am pus e2 pe un azbox premium se pare ca tuneru merge am dat scan la 19e apar toate canalele dar nu am imagine pe nicun canal
Este vorba doar de o versiune "beta", finalizata prin 02.09. O versiune functionala, cu drivere incluse, se va lansa in perioada urmatoare. Este o chestiune de zile sau saptamani, in funcţie de cum merg lucrurile. Sa speram ca de Craciun putem renunta pentru totdeauna la firware-ul Opensat, care multora le-a scos peri albi.
AzBox HD Web Interface v 1.0 by DDamir
I uploaded new em8634dvb.ko file. Pls replace old one from /lib/modules/2.6.22.19-19-the_ripper/extra/.
There is bootup file too, replace it from /etc/init.d, so you can activate showiframe bootlogo.
Reboot pls.
I started writing down changes.txt for DVB driver.
un pic de "lumina" in E2:
doar pentru Elite/Premium
What is new ?
- FTA SD and HD channels working. ( DD 2.0 , AC3 working by HDMI tested on Einsfestival HD )
- New IR driver ( few more mapped buttons e.g Info button, Audio selection is Check button on RCU )
- Fixed Section filters and PID selection.
- Added part of CA system
- Multimedia support for MPEG2 , MPEG4 ( XviD ), h264, and various audio support.
- Please read ReadMe file if You want also to install additional things to get working Multimedia by Media Player in E2.
- If You have Full HD TV , You can set resolution by editing bootup file located in :
/etc/init.d
Find line :
below You will see line insmode ...Code:# Elite and Premium
and replace existing insmode line with this one :
Few tips :Code:insmod /lib/modules/2.6.22.19-19-the_ripper/extra/em8634dvb.ko options="-analog -f PAL_BG -digital -f HDMI_1080p50 -hdmi_chip SiI9030 0 14 15 100 0"
Before loading Enigma 2 , move Your dish to some satellite ( Astra 19.2 e is good because of FTA HD channels ), as on E2 currently we didnt fix DiseQc bug ( We will fix it when we finish Premium+ driver ).
Try to use Simple configuration in Tuner Configuration, e.g choose satellite on which position currently You are.
README for MULTIMEDIA :
First download 2 .so filles attached to this post and put them in :
/usr/lib/gstreamer-0.10 directory, and after that follow procedure below :
If You see error while installing .ipk files, that is ok, dont worry about it, but dont forgett to transfer 2 .so files attached to my post in addons.zip archive to directory :Code:If You want also to test Multimedia on AzBox Enigma 2 media player , You have to install 3 IPK files located in this archive :
gst-plugin-asf_0.10.16-r0.0_mipsel.ipk
gst-plugin-avi_0.10.25-r0.0_mipsel.ipk
gst-plugin-dvbmediasink-dbg_0.10+cvs20101006-r0_dm800.ipk
working formats:
audio: mpeg, aac, ac3, dts, wma (but not pro), pcm (not all ?)
video: mpeg2, mpeg4 (xvid), h264 (only show singe frames)
IPK Installation procedure :
Transfer 3 *.ilk files to /tmp folder of Your AzBox and run this commands, one by one :
ipkg install /tmp/gst-plugin-asf_0.10.16-r0.0_mipsel.ipk
ipkg install /tmp/gst-plugin-avi_0.10.25-r0.0_mipsel.ipk
ipkg install /tmp/gst-plugin-dvbmediasink-dbg_0.10+cvs20101006-r0_dm800.ipk
If You cant use ipkg install, use command opkg install or ipkg-extract .
Metoda alternativa de instalare E2
patch.bin in fat32 usb pen, update boot menu, press update, then reboot, then open azup and press "update" with usb stick STILL in azbox hd, using IP that shows in VDF.
then after update goes to 100%, remove usb and reboot.
all should go well to 100% in VDF display.
Wireless for Premium and Premium+
Thanks to joseba for providing and compiling driver !
