Asta imi arata inainte sa intru in router.
Am rezolvat pana la urma cu ajutorul lui @ TKD29 de [Only registered and activated users can see links. Click Here To Register...] ii multumesc foarte mult ! multumesc si lui @dmd !
Si acum eu pun si rezolvarea nu ca altii dupa ce au reusit pa nu mai zic nimic pe forum.
Romtelecom Clicknet Mobile modem: Anydata ADU-510L
Router testat: Asus WL-500W
Firmware: 1.9.2.7-10-USB-1.71 Koppel
0) setati la Wan& lan connection Mode: USB (cu automaticaly get ip address yes si automaticaly get DNS yes)
dupa care urmati exact pasii astia si va functiona. Nu conteaza in ce port usb al routerului conectati modemul:
1) USB Connection ->
Automatic Dial On Boot – Yes
GPRS/EDGE/UMTS
Apply
2) USB Connection -> GPRS/EDGE/UMTS Config
Zero CD Configuration -> AnyDATA ADU-500A, ADU-510A, ADU-520A
Connect
Apply
3) USB Connection ->
CDMA
Apply
4) USB Connection -> CDMA Config
username: (the one from the provider)
password: (the one from the provider)
Connect
Apply
Finish
Save And Restart
if it does not connect after 60 seconds since reboot and in Status & Log -> System log you see in one of the last lines like this
Jan 1 02:00:11 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 02:00:11 kernel: Vendor: AnyDATA Model: CD-ROM Rev: 1.00
Jan 1 02:00:11 kernel: Type: CD-ROM ANSI SCSI revision: 02
Jan 1 02:00:11 kernel: USB Mass Storage support registered.
then you have to do the following:
start -> run -> telnet my.router -> admin/admin
#urmatoarele linii trebuiesc luate ca atare cu copy paste
echo usb_modeswitch -c /tmp/ppp/zerocdconf/AnyDATA_ADU/usb_modeswitch.conf >> /usr/local/sbin/post-boot
#acum salvam ce am facut in memoria flash a router-ului
flashfs save && flashfs commit && flashfs enable
#restartam
reboot
Sa auzim de bine!
felicitari pentru rausite si pentru tutorialul facut.
