da greseala mea , vroiam sa spun TVR HDQuote:
nu este card dolce ci tvr [Only registered and activated users can see links. Click Here To Register...]
Code:3001F8B0 s 0 root 127.0.0.1 0 server 02.07.11 11:27:05 00:43:05 0000:0000 00:00:00 OK
3182C4F0 h 1 root 127.0.0.1 0 http 02.07.11 11:27:05 00:51:06 0000:0000 00:22:24 OK
c 1 tvr ON ON 127.0.0.1 1103 newcamd (CCcam) 02.07.11 12:31:31 00:00:28 0000:0000 00:00:28 OK
Am reinstalat imaginea Gemini 4.70 si un nou Cccam 2.2.1 + Oscam 1.0(ambele manual ca pe Gemini server nu mai gasesc nimic).Quote:
2011/07/02 12:30:48 3001F8B0 s >> OSCam << cardserver started, version 1.00-unstable_svn, build #5509 (powerpc-tuxbox-linux)
2011/07/02 12:30:48 3001F8B0 s version=1.00-unstable_svn, build #5509, system=powerpc-tuxbox-linux, nice=-1
2011/07/02 12:30:48 3001F8B0 s client max. idle=120 sec, debug level=0
2011/07/02 12:30:48 3001F8B0 s max. logsize=10000 Kb, loghistorysize=4096 bytes
2011/07/02 12:30:48 3001F8B0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=0 ms
2011/07/02 12:30:48 3001F8B0 s services reloaded: 0 services freed, 1 services loaded, rejected 0
2011/07/02 12:30:48 3001F8B0 s userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2011/07/02 12:30:48 3001F8B0 s signal handling initialized (type=sysv)
2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2 No such file or directory), no service-id's loaded
2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2 No such file or directory), no tier-id's loaded
2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2 No such file or directory), no provids's loaded
2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2 No such file or directory) irdeto guessing not loaded
2011/07/02 12:30:48 3001F8B0 s monitor: initialized (fd=9, port=988)
2011/07/02 12:30:48 3001F8B0 s camd33: disabled
2011/07/02 12:30:48 3001F8B0 s camd35: disabled
2011/07/02 12:30:48 3001F8B0 s cs378x: disabled
2011/07/02 12:30:48 3001F8B0 s newcamd: initialized (fd=10, port=34000, crypted)
2011/07/02 12:30:48 3001F8B0 s CAID: 0500
2011/07/02 12:30:48 3001F8B0 s provid #0: 1F1F1F
2011/07/02 12:30:48 3001F8B0 s provid #1: 025910
2011/07/02 12:30:48 3001F8B0 s radegast: disabled
2011/07/02 12:30:48 3001F8B0 s http thread started
2011/07/02 12:30:48 3001F8B0 s loadbalancer: can't read from file /tmp/.oscam/stat
2011/07/02 12:30:48 3001F8B0 s waiting for local card init
2011/07/02 12:30:48 3182C4F0 h HTTP Server listening on port 16002
2011/07/02 12:30:48 3001F8B0 s init for all local cards done
2011/07/02 12:30:48 3001F8B0 s anti cascading disabled
2011/07/02 12:31:31 3282D4F0 c client connected to 34000 port
2011/07/02 12:31:31 3282D4F0 c encrypted newcamd:34000-client 127.0.0.1 granted (tvr, au=on (1 reader))
2011/07/02 12:31:31 3282D4F0 c user tvr authenticated successfully (CCcam)
2011/07/02 12:31:31 3282D4F0 c AU disabled for user tvr
Testele le fac pe Skystar2 cu pluginsul Hadu 0.1.2.6.
@franta deci pe cccam nu am sa deschid tvrul? dar vad ca o poate da mai departe.
@ombre, tu citeşti ce scrie lumea pe aici ?
Mai reciteşte odata postul [Only registered and activated users can see links. Click Here To Register...]
Eu nu vad readerul tau nicaieri. Ai bagat o linie N de tvr in oscam?
Cam asa trebuie sa se vada in webif:Quote:
Va salut, mai merge combinatia CCCam+Oscam pentru TVR, deoarece nu reusesc sa-i dau de cap, am incercat setarile de aici dar nu merge.Setarile mele sunt urmatoarele:
oscam conf:
[global]
pidfile = /tmp/oscam.pid
usrfile = /var/log/oscamusr.log
logfile = /var/log/oscam.log
disablelog = 0
disableuserfile = 0
usrfileflag = 0
clienttimeout = 5000
fallbacktimeout = 2500
clientmaxidle = 120
bindwait = 120
netprio = 0
clientdyndns = 1
resolvedelay = 30
unlockparental = 0
nice = -1
serialreadertimeout = 1500
maxlogsize = 10000
waitforcards = 1
preferlocalcards = 1
saveinithistory = 1
readerrestartseconds = 5
readerautoloadbalance = 0
readerautoloadbalance_save = 0
[monitor]
port = 988
nocrypt =
aulow = 1
hideclient_to = 0
monlevel = 0
appendchaninfo = 0
[newcamd]
port = 34000@0500:000000
allowed =
keepalive = 1
mgclient = 0
[webif]
httpport = 8080
httpuser = root
httppwd = xxx
httprefresh = 10
httpallowed = 0.0.0.0-255.255.255.0
httphideidleclients = 0
httpreadonly = 0
oscam server:
[reader]
label=TVRHD
protocol=internal
detect=CD
device=/dev/sci0
group=1
emmcache=1,3,2
mhz=357
cardmhz= 357
CAID=500:000000
IDENT= 025900, 025910
ReconnectTimeout= 20
DisableServerFilter= 1
oscam user:
[account]
user =
pwd =
group = 1
au = TVRHD
caid = 500:000000
ident= 025900, 025910
cccamcfg:
N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256 1
Receptorul este dm800se clona.Multumesc pentru ajutor, orice sugestie este binevenita.
Care setari de aici?Quote:
In postul 14 sunt setarile, ale tale sunt gresite
Am un DM800 si card TVR. Am urmat setarile din postul 13. Am avut lumina, insa de ceva vreme nu imi mai decodeaza de pe card, imi decodeaza decat din linie de la CCCAM.
Am vazut in status ca nu se initializeaza SCI0, si am remarcat ca are legatura cu ora sistemului, insa ora este aiurea, iar anul 1970...daca modific manual data si ora, se initializeaza SCI0, insa tot nu citeste de pe card, imi apare ERROR (no entitlements), desi in combinatia NEWCS+Mgcamd am lumina si am subscriptie pana pe 23.10.2013.
Prima oara cand mi-a functionat era Oscam 1.20-r8241, acum folosesc 1.20 - r8972, dar tot degeaba.
Da-ti-mi vre-o idee, ce sa mai caut, ce sa mai modific...
Pune frecventele pe auto la card, s-a mai scris despre asta zilele astea pe forum.
Citeste mai mult, in principiu gasesti orice pe forum
