MgCamd este un EMU folosit azi doar pentru conexiunea la un server CCcam pe o linie
de tip N: ( protocol NewCamd ) ... sau pentru a te lega la un CSP ! cat despre coduri ...
Oscam este taticul tuturor ! acolo trebuie sa va concentrati interesul ...
exista cineva care sa i-mi dea putin ajutor sa configurez oscam sa lucreze emu?
---------- Post added at 14:50 ---------- Previous post was at 14:19 ----------
a testat cineva vizcam?
edit oscam.conf :)
boxtype = dreambox
am introdus dar nu s-a facut lumina,
sigur mai trebuie modificat si in alta parte daca stii toata conf si ai timp sa ma ajuti ar fi super,i-ti multumesc pt ajutor
---------- Post added at 15:53 ---------- Previous post was at 15:34 ----------
nimeni nu ma poate ajuta sa configurez oscam-ul?
My Faile
oscam.conf.
box.tipe remove= write dreambox
# oscam.conf generated automatically by Streamboard OSCAM 1.00-svn build #3273
# Read more: [Only registered and activated users can see links. Click Here To Register...]
[global]
pidfile = /tmp/osca.pid
logfile = /tmp/stdout
disablelog = 1
disableuserfile = 1
usrfileflag = 0
clienttimeout = 5000
fallbacktimeout = 2000
clientmaxidle = 120
cachedelay = 120
bindwait = 120
netprio = 0
clientdyndns = 0
resolvedelay = 30
sleep = 10
unlockparental = 0
nice = 0
serialreadertimeout = 1500
maxlogsize = 500
waitforcards = 1
preferlocalcards = 1
saveinithistory = 0
readerrestartseconds = 5
lb_mode = 1
lb_save = 50
lb_nbest_readers = 1
lb_nfb_readers = 3
lb_min_ecmcount = 4
lb_max_ecmcount = 500
lb_reopen_seconds = 900
resolvegethostbyname = 0
[dvbapi]
enabled = 1
au = 0
boxtype = dreambox
user = kathy
pmt_mode = 1
priority = 0D05,1702,1830,1833,1801,0963,0B02,0100:003311,093 B,0BAA,0D03:000008
ignore = 09C7,09C4
[webif]
httpport = 84
httprefresh = 0
httpallowed = 127.0.0.1,192.168.0.1-192.168.254.254
httphideidleclients = 0
httpreadonly = 0
i-mi da o eroare de conectare la web if
si nu se deschide nimic
Da un restart dupa ce modifici.
Esti roman sau scrii cu google translate ?
sunt roman,am dat restart dar nu a avut nici un efect,probabil voi reinstala enigma 2 si o voi lua de la capat
Nu e din enigma2 problema. Din filele de config e !
stiu,sunt incepator si de aceea am intrebat daca cineva ma poate ajuta sa configurez corect
Yes total tv,signal strength is weak on e2 spark is better and maybe hd skins.Quote:
Originally Posted by amikohd [Only registered and activated users can see links. Click Here To Register...]
when we can expect the next enigma2 ?:)
as soon we solve the problems ...
:clap:nice bravo!
I also noticed that the sound is lost at times so I have to manually move to ready.
ty guys:drinks:
tnx,,pleas fix subtitl total tv,plugins [Only registered and activated users can see links. Click Here To Register...]. :clap:Quote:
