Am reusit cu
ifconfig eth0 down
ifconfig eth0 hw ether 00:00:00:00 (macul)
ifconfig eth0 up
Asa la toate placile.
Pentru ca am 3 mac-uri inregistrate am reusit sa fac 3 placi sa mearga. De aici incolo am bifat la uplink "multipath".
Code:
Merge multiple Internet Uplinks together either as Failover, where all outgoing connections are sent over the first available interface or as Multipath, where outgoing connections are balanced over all available interfaces.
The interface list is sorted by descending priority. After activation Packet Filter and DynDNS configuration options regarding the first interface are replaced by the newly created objects Uplink Interfaces and Uplink Primary Addresses.
For connectivity monitoring either select automatic mode or specify one or more hosts.
Momentan nu vad nici o diferenta. Mai am ceva de facut?
ASTARO functioneaza perfect. Problema e alta:
Pe firul de retea, in camera, nu vine mai mult de 1mbps/fir si nu pe mac.
Daca pun un switch, leg 2 laptopuri cu mac-uri inregistrate, pica tot.
Netul merge pe amandoua doar ca daca dau ping la google.ro am peste 800ms iar daca scot unul dintre laptopuri din switch pingul scade la sub 70ms.
De aici totul se blocheaza. Acuma imi dau seama de ce nu mergea uplink balancing.
In concluzie, va multumesc pentru tot. :cheers:
