Si cum verifica care carti sunt in uk si care nu?Quote:
@lao - incearca sa stai pe sky 1.
Nu conteaza canalul sa ai semnal , in contract i-ti scrie seria de card cu seria receiverului nu le schimba intre ele daca zici ca ai doua
Daca sunt amandoua pe acelasi contract nu ai nici o sansa sa le folosesti in Romania pentru ca trebuie conectate permanent la linie telefonica deorece pe al doilea aparat nu se incaseaza decat 10 lire nu abo full si atunci te controleaza sa fie la aceeasi adresa
Teoretic prima activare se face tot pe linie telefonica ''call back'' fara linie telefonica doar un inginer acreditat sky te poate rezolva si asta numai in cazul ai un singur receiver la 2 nici o sansa
Iti multumesc pentru interventie, dar as fi dorit sa citesti tot threadul, ai fi aflat ca nu e o situatie clasica.
Receptorul este un Tandberg
si zice in continuare "bad smart card"
Gata!!!!
Active amandoua pe scula de mai sus. Fara imperechere!
Urmeaza o proba si in regele card-readerelor sa vedem tot ce deschide...
Sa-l pun in sci sau smargo?
---------- Post added at 23:09 ---------- Previous post was at 22:14 ----------
Cam asta a fost tot...
2011/06/15 23:05:15 2D0F54B0 c sky (0963&000000/0ee6/3E:24A5): found (70 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:05:23 2D0F54B0 c sky (0963&000000/0ee6/3E:ACEF): found (70 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:05:31 2D0F54B0 c sky (0963&000000/0ee6/3E:69B4): found (69 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:05:39 2D0F54B0 c sky (0963&000000/0ee6/3E:F928): found (70 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:05:48 2D0F54B0 c sky (0963&000000/0ee6/3E:97AB): found (69 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:05:55 2D0F54B0 c sky (0963&000000/0ee6/3E:0B84): found (70 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:06:03 2D0F54B0 c sky (0963&000000/0ee6/3E:CCEC): found (69 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:06:11 2D0F54B0 c sky (0963&000000/0ee6/3E:82CC): found (69 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
2011/06/15 23:06:20 2D0F54B0 c sky (0963&000000/0ee6/3E:8ACC): found (79 ms) by sky (of 1 avail 1) - 0963:0ee6 unknown
Are cineva idee daca se poate face AU in alt box, unul cu care nu este pereche? Box tot de sky.
Cam ca la cartile mioritice...
Si cam cum vin emm-urile, zilnic, la inceput de luna, etc, ca am unul care a stat cam mult in sertar.
Pentru cine e interesat face AU si in box strain, chiar daca nu e imperecheat.
Bineinteles ca nu deschide in acel box, dar AU face.
am sky uk pachet original si movies.
folosesc oscam in vusolo2
canalele de baza merg in oscam cele de filme nu deschid
stb original cel HD
mai exista vreo solutie de "vindecare" si sa deschida si canalele de filme (sky movies)?
sau....
multumesc de raspunsuri
caid 0960 (card rosu) deschide tot ce e SD (oscam)...si citeodata da "rateuri" si da din el si BT-urile HD !
caid 0963...nici o sansa la HD in stb strain, numai SD...tot oscam.
ce card ai? in ce i-ai facut update? ai pus bine seria (in hex) in oscam?
e cardul alb 0963
update in recul original
am avut prima data canalele de baza (pachet original) si inca imi merg din local.
acum cateva zile am decis sa adaug si canalele de filme. alea nu le ia din local numai din..... :)
am doar canalele sd contratate nu si cele hd. stiam ca alea nu mai merg in oscam
deci nici o sansa?
cine rezolva ii dau linie N :D
ce oscam folosesti? posteaza configul (fara box-id :) )Quote:
0960@000000:1134:FFFF Sky Movies Premier 0063 found 105 106 580 28.11.15 11:39:59
0960@000000:1135:FFFF Sky Movies Premier +1 0063 found 105 109 303 28.11.15 10:36:31
care canale nu itzi deschide?... ce zice oscam? dcw = 0? posteaza ceva loguri...
