Cccam nu deschide TVR.
merci @zmeura,
vad ca merge si combinatia oscam+MultiCAS
oscam+CCcam2.1.4
asta imi da in telnet,
asta nu zice CCcam:Code:>> OSCam << cardserver started version 0.99.4svn, build #1211 (mipsel-azbox-linux-uclibc)
2010/02/26 8:09:35 1283 s AZBOX internal card reader by http://www.satdream.ru/forum/
2010/02/26 8:09:35 1283 s AZBOX project maintainer at Germany by http://www.pristavka.de
2010/02/26 8:09:35 1283 s Open OpenXCAS interface
[OPENXCAS_API:Fri Feb 26 08:09:35.517] load_xcas_control:68 ## loaded controller ID = 0x19760507
osdep_msq_server_open : key_request 0x51ABA284 key_response 0x51ABA285
key(51aba284), msgflg(448)
key(51aba285), msgflg(448)
osdep_msq_client_connect : key_request 0x51ABA284 key_response 0x51ABA285
2010/02/26 8:09:36 1283 s auth size=4740
2010/02/26 8:09:36 1283 s services reloaded: 0 services freed, 2 services loaded
2010/02/26 8:09:36 1283 s userdb reloaded: 0 accounts freed, 1 accounts loaded, 0 expired
2010/02/26 8:09:36 1283 s signal handling initialized (type=sysv)
2010/02/26 8:09:36 1283 s 2276 service-id's loaded
2010/02/26 8:09:36 1283 s 1 lengths for caid guessing loaded
2010/02/26 8:09:36 1283 s monitor: initialized (fd=6, port=988)
2010/02/26 8:09:36 1283 s camd 3.3x: disabled
2010/02/26 8:09:36 1283 s camd 3.5x: disabled
2010/02/26 8:09:36 1283 s cs378x: disabled
2010/02/26 8:09:36 1283 s newcamd: initialized (fd=7, port=34000, crypted)
2010/02/26 8:09:36 1283 s CAID: 0500
2010/02/26 8:09:36 1283 s provid #0: FFF720
2010/02/26 8:09:36 1283 s provid #1: 025900
2010/02/26 8:09:36 1283 s provid #2: 025910
2010/02/26 8:09:36 1283 s provid #3: 000000
2010/02/26 8:09:36 1283 s radegast: disabled
2010/02/26 8:09:36 1283 s resolver thread started
2010/02/26 8:09:36 1283 s logger started (pid=1288)
2010/02/26 8:09:36 1283 s resolver started (pid=1289, delay=30 sec)
2010/02/26 8:09:36 1283 s reader started (pid=1290, device=/dev/scard)
2010/02/26 8:09:36 1283 s Waiting for local card init ....
2010/02/26 8:09:36 1290 r02 OpenXCAS open /dev/scard0
2010/02/26 8:09:36 1290 r02 card detected
2010/02/26 8:09:41 1290 r02 ATR: 3F 77 18 00 00 C2 14 00 C1 68 90 00
2010/02/26 8:09:42 1290 r02 type: viaccess(standard atr), caid: 0500, serial: 3211025502
2010/02/26 8:09:43 1290 r02 providers: 3 (FFF720,025900,025910)
2010/02/26 8:09:43 1290 r02 ready for requests
2010/02/26 8:09:43 1290 r02 card detected
2010/02/26 8:09:43 1290 r02 serial: 321........
2010/02/26 8:09:44 1290 r02 provider: 1, id: FFF720, name: TVR, sa: BF645C5E, geo: empty
2010/02/26 8:09:45 1290 r02 provider: 2, id: 025900, name: TVR 1, sa: BF645C5E, geo: FF FF FF FF
2010/02/26 8:09:45 1290 r02 class: FF, expiry date: 2010/02/18 - 2010/03/19
2010/02/26 8:09:45 1290 r02 provider: 3, id: 025910, name: TVR 2, sa: BF645C5E, geo: FF FF FF FF
2010/02/26 8:09:45 1283 s Init for all local cards done !
2010/02/26 8:09:45 1283 s anti cascading disabled
2010/02/26 8:09:45 1283 s serial: initialized (pid=1291, auto@/dev/ttyS0)
2010/02/26 8:09:45 1283 s client(2) connect from 127.0.0.1 (pid=1292, pipfd=16)
2010/02/26 8:09:45 1292 c02 encrypted newcamd:34000-client 127.0.0.1 granted (qwess, au=tvrhd)
2010/02/26 8:09:45 1292 c02 user qwess authenticated successfully (using client 4343)
2010/02/26 8:09:45 1292 c02 AU flag 0 for user qwess
Code:+------------------------------+------------+---------+--------+----------------+-------+-------------------------------+
| Host | Connected | Type | Version| NodeID | Cards | CAID/Idents |
|127.0.0.1:34000 |00d 00:01:18|newcamd | | | 1 | :oops:
P.S. interesanta ultima versiune de MultiCAS cu cccam client+newcamd=1Code:+----+----------+------------------------------------+--------+
|Caid| Provider | Provider Name | System |
| 500| fff720|[Viaccess] Issuer TVR Cultural (Old)|viaccess|
| 500| 25900|[Viaccess] TVR (16E) |viaccess|
| 500| 25910|[Viaccess] TVR(ID.Unused) |viaccess|
| 500| |[Viaccess] Viaccess CAid |viaccess|
Oscam face update la perioada de valabilitate si/sau la keys pentru cartela TVR HD?Quote:
imi merge prin newcs+mgcamd, newcs+MultiCAS, oscam+mgcamd
la oscam+CCcam2.1.4 prin newcamd, oscam face updare dar cccam-ul nu recunoaste cartela.
Nu am setat bine CCcam, sau nu stie sa citeasca prin card reader intern?
Un fisier oscam.conf ar fi de ajutor pentru cei neinitiati. In plus, care ar fi versiunea recomandata?
Multumesc anticipat.
Inca nu stiu daca face update la perioada de valabilitate, cred ca da...
atasez un link cu oscam_0.99.4_1211svn, configurat pentru cartela TVR,reader intern.
copy: /EMU/OpenXCAS/oscam[chmod755]--Code:protocol = internal
device = /dev/scard
pentru mgcamd/MultiCAS:
de vazut oscam(*.conf; *.user; *.server)Code:N: 127.0.0.1 34000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
Am incarcat modulul de la qwess, este recunsocuta cartela, dar perioada de valabilitate este tot pana la sf. lui 2009.Quote:
Originally Posted by qwess [Only registered and activated users can see links. Click Here To Register...]
Dintr-o discutie cu cei de la TVR am inteles ca este incarcata toata baza de date cu valabilitate pana pe la sf. lui august 2010. Daca eu nu am mai intrat din 2009 pe TVR HD, este posibil sa fie dezactivata cartela mea?
Poate confirma cineva ca oscam face update si la perioada de valabilitate?
Eu cred ca le puteti face cauza. Atata timp cat exista o perioada de acitivitate, aceasta trebuie sa fie activa. Deci, ei prin anumite mijloace incearca sa elimine din punct de vedere al consumatorului anumite drepturi pe deplin platite. In acelasi timp ei sunt obligati sa dea drumul transmisiei si in cazul riceiverelor alternative, asta in caz ca ei pun la dispozitie unul legitim.
Deci, facetzi voi.................
si la mine a expirat perioada de valabilitate(19.03), si de atunci intuneric.
cumparat de.....o luna:clap:
dupa ce l-am cumparat s-a activat cam in 5 min.
nu mai vrea nici prin newcs nici prin oscam.
o solutie ceva?Quote:
2010/03/24 9:42:14 1210 r02 provider: 1, id: FFF720, name: TVR, sa: BF645C5E, geo: empty
2010/03/24 9:42:14 1210 r02 provider: 2, id: 025900, name: TVR 1, sa: BF645C5E, geo: FF FF FF FF
2010/03/24 9:42:15 1210 r02 class: FF, expiry date: 2010/02/18 - 2010/03/19
2010/03/24 9:42:15 1210 r02 provider: 3, id: 025910, name: TVR 2, sa: BF645C5E, geo: FF FF FF FF
2010/03/24 9:42:16 1203 s Init for all local cards done !
2010/03/24 9:42:16 1203 s anti cascading disabled
2010/03/24 9:42:16 1203 s client(1) connect from 127.0.0.1 (pid=1211, pipfd=16)
2010/03/24 9:42:16 1211 c01 encrypted newcamd:34000-client 127.0.0.1 granted (qwess, au=tvr)
2010/03/24 9:42:16 1211 c01 user qwess authenticated successfully (using client 6D67)
2010/03/24 9:42:16 1211 c01 AU flag 0 for user qwess
2010/03/24 9:42:16 1211 c01 qwess (0500&025900/000F/6B:F7EA): not found (6 ms)
2010/03/24 9:42:18 1211 c01 qwess (0500&025900/000F/6B:F7EA): not found (7 ms)
2010/03/24 9:42:20 1211 c01 qwess (0500&025900/000F/6B:F7EB): not found (6 ms)
Bagal intr-un modul cam face sigur
Code:Viaccess card
Caid 500
Cardserial bf645a
ident fff720 - bf645a
ident 25900 - bf645a
ident 25910 - bf645a
valid from 1-3-2010 untill 31-3-2010
valid from 1-1-2010 untill 31-1-2010
valid from 5-12-2009 untill 26-8-2010
valid from 1-12-2009 untill 31-12-2009
valid from 3-11-2009 untill 26-8-2010
valid from 5-10-2009 untill 26-8-2010
valid from 16-7-2009 untill 14-8-2009
multumescQuote:
Originally Posted by Diablo1 [Only registered and activated users can see links. Click Here To Register...]
cred ca e singura solutie,xml-ul cred ca este bine configurat, in ultima instanta am si telefonat la ei pentru reactivare(0213199112 /405), nimic...nu isi face update.
printr-un module via se modifica frecventa in newcs/oscam, este setat in 357MHz?