Download [Only registered and activated users can see links. Click Here To Register...], unzip it, and transfer whole folder wlan by FTP to /tmp folder on Your receiver
Connect to Your receiver by telnet and execute this commands :
mkdir -p /etc/Wireless/RT61STA
cd /tmp
cp /tmp/wlan/rt2561.bin /etc/Wireless/RT61STA/
cp /tmp/wlan/rt2561s.bin /etc/Wireless/RT61STA/
cp /tmp/wlan/rt2661.bin /etc/Wireless/RT61STA/
cp /tmp/wlan/rt61sta.dat /etc/Wireless/RT61STA/rt61sta.dat
dos2unix /etc/Wireless/RT61STA/rt61sta.dat
cd /lib/modules/2.6.22.19-19-the_ripper/kernel/
mkdir drivers
cd drivers
mkdir net
cd net
mkdir wireless
cp /tmp/wlan/rt61.ko /lib/modules/2.6.22.19-19-the_ripper/kernel/drivers/net/wireless
modprobe rt61.ko
cd /tmp
wget [Only registered and activated users can see links. Click Here To Register...]
ipkg install wireless-tools_29-r5_mipsel.ipk ( If error appear dont worry )
ifconfig ra0 192.168.1.22 up ( my gateway is 192.168.1.1, so i put ifconfig ra0 192.168.1.22 up )
iwlist ra0 scanning ( this will list available networks in your range )
output will be something like this :
iwconfig ra0 essid HomeLanCode:root@AZBox:/tmp# iwlist ra0 scanning
ra0 Scan completed :
Cell 01 - Address: 00:0C:21:16:DD:2A
Mode:Managed
ESSID:"HomeLan"
Channel:6
Encryption key:on
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 6 Mb/s; 9 Mb/s
11 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s
48 Mb/s; 54 Mb/s
Quality:82/100 Signal level:-57 dBm Noise level:-111 dBm
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
Authentication Suites (1) : PSK
iwconfig ra0 mode Managed
iwconfig ra0 channel 6 ( as my network broadcast on channel 6, in Your case choose what is appropriate for Your network ).
iwconfig ra0 key s:mywpakey (mywpakey will be your network key ).
Result is when i ping it from my pc :
MickeySa:~ mickey$ ping 192.168.1.22
PING 192.168.1.22 (192.168.1.22): 56 data bytes
64 bytes from 192.168.1.22: icmp_seq=0 ttl=64 time=5.569 ms
64 bytes from 192.168.1.22: icmp_seq=1 ttl=64 time=3.591 ms
64 bytes from 192.168.1.22: icmp_seq=2 ttl=64 time=1.501 ms
64 bytes from 192.168.1.22: icmp_seq=3 ttl=64 time=1.637 ms
64 bytes from 192.168.1.22: icmp_seq=4 ttl=64 time=1.649 ms
64 bytes from 192.168.1.22: icmp_seq=5 ttl=64 time=1.738 ms
64 bytes from 192.168.1.22: icmp_seq=6 ttl=64 time=1.533 ms
64 bytes from 192.168.1.22: icmp_seq=7 ttl=64 time=1.795 ms
64 bytes from 192.168.1.22: icmp_seq=8 ttl=64 time=1.754 ms
64 bytes from 192.168.1.22: icmp_seq=9 ttl=64 time=1.649 ms
Thats all, soon GUI version.
This procedure works also with Elite model, which have WiFi stick with this RT chipset
pentru teste cu CCcam folositi mipsel pentru DM.
control media: hdb1 = HDD
for scrambled channels:
new driver [Only registered and activated users can see links. Click Here To Register...] attached ...
It is necessary to unpack the new file and FTP to transfer the location
azbox hd elite ENIGMA2 CCCAM FAST ZAPPING
Da , se misca bine, avand in vedere ca e o versiune alpha.
Unele blocari, cateva green screen dar sa nu cerem prea mult in momentul de fata.
Testat cu cccam214, mgcamd135a, si oscam 093080
cu mgcamd a decodat 2 canale dupa care s-a blocat, cccam ruleaza destul de bine,dar cu unele blocari pe HD, insa cu oscam merge mult mai stabil+zapp mai bun.
