incearca asta [Only registered and activated users can see links. Click Here To Register...]
Am pus si pe zshare:
Succes!
cateva modificari
asa este corect in cccam.cfg
daca vrei sa pui card de focussat in share pe cccam in cccam.cfg trebuie sa ai urmatoarele linii:
SMARTCARD CLOCK FREQUENCY: /dev/sci0 3570000
TRY ALL CHIDS : /dev/sci0
CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
se considera ca aveti dm 500 care are un singur sl0t de cartela, oricum daca aveti mai multe sloturi inlocuiti sci0 cu sci1
SMARTCARD CLOCK FREQUENCY: /dev/sci1 3570000
TRY ALL CHIDS : /dev/sci1
CAMKEY: /dev/sci1 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
daca aveti si pheonix reader
mai adaugati:
SERIAL READER : /dev/tts/0
PHOENIX READER PATH : /dev/tts/0
si rezulta :=>
SMARTCARD CLOCK FREQUENCY: /dev/tts/0 3570000
TRY ALL CHIDS : /dev/tts/0
CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
CAMDATA: /dev/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
pentru card de dolce procedati ca mai sus cu diferenta ca frecventa de lucru a cardului este 5250000
si mai adaugati si urmatoarele linii:
BOXKEY: /dev/sci0 xx xx xx xx
B: /dev/sci0 00
B: /dev/sci1 00
PIN: /dev/sci0 0000
unde xx xx xx xx se gasesc astfel
nds box key find
serial nr of original box= adcdef1234567890
please use 123456789 in hex=75BCD15
from obtain use windows default scientific calculator put in decimal
and push hex to convert box key in hex,
add one 0 first digit= 075BCD15 this is the ready hex box key u can update by remote control "
adica pe romaneste din Identitatea receptorului (la dolce este in contract) care are mai multe cifre trebuie sa iei ultimele 10 cifre ,"scazi" (tai) ultima cifra deci numai "123456789 " (vezi ce e cu bold) si iti raman numai 9 cifre care trebuie convertite din sistem decimal in sistem hex cu windows calculator format scientific rezultand doar 7 caractere la care adaugi un zero " 0 " in fata ca sa fie 8 caractere xx xx xx xx
Originally Posted by dream007 [Only registered and activated users can see links. Click Here To Register...]
Pentru cardul de focussat NU TREBUIE configurat NIMIC in CFG!! cardul merge de la sine,il pui in dream si e ok atat ca simplu card cat si pentru share!! nu mai induceti lumea in eroare cu setari inutile!!
mdea merge doar ca
cine seteza frecventa cardului?
si maxul merge de ce nu il pui asa cum e?
Daca citesti CCcam.cfg cu atentie vei gasi urmatoarele :
# Smartcard clock speed override
# Setting override specified speed for smartcard.
# Don't add setting unless you're sure what you're doing.
# In 99% of the cases the reader selects the optimal speed.
# Adding this setting either slows your card down, or might destroy it.
# SMARTCARD CLOCK FREQUENCY : <device> <freq>
Deci @andres a precizat corect ... poate pinul trebuie trecut ( PIN: /dev/sci0 1234) doar daca esti abonat la canalul pt adulti, in rest merge cu siguranta.