Nu are treaba cu MHz daca ai camul bagi cartela si in nici 2 minute se lumineaza Tv
Eu il bag in Dm 8000 si nu mai am dureri de cap :)
Eu il folosesc in Dm800 Cu Mgcamd1.313/NewsCS 1.67 si merge foarte bine.
Viaccess card
Caid 500
Cardserial bf645a
valid from 29-1-2010 untill 26-8-2010
valid from 15-12-2009 untill 26-8-2010
valid from 1-11-2009 untill 30-11-2009
valid from 1-10-2009 untill 31-10-2009
valid from 29-9-2009 untill 28-10-2009
valid from 25-9-2009 untill 26-8-2010
valid from 1-9-2009 untill 30-9-2009
Cine incearca combinatia Mgcamd1.313/NewsCS 1.67 sa verifice daca un usr/keys are fisierele ignore.list , mg_cfg ,newcamd.list si priority.list altfel nu merge.
salut nu stiti de ce o scazut asa de mult fregventa la tvr hd inainte imi intra 68 la suta cu antena de 1 m si acuma imi piseleaza nu intra nici 50
nu stiu ce sa mai fac stau in spania stiti daca o sa scimbe iara fregventa pe care a avuto sau nu
multumesc pentru raspuns
Nu vrea nici cu modul viaccess :!: :!: :!: aceeasi perioada, <19.03.
Am sunat si la dep.tehnic si se pare ca sunt ceva probleme, ii sun luni iar.
@Snow tu ai reusit?Quote:
Voi cu ce mai faceti update la cartela de tvr? La mine nu mai vrea.
La mine am mers cu mgcamd+newcs dupa ce-am vorbit la ei si am cerut o reactivare.
Ne poti spune ce versiuni utilizezi pentru mgcamd si newcs?Quote:
Originally Posted by Snow [Only registered and activated users can see links. Click Here To Register...]
Dupa ce ai sunat pentru reactivare, dupa cat timp s-a luminat? [Only registered and activated users can see links. Click Here To Register...]
PS. Un fisier de configuratie ar fi de ajutor pentru noi ceilalti.
Uite o combinatie in care merge la mine , s-a activat prima data acum 3 luni si de atunci nu am treaba cu el !
download din adons mgcamd 1.35a si newcs 1.67 si inlocui-ti doar fisierele de mai sus !
ps: pentru E2
Mai avem de asteptat un fw cu E2 (sau macar modulul TV) pe AZBox, asa ca ar fi de ajutor o configuratie pentru versiunea actuala de fw.Quote:
ps: pentru E2
am luat un cam viaccess pentru cartela tvr, dar nu deschide TVRHD
mentionez ca acum 3-4 luni mi-a mers cu newcs+mgcamd, poate s-a blocat intre timp?
trebuie sa sun la tvr pentru activare?
in common interface, recunoaste cartela, dar la "subscription information" nu apare valid until....
eventual unde sa setez prioritatea de citire de pe cam, ca s-ar putea sa caute cheile prin cccam
mersi
ron
suna pentru activare poate ai noroc.
la mine de cand a expirat nu isi mai face activarea, nici cu newcs/oscam+mgcamd nici prin CI(modul viaccess), iar pe debian via smargo la fel.
tind sa cred ca se intampla ceva la acesarea bazei de date de la ei, nu mai vrea prin nici un fel de reader si nici prin modul viaccess.
Apropo e cineva care a facut re/activare recenta la card, in ultimile 3 saptamani?
In sfarsit si-a reluat activitatea!!!!
valid from 27-3-2010 untill 26-8-2010
valid from 18-2-2010 untill 19-3-2010 ,
merge perfect "momentan" si prin combinatia:
in azbox prin cititor intern:
newcs--Nline(fara terminatie 256)--cccam 2.1.4(server/client)--Cline--MultiCAS(HOP1)
:!:in combinatia newcs+cccam+multicas/simultan:multicas se conecteaza la cccam doar prin terminal.(telnet) ...cazul meu
newcs--mgcamd ramane doar pentru prelungire valabilitate.
in Debian (PC)prin Smargo:
doar CCcam.x86 2.1.4(recunoaste direct cardul-/dev/ttyUSB0)->-Cline->-MultiCAS(HOP0)