[reader]
label = skyuk
protocol = pcsc
device = 1
caid = 0963
boxid =
detect = cd
ident = 0963:000000
group = 3
emmcache = 1,3,2
blockemm-unknown = 1
blockemm-g = 1
lb_weight = 101
audisabled = 1
- 2015/11/29 19:28:06 75E62498 c dvbapi (0963&000000/FFFF/1658/63:4CE7973601587CCAEAE6E91E60856683): rejected group (2 ms) - Sky Showcase (no matching reader)
- 2015/11/29 19:28:06 75E62498 c dvbapi (0963&000000/FFFF/1658/63:4CE7973601587CCAEAE6E91E60856683): rejected group (1 ms) - Sky Showcase (no matching reader)
- 2015/11/29 19:28:06 75E62498 c [DVBAPI] Demuxer #0 impossible to descramble PID #1 CAID 0961 PROVID 000000 ECMPID 0504 PMTPID 0119 (NO MATCHING READER)
- 2015/11/29 19:28:06 75E62498 c [DVBAPI] Demuxer #0 impossible to descramble PID #2 CAID 0960 PROVID 000000 ECMPID 0504 PMTPID 0119 (NO MATCHING READER
- 2015/11/29 19:33:14 75E62498 c dvbapi (0963&000000/FFFF/1134/63:8EE4E300256984520225B9C6D7E7F297): rejected group (1 ms) - Sky Movies Premier (no matching reader)
- 2015/11/29 19:33:14 75E62498 c dvbapi (0963&000000/FFFF/1134/63:8EE4E300256984520225B9C6D7E7F297): rejected group (2 ms) - Sky Movies Premier (no matching reader)
- OSCAM: 1.20-modern Build: r1132 Compiler: mipsel-openpli40-linux-gnu-ssl-libusb-pcsc
deci nu deschide nimic din canalele sky movies
cite tiers-uri ai deschise? nu folosesti whitelist? ce zice cardul la initializare? tot ok? dupa ce ai luat pachetul movies, ai mai multe tiers-uri?
schimba canalul din unu care merge in unu care nu merge si viceversa...posteaza logul de oscam -> debug=4
15 entitlements
- 2015/11/29 20:04:45 5C0428 c dvbapi (0963&000000/FFFF/C78B/63:CB9F19044E39A9AEDC179BAC69DC3D58): found (92 ms) by skyuk - Comedy Central +1 UK
- 2015/11/29 20:05:35 5C0428 c dvbapi (0963&000000/FFFF/164F/63:7E48B37225F46F4206CA60DA5A88EC22): found (93 ms) by skyuk - Sky Atlantic
- 2015/11/29 20:06:21 5C0428 c dvbapi (0963&000000/FFFF/10D0/63:7AA8C49C5EA351D8128F75665FB6E025): rejected group (1 ms) - Sky SciFi / Horror (no matching reader)
- 2015/11/29 20:06:21 5C0428 c [DVBAPI] Demuxer #0 impossible to descramble PID #1 CAID 0961 PROVID 000000 ECMPID 0509 PMTPID 0102 (NO MATCHING READER)
- 2015/11/29 20:06:21 5C0428 c [DVBAPI] Demuxer #0 impossible to descramble PID #2 CAID 0960 PROVID 000000 ECMPID 0509 PMTPID 0102 (NO MATCHING READER)
nu folosesc whitelist
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] cardreader_do_ecm: after csystem.do_ecm rc=1
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] cardreader_do_ecm: ret rc=1
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] cardreader_process_ecm: cardreader_do_ecm returned rc=1 (ERROR=0)
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] ecm hash: 7DC259B6741291B11203E3132C734ACB real time: 92 ms
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] cardreader_do_checkhealth: reader->card_status = 2, ret = 1
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] cardreader_do_ecm: cardreader_do_checkhealth returned rc=1
- 2015/11/29 20:14:17 5BE6B8 r skyuk [videoguard2] write to cardreader
nu sint de ajuns logurile ca sa-mi dau seama unde e buba... poate nu ai lasat indeajuns sa faca update...eu am 24 de tiersuri...
daca esti pe aici in seara asta, arunc o privire ...
ciudat
pentru ca in stb original imi deschide