In media player mai e foarte mult de munca, ....nu a rulat nimic din contentul meu din HDD(doar mp3).-sper sa ajunga la nivelul fw.OpenSAT, altfel....nu vad rostul E2 pe azbox.
Scanarea e foarte lenta,insa puteti incarca cu Dreamset(fw.Enigma2 ver4).
pentru a testa canalele codate nu uitati sa inlocuiti driverul postat mai sus(chmod755+reboot).
**La incarcarea cu vechea versiune AZUP am avut o eroare de instalare-am dezinstalat si instalat versiunea prezenta in arhiva E2_Update_1.0.25.rar, si totul a mers OK.
inapoi la 4890!
am instalat noua versiune e2 de test. si am vrut sa revin la Firmware Official si in loc sa pun 0.9.5020 am pus 0.9.4466 si cred ca lam busit nu ma mai pot conecta cu nimic la box nici cu azup nu mai ia nici usb scrie booting si asa ramine
nu trebuie neaparat 5020, din cate am inteles nu sunt recomandate versiune KGD.
pune o alta versiune de fw.bin( em am mers cu 4890) pe flash disk si opeste/reporneste-l din spate cu stickul in portul USB intrat.
nimic mort booting apare si atit
incearca sa schimbi usb-ul, formatat fat32, redenumire in patch.bin si incearca cu o versiune 0.9.2372 sau mai veche.
Daca nu vrea, .....JTAG sau probleme DOM.
am incercat toate vatiantele a mai ramas jtagu am mai resuscitat un strong cu el dar asta cred ca e mai complicat
vezi postul #12, iei legatura cu @radu67 daca nu te descurci.
bafta
merci mult man sper sal fac
---------- Post added 23-10-10 at 00:10 ---------- Previous post was 22-10-10 at 23:30 ----------
am inteles ca merge cu interfata max232 cu jtagu nu merge ?
Project Valerie
project valerie
The aim of project valerie is to create an easy to use full feature media center for all enigma2 based set top boxes.
am instalat noua versiune e2 de test. si am vrut sa revin la Firmware Official si in loc sa pun 0.9.5020 am pus 0.9.4466 si cred ca lam busit nu ma mai pot conecta cu nimic la box nici cu azup nu mai ia nici usb scrie booting si asa ramine Am construit o interfata Com TX RX am pornit putty Speed 115200 pornesc azboxul si in terminal apare UUU si nu pot da nico comanda
Aveţi nevoie de:
TFTPD32
backup_kernel
chit
Interfaţă serială pentru conectarea la AZBox
Trebuie să ştii că adresa IP a computerului dvs., puteţi afla dacă introduceţi PROMT comanda,
inseamnă că sunteţi de gand să inceapă şi să rulaţi in caseta de tip cmd şi apăsaţi ENTER, apoi tastaţi ipconfig şi introduceţi şi veţi obţine informaţii despre adresa IP
Presupunand că adresa IP a computerului: 192.168.1.12 (necesar de mai jos)
In acest caz, vom alege adresa IP pentru rang AZBox in cazul in care IP a computerului, vom spune: 192.168.1.34
1.Pokrenite TFTPD32
2.Start Putty, a comuta la serial, introduceţi portul COM unde aţi conectat interfata seriala, introduceţi viteza de 115200
3.Povezite interfata seriala cu AZBox şi rotiţi AZBox
4.Pratisnite CTRL + C pentru a opri bootiranje
5.kucajte:
y.ipaddr setxenv "192.168.1.34"
y.gateway setxenv "192.168.1.1"
y.subnetmask setxenv "255.255.255.0"
net init
b-sarcină tftp: / / 192.168.1.12/backup_kernel 0xb0100000
pflash scrie-f 0x80000 0xb0100000 0x680000
Acum, aşteptaţi pană la prima contururile flash, apoi introduceţi un nou conţinut.
Acest lucru durează aproximativ 5-6minuta, rabdare pentru a finaliza şi in cele din urmă vă rebootajte AZBox.
Dacă totul a mers bine, veţi obţine la TV intr-o actualizare standard care ştiţi că,
introduceti stick-ul USB cu Oficial FW-om şi ubacitega ca inainte.
