Cu ce merge cardul de Dolce pe PC daca nici in phoenix nu merge?Quote:
Originally Posted by ionitagelu [Only registered and activated users can see links. Click Here To Register...]
In curand nu va mai merge pe nimic decat in conserva lor si cred ca va trece ceva timp pana se va rezolva, asta daca se va rezolva.
[d_0lC_e = b__oo__m]
buna,
daca va rog frumos poate sa-mi dea cineva fisierul newcs.xml? deoarece eu nu il am.
Am CCcam 2.1.4/NewCS1.67.
Incearca asta. Nu este configurat pentru niciun provider.
multumesc, intre timp am gasit unul preconfigurat pe cardul tvrHD doar ca nu imi merge(am card tvrHD si Dreambox 600).
newcs.xml:
CCcam.cfgCode:<?xml version="1.0"?>
<newCSconfig>
<globals>
<!--<listening-ip>127.0.0.1</listening-ip>-->
</globals>
<readers name="Dreambox SCI">
<device>
<name>SCI Lower Slot</name>
<type>sci</type>
<mhz>368</mhz>
<node>/dev/sci0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<blockC0>Yes</blockC0>
<PTShandshake>Yes</PTShandshake>
<crypto-special>No</crypto-special>
<carddetect>Yes</carddetect>
<newcamd_port>32100</newcamd_port>
<autosid>No</autosid>
<sid>
<allow>
<id>0000:0002</id><id>000F</id>
</allow>
<deny>
<!--<id>xxxx</id>-->
</deny>
</sid>
<pincode>0000</pincode>
<priority>round</priority>
</device>
</readers>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server>
<port>100</port>
<enabled>yes</enabled>
</server>
<user>
<name>user</name>
<password>pass</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<password>NewCSpwd</password>
<mode>simple</mode>
<level>internal</level>
<type>all</type>
<output>console,tcp</output>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>cardserv</name>
<deskey>11 22 33 44 55 66 70 07 66 55 44 33 22 11</deskey>
<user>
<name>tvrhd</name>
<password>card</password>
<au>on</au>
<allow>SCI Lower Slot</allow>
<sidoverride>off</sidoverride>
<spider>No</spider>
</user>
</newcamdserver>
</newCSconfig>
Trebuie sa mai adaug ceva? sau ce nu este bine?Code:N: 127.0.0.1 32100 tvrhd card 11 22 33 44 55 66 70 07 66 55 44 33 22 11
...sau poti incerca Oscam
Ce i-mi recomandati pentru dreambox 500s si un card Focus! Cardul Focus daca introduc in rec deja funtioneaza? daca am intalata cccam 2.2.1?
vreau s-l folosesc in share pe retea privata. Un how to daca este undev ape forum. Multumesc!
Functioneaza direct in cccam, doar daca ai canalele XXX trebuie sa pui in cccam.cfg PIN: /dev/sci0 1234
Multumesc! Ce parere ai? In retea privata ar era mai bine sa fac share cu linie N intre Dream500s si Dbox? Daca merita atunci in newcamd am de setat, gasasc aici how to? La newcs am vazut ceva setari.
Oscamu o pot pune mai usor si setat da la dream box nu stiu daca gasesc versiune stabila sa coraspunda si la dvb.api
Daca Dbox stie doar protocolul newcamd folosesti doar oscam pe DM500, pentru o retea interna e foarte stabil cu dvbapi activ.
