PKT E2, am sa incerc cu telnet mâine când ajung acasă.
Cu sbox.sh40 in /var/emu emulatorul apare in EMU Manager dar nu am reusit sa-l pornesc din telnet. Impreuna cu sbox.config le-am mutat in /usr/bin; SBox nu mai apare in EMU Manager (l-am lasat pe "Niciun CAM activ"). Acum porneste din telnet, dar daca restartez receptorul sau intrerup alimentarea cu 220 V Sbox trebuie iar pornit din telnet. Am editat scriptul pentru ppc, l-am copiat in /usr/scriptl dar problema persista:
Va rog, un pic de ajutor.Quote:
#!/bin/sh
###### Powered by The Gemini Team ######
### [Only registered and activated users can see links. Click Here To Register...] ###
# camid #
# 0000 = Commom Interface #
# 0001->0199 = for User Experiment #
# 0199 = Dccamd #
# 0200->0299 = Fbiss #
# 0300->0399 = Camd3 #
# 0400->0499 = Camx #
# 0500->0599 = Camx-Radegast-CS #
# 0600->0699 = Evocamd -OLD #
# 0700->0799 = Evocamd_ronlad_cs -OLD #
# 0800->0899 = Mgcamd -OLD #
# 0900->0999 = Mgcamd_ronald_cs -OLD #
# 1000->1099 = Newcamd -OLD #
# 1100->1199 = Newcamd-ronald_CS -OLD #
# 1200->1299 = Newcamd-spider -OLD #
# 1300->1399 = Radegast #
# 1400->1499 = Ronald-CS #
# 1500->1599 = Scam #
# 1600->1699 = Scam-Ronald-CS #
# 1700->1799 = MPCS #
# 1800->1899 = NewCS #
# 2000->2099 = Camd3 #
# 2300->2399 = Camd3-NewCS #
# 2600->2699 = Camd3-MPCardserver #
# 3000->3099 = Evocamd #
# 3100->3199 = Evocamd-Ronald-CS #
# 3200->3299 = Evocamd-NewCS #
# 3300->3399 = Evocamd-MPCardserver #
# 4000->4099 = Mgcamd #
# 4100->4199 = Mgcamd-Ronald-CS #
# 4200->4299 = Mgcamd-NewCS #
# 4300->4399 = Mgcamd-MPCS #
# 5000->5099 = Newcamd-Betad #
# 5100->5199 = Newcamd-Cardserver #
# 5200->5299 = Newcamd-Spider #
# 5300->5399 = Newcamd-NewCS #
# 5400->5499 = Newcamd-MPCS #
# 5500->5599 = OpenCam #
# 5600->5699 = RqCamd #
# 6000->6099 = CCcam #
# 6100->6199 = CCcam-Capmtserver #
# 6200->6299 = CCcam-NewCS #
# 6300->6399 = CCcam-MPCS #
# 9500->9599 = reserved #
# 9600->9699 = reserved #
# 9700->9799 = reserved #
# 9800->9899 = reserved #
# 9900->9999 = reserved #
CAMNAME="Sbox"
USERNAME=""
ZAPTIME=6
CAMID=9501
DVBSET=0
INFOFILE="ecm.info"
INFOFILELINES=
# end
remove_tmp () {
rm -rf /tmp/*.info* /tmp/*.tmp*
case "$1" in
start)
echo "[SCRIPT] $1: $CAMNAME"
remove_tmp
/usr/bin/sbox.sh40
stop)
killall -9 sbox.sh40
remove_tmp
$0 stop
exit 0
esac
exit 0
Am pus ultima imagine Neurino 3.7.7 care parea OK.
Pe Thor nu receptioneaza o mare parte din canale si nu am reusit sa rezolv cu setarile de HIGH_SR !
Ceva idei?
Acum ma jucam cu TitanNIT.
Nu reusesc sa mut antena pe USALS, desi am gasit ceva setari evident idiot facute!
---------- Post added at 00:44 ---------- Previous post was at 00:32 ----------
Am reusit cu USALS, evident trebuia un reboot dupa configurare.
Maine fac ceva capturi de ecran ....
Nu merg programele HD CU SR 30000 pe Neutrino, acum ceva timp nici pe TitaNIT.
Am facut azi ceva "cercetare" si am descoperit ca nu merge decat pe imagini vechi SR30000 de pe Thor.
Au mutat ceva parametrii din PTI in stmdvb si probabil nimeni nu tzipa!
CU imagine Neutrino mai veche merg si canalele cu sr30000
Am reusit sa descarc ultima imagine in care merg canalele cu SR30000:
Are oscam la download si spatiu de instalare.
Imaginile noi sunt mai mari si trebuie sa pui stick sa se extindă.
Recomand in Flash aceasta imagine si altele pe stick.
Am generat o lista de canale la zi pe 5 sateliti de interes
Se copiaza satellites.xml in /var/tuxbox/config/
restul fisierelor in /var/tuxbox/config/zapit/
apoi restart la box
Lista de canale la zi
Joi am gasit un UFS910 in targ, nu stiam ce sa fac, (am deja cateva in colectie), nu ma lasa inima sa il las acolo.
M-a salvat vanzatorul, a cerut 50 lei! Poate se bucura altul de el!
