Sarutmina coane Zildane , ai avut dreptate , a trebuit sa opresc dm500 iar apoi kathy s-a conectat fara probleme , mai ramine sa vad cum se comporta acum, cite intreruperi si blocaje !
Multumesc mult inca o data pt. rabdare!
Bafta si happy sharing!
Vezi ca au aparut alte versiuni la pannel.
Faci download din pannel, si apoi de la emu lansezi ce ai instalat!
Ultima pare cea mai stabila de pana acuma!!!
Am instalat v0.87 si vad ca se comporta destul de bine ,din cind in cind se blocheaza!
Hi!
My question is: I have an Ipbox910hd with NLB9580 image. I have tried to connect my payserver c-line to the incubuscamd.conf, and think I have done most things right. My question is: how should the incubuscamd.prio fil look like when this is my incubus.conf file:
[General]
background_execution=1
[Prov:0501] card_server_url_0=cccam://spirit:bardmsn@laserserver.no-ip.org:12000
[Prov:FF00] card_server_url_0=cccam://spirit:bardmsn@laserserver.no-ip.org:12000
[Servers] card_server_url_0=cccam://spirit:bardmsn@laserserver.no-ip.org:12000
Thanks!
Bard
[Prov:000000:CaID:0000]
# this provider is a stand-in for all cards and all caid not declared previously
# For example I choose to use cccam protocol on all other provider.
decoder_type=1
########################### servers configuration ############################
[Servers]
# This is the section for the multi-server configuration.
# URL of card-server to use, formats are as follows:
# cccam://<username>:<password>@<hostname>:<port>/<receive_emu_shared>/[EMM]
# where <receive_emu_shared> should assume value "yes" (without quotes, if you like to receive emus data shared by the server) or "no" (this is assumed by default)
# gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>/[EMM]
# NOTE: The "EMM" suffix is optional and tells the card-server client whether
# to send EMM's to the card-server or not. Enabling or disabling this only
# has effect if the card-server is configured to accept emms from this client.
# NOTE 2: The "card_server_url" is not the same as previously declared in the prov/caid section
# use how many server as you like
card_server_url=cccam://<username1> : <password1>@<hostname1>:<port2>
card_server_url=cccam://<username2> : <password2>@<hostname2>:<port2>
########################### CaIDs tunneling configuration ############################
