cu cccam+newcs nu mai vad nici ce am in local !Quote:
Originally Posted by dan2000 [Only registered and activated users can see links. Click Here To Register...]
ce as mai avea de configurat ca doar ramäne cfg.
In newcs trebuie sa ai cam asa:
<newCSconfig>
<readers name="sci">
<device>
<name>lower</name>
<type>sci</type>
<node>/dev/sci0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>no</blocksa>
<blockua>no</blockua>
<blockga>No</blockga>
<boxkey></boxkey>
<rsa></rsa>
<irdeto-camkey>0000000000000000</irdeto-camkey>
<irdeto-camkey-data>00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000</irdeto-camkey-data>
<crypto-special>No</crypto-special>
<ipk>00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000</ipk>
<ucpk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>34001</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
</readers>
<radegastserver>
<enabled>No</enabled>
<port>16000</port>
<allow>
<hostname>localhost</hostname>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server>
<port>12354</port>
<enabled>yes</enabled>
</server>
<user>
<name>admin</name>
<password>admin</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<password></password>
<level>normal</level>
<type>init</type>
<output>console,tcp</output>
<console_options>normal,init</console_options>
<tcp_port>12356</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<user>
<name>mydream</name>
<password>mydream</password>
<au>on</au>
<spider>off</spider>
<rate>0</rate>
<sidoverride>on</sidoverride>
<status>access</status>
</user>
</newcamdserver></newCSconfig>
binenteles ca trebuie pus boxkey la <boxkey></boxkey>si rsa-ul la <rsa></rsa>
acum in ccam.cfg pui o linie de forma
N: 127.0.0.1 34001 mydream mydream 01 02 03 04 05 06 07 08 09 10 11 12 13 14
atentie nu copiati direct, in exemplu e dat ptr cardreaderul dm . ptr phoenix la dream trebuie sa arate cam asa newcs.xml :
<newCSconfig>
<readers name="Phoenix">
<device>
<name>Lower Cardreader</name>
<type>sci</type>
<mhz>357</mhz>
<blocksa>No</blocksa>
<blockua>No</blockua>
<!-- <boxkey>0000000000</boxkey> -->
<!-- <rsa>0000000000</rsa> -->
<newcamd_port>15000</newcamd_port>
</device>
<device>
<name>Phoenix Interface</name>
<type>phoenix</type>
<mhz>368</mhz>
<node>/dev/tts/0</node>
</device>
iar ptr pc cu win :
<device>
<mhz>368</mhz>
<node>COM1</node>
</device>
Dupa cum vad pe COM2 este :Quote:
Originally Posted by Snow [Only registered and activated users can see links. Click Here To Register...]
=> pe COM1 este la fel inainte de a porni newcs-u.Code:Baud_base: 115200
- dupa ce il seteaza newcs-u este asa :
Code:/dev/ttyS0, Line 0, UART: undefined, Port: 0x03f8, IRQ: 4
Baud_base: 921600, close_delay: 50, divisor: 8
closing_wait: 3000
Flags: spd_cust skip_test
man @snow se referea la <rate></rate>, cu ce viteza comunica pe seriala e treaba newcs.
Am gäsit ceva interesant la fratii nostri polonezi
Cred ca e interesant si pentru noi
Poate cineva sa traduca ?
Poate cineva sa traduca ?[/QUOTE]
ati avea curajul sa va trimiteti boxele cu cartela la Polonezi ???
Eu unul Nu asi avea- imi pare prea riscant
mai ales ca nu cunosc limba sa te poti intelege cu ei
Angel din cate cunosc eu nu trebuie si boxele ci doar ce bagi in ele :D si ti se de rezolvarea
