add Synology Marvell 88F628x Toolchain with usb ssl pcsc and static support
-oscam-svn url now in var editable for using mirrors
-delete oscam-svn (urlchange to .tv)
start with ./simplebuild menu
simplebuild 1.34
-add TOUCH WEBIF (console support later)
Code:rm -rf toolchains/configs
simplebuild 1.35
-console checkout extension with revnumber (first try)
Code:./simplebuild checkout 7123
simplebuild 1.36
-add MODULE_CCCSHARE (console support later sorry no time now)
work with saved !
first of all; if u have problems, begin with a empty directory and simplebuild script only
CROSS COMPILE ONLY WITH x64 or x86
Again, thanks Gorgone (Streamboardler )
simplebuild 1.38
-first try to fix ./simplebuild debinstall
(this installs all needet packages i think)
-another bugfix prepare for the new releases
sper ca sa rezolvat problema de compilare ptr dm500
cel putin eu nu am reusit deloc sa fac ptr dm500 cu 1.36
Cu 1.36 am compilat eu de 2 ori pentru cineva de aici. Si i-au mers ambele...
Poate nu ti-a mers:
ppcold e pentru dm 500Quote:
DOWNGRADE PACKS FOR PPC-OLD / DBOX2
[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
just replace the files in the toolchain
am facut si eu la inceput pe urma incepand cu vers 7688 parca nu a mai mers nimic..naiba stie
vad ca si acum cu 1.38 sta sa ia toolchain ptr dm500 de vreo 10 min
reinstalat de vreo cateva ori..nimic
doar la 500 am problema asta..in rest ok
pfff
greu dar a mers pana la urma..vreo 15 min..
simplebuild 1.41
-allways menu remove
-begin with
Code:./simplebuild reset_all
-now all packages buildable on 32bit and 64bit
-removed uni2ascii
-replaced ppc-tuxbox-old now with ssl 0.9.7
-replaced sh_4 toolchain (no 64bit needet anymore)
-rewrite simplebuild.config (please check ur own paths)
-first try to fix ./simplebuild debinstall (missing package installer ,this installs all needet packages i think)
-fixed typos
PS Salvati arhiva si ce mai doriti ca sterge tot!
simplebuild 1.42
-begin with
-removed uni2ascii
-fixed typos
-found update bug fixed now
-simplebuild.config update
first of all; if u have problems begin with a empty directory and simplebuild script only
simplebuild 1.43
-OpenWRT Brcm63xx toolchain addet incl. consolemode
-config update (change ur paths)
-add staging enviornment to build
-new header option deldebug this delete the binary.debug enabled by default
-changed Binary info on menu build now its waiting for enter
Code:
cd /opt or cd /home/ur_username
mkdir simplebuild
cd simplebuild
wget [Only registered and activated users can see links. Click Here To Register...]
chmod 777 simplebuild
./simplebuild debinstall (look for errors)
./simplebuild menu
simplebuild 1.44
-fixed a bug found by pr2 (configpath save)
-fixed bug save and restore ssl build in menu mode
-config change for nlsu (horsti58 reportet thanx)
PCSC SUPPORT ONLY FOR
-fritz33xx
-fritz72xx
-fritz73xx
-openwrt26
-ddwrt346
-ddwrt410
-marv_6281
-native
Code:cd /opt or cd /home/ur_username
mkdir simplebuild
cd simplebuild
./simplebuild menu
simplebuild 1.46
-add dream_hw toolchain console support
simplebuild 1.45
-add dream_hw toolchain (menu build only ,console next release)
-add "build.log viewer" in build menu
simplebuild 1.47
-add orginal oscam config support (now with reader support)
-set debug mode & delete debug into simplebuild.config
-fritz33xx
-fritz72xx
-fritz73xx
-openwrt26
-ddwrt346
-ddwrt410
-marv_6281
-native
simplebuild 1.48
-fix console build
simplebuild 1.49
-fix build again *grml*
simplebuild 1.51
-enable deldebug="1" in console mode (this parameter is to set in simplebuild.config)
-first try to implement the next very simple console build
mkdir simplebuild
cd simplebuild
wget http://ss4200.homelinux.com/oscam/simplebuild
./simplebuild menu
just type
./simplebuild mipsel
to fetch extract and build a mipsel binary (without config it takes the default)
supported platforms :
Code:-native (if compiler installed on ANY SYSTEM)
-dbox2, dreambox 500,500-S
-dreambox 600,7000,7020
-dreambox 500HD,800,800se,8000,7025 vu+ clones + derivate
-openembedded 1.6 & 2.0
-fritzbox 33XX
-fritzbox 72XX
-fritzbox 73XX
-marvel 88F628x
-raspberry pi hard fpu
-raspberry pi soft fpu
-powerpc
-dockstar
-coolstream
-sh4
-sh_4 (new toolchain without segfaults)
-tplink (1043ND)
-fonera
-ddwrt 2.4
-ddwrt 2.6
-openwrt 3.4.6
-openwrt 4.1.0
-openwrt brcm63xx
-arm nslu2 unslug
-arm nslu2 openwrt
simplebuild 1.54
-add a new toolchain check system for console & menubuild (it can have some bugs !!!)
-libsearchdir is now saved in profile (please report)
-build optimisations add -Os & USE_LIBCRYPTO=1 for a smaler binary size
-renamed dream_hw to dreambox_fpu
-fixed name in consolebuild (thnx ChiefOBrien)
-very simple console build just type
simplebuild 1.56
-add (for starting clean without lost of toolchains)
Code:
./simplebuild clean
simplebuild 1.57
-fix libsearchdir thanks for report *hk2k2*
Code:
./simplebuild clean
