I was trying flash Spark 1.1.35 first, then RC1 (long power off after first run), but with the same result - reboot after load modules on display. May this relate to the boot logo?
Thanks for the next help.
Super tare noul RC1 Enigma2. Este stabil , merge bine, MULTUMIM!!!!!!
Skinul HD-Glass 16 este f. fain.
Se poate instala si pluginul pentru subtirari DD-subt?
Multumiri pentru munca depusa :)
Am scos DD-subt pentru ca uneori nu mai pornea e2 de la el si nu am avut rabdare sa studiez problema.
HD-Glass 16 e frumos, util pentru informatiile sale, dar mananca 10 mega de ram in plus si ceva procesor.
Si, am uitat sa mentionez in primul post, acum subservices functioneaza pe VERDE.
---------- Post added at 12:18 ---------- Previous post was at 11:48 ----------
Am mai uitat si FLAC in media player, si multe altele adaugate in ultima luna.
Tanks i tested this versión anr report Log
Am uitat sa mentionez ca nu se mai poate face inregistare accidental in flash, nici timeshift.
Sunt implicit dezactivate la boot pentru ca accidental se putea face recording in flash!
Pentru inregistrari trebuie sa stiti urmatoarele:
- se poate inregistra doar pe partitii EXT2, EXT3 si FAT32 (cu limitare la 2Giga a unui fisier la FAT32)
- Daca partitia pe care inregistrati are LABEL = RECORD e montata automat la boot.
- O alta metoda este sa creati un director movie pe prima partitie !
---------- Post added at 16:32 ---------- Previous post was at 15:17 ----------
I forgot to mention that accidental recording in flash or timeshift recording start is no longer possible.
These are now disabled by default on boot.
To be able to use recording function, you must know the following:
- can be done only on EXT2, EXT3 and FAT32 partitions (with 2GB file limit applied on FAT32).
- If the recording partition is labeled RECORD it will be mounted on boot.
- Another method is to create a folder named movie on your first partition.
How to connect network hdd (cifs)? (timeshift,record)
cine a testat,stiti ceva citeste cardul conax ?? exemplu pocus?? asta pentru cei care au servere cu card local?? oricum multumim maestre zildan pt munca depusa !!! :clap:
@rudi77
For CIFS mount:
-enable CIFS in User options (RSP menu)
-edit /var/config/amnt.cfg
-restart box
For RECORDING read previous page
Timeshift need a lynk in image, momentan is disabled.
@spiry
Nu cred, inca nu am rezolvat total card readerul. Testate sunt vi@ si n@gr@
Buna,
Dupa instalare numai "boot-loading modules", am incercat de mai multe ori dar nu merge mai departe.Variantele anterioare au mers din prima.Oare sunt diferente hardware?
Thx
I had a movie folder on my Hard disk. I copied a movie in that folder. And now all of a sudden, it is deleted. It is no longer there.
Also the hard disk is not mounted on boot. Very anoying.
Can you explain how to format the hard disk? So I can use the Record, time-shift, media-player and also use Swap?
Or maybe you can make a menu item in the next image?
Because it is not clear to me now.
Not mount hdd!!!!!!!!
cfg:
record="RECORD"
cifssrv="192.168.1.8"
cifsdir="movies"
cifsuser=""
cifspass=""
#RECORD
# Edit this if you want to use a different name for the label to mount
# in /hdd/movie used for recording
record="RECORD"
####CIFS
# IP of the PC on which the shares are
cifssrv="192.168.1.110"
# A list of share names (it may be or not the directory name).
# You can add more than one separated by spaces. If the share name
# has spaces in it use '%' to replace it
cifsdir="moviepc"
# User used to log on on the PC
cifsuser="user"
# Password used to log on on the PC. If you don't use any just leave
# it empty
cifspass=""
Can you give to us (I think waterman has the same problem) new kernel with old boot options please? I would to try new version your very good work, but we have this problem with restart.
Thanks for your work :clap:
You don't understand my point.
It is the USB connected harddrive. It is not mounted to /dev/sda1. Not automatically
I had it perfectly formated as ext3 with a movie folder in it. Inside there was a mkv movie. After connection to this image, the movie folder is empty. The file was deleted somehow. And I did not do it. So, there is something terrible wrong with the mounting of the USB drive.
I did a re-format of the drive with the menu of this image. And again I copied a MKV movie to the /movie folder. There-after, the same thing hapened. After reboot, the MKV disappears. It was deleted somehow. I tried to re-mount the harddisk, but the file was still not there.
Then, just to be sure I started SPARK. And indeed, no MKV file in the movie folder.
So my question remains: How to handle with the USB harddrive? Because, it is pretty annoying to lose those big MKV files.
@waterman
Formateaza stickul, scrie imaginea iar, si lasa 10 minute aparatul oprit inainte de boot.
Daca face la fel, il opresti si il lasi iar oprit timp indelungat, apoi il pornesti.
---------- Post added at 21:48 ---------- Previous post was at 21:43 ----------
@satrich
Is a bug in my code.
Mount HDD before delete "movie" folder.
edit /etc/init.d/rcS
rm -r /hdd/movie
replace with
#rm -r /hdd/movie
Put mkv movie in other folder (on hdd) and find file in /hdd or /tmp/sda1 with media player !
Ok good mount!
How to activation timeshift?
How do you install CCcam, in this version? and What to use?:clap:
Same problem here, tried to reflash a couple times but every time with same result.Quote:
Originally Posted by joberuc [Only registered and activated users can see links. Click Here To Register...]
Also tried to leave the device off for a couple minutes but same result agian.
@fundidum --- use Oscam instead ! there is no CCcam in SH4 boxes world ! but Oscam
is the EMU witch solves all the required functions ... read and use it !
Use RED ...then RSP pannel ...download Oscam emu and his configs !
Bravo pentru noua versiune enigma2!
A inaintat mult enigma pentru alienul nostru, si functioneaza perfect. Dar calitatea imaginii tot e mai slab fata de spark...
